Opened port 53 is problem?
Internet provider notify me (when a solution of another problem) to opened open port 53 DNS … It is so very easy to use You for a DDOS attack.
Is my problem-that is, caused by my hands, or is it the default FW error?
They asked you to open port 53 on your router ? Or you have port 53 opened to the web ?
No , they ask nothing. The router has open a port 53 to the Internet.
My IP is 93.91.50.207, you can check it.
Is this standard FW setup ready ?
You have more than 53 open towards net…
Scanning buchtik.inet4.cz (93.91.50.207) [1024 ports]
Discovered open port 22/tcp on 93.91.50.207
Discovered open port 80/tcp on 93.91.50.207
Discovered open port 443/tcp on 93.91.50.207
Discovered open port 53/tcp on 93.91.50.207
Increasing send delay for 93.91.50.207 from 0 to 5 due to 53 out of 132 dropped probes since last increase.
Completed SYN Stealth Scan at 15:58, 33.46s elapsed (1024 total ports)
Initiating Service scan at 15:58
Scanning 4 services on buchtik.inet4.cz (93.91.50.207)
Completed Service scan at 15:58, 6.65s elapsed (4 services on 1 host)
Initiating OS detection (try #1) against buchtik.inet4.cz (93.91.50.207)
Retrying OS detection (try #2) against buchtik.inet4.cz (93.91.50.207)
Initiating Traceroute at 15:58
Completed Traceroute at 15:58, 2.05s elapsed
NSE: Script scanning 93.91.50.207.
Initiating NSE at 15:58
Completed NSE at 15:58, 1.64s elapsed
[+] Nmap scan report for buchtik.inet4.cz (93.91.50.207)
Host is up (0.078s latency).
Not shown: 846 closed ports, 174 filtered ports
PORT STATE SERVICE VERSION
22/tcp open ssh OpenSSH 6.0p1 Debian 4+deb7u4 (protocol 2.0)
53/tcp open tcpwrapped
80/tcp open http lighttpd 1.4.42
443/tcp open http nginx
Your whole omnia setting page and ssh is open towards net = very very bad idea in my opinion !
If this is not deliberate, something gone wrong with firewall rules.
I have also 53 open since I specified the port in LuCi setting, but I think its not accepting request from outside of NW ( at least I think so :smiley: )
Port 22 is knowingly opened and forwarded to other port to honeypot.
viz https://www.turris.cz/doc/cs/howto/ssh_honeypot
My problem is port 53 … Why is open in standard firewall rule ?
And do you really see it in your firewall rules? because its not default configuration I guess.
Could it be that you have also configured a honeypot for port 53?
Port 53 I certainly wouldn’t change. Therefore, I am putting this question.
Certainly not.
Please read the question on the top and the answer only just this question!
Then you already have an answer. Please, see pgotze’s post.
Port 53 is DNS and it si open. Port 22 is forwarded to other port to honeypot. My question is not solved.
The answer is that it is not the default. First check that your Internet cable is connected to WAN port. After that check that you have not changed port or bridging settings. Then check the firewall settings and finally check that the firewall rules are applied.
