I am in need of some help with the following problem:
My Omnia (TOS7.2) is atm serving as an AccessPoint, connected via WiFi as a client to my router, and via relayd all clients connected to it´s LAN ports are integrated into the home network.
All clients connected to the lan ports of the omnia - except the philips hue bridge - are working well. The bridge gets one to four timeouts within a span of twenty seconds when i run ping -t to check on it.
What I did to troubleshoot:
- bought a second hue bridge. same behaviour.
- changed lan cable from bridge > omnia, no improvement
- changed lan port on the omnia, no improvement
- ran ping -t on all other devices connected to the omnia (RasPi, NAS) no timeouts!
- connected the hue bridge dirctly to my main router = no timeouts
That led me to the following conclusions:
- the WiFi link and relayd configuration works
- the bridge works connected to the other router, too
- is has to be something specific to the omnia AND the bridge, but I´m not able to narrow it down.
Is the omnia refusing packets ? actively blocking the hue bridge? if so, why?
Any hints on what to check / do? (besides installing a lan cable to that room where the omnia is…)
Thanks!
