Hi folks,
I really hope you can help me and give me direction.
Since last reboot my Turris Omnia does not boot successfully anymore.
UART debugging gives me the following.
U-Boot SPL 2015.10-rc2 (Aug 18 2016 - 20:43:35)
High speed PHY - Version: 2.0
SERDES0 card detect: SATA
Initialize Turris board topology
Detected Device ID 6820
board SerDes lanes topology details:
| Lane # | Speed | Type |
| 0 | 6 | SATA0 |
| 1 | 5 | USB3 HOST0 |
| 2 | 5 | PCIe1 |
| 3 | 5 | USB3 HOST1 |
| 4 | 5 | PCIe2 |
| 5 | 0 | SGMII2 |
poll_op_execute: TIMEOUT
:** Link is Gen1, check the EP capability
PCIe, Idx 1: remains Gen1
PCIe, Idx 2: Link upgraded to Gen2 based on client cpabilities
DDR3 Training Sequence - Ver TIP-1.29.0
Memory config in EEPROM: 0x01
DDR3 Training Sequence - Switching XBAR Window to FastPath Window
DDR3 Training Sequence - Ended Successfully
U-Boot 2015.10-rc2 (Aug 18 2016 - 20:43:35 +0200), Build: jenkins-omnia-master-23
SoC: MV88F6820-A0
Watchdog enabled
I2C: ready
SPI: ready
DRAM: 1 GiB (ECC not enabled)
Enabling Armada 385 watchdog.
Disabling MCU startup watchdog.
Regdomain set to **
MMC: mv_sdh: 0
SF: Detected S25FL164K with page size 256 Bytes, erase size 64 KiB, total 8 MiB
PCI:
00:01.0 - 168c:003c - Network controller
PCI:
01:00.0 - 11ab:6820 - Memory controller
01:01.0 - 1b21:0622 - Mass storage controller
Model: Marvell Armada 385 GP
Board: Turris Omnia SN: 0000000B0000B630
Regdomain set to **
SCSI: MVEBU SATA INIT
Target spinup took 0 ms.
SATA link 1 timeout.
AHCI 0001.0000 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
flags: 64bit ncq led only pmp fbss pio slum part sxs
Net: neta2
Hit any key to stop autoboot: 0
Setting bus to 1
BOOT eMMC FS
scanning bus for devices...
Device 0: (0:0) Vendor: ATA Prod.: SATA SSD Rev: SBFM
Type: Hard Disk
Capacity: 114473.4 MB = 111.7 GB (234441648 x 512)
Found 1 device(s).
BtrFS init: Max node or leaf size 16384
4282952 bytes read in 162 ms (25.2 MiB/s)
20709 bytes read in 110 ms (183.6 KiB/s)
Kernel image @ 0x1000000 [ 0x000000 - 0x415a48 ]
## Flattened Device Tree blob at 02000000
Booting using the fdt blob at 0x2000000
Loading Device Tree to 0fff7000, end 0ffff0e4 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.15.74 (packaging@turris.cz) (arm-openwrt-linux-muslgnueabi-gcc (OpenWrt GCC 8.4.0 r16691+128-060aa0021f) 8.4.0, GNU ld (GNU Binutils) 2.34) #0 SMP Thu Oct 20 23:59:29 2022
[ 0.000000] CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Turris Omnia
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000000000000-0x000000002fffffff]
[ 0.000000] HighMem [mem 0x0000000030000000-0x000000003fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000003fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000003fffffff]
[ 0.000000] percpu: Embedded 11 pages/cpu s14732 r8192 d22132 u45056
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 260416
[ 0.000000] Kernel command line: earlyprintk console=ttyS0,115200 rootfstype=btrfs rootwait root=/dev/sdc1 rootflags=subvol=@,commit=5 rw cfg80211.freg=**
[ 0.000000] Bootloader command line not present
[ 0.000000] Unknown kernel command line parameters "earlyprintk mangled_fs=btrfs", will be passed to user space.