Here are the default firewall settings:
config defaults
	option syn_flood '1'
	option input 'ACCEPT'
	option output 'ACCEPT'
	option forward 'REJECT'
config zone
	option name 'lan'
	list network 'lan'
	option forward 'ACCEPT'
config zone
	option name 'wan'
	list network 'wan'
	list network 'wan6'
	option input 'REJECT'
	option masq '1'
	option mtu_fix '1'
config forwarding
	option src 'lan'
	option dest 'wan'
config rule
	option name 'Allow-DHCP-Renew'
	option src 'wan'
	option proto 'udp'
	option dest_port '68'
	option target 'ACCEPT'
	option family 'ipv4'
config rule
	option name 'Allow-Ping'
	option src 'wan'
	option proto 'icmp'
	option icmp_type 'echo-request'
config rule
	option name 'Allow-IGMP'
	option src 'wan'
	option proto 'igmp'
config rule
	option name 'Allow-DHCPv6'
	option src 'wan'
	option proto 'udp'
	option src_ip 'fe80::/10'
	option src_port '547'
	option dest_ip 'fe80::/10'
	option dest_port '546'
	option family 'ipv6'
config rule
	option name 'Allow-MLD'
	option src 'wan'
	option proto 'icmp'
	list icmp_type '130/0'
	list icmp_type '131/0'
	list icmp_type '132/0'
	list icmp_type '143/0'
config rule
	option name 'Allow-ICMPv6-Input'
	option src 'wan'
	option proto 'icmp'
	list icmp_type 'echo-request'
	list icmp_type 'echo-reply'
	list icmp_type 'destination-unreachable'
	list icmp_type 'packet-too-big'
	list icmp_type 'time-exceeded'
	list icmp_type 'bad-header'
	list icmp_type 'unknown-header-type'
	list icmp_type 'router-solicitation'
	list icmp_type 'neighbour-solicitation'
	list icmp_type 'router-advertisement'
	list icmp_type 'neighbour-advertisement'
	option limit '1000/sec'
config rule
	option name 'Allow-ICMPv6-Forward'
	option src 'wan'
	option dest '*'
	option proto 'icmp'
config include
	option path '/etc/firewall.user'
config include
	option path '/usr/share/firewall/turris'
	option reload '1'
config include
	option path '/etc/firewall.d/with_reload/firewall.include.sh'
	option reload '1'
config include
	option path '/etc/firewall.d/without_reload/firewall.include.sh'
	option reload '0'
config rule
	option src 'wan'
	option dest 'lan'
	option proto 'esp'
config rule
	option src 'wan'
	option dest 'lan'
	option dest_port '500'
	option proto 'udp'
config include 'miniupnpd'
	option type 'script'
	option path '/usr/share/miniupnpd/firewall.include'
	option family 'any'
	option reload '1'
You should compare them to what you have in /etc/config/firewall file.
You can check that the firewall rules are applied by giving command “iptables -v -L”. It will print out the kernel’s active firewall rules. There should be a lots of lines.
Thanks for command :slight_smile:
# iptables -v -L
Chain INPUT (policy DROP 0 packets, 0 bytes)
 pkts bytes target     prot opt in     out     source               destination
 8693 1040K delegate_input  all  --  any    any     anywhere             anywhere
Chain FORWARD (policy DROP 0 packets, 0 bytes)
 2903  889K delegate_forward  all  --  any    any     anywhere             anywhere
Chain OUTPUT (policy DROP 0 packets, 0 bytes)
 8862 1147K delegate_output  all  --  any    any     anywhere             anywhere
Chain MINIUPNPD (1 references)
Chain accept (14 references)
 2308  186K turris     all  --  any    any     anywhere             anywhere
 2315  186K ACCEPT     all  --  any    any     anywhere             anywhere
Chain delegate_forward (1 references)
 2903  889K forwarding_rule  all  --  any    any     anywhere             anywhere             /* user chain for forwarding */
 2865  887K ACCEPT     all  --  any    any     anywhere             anywhere             ctstate RELATED,ESTABLISHED
   34  2052 zone_lan_forward  all  --  br-lan any     anywhere             anywhere
    4   192 zone_wan_forward  all  --  eth1   any     anywhere             anywhere
    0     0 reject     all  --  any    any     anywhere             anywhere
Chain delegate_input (1 references)
 6213  716K ACCEPT     all  --  lo     any     anywhere             anywhere
 2480  324K input_rule  all  --  any    any     anywhere             anywhere             /* user chain for input */
