I have an Omnia 2020 I am trying to setup. Previously it was working fine, but when I moved my setup from one place to another the Omnia stopped working. It started with only the B led blinking when plugged in. I tried the factory reset instructions and nothing happened. I opened the box and looked at the fuse, which was intact and had continuity. I put the box back together and the situation was the same. I left the box alone for a few hours then came back and now the box won’t power on at all, and the power supply light blinks slow green. I checked the output of the power supply and it reads 12.11 volts.
What troubleshooting steps do I take at this stage?
Thank you,