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 1024136K/1048576K available (9216K kernel code, 668K rwdata, 2176K rodata, 1024K init, 259K bss, 24440K reserved, 0K cma-reserved, 262144K highmem)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] Registering MPIC SoC Error Interrupt Controller
[ 0.000000] L2C: DT/platform modifies aux control register: 0x06070000 -> 0x16070000
[ 0.000000] L2C-310 enabling early BRESP for Cortex-A9
[ 0.000000] L2C-310 full line of zeros enabled for Cortex-A9
[ 0.000000] L2C-310 D prefetch enabled, offset 1 lines
[ 0.000000] L2C-310 dynamic clock gating enabled, standby mode enabled
[ 0.000000] L2C-310 Coherent cache controller enabled, 16 ways, 1024 kB
[ 0.000000] L2C-310 Coherent: CACHE_ID 0x410054c9, AUX_CTRL 0x56070001
[ 0.000000] sched_clock: 64 bits at 800MHz, resolution 1ns, wraps every 4398046511103ns
[ 0.000017] clocksource: arm_global_timer: mask: 0xffffffffffffffff max_cycles: 0xb881274fa3, max_idle_ns: 440795210636 ns
[ 0.000033] Switching to timer-based delay loop, resolution 1ns
[ 0.000181] Ignoring duplicate/late registration of read_current_timer delay
[ 0.000187] clocksource: armada_370_xp_clocksource: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 76450417870 ns
[ 0.000373] Console: colour dummy device 80x30
[ 0.000401] Calibrating delay loop (skipped), value calculated using timer frequency.. 1600.00 BogoMIPS (lpj=8000000)
[ 0.000409] pid_max: default: 32768 minimum: 301
[ 0.000501] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.000510] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.000893] CPU: Testing write buffer coherency: ok
[ 0.000915] CPU0: Spectre v2: using BPIALL workaround
[ 0.001010] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.001309] Setting up static identity map for 0x100000 - 0x100060
[ 0.001392] mvebu-soc-id: MVEBU SoC ID=0x6820, Rev=0x4
[ 0.001480] mvebu-pmsu: Initializing Power Management Service Unit
[ 0.001540] rcu: Hierarchical SRCU implementation.
[ 0.001613] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[ 0.001673] smp: Bringing up secondary CPUs ...
[ 0.001838] Booting CPU 1
[ 0.001967] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.001973] CPU1: Spectre v2: using BPIALL workaround
[ 0.002030] smp: Brought up 1 node, 2 CPUs
[ 0.002037] SMP: Total of 2 processors activated (3200.00 BogoMIPS).
[ 0.002043] CPU: All CPU(s) started in SVC mode.
[ 0.002300] devtmpfs: initialized
[ 0.004120] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[ 0.004171] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.004182] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.004253] pinctrl core: initialized pinctrl subsystem
[ 0.004780] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.005317] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.005764] thermal_sys: Registered thermal governor 'step_wise'
[ 0.005898] cpuidle: using governor ladder
[ 0.005988] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
[ 0.005995] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.006120] mvebu-pmsu: CPU hotplug support is currently broken on Armada 38x: disabling
[ 0.006127] mvebu-pmsu: CPU idle is currently broken on Armada 38x: disabling
[ 0.014512] cryptd: max_cpu_qlen set to 1000
[ 0.015284] raid6: skip pq benchmark and using algorithm neonx8
[ 0.015293] raid6: using neon recovery algorithm
[ 0.015551] SCSI subsystem initialized
[ 0.015714] usbcore: registered new interface driver usbfs
[ 0.015735] usbcore: registered new interface driver hub
[ 0.015752] usbcore: registered new device driver usb
[ 0.016356] clocksource: Switched to clocksource arm_global_timer
[ 0.018585] NET: Registered PF_INET protocol family
[ 0.018693] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.019222] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.019241] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.019251] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.019290] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.019352] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.019398] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.019426] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.019533] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.019551] PCI: CLS 0 bytes, default 64
[ 0.019956] hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
[ 0.021824] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[ 0.023799] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.023805] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.024247] xor: measuring software checksum speed
[ 0.028083] arm4regs : 2594 MB/sec
[ 0.032993] 8regs : 2005 MB/sec
[ 0.037721] 32regs : 2083 MB/sec
[ 0.042919] neon : 1892 MB/sec
[ 0.042923] xor: using function: arm4regs (2594 MB/sec)
[ 0.042964] bounce: pool size: 64 pages
[ 0.042996] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 0.044086] armada-38x-pinctrl f1018000.pinctrl: registered pinctrl driver
[ 0.044620] debugfs: Directory 'f1018100.gpio' with parent 'regmap' already present!
