I’ve just acquired a brand new Omnia 2022 (the one with 4 antenas).
Unfortunetaly, I have an issue with the wifi cards; only one is detected.
In the reForis > Network Settings > Wifi, I have only one Wifi available.
I’ve already tried software reset, software update, but still, it not sown.
When mounting the antenas, the one from the left was not correctly tighted. I had to unscrews the 6 left/right screws and tight the left antenas. The connect disconnect, I managed to reconnect it.
I can’t past the wholde diagnostic so I’m putting here only the lshw result.
Do you have any idea? I haven’t yet contacted the support via e-mail because I don’t know if I miss something.
Thanks for your help.
Regards.
(as a new user I can’t post two images; I put the onee from the “luci” interface, where the wifi card name is avaialble)
Edit: I managed to connect via ssh and run lscpi too
root@turris:~# lspci
00:01.0 PCI bridge: Marvell Technology Group Ltd. 88F6820 [Armada 385] ARM SoC (rev 04)
00:02.0 PCI bridge: Marvell Technology Group Ltd. 88F6820 [Armada 385] ARM SoC (rev 04)
00:03.0 PCI bridge: Marvell Technology Group Ltd. 88F6820 [Armada 385] ARM SoC (rev 04)
02:00.0 Unclassified device [0002]: MEDIATEK Corp. MT7915E 802.11ax PCI Express Wireless Network Adapter
************** foris
############## haas
!! Program 'haas-proxy' not found !!
************** haas
############## lshw
== cpuinfo ==
processor : 0
model name : ARMv7 Processor rev 1 (v7l)
BogoMIPS : 1600.00
Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpd32
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x4
CPU part : 0xc09
CPU revision : 1
processor : 1
BogoMIPS : 1600.00
CPU architecture: 7
CPU variant : 0x4
CPU part : 0xc09
CPU revision : 1
Hardware : Marvell Armada 380/385 (Device Tree)
Revision : 0000
Serial : 0000000E700171F6
== meminfo ==
MemTotal: 2064520 kB
MemFree: 1780088 kB
MemAvailable: 1759220 kB
Buffers: 1536 kB
Cached: 103556 kB
SwapCached: 0 kB
Active: 50772 kB
Inactive: 152568 kB
Active(anon): 576 kB
Inactive(anon): 118720 kB
Active(file): 50196 kB
Inactive(file): 33848 kB
Unevictable: 0 kB
Mlocked: 0 kB
HighTotal: 1310720 kB
HighFree: 1108832 kB
LowTotal: 753800 kB
LowFree: 671256 kB
SwapTotal: 0 kB
SwapFree: 0 kB
Dirty: 0 kB
Writeback: 0 kB
AnonPages: 98280 kB
Mapped: 18696 kB
Shmem: 21048 kB
KReclaimable: 7228 kB
Slab: 24732 kB
SReclaimable: 7228 kB
SUnreclaim: 17504 kB
KernelStack: 1712 kB
PageTables: 944 kB
NFS_Unstable: 0 kB
Bounce: 0 kB
WritebackTmp: 0 kB
CommitLimit: 1032260 kB
Committed_AS: 149556 kB
VmallocTotal: 245760 kB
VmallocUsed: 8096 kB
VmallocChunk: 0 kB
Percpu: 256 kB
== lsusb ==
Bus 002 Device 001: ID 1d6b:0002 Linux 5.15.64 xhci-hcd xHCI Host Controller
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9
bDeviceSubClass 0
bDeviceProtocol 1
bMaxPacketSize0 64
idVendor 0x1d6b
idProduct 0x0002
bcdDevice 5.15
iManufacturer 3 Linux 5.15.64 xhci-hcd
iProduct 2 xHCI Host Controller
iSerial 1 f10f0000.usb3
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 0x0019
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 9
bInterfaceSubClass 0
bInterfaceProtocol 0
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0004 1x 4 bytes
bInterval 12
Hub Descriptor:
bLength 9
bDescriptorType 41
nNbrPorts 1
wHubCharacteristic 0x000a
No power switching (usb 1.0)
Per-port overcurrent protection
TT think time 8 FS bits
bPwrOn2PwrGood 10 * 2 milli seconds
bHubContrCurrent 0 milli Ampere
DeviceRemovable 0x00
PortPwrCtrlMask 0xff
Hub Port Status:
Port 1: 0000.0100 power
can't get device qualifier: Resource temporarily unavailable
can't get debug descriptor: Resource temporarily unavailable
Device Status: 0x0001
Self Powered
Bus 004 Device 001: ID 1d6b:0002 Linux 5.15.64 xhci-hcd xHCI Host Controller
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9
bDeviceSubClass 0
bDeviceProtocol 1
bMaxPacketSize0 64
idVendor 0x1d6b
idProduct 0x0002
bcdDevice 5.15
iSerial 1 f10f8000.usb3
bLength 9
bDescriptorType 2
wTotalLength 0x0019
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 9
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
Hub Descriptor:
bLength 9
