Hi!
I have successfully setup a OpenVPN server using foris plugin. I also generated config for my client. And I can connect. I get public IP of my router so the VPN purpose is achieved I also can access the Internets but I would like a bit more.
MY GOAL: is to be able to connect (ping/ssh) to machines in my local network using openvpn. So if I am on my client (android phone) and I connect to OpenVPN then I would like to ssh into the raspberry pi for example (in my local network). I know it’s possible but I cannot achieve it in any way.
here is my /etc/config/openvpn
config openvpn 'server_turris'
option enabled '1'
option port '1194'
option proto 'udp6'
option dev 'tun_turris'
option ca '/etc/ssl/ca/openvpn/ca.crt'
option crl_verify '/etc/ssl/ca/openvpn/ca.crl'
option cert '/etc/ssl/ca/openvpn/01.crt'
option key '/etc/ssl/ca/openvpn/01.key'
option dh '/etc/dhparam/dh-default.pem'
option server '192.168.12.0 255.255.255.0'
option ifconfig_pool_persist '/tmp/ipp.txt'
option duplicate_cn '0'
option keepalive '10 120'
option compress 'lzo'
option persist_key '1'
option persist_tun '1'
option status '/tmp/openvpn-status.log'
option verb '6'
option mute '20'
list push 'route 192.168.13.0 255.255.255.0'
list push 'redirect-gateway def1'
list push 'dhcp-option DNS 192.168.13.37'
Any help and ideas welcomed.