[ 0.044911] debugfs: Directory 'f1018140.gpio' with parent 'regmap' already present!
[ 0.045219] mvebu-pcie soc:pcie: host bridge /soc/pcie ranges:
[ 0.045247] mvebu-pcie soc:pcie: MEM 0x00f1080000..0x00f1081fff -> 0x0000080000
[ 0.045263] mvebu-pcie soc:pcie: MEM 0x00f1040000..0x00f1041fff -> 0x0000040000
[ 0.045277] mvebu-pcie soc:pcie: MEM 0x00f1044000..0x00f1045fff -> 0x0000044000
[ 0.045290] mvebu-pcie soc:pcie: MEM 0x00f1048000..0x00f1049fff -> 0x0000048000
[ 0.045303] mvebu-pcie soc:pcie: MEM 0xffffffffffffffff..0x00fffffffe -> 0x0100000000
[ 0.045315] mvebu-pcie soc:pcie: IO 0xffffffffffffffff..0x00fffffffe -> 0x0100000000
[ 0.045328] mvebu-pcie soc:pcie: MEM 0xffffffffffffffff..0x00fffffffe -> 0x0200000000
[ 0.045340] mvebu-pcie soc:pcie: IO 0xffffffffffffffff..0x00fffffffe -> 0x0200000000
[ 0.045352] mvebu-pcie soc:pcie: MEM 0xffffffffffffffff..0x00fffffffe -> 0x0300000000
[ 0.045365] mvebu-pcie soc:pcie: IO 0xffffffffffffffff..0x00fffffffe -> 0x0300000000
[ 0.045376] mvebu-pcie soc:pcie: MEM 0xffffffffffffffff..0x00fffffffe -> 0x0400000000
[ 0.045386] mvebu-pcie soc:pcie: IO 0xffffffffffffffff..0x00fffffffe -> 0x0400000000
[ 0.045490] mvebu-pcie soc:pcie: pcie0.0: Slot power limit 10.0W
[ 0.045545] mvebu-pcie soc:pcie: pcie1.0: Slot power limit 10.0W
[ 0.045597] mvebu-pcie soc:pcie: pcie2.0: Slot power limit 10.0W
[ 0.046153] mvebu-pcie soc:pcie: PCI host bridge to bus 0000:00
[ 0.046164] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.046173] pci_bus 0000:00: root bus resource [mem 0xf1080000-0xf1081fff] (bus address [0x00080000-0x00081fff])
[ 0.046180] pci_bus 0000:00: root bus resource [mem 0xf1040000-0xf1041fff] (bus address [0x00040000-0x00041fff])
[ 0.046187] pci_bus 0000:00: root bus resource [mem 0xf1044000-0xf1045fff] (bus address [0x00044000-0x00045fff])
[ 0.046194] pci_bus 0000:00: root bus resource [mem 0xf1048000-0xf1049fff] (bus address [0x00048000-0x00049fff])
[ 0.046200] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xe7ffffff]
[ 0.046205] pci_bus 0000:00: root bus resource [io 0x1000-0xeffff]
[ 0.046270] pci 0000:00:01.0: [11ab:6820] type 01 class 0x060400
[ 0.046464] pci 0000:00:02.0: [11ab:6820] type 01 class 0x060400
[ 0.046609] pci 0000:00:03.0: [11ab:6820] type 01 class 0x060400
[ 0.047444] PCI: bus0: Fast back to back transfers disabled
[ 0.047452] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.047463] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.047472] pci 0000:00:03.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.048313] PCI: bus1: Fast back to back transfers enabled
[ 0.048321] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 0.048394] pci 0000:02:00.0: [168c:003c] type 00 class 0x028000
[ 0.048417] pci 0000:02:00.0: reg 0x10: [mem 0xe8000000-0xe81fffff 64bit]
[ 0.048449] pci 0000:02:00.0: reg 0x30: [mem 0xe8200000-0xe820ffff pref]
[ 0.048519] pci 0000:02:00.0: supports D1 D2
[ 0.049399] PCI: bus2: Fast back to back transfers disabled
[ 0.049406] pci_bus 0000:02: busn_res: [bus 02-ff] end is updated to 02
[ 0.049472] pci 0000:03:00.0: [1b21:0622] type 00 class 0x010601
