Zdravím. Rád bych pomocí CCD file dosáhl přidělení statické IP některým klientům.
v /etc/openvpn/ccd mám soubor “ntb”:
ifconfig-push 192.168.111.201 255.255.255.0
Má konfigurace:
config openvpn ‘custom_config’
option enabled ‘0’
option config ‘/etc/openvpn/my-vpn.conf’
config openvpn 'sample_server'
option enabled '0'
option port '1194'
option proto 'udp'
option dev 'tun'
option ca '/etc/openvpn/ca.crt'
option cert '/etc/openvpn/server.crt'
option key '/etc/openvpn/server.key'
option dh '/etc/openvpn/dh1024.pem'
option server '10.8.0.0 255.255.255.0'
option ifconfig_pool_persist '/tmp/ipp.txt'
option keepalive '10 120'
option compress 'lzo'
option persist_key '1'
option persist_tun '1'
option user 'nobody'
option status '/tmp/openvpn-status.log'
option verb '3'
config openvpn 'sample_client'
option enabled '0'
option client '1'
option dev 'tun'
option proto 'udp'
list remote 'my_server_1 1194'
option resolv_retry 'infinite'
option nobind '1'
option cert '/etc/openvpn/client.crt'
option key '/etc/openvpn/client.key'
option verb '3'
config openvpn 'server_turris'
option port '1194'
option dev 'tun_turris'
option ca '/etc/ssl/ca/openvpn/ca.crt'
option crl_verify '/etc/ssl/ca/openvpn/ca.crl'
option cert '/etc/ssl/ca/openvpn/01.crt'
option key '/etc/ssl/ca/openvpn/01.key'
option dh '/etc/dhparam/dh-default.pem'
option ifconfig-pool '192.168.111.2 192.168.111.199 255.255.255.0'
option duplicate_cn '0'
option verb '3'
option mute '20'
option enabled '1'
option proto 'tcp-server'
option server '192.168.111.0 255.255.255.0'
option client-config-dir '/etc/openvpn/ccd'
list push 'route 192.168.1.0 255.255.255.0'
Bohužel, klient stále dostává jinou IP. Už opravdu netuším, kde mám chybu.