 2392  318K ACCEPT     all  --  any    any     anywhere             anywhere             ctstate RELATED,ESTABLISHED
   58  2616 syn_flood  tcp  --  any    any     anywhere             anywhere             tcp flags:FIN,SYN,RST,ACK/SYN
   85  5572 ucollect_fake_accept  all  --  any    any     anywhere             anywhere
   22  1689 zone_lan_input  all  --  br-lan any     anywhere             anywhere
   66  4027 zone_wan_input  all  --  eth1   any     anywhere             anywhere
    0     0 accept     all  --  any    any     anywhere             anywhere
Chain delegate_output (1 references)
 6213  716K ACCEPT     all  --  any    lo      anywhere             anywhere
 2649  430K output_rule  all  --  any    any     anywhere             anywhere             /* user chain for output */
  454  252K ACCEPT     all  --  any    any     anywhere             anywhere             ctstate RELATED,ESTABLISHED
    0     0 zone_lan_output  all  --  any    br-lan  anywhere             anywhere
 2195  179K zone_wan_output  all  --  any    eth1    anywhere             anywhere
Chain drop (0 references)
    0     0 turris-log-incoming  all  --  eth1   any     anywhere             anywhere
    0     0 DROP       all  --  any    any     anywhere             anywhere
Chain forwarding_lan_rule (1 references)
Chain forwarding_rule (1 references)
3362K 2089M turris-nflog  all  --  any    any     anywhere             anywhere
Chain forwarding_wan_rule (1 references)
Chain input_lan_rule (1 references)
Chain input_rule (1 references)
1438K  124M turris-nflog  all  --  any    any     anywhere             anywhere
Chain input_wan_rule (1 references)
Chain output_lan_rule (1 references)
Chain output_rule (1 references)
2129K  154M turris-nflog  all  --  any    any     anywhere             anywhere
Chain output_wan_rule (1 references)
Chain reject (3 references)
    0     0 REJECT     tcp  --  any    any     anywhere             anywhere             reject-with tcp-reset
    0     0 REJECT     all  --  any    any     anywhere             anywhere             reject-with icmp-port-unreachable
Chain syn_flood (1 references)
   58  2616 RETURN     tcp  --  any    any     anywhere             anywhere             tcp flags:FIN,SYN,RST,ACK/SYN limit: avg 25/sec burst 50
Chain turris (1 references)
    0     0 LOG        all  --  any    eth1    anywhere             anywhere             limit: avg 1/sec burst 5 match-set turris_00005E11_l_a_4_X dst LOG level debug prefix "turris-00005E11: "
    0     0 LOG        all  --  eth1   any     anywhere             anywhere             limit: avg 1/sec burst 5 match-set turris_00005E11_l_a_4_X src LOG level debug prefix "turris-00005E11: "
    0     0 LOG        all  --  any    eth1    anywhere             anywhere             limit: avg 1/sec burst 5 match-set turris_00415B11_l_a_4_X dst LOG level debug prefix "turris-00415B11: "
    0     0 LOG        all  --  eth1   any     anywhere             anywhere             limit: avg 1/sec burst 5 match-set turris_00415B11_l_a_4_X src LOG level debug prefix "turris-00415B11: "
    0     0 LOG        all  --  any    eth1    anywhere             anywhere             limit: avg 1/sec burst 5 match-set turris_00557B71_l_ap_4_X dst,dst LOG level debug prefix "turris-00557B71: "
    0     0 LOG        all  --  eth1   any     anywhere             anywhere             limit: avg 1/sec burst 5 match-set turris_00557B71_l_ap_4_X src,src LOG level debug prefix "turris-00557B71: "
    0     0 LOG        all  --  any    eth1    anywhere             anywhere             limit: avg 1/sec burst 5 match-set turris_007E0511_l_a_4_X dst LOG level debug prefix "turris-007E0511: "
    0     0 LOG        all  --  eth1   any     anywhere             anywhere             limit: avg 1/sec burst 5 match-set turris_007E0511_l_a_4_X src LOG level debug prefix "turris-007E0511: "
    0     0 LOG        all  --  any    eth1    anywhere             anywhere             limit: avg 1/sec burst 5 match-set turris_009A7E41_l_a_4_X dst LOG level debug prefix "turris-009A7E41: "