[ 0.049512] pci 0000:03:00.0: reg 0x24: [mem 0xea000000-0xea001fff]
[ 0.049524] pci 0000:03:00.0: reg 0x30: [mem 0xea080000-0xea0fffff pref]
[ 0.050432] PCI: bus3: Fast back to back transfers disabled
[ 0.050439] pci_bus 0000:03: busn_res: [bus 03-ff] end is updated to 03
[ 0.050462] pci 0000:00:01.0: BAR 8: assigned [mem 0xe0000000-0xe03fffff]
[ 0.050471] pci 0000:00:02.0: BAR 8: assigned [mem 0xe0400000-0xe07fffff]
[ 0.050479] pci 0000:00:03.0: BAR 8: assigned [mem 0xe0800000-0xe0bfffff]
[ 0.050486] pci 0000:00:01.0: BAR 7: assigned [io 0x10000-0x10fff]
[ 0.050492] pci 0000:00:02.0: BAR 7: assigned [io 0x20000-0x20fff]
[ 0.050498] pci 0000:00:03.0: BAR 7: assigned [io 0x30000-0x30fff]
[ 0.050505] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.050511] pci 0000:00:01.0: bridge window [io 0x10000-0x10fff]
[ 0.050522] pci 0000:00:01.0: bridge window [mem 0xe0000000-0xe03fffff]
[ 0.050535] pci 0000:02:00.0: BAR 0: assigned [mem 0xe0400000-0xe05fffff 64bit]
[ 0.050548] pci 0000:02:00.0: BAR 6: assigned [mem 0xe0600000-0xe060ffff pref]
[ 0.050555] pci 0000:00:02.0: PCI bridge to [bus 02]
[ 0.050560] pci 0000:00:02.0: bridge window [io 0x20000-0x20fff]
[ 0.050569] pci 0000:00:02.0: bridge window [mem 0xe0400000-0xe07fffff]
[ 0.050581] pci 0000:03:00.0: BAR 6: assigned [mem 0xe0800000-0xe087ffff pref]
[ 0.050588] pci 0000:03:00.0: BAR 5: assigned [mem 0xe0880000-0xe0881fff]
[ 0.050596] pci 0000:00:03.0: PCI bridge to [bus 03]
[ 0.050601] pci 0000:00:03.0: bridge window [io 0x30000-0x30fff]
[ 0.050610] pci 0000:00:03.0: bridge window [mem 0xe0800000-0xe0bfffff]
[ 0.050675] pcieport 0000:00:01.0: enabling device (0140 -> 0143)
[ 0.050736] pcieport 0000:00:01.0: pciehp: Slot #1 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise- Interlock- NoCompl+ IbPresDis- LLActRep+
[ 0.050957] pcieport 0000:00:01.0: pciehp: Slot(1): Card present
[ 0.051032] pcieport 0000:00:02.0: enabling device (0140 -> 0143)
[ 0.051086] pcieport 0000:00:02.0: pciehp: Slot #2 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise- Interlock- NoCompl+ IbPresDis- LLActRep+
[ 0.051483] pcieport 0000:00:03.0: enabling device (0140 -> 0143)
[ 0.051546] pcieport 0000:00:03.0: pciehp: Slot #3 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise- Interlock- NoCompl+ IbPresDis- LLActRep+
[ 0.052124] mv_xor f1060800.xor: Marvell shared XOR driver
[ 0.066358] mvebu-pcie soc:pcie: pcie2.0: link up
[ 0.066382] mvebu-pcie soc:pcie: pcie1.0: link up
[ 0.106762] mv_xor f1060800.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
[ 0.106917] mv_xor f1060900.xor: Marvell shared XOR driver
[ 0.166744] mv_xor f1060900.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
[ 0.167013] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[ 0.168142] printk: console [ttyS0] disabled
[ 0.188240] f1012000.serial: ttyS0 at MMIO 0xf1012000 (irq = 30, base_baud = 15625000) is a 16550A
[ 1.442023] printk: console [ttyS0] enabled
[ 1.466766] f1012100.serial: ttyS1 at MMIO 0xf1012100 (irq = 31, base_baud = 15625000) is a 16550A
[ 1.478023] loop: module loaded
[ 1.481182] Loading iSCSI transport class v2.0-870.
