I’ve got a dns issue while trying to set up an OpenVPN client.
When DNSSEC validation is enabled (through the Foris UI) I’m unable to ping VPN servers and cannot make a connection.
If I disable DNSSEC I can ping the VPN servers and make a connection but I can’t get any traffic through the connection for all the devices on my Lan except a Fire TV stick. The Fire TV can get traffic through the VPN when nothing else can.
Any ideas on why I can’t ping the VPN servers while I have DNSSEC validation enabled on the router?
I assume that the VPN redefines what is used as upstream DNS servers for forwarding – and that those servers break standards in a way that blocks DNSSEC validation for some names. If you don’t need to resolve names defined by the VPN, I’d simply disable forwarding in Foris (in DNS tab).
Still, I expect your main problem is traffic not going through the VPN (at IP level already?) and not any DNS stuff.