    0     0 LOG        all  --  eth1   any     anywhere             anywhere             limit: avg 1/sec burst 5 match-set turris_009A7E41_l_a_4_X src LOG level debug prefix "turris-009A7E41: "
    0     0 LOG        all  --  any    eth1    anywhere             anywhere             limit: avg 1/sec burst 5 match-set turris_00A704A1_l_a_4_X dst LOG level debug prefix "turris-00A704A1: "
    0     0 LOG        all  --  eth1   any     anywhere             anywhere             limit: avg 1/sec burst 5 match-set turris_00A704A1_l_a_4_X src LOG level debug prefix "turris-00A704A1: "
    0     0 LOG        all  --  any    eth1    anywhere             anywhere             limit: avg 1/sec burst 5 match-set turris_00CE6701_l_a_4_X dst LOG level debug prefix "turris-00CE6701: "
    0     0 LOG        all  --  eth1   any     anywhere             anywhere             limit: avg 1/sec burst 5 match-set turris_00CE6701_l_a_4_X src LOG level debug prefix "turris-00CE6701: "
    0     0 LOG        all  --  any    eth1    anywhere             anywhere             limit: avg 1/sec burst 5 match-set turris_00D05711_l_a_4_X dst LOG level debug prefix "turris-00D05711: "
    0     0 LOG        all  --  eth1   any     anywhere             anywhere             limit: avg 1/sec burst 5 match-set turris_00D05711_l_a_4_X src LOG level debug prefix "turris-00D05711: "
    0     0 LOG        all  --  any    eth1    anywhere             anywhere             limit: avg 1/sec burst 5 match-set turris_00DEAD51_l_a_4_X dst LOG level debug prefix "turris-00DEAD51: "
    0     0 LOG        all  --  eth1   any     anywhere             anywhere             limit: avg 1/sec burst 5 match-set turris_00DEAD51_l_a_4_X src LOG level debug prefix "turris-00DEAD51: "
    0     0 LOG        all  --  any    eth1    anywhere             anywhere             limit: avg 1/sec burst 5 match-set turris_00DEB060_lb_a_4_X dst LOG level debug prefix "turris-00DEB060: "
    0     0 LOG        all  --  eth1   any     anywhere             anywhere             limit: avg 1/sec burst 5 match-set turris_00DEB060_lb_a_4_X src LOG level debug prefix "turris-00DEB060: "
    0     0 LOG        all  --  any    eth1    anywhere             anywhere             limit: avg 1/sec burst 5 match-set turris_00FE0D01_l_a_4_X dst LOG level debug prefix "turris-00FE0D01: "
    0     0 LOG        all  --  eth1   any     anywhere             anywhere             limit: avg 1/sec burst 5 match-set turris_00FE0D01_l_a_4_X src LOG level debug prefix "turris-00FE0D01: "
    0     0 LOG        all  --  any    eth1    anywhere             anywhere             limit: avg 1/sec burst 5 match-set turris_047C0DE1_l_a_4_X dst LOG level debug prefix "turris-047C0DE1: "
    0     0 LOG        all  --  eth1   any     anywhere             anywhere             limit: avg 1/sec burst 5 match-set turris_047C0DE1_l_a_4_X src LOG level debug prefix "turris-047C0DE1: "
    0     0 LOG        all  --  any    eth1    anywhere             anywhere             limit: avg 1/sec burst 5 match-set turris_06E7E701_l_a_4_X dst LOG level debug prefix "turris-06E7E701: "
    0     0 LOG        all  --  eth1   any     anywhere             anywhere             limit: avg 1/sec burst 5 match-set turris_06E7E701_l_a_4_X src LOG level debug prefix "turris-06E7E701: "
    0     0 LOG        all  --  any    eth1    anywhere             anywhere             limit: avg 1/sec burst 5 match-set turris_07E7E411_l_a_4_X dst LOG level debug prefix "turris-07E7E411: "
    0     0 LOG        all  --  eth1   any     anywhere             anywhere             limit: avg 1/sec burst 5 match-set turris_07E7E411_l_a_4_X src LOG level debug prefix "turris-07E7E411: "
    0     0 LOG        all  --  any    eth1    anywhere             anywhere             limit: avg 1/sec burst 5 match-set turris_0A566041_l_ap_4_X dst,dst LOG level debug prefix "turris-0A566041: "
    0     0 LOG        all  --  eth1   any     anywhere             anywhere             limit: avg 1/sec burst 5 match-set turris_0A566041_l_ap_4_X src,src LOG level debug prefix "turris-0A566041: "