[ 1.487303] ahci-mvebu f10a8000.sata: supply ahci not found, using dummy regulator
[ 1.494966] ahci-mvebu f10a8000.sata: supply phy not found, using dummy regulator
[ 1.502511] ahci-mvebu f10a8000.sata: supply target not found, using dummy regulator
[ 1.510349] ahci-mvebu f10a8000.sata: AHCI 0001.0000 32 slots 2 ports 6 Gbps 0x3 impl platform mode
[ 1.519429] ahci-mvebu f10a8000.sata: flags: 64bit ncq sntf led only pmp fbs pio slum part sxs
[ 1.528739] scsi host0: ahci-mvebu
[ 1.532421] scsi host1: ahci-mvebu
[ 1.535907] ata1: SATA max UDMA/133 mmio [mem 0xf10a8000-0xf10a9fff] port 0x100 irq 53
[ 1.543865] ata2: SATA max UDMA/133 mmio [mem 0xf10a8000-0xf10a9fff] port 0x180 irq 53
[ 1.552821] spi-nor spi0.0: s25fl164k (8192 Kbytes)
[ 1.557852] 2 fixed-partitions partitions found on MTD device spi0.0
[ 1.564225] Creating 2 MTD partitions on "spi0.0":
[ 1.569050] 0x000000000000-0x000000100000 : "U-Boot"
[ 1.574295] 0x000000100000-0x000000800000 : "Rescue system"
[ 1.582434] hwmon hwmon0: temp1_input not attached to any thermal zone
[ 1.589443] mvneta_bm f10c8000.bm: Buffer Manager for network controller enabled
[ 1.598453] mvneta f1070000.ethernet eth0: Using hardware mac address d8:58:d7:00:4c:40
[ 1.607741] mvneta f1030000.ethernet eth1: Using hardware mac address d8:58:d7:00:4c:3e
[ 1.617013] mvneta f1034000.ethernet eth2: Using hardware mac address d8:58:d7:00:4c:3f
[ 1.625166] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.631722] ehci-pci: EHCI PCI platform driver
[ 1.636208] ehci-platform: EHCI generic platform driver
[ 1.641531] ehci-orion: EHCI orion driver
[ 1.645643] orion-ehci f1058000.usb: EHCI Host Controller
[ 1.651074] orion-ehci f1058000.usb: new USB bus registered, assigned bus number 1
[ 1.658718] orion-ehci f1058000.usb: irq 49, io mem 0xf1058000
[ 1.686365] orion-ehci f1058000.usb: USB 2.0 started, EHCI 1.00
[ 1.692597] hub 1-0:1.0: USB hub found
[ 1.696458] hub 1-0:1.0: 1 port detected
[ 1.700787] xhci-hcd f10f0000.usb3: xHCI Host Controller
[ 1.706122] xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 2
[ 1.713688] xhci-hcd f10f0000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x0000000000010010
[ 1.722967] xhci-hcd f10f0000.usb3: irq 55, io mem 0xf10f0000
[ 1.728811] xhci-hcd f10f0000.usb3: xHCI Host Controller
[ 1.734140] xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 3
[ 1.741683] xhci-hcd f10f0000.usb3: Host supports USB 3.0 SuperSpeed
[ 1.748321] hub 2-0:1.0: USB hub found
[ 1.752094] hub 2-0:1.0: 1 port detected
[ 1.756153] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.764482] hub 3-0:1.0: USB hub found
[ 1.768263] hub 3-0:1.0: 1 port detected
[ 1.772381] xhci-hcd f10f8000.usb3: xHCI Host Controller
[ 1.777732] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 4
[ 1.785304] xhci-hcd f10f8000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x0000000000010010
