However, I have a second omnia with a second power supply. My second omnia works fine using both of my supplies. And both supplies behave the same with the faulty omnia.
Also, the omnia’s B LED is blinking at the same rate as the supply LED.
I’m attempting to use a serial connection to access the omnia file system. I’m able to open a Putty screen in Windows 10, as the serial page describes. However, when I press enter, I’m not seeing the Turris portal.
I’m using a 4-wire TTL USB serial cable, and I’m connecting to the omnia pins from left-to-right - GND, RX, TX, Open. I’m not sure what my issue is here.
I’m using the Prolific PL2303HXA USB-to-Serial Cable now. I’ve ordered a new cable - the same that is used in the /serial webpage. Hopefully that will solve the problem.
Serial config:
Baud Rate = 115200
Data bits = 8
Stop bits = 1
Parity = None
Flow Control = None (also tried XON/XOFF)
My USB-to-Serial device’s pcb board has 2 output voltage pins (3.3v / 5v). Currently, the 5v pin is soldered to 1 of the 4 wires that are inside the cable. I can desolder the wire from the 5v pad and solder it to the 3v pad. However, I’m not even using this wire when I connect the cable to the omnia. I’m only using the GND, RX, and TX wires, as the serial webpage describes.
I will try to use the 3v3 output anyway, once I have the soldering iron. Thanks for the input.
The fact that I was observing this behavior before attempting to connect my serial cable gives me hope. The aerial cable works with another router I own.
I can now verify that the serial cable I’m using is working properly. The omnia is still completely unresponsive. No LED activity, no serial access/response, and no lan activity.
Does this sound like a hardware problem at this point? Any help is greatly appreciated.
If this is a hardware problem, is anyone willing to help with hardware repair?
3 LEDs rollback to faktory reset no succes? record the entire process on video
if there is no more experienced member in your area, all that remains is to send a router to support CZ.NIC. SSH is the way to install the system on mSATA DISK