    0     0 LOG        all  --  any    eth1    anywhere             anywhere             limit: avg 1/sec burst 5 match-set turris_0A7D7011_l_a_4_X dst LOG level debug prefix "turris-0A7D7011: "
    0     0 LOG        all  --  eth1   any     anywhere             anywhere             limit: avg 1/sec burst 5 match-set turris_0A7D7011_l_a_4_X src LOG level debug prefix "turris-0A7D7011: "
    0     0 LOG        all  --  any    eth1    anywhere             anywhere             limit: avg 1/sec burst 5 match-set turris_100FA4E0_lb_a_4_X dst LOG level debug prefix "turris-100FA4E0: "
    6   340 LOG        all  --  eth1   any     anywhere             anywhere             limit: avg 1/sec burst 5 match-set turris_100FA4E0_lb_a_4_X src LOG level debug prefix "turris-100FA4E0: "
    0     0 DROP       all  --  any    eth1    anywhere             anywhere             match-set turris_00DEB060_lb_a_4_X dst
    0     0 DROP       all  --  eth1   any     anywhere             anywhere             match-set turris_00DEB060_lb_a_4_X src
    0     0 DROP       all  --  any    eth1    anywhere             anywhere             match-set turris_100FA4E0_lb_a_4_X dst
    6   340 DROP       all  --  eth1   any     anywhere             anywhere             match-set turris_100FA4E0_lb_a_4_X src
Chain turris-log-incoming (2 references)
    0     0 LOG        all  --  any    any     anywhere             anywhere             limit: avg 1/sec burst 5 match-set turris_00005E11_l_a_4_X src LOG level debug prefix "turris-00005E11: "
    0     0 ucollect_fake  all  --  any    any     anywhere             anywhere
    0     0 LOG        all  --  any    any     anywhere             anywhere             limit: avg 1/sec burst 5 match-set turris_00415B11_l_a_4_X src LOG level debug prefix "turris-00415B11: "
    0     0 LOG        all  --  any    any     anywhere             anywhere             limit: avg 1/sec burst 5 match-set turris_00557B71_l_ap_4_X src,src LOG level debug prefix "turris-00557B71: "
    0     0 LOG        all  --  any    any     anywhere             anywhere             limit: avg 1/sec burst 5 match-set turris_007E0511_l_a_4_X src LOG level debug prefix "turris-007E0511: "
    0     0 LOG        all  --  any    any     anywhere             anywhere             limit: avg 1/sec burst 5 match-set turris_009A7E41_l_a_4_X src LOG level debug prefix "turris-009A7E41: "
    0     0 LOG        all  --  any    any     anywhere             anywhere             limit: avg 1/sec burst 5 match-set turris_00A704A1_l_a_4_X src LOG level debug prefix "turris-00A704A1: "
    0     0 LOG        all  --  any    any     anywhere             anywhere             limit: avg 1/sec burst 5 match-set turris_00CE6701_l_a_4_X src LOG level debug prefix "turris-00CE6701: "
    0     0 LOG        all  --  any    any     anywhere             anywhere             limit: avg 1/sec burst 5 match-set turris_00D05711_l_a_4_X src LOG level debug prefix "turris-00D05711: "
    0     0 LOG        all  --  any    any     anywhere             anywhere             limit: avg 1/sec burst 5 match-set turris_00DEAD51_l_a_4_X src LOG level debug prefix "turris-00DEAD51: "
    0     0 LOG        all  --  any    any     anywhere             anywhere             limit: avg 1/sec burst 5 match-set turris_00DEB060_lb_a_4_X src LOG level debug prefix "turris-00DEB060: "
    0     0 LOG        all  --  any    any     anywhere             anywhere             limit: avg 1/sec burst 5 match-set turris_00FE0D01_l_a_4_X src LOG level debug prefix "turris-00FE0D01: "
    0     0 LOG        all  --  any    any     anywhere             anywhere             limit: avg 1/sec burst 5 match-set turris_047C0DE1_l_a_4_X src LOG level debug prefix "turris-047C0DE1: "
    0     0 LOG        all  --  any    any     anywhere             anywhere             limit: avg 1/sec burst 5 match-set turris_06E7E701_l_a_4_X src LOG level debug prefix "turris-06E7E701: "
    0     0 LOG        all  --  any    any     anywhere             anywhere             limit: avg 1/sec burst 5 match-set turris_07E7E411_l_a_4_X src LOG level debug prefix "turris-07E7E411: "
