Hello, I have problem with my Omnia. After plugin power supply, controll led light blue then 5 times blink red and this is repeat again and again. Power suplly is ok and I try another. Also I try connect usb stick with medkit, no reaction. Is It hw KO? or it is any chance to save router?
the power led blinking indicates a HW problem on the power rail. Please contact the support to discuss the next steps.
Kind regards, Hagrid
Hi enso
I have the same problem.
Can you share the process they ask you to not ask the same another time.
