Zdravím,
nějakou dobu už se nemůžu připojit k mému domácímu VPN (z mobilu ani odjinud).
|Verze reForisu|1.4.1||Verze Turris OS|6.3.0||Větev Turris OS|HBS||Verze kernelu|5.15.96|
Co je zajímavé, nejdou přidávat noví klienti ve webovém rozhraní.
Prosím o radu, co zkusit. Díky
Fri May 03 08:59:32 2024 OpenVPN 2.4.8 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019
Fri May 03 08:59:32 2024 Windows version 6.2 (Windows 8 or greater) 64bit
Fri May 03 08:59:32 2024 library versions: OpenSSL 1.1.0l 10 Sep 2019, LZO 2.10
Fri May 03 08:59:32 2024 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:25340
Fri May 03 08:59:32 2024 Need hold release from management interface, waiting...
Fri May 03 08:59:32 2024 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:25340
Fri May 03 08:59:32 2024 MANAGEMENT: CMD 'state on'
Fri May 03 08:59:32 2024 MANAGEMENT: CMD 'log all on'
Fri May 03 08:59:33 2024 MANAGEMENT: CMD 'echo all on'
Fri May 03 08:59:33 2024 MANAGEMENT: CMD 'bytecount 5'
Fri May 03 08:59:33 2024 MANAGEMENT: CMD 'hold off'
Fri May 03 08:59:33 2024 MANAGEMENT: CMD 'hold release'
Fri May 03 08:59:33 2024 TCP/UDP: Preserving recently used remote address: [AF_INET]141.*.*.*:1194
Fri May 03 08:59:33 2024 Socket Buffers: R=[65536->65536] S=[65536->65536]
Fri May 03 08:59:33 2024 UDP link local: (not bound)
Fri May 03 08:59:33 2024 UDP link remote: [AF_INET]141.*.*.*:1194
Fri May 03 08:59:33 2024 MANAGEMENT: >STATE:1714719573,WAIT,,,,,,
Fri May 03 08:59:33 2024 MANAGEMENT: >STATE:1714719573,AUTH,,,,,,
Fri May 03 08:59:33 2024 TLS: Initial packet from [AF_INET]141.*.*.*:1194, sid=920969f9 a8178456
Fri May 03 08:59:33 2024 VERIFY OK: depth=1, CN=openvpn
Fri May 03 08:59:33 2024 VERIFY KU OK
Fri May 03 08:59:33 2024 Validating certificate extended key usage
Fri May 03 08:59:33 2024 ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Fri May 03 08:59:33 2024 VERIFY EKU OK
Fri May 03 08:59:33 2024 VERIFY OK: depth=0, CN=turris
Fri May 03 09:00:33 2024 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri May 03 09:00:33 2024 TLS Error: TLS handshake failed
Fri May 03 09:00:33 2024 SIGUSR1[soft,tls-error] received, process restarting
Fri May 03 09:00:33 2024 MANAGEMENT: >STATE:1714719633,RECONNECTING,tls-error,,,,,
Fri May 03 09:00:33 2024 Restart pause, 5 second(s)
Fri May 03 09:00:38 2024 TCP/UDP: Preserving recently used remote address: [AF_INET]141.170.141.124:1194
Fri May 03 09:00:38 2024 Socket Buffers: R=[65536->65536] S=[65536->65536]
Fri May 03 09:00:38 2024 UDP link local: (not bound)
Fri May 03 09:00:38 2024 UDP link remote: [AF_INET]141.*.*.*:1194
Fri May 03 09:00:38 2024 MANAGEMENT: >STATE:1714719638,WAIT,,,,,,
Fri May 03 09:00:38 2024 MANAGEMENT: >STATE:1714719638,AUTH,,,,,,
Fri May 03 09:00:38 2024 TLS: Initial packet from [AF_INET]141.*.*.*:1194, sid=ecdf051e 4735544c
Fri May 03 09:00:39 2024 VERIFY OK: depth=1, CN=openvpn
Fri May 03 09:00:39 2024 VERIFY KU OK
Fri May 03 09:00:39 2024 Validating certificate extended key usage
Fri May 03 09:00:39 2024 ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Fri May 03 09:00:39 2024 VERIFY EKU OK
Fri May 03 09:00:39 2024 VERIFY OK: depth=0, CN=turris