    0     0 LOG        all  --  any    any     anywhere             anywhere             limit: avg 1/sec burst 5 match-set turris_0A566041_l_ap_4_X src,src LOG level debug prefix "turris-0A566041: "
    0     0 LOG        all  --  any    any     anywhere             anywhere             limit: avg 1/sec burst 5 match-set turris_0A7D7011_l_a_4_X src LOG level debug prefix "turris-0A7D7011: "
    0     0 LOG        all  --  any    any     anywhere             anywhere             limit: avg 1/sec burst 5 match-set turris_100FA4E0_lb_a_4_X src LOG level debug prefix "turris-100FA4E0: "
    0     0 RETURN     all  --  any    any     anywhere             anywhere             match-set turris_00005E11_l_a_4_X src
    0     0 RETURN     all  --  any    any     anywhere             anywhere             match-set turris_00415B11_l_a_4_X src
    0     0 RETURN     all  --  any    any     anywhere             anywhere             match-set turris_00557B71_l_ap_4_X src,src
    0     0 RETURN     all  --  any    any     anywhere             anywhere             match-set turris_007E0511_l_a_4_X src
    0     0 RETURN     all  --  any    any     anywhere             anywhere             match-set turris_009A7E41_l_a_4_X src
    0     0 RETURN     all  --  any    any     anywhere             anywhere             match-set turris_00A704A1_l_a_4_X src
    0     0 RETURN     all  --  any    any     anywhere             anywhere             match-set turris_00CE6701_l_a_4_X src
    0     0 RETURN     all  --  any    any     anywhere             anywhere             match-set turris_00D05711_l_a_4_X src
    0     0 RETURN     all  --  any    any     anywhere             anywhere             match-set turris_00DEAD51_l_a_4_X src
    0     0 RETURN     all  --  any    any     anywhere             anywhere             match-set turris_00DEB060_lb_a_4_X src
    0     0 RETURN     all  --  any    any     anywhere             anywhere             match-set turris_00FE0D01_l_a_4_X src
    0     0 RETURN     all  --  any    any     anywhere             anywhere             match-set turris_047C0DE1_l_a_4_X src
    0     0 RETURN     all  --  any    any     anywhere             anywhere             match-set turris_06E7E701_l_a_4_X src
    0     0 RETURN     all  --  any    any     anywhere             anywhere             match-set turris_07E7E411_l_a_4_X src
    0     0 RETURN     all  --  any    any     anywhere             anywhere             match-set turris_0A566041_l_ap_4_X src,src
    0     0 RETURN     all  --  any    any     anywhere             anywhere             match-set turris_0A7D7011_l_a_4_X src
    0     0 RETURN     all  --  any    any     anywhere             anywhere             match-set turris_100FA4E0_lb_a_4_X src
    0     0 LOG        all  --  any    any     anywhere             anywhere             limit: avg 1/sec burst 500 LOG level debug prefix "turris-00000000: "
Chain turris-nflog (3 references)
Chain ucollect_fake (1 references)
    0     0 LOG        all  --  any    any     anywhere             anywhere             mark match 0x80000/0xc0000 limit: avg 100/sec burst 200 LOG level debug prefix "ucollect-fake-open-inet: "
    0     0 DROP       all  --  any    any     anywhere             anywhere             mark match 0x80000/0xc0000
Chain ucollect_fake_accept (1 references)
    0     0 ACCEPT     tcp  --  any    any     anywhere             anywhere             tcp dpt:3692 mark match 0xc0000/0xc0000
    0     0 ACCEPT     tcp  --  any    any     anywhere             anywhere             tcp dpt:1392 mark match 0xc0000/0xc0000
    0     0 ACCEPT     tcp  --  any    any     anywhere             anywhere             tcp dpt:1449 mark match 0xc0000/0xc0000
Chain zone_lan_dest_accept (4 references)
    0     0 accept     all  --  any    br-lan  anywhere             anywhere
Chain zone_lan_forward (1 references)
   34  2052 forwarding_lan_rule  all  --  any    any     anywhere             anywhere             /* user chain for forwarding */
