It took me a while to figure out but I think I was able to boot from serial and later also write new uboot to NOR ( Omnia - Turris Documentation). I hope, I understand it correctly.
Now I am little stuck and not sure how to make it to boot from internal SSD I have installed or external USB. Any suggestions please?
This is what I get now:
BootROM - 1.73
Booting from SPI flash
U-Boot SPL 2024.10-rc3-OpenWrt-r20343+127-4e1d1b7df0 (Sep 13 2024 - 01:38:50 +00 00)
High speed PHY - Version: 2.0
MiniPCIe/mSATA card detection... mSATA
WWAN slot configuration... PCIe+USB2.0
Detected Device ID 6820
board SerDes lanes topology details:
| Lane # | Speed | Type |
| 0 | 6 | SATA0 |
| 1 | 5 | USB3 HOST0 |
| 2 | 5 | PCIe1 |
| 3 | 5 | USB3 HOST1 |
| 4 | 5 | PCIe2 |
| 5 | 0 | SGMII2 |
mv_ddr: 14.0.0
DDR3 Training Sequence - Switching XBAR Window to FastPath Window
mv_ddr: completed successfully
Trying to boot from SPI
U-Boot 2024.10-rc3-OpenWrt-r20343+127-4e1d1b7df0 (Sep 13 2024 - 01:38:50 +0000), Build: jenkins-TurrisOS-packages-hbk-omnia-1216
SoC: MV88F6820-A0 at 1600 MHz
DRAM: 2 GiB (800 MHz, 32-bit, 2T, ECC not enabled)
Core: 89 devices, 31 uclasses, devicetree: separate
WDT: Started watchdog@20300 with servicing every 1000ms (60s timeout)
MMC: mv_sdh: 0
Loading Environment from SPIFlash... SF: Detected s25fl164k with page size 256 B ytes, erase size 4 KiB, total 8 MiB
*** Warning - bad CRC, using default environment
Model: Turris Omnia
MCU type: STM32
MCU version: b5a8a24e007eb72be16aeb3fff6f03ec647023e4
RAM size: 2048 MiB
Board version: unknown
Serial Number: 0000000C0000211D
Disabling MCU watchdog... disabled
Regdomain set to **
pcie1.0: Link up
pcie2.0: Link up
Net: eth0: ethernet@70000, eth1: ethernet@30000, eth2: ethernet@34000 [PRIME], eth3: lan0, eth4: lan1, eth5: lan2, eth6: lan3, eth7: lan4
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1...
No EFI system partition
Failed to persist EFI variables
Missing RNG device for EFI_RNG_PROTOCOL
Loading Boot0000 'mmc 0' failed
EFI boot manager: Cannot load any image
Device 0: unknown device
scanning bus for devices...
Target spinup took 0 ms.
SATA link 1 timeout.
AHCI 0001.0000 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
flags: 64bit ncq led only pmp fbss pio slum part sxs
Device 0: (0:0) Vendor: ATA Prod.: Samsung SSD 860 Rev: RVT4
Type: Hard Disk
Capacity: 953869.7 MB = 931.5 GB (1953525168 x 512)
Type: Hard Disk
... is now current device
** No partition table - scsi 0 **
Couldn't find partition scsi 0:1
starting USB...
Bus usb@58000: USB EHCI 1.00
Bus usb3@f0000: MVEBU XHCI INIT controller @ 0xf10f4000
Register 2000120 NbrPorts 2
Starting the controller
USB XHCI 1.00
Bus usb3@f8000: MVEBU XHCI INIT controller @ 0xf10fc000
USB XHCI 1.00
scanning bus usb@58000 for devices... 1 USB Device(s) found
scanning bus usb3@f0000 for devices... 1 USB Device(s) found
scanning bus usb3@f8000 for devices... 1 USB Device(s) found
scanning usb for storage devices... 0 Storage Device(s) found
ethernet@34000 Waiting for PHY auto negotiation to complete................. TIMEOUT !
ethernet@34000: No link.
lan0 Waiting for PHY auto negotiation to complete................. TIMEOUT !
lan1 Waiting for PHY auto negotiation to complete................. TIMEOUT !
lan2 Waiting for PHY auto negotiation to complete................. TIMEOUT !
lan3 Waiting for PHY auto negotiation to complete................. TIMEOUT !
lan4 Waiting for PHY auto negotiation to complete................. TIMEOUT !
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
Abort
missing environment variable: pxeuuid
Retrieving file: pxelinux.cfg/01-d8-58-d7-00-81-56
*** ERROR: `serverip' not set
Retrieving file: pxelinux.cfg/00000000
Retrieving file: pxelinux.cfg/default-arm-mvebu-turris_omnia
Config file not found