[ 1.794577] xhci-hcd f10f8000.usb3: irq 56, io mem 0xf10f8000
[ 1.800412] xhci-hcd f10f8000.usb3: xHCI Host Controller
[ 1.805741] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 5
[ 1.813259] xhci-hcd f10f8000.usb3: Host supports USB 3.0 SuperSpeed
[ 1.819872] hub 4-0:1.0: USB hub found
[ 1.823644] hub 4-0:1.0: 1 port detected
[ 1.827716] usb usb5: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.836027] hub 5-0:1.0: USB hub found
[ 1.839806] hub 5-0:1.0: 1 port detected
[ 1.843955] usbcore: registered new interface driver usb-storage
[ 1.850478] armada38x-rtc f10a3800.rtc: registered as rtc0
[ 1.856181] i2c_dev: i2c /dev entries driver
[ 1.862672] orion_wdt: Initial timeout 171 sec
[ 1.867392] sdhci: Secure Digital Host Controller Interface driver
[ 1.873588] sdhci: Copyright(c) Pierre Ossman
[ 1.878067] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.882635] ata2: SATA link down (SStatus 0 SControl 300)
[ 1.887093] marvell-cesa f1090000.crypto: CESA device successfully registered
[ 1.896822] NET: Registered PF_INET6 protocol family
[ 1.902429] Segment Routing with IPv6
[ 1.906121] In-situ OAM (IOAM) with IPv6
[ 1.910105] NET: Registered PF_PACKET protocol family
[ 1.915127] mmc0: SDHCI controller on f10d8000.sdhci [f10d8000.sdhci] using ADMA
[ 1.915196] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.935702] 8021q: 802.1Q VLAN Support v1.8
[ 1.939992] Registering SWP/SWPB emulation handler
[ 1.946976] Btrfs loaded, crc32c=crc32c-generic, zoned=no, fsverity=no
[ 2.039250] mmc0: Enabling HPI failed
[ 2.042928] mmc0: new high speed MMC card at address 0001
[ 2.048748] mmcblk0: mmc0:0001 M MOR 1.83 GiB
[ 2.053990] mmcblk0boot0: mmc0:0001 M MOR 2.00 MiB
[ 2.059405] mmcblk0boot1: mmc0:0001 M MOR 2.00 MiB
[ 2.064635] mmcblk0rpmb: mmc0:0001 M MOR 128 KiB, chardev (247:0)
[ 2.070876] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 2.077191] ata1.00: ATA-11: SATA SSD, SBFM61.3, max UDMA/133
[ 2.082956] ata1.00: 234441648 sectors, multi 16: LBA48 NCQ (depth 32)
[ 2.089604] ata1.00: configured for UDMA/133
[ 2.094059] scsi 0:0:0:0: Direct-Access ATA SATA SSD 61.3 PQ: 0 ANSI: 5
[ 2.102630] sd 0:0:0:0: [sda] 234441648 512-byte logical blocks: (120 GB/112 GiB)
[ 2.110176] sd 0:0:0:0: [sda] Write Protect is off
[ 2.115016] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.124682] sda: sda1
[ 2.127348] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 2.132901] Waiting for root device /dev/sdc1...
[ 3.406355] pcieport 0000:00:01.0: pciehp: Slot(1): No link
Any clue why all of a sudden no PCIe link is found? Is that referring to the mSATA SSD drive? Is it full or something alike?
I cleaned a number of snapshots (I thought Schnapps snapshots) before last rebooting.
That reboot then did not work
Hope someone is able to give me driection,
Thanks a mile.
