When I plug in my Omnia, the B LED and the light on the power supply blink on and off about once per second.
Where should I start debugging this?
I have the same problem. The power supply unit LED is blinking with about a second interval when it’s plugged into the turris omnia. When I unplug it from the router the LED stays on constantly.
It seems to have been a bad power supply in my case. I bought a new one and the router appears to boot.
Hello, how did you solved your issue? I turned off my Omnia yesterday (was completely working correctly), today I turn on my Omnia and power supply is only blinking (LED light). Omnia is turned off. Thank you