   14   728 zone_wan_dest_accept  tcp  --  any    any     anywhere             anywhere             /* @rule[10] */
   20  1324 zone_wan_dest_accept  udp  --  any    any     anywhere             anywhere             /* @rule[10] */
    0     0 zone_wan_dest_accept  all  --  any    any     anywhere             anywhere             /* forwarding lan -> wan */
    0     0 accept     all  --  any    any     anywhere             anywhere             ctstate DNAT /* Accept port forwards */
    0     0 zone_lan_dest_accept  all  --  any    any     anywhere             anywhere
Chain zone_lan_input (1 references)
   22  1689 input_lan_rule  all  --  any    any     anywhere             anywhere             /* user chain for input */
    0     0 accept     all  --  any    any     anywhere             anywhere             ctstate DNAT /* Accept port redirections */
   22  1689 zone_lan_src_accept  all  --  any    any     anywhere             anywhere
Chain zone_lan_output (1 references)
    0     0 output_lan_rule  all  --  any    any     anywhere             anywhere             /* user chain for output */
Chain zone_lan_src_accept (1 references)
   22  1689 accept     all  --  br-lan any     anywhere             anywhere
Chain zone_wan_dest_REJECT (1 references)
    0     0 reject     all  --  any    eth1    anywhere             anywhere
Chain zone_wan_dest_accept (4 references)
 2229  181K accept     all  --  any    eth1    anywhere             anywhere
Chain zone_wan_forward (1 references)
    4   192 MINIUPNPD  all  --  any    any     anywhere             anywhere
    4   192 forwarding_wan_rule  all  --  any    any     anywhere             anywhere             /* user chain for forwarding */
    0     0 zone_lan_dest_accept  esp  --  any    any     anywhere             anywhere             /* @rule[7] */
    0     0 zone_lan_dest_accept  udp  --  any    any     anywhere             anywhere             udp dpt:isakmp /* @rule[8] */
    4   192 accept     all  --  any    any     anywhere             anywhere             ctstate DNAT /* Accept port forwards */
    0     0 zone_wan_dest_REJECT  all  --  any    any     anywhere             anywhere
Chain zone_wan_input (1 references)
   66  4027 input_wan_rule  all  --  any    any     anywhere             anywhere             /* user chain for input */
    0     0 accept     udp  --  any    any     anywhere             anywhere             udp dpt:bootpc /* Allow-DHCP-Renew */
    1   128 accept     icmp --  any    any     anywhere             anywhere             icmp echo-request /* Allow-Ping */
    6   168 accept     igmp --  any    any     anywhere             anywhere             /* Allow-IGMP */
   48  2096 accept     tcp  --  any    any     anywhere             anywhere             /* @rule[9] */
   11  1635 accept     udp  --  any    any     anywhere             anywhere             /* @rule[9] */
    0     0 zone_wan_src_REJECT  all  --  any    any     anywhere             anywhere
Chain zone_wan_output (1 references)
 2195  179K output_wan_rule  all  --  any    any     anywhere             anywhere             /* user chain for output */
 2195  179K zone_wan_dest_accept  all  --  any    any     anywhere             anywhere
Chain zone_wan_src_REJECT (1 references)
    0     0 reject     all  --  eth1   any     anywhere             anywhere
I am no so skill to command line. I can’t open a text editor to edit the configuration files
There should not be those two rules in the chain zone_wan_input.
No understand - this text - I can`t it found. Do you think these lines ?
I do it, but ports 22, 80, 53 and 443 are open - port 53 is not close.
Port 53 DNS port is to be opened in the default ?
AHA-it’s up to the next rule !
Port 22 open, port80 stealth, port 443 open
It is ready ? Can I all three line disable ? On what is the the esp protokol ? First two line is for VPN ?
ESP and IKE are for IPSec, which is one way for implementing VPN.
And you should be able to check what is rule 9 by giving command “uci show ‘firewall.@rule[9]’” via SSH.
It is sufficient to simply disable just the last rule of three on picture - yes ?
