OOM Killer Kresd
Hello everyone,
I have noticed a rather strange behavior.
This process:
“/usr/sbin/kresd --noninteractive -c /tmp/kresd.config /tmp/kresd”
has been slowly filling up my RAM bit by bit. Until, according to the system log, the OOM kill strikes and the router then goes to 10 times its capacity and doesn’t respond at all for about 5 minutes.
I have not made any changes, but I suspect that it only occurred after the update to TurrisOS 7.0.3.
All firmware updates were also carried out successfully.
First it occurred sporadically, now every 3 hours.
Do you have any idea what the problem could be?
Best regards!
I have a very similar issue What is knot's msg_buffer_size? - #10 by bamf
Here it takes a few days until all memory is consumed and the OOM killer strikes.
Unfortunately no solution from Turris yet.