bDescriptorType 41
nNbrPorts 1
Hub Port Status:
Self Powered
Bus 001 Device 001: ID 1d6b:0002 Linux 5.15.64 ehci_hcd EHCI Host Controller
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9
bDeviceSubClass 0
bDeviceProtocol 1
bMaxPacketSize0 64
idVendor 0x1d6b
idProduct 0x0002
bcdDevice 5.15
iManufacturer 3 Linux 5.15.64 ehci_hcd
iProduct 2 EHCI Host Controller
iSerial 1 f1058000.usb
bLength 9
bDescriptorType 2
wTotalLength 0x0019
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 9
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
Hub Descriptor:
bLength 9
bDescriptorType 41
nNbrPorts 1
wHubCharacteristic 0x0009
Per-port power switching
Hub Port Status:
Self Powered
Bus 003 Device 001: ID 1d6b:0003 Linux 5.15.64 xhci-hcd xHCI Host Controller
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 3.00
bDeviceClass 9
bDeviceSubClass 0
bDeviceProtocol 3
bMaxPacketSize0 9
idVendor 0x1d6b
idProduct 0x0003
bcdDevice 5.15
bLength 9
bDescriptorType 2
wTotalLength 0x001f
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 9
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
bMaxBurst 0
Hub Descriptor:
bLength 12
bDescriptorType 42
nNbrPorts 1
bPwrOn2PwrGood 50 * 2 milli seconds
bHubDecLat 0.0 micro seconds
wHubDelay 0 nano seconds
Hub Port Status:
Port 1: 0000.02a0 5Gbps power Rx.Detect
Binary Object Store Descriptor:
bLength 5
bDescriptorType 15
wTotalLength 0x000f
bNumDeviceCaps 1
SuperSpeed USB Device Capability:
bLength 10
bDescriptorType 16
bDevCapabilityType 3
bmAttributes 0x00
wSpeedsSupported 0x0008
Device can operate at SuperSpeed (5Gbps)
bFunctionalitySupport 1
Lowest fully-functional device speed is Full Speed (12Mbps)
bU1DevExitLat 0 micro seconds
bU2DevExitLat 0 micro seconds
Self Powered
Bus 005 Device 001: ID 1d6b:0003 Linux 5.15.64 xhci-hcd xHCI Host Controller
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 3.00
bDeviceClass 9
bDeviceSubClass 0
bDeviceProtocol 3
bMaxPacketSize0 9
idVendor 0x1d6b
idProduct 0x0003
bcdDevice 5.15
bLength 9
bDescriptorType 2
wTotalLength 0x001f
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 9
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
bMaxBurst 0
Hub Descriptor:
bLength 12
bDescriptorType 42
nNbrPorts 1
Hub Port Status:
bLength 5
bDescriptorType 15
wTotalLength 0x000f
bNumDeviceCaps 1
bLength 10
bDescriptorType 16
bmAttributes 0x00
Self Powered
== lspci ==
00:01.0 PCI bridge [0604]: Marvell Technology Group Ltd. 88F6820 [Armada 385] ARM SoC [11ab:6820] (rev 04) (prog-if 00 [Normal decode])
Subsystem: Marvell Technology Group Ltd. Device [11ab:11ab]
Device tree node: /sys/firmware/devicetree/base/soc/pcie/pcie@1,0
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 64
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 10000-10fff [size=4K] [16-bit]
Memory behind bridge: e0000000-e03fffff [size=4M] [32-bit]
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
BridgeCtl: Parity+ SERR+ NoISA- VGA- VGA16- MAbort- >Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Capabilities: [40] Subsystem: Marvell Technology Group Ltd. Device [11ab:11ab]
Capabilities: [60] Express (v2) Root Port (Slot+), MSI 00
DevCap: MaxPayload 128 bytes, PhantFunc 0
ExtTag- RBE+
DevCtl: CorrErr- NonFatalErr- FatalErr- UnsupReq-
RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop-
MaxPayload 128 bytes, MaxReadReq 512 bytes
DevSta: CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr- TransPend-
LnkCap: Port #0, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <256ns, L1 unlimited
ClockPM- Surprise- LLActRep+ BwNot- ASPMOptComp-
LnkCtl: ASPM Disabled; RCB 64 bytes, Disabled- CommClk+
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 2.5GT/s, Width x1
TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
SltCap: AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise-
Slot #1, PowerLimit 10W; Interlock- NoCompl+
SltCtl: Enable: AttnBtn- PwrFlt- MRL- PresDet- CmdCplt- HPIrq+ LinkChg+
Control: AttnInd Unknown, PwrInd Unknown, Power- Interlock-
SltSta: Status: AttnBtn- PowerFlt- MRL- CmdCplt- PresDet+ Interlock-
Changed: MRL- PresDet- LinkState-
RootCap: CRSVisible-
RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna- CRSVisible-
RootSta: PME ReqID 0000, PMEStatus- PMEPending-
DevCap2: Completion Timeout: Not Supported, TimeoutDis- NROPrPrP- LTR-
10BitTagComp- 10BitTagReq- OBFF Not Supported, ExtFmt- EETLPPrefix-
EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
FRS- LN System CLS Not Supported, TPHComp- ExtTPHComp- ARIFwd-
AtomicOpsCap: Routing- 32bit- 64bit- 128bitCAS-
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis- LTR- 10BitTagReq- OBFF Disabled, ARIFwd-
AtomicOpsCtl: ReqEn- EgressBlck-
LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance Preset/De-emphasis: -6dB de-emphasis, 0dB preshoot
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete- EqualizationPhase1-
EqualizationPhase2- EqualizationPhase3- LinkEqualizationRequest-
Retimer- 2Retimers- CrosslinkRes: unsupported
Capabilities: [100 v1] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr-
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr+
AERCap: First Error Pointer: 00, ECRCGenCap- ECRCGenEn- ECRCChkCap- ECRCChkEn-
MultHdrRecCap- MultHdrRecEn- TLPPfxPres- HdrLogCap-
HeaderLog: 00000000 00000000 00000000 00000000
RootCmd: CERptEn- NFERptEn- FERptEn-
RootSta: CERcvd- MultCERcvd- UERcvd- MultUERcvd-
FirstFatal- NonFatalMsg- FatalMsg- IntMsg 0
ErrorSrc: ERR_COR: 0000 ERR_FATAL/NONFATAL: 0000
Kernel driver in use: pcieport
lspci: Unable to load libkmod resources: error -12
00:02.0 PCI bridge [0604]: Marvell Technology Group Ltd. 88F6820 [Armada 385] ARM SoC [11ab:6820] (rev 04) (prog-if 00 [Normal decode])
Device tree node: /sys/firmware/devicetree/base/soc/pcie/pcie@2,0
Interrupt: pin A routed to IRQ 65
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 20000-20fff [size=4K] [16-bit]
Memory behind bridge: e0400000-e07fffff [size=4M] [32-bit]
ExtTag- RBE+
LnkSta: Speed 5GT/s, Width x1
TrErr- Train- SlotClk+ DLActive+ BWMgmt- ABWMgmt-
Slot #2, PowerLimit 10W; Interlock- NoCompl+
HeaderLog: 4a000001 02000004 02080100 60010000
00:03.0 PCI bridge [0604]: Marvell Technology Group Ltd. 88F6820 [Armada 385] ARM SoC [11ab:6820] (rev 04) (prog-if 00 [Normal decode])
Device tree node: /sys/firmware/devicetree/base/soc/pcie/pcie@3,0
Interrupt: pin A routed to IRQ 66
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
I/O behind bridge: 30000-30fff [size=4K] [16-bit]
Memory behind bridge: e0800000-e0bfffff [size=4M] [32-bit]
ExtTag- RBE+
Slot #3, PowerLimit 10W; Interlock- NoCompl+
02:00.0 Unclassified device [0002]: MEDIATEK Corp. MT7915E 802.11ax PCI Express Wireless Network Adapter [14c3:7915] (prog-if 80)
Subsystem: MEDIATEK Corp. MT7915E 802.11ax PCI Express Wireless Network Adapter [14c3:7915]
Physical Slot: 2
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx+
Interrupt: pin A routed to IRQ 97
Region 0: Memory at e0400000 (64-bit, prefetchable) [size=1M]
Region 2: Memory at e0500000 (64-bit, prefetchable) [size=16K]
Region 4: Memory at e0504000 (64-bit, prefetchable) [size=4K]
Capabilities: [80] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 128 bytes, PhantFunc 0, Latency L0s <1us, L1 <4us
ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset- SlotPowerLimit 10W
RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop+
LnkCap: Port #1, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <2us, L1 <8us
ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
LnkCtl: ASPM Disabled; RCB 64 bytes, Disabled- CommClk-
DevCap2: Completion Timeout: Range ABCD, TimeoutDis+ NROPrPrP- LTR+
10BitTagComp- 10BitTagReq- OBFF Not Supported, ExtFmt+ EETLPPrefix-
FRS- TPHComp- ExtTPHComp-
AtomicOpsCap: 32bit- 64bit- 128bitCAS-
LnkCap2: Supported Link Speeds: 2.5-5GT/s, Crosslink- Retimer- 2Retimers- DRS-
LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete- EqualizationPhase1-
Capabilities: [e0] MSI: Enable+ Count=1/32 Maskable+ 64bit+
Address: 00000000f1020a04 Data: 0f00
Masking: fffffffe Pending: 00000000
Capabilities: [f8] Power Management version 3
Flags: PMEClk- DSI+ D1+ D2+ AuxCurrent=0mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [100 v1] Vendor Specific Information: ID=1556 Rev=1 Len=008 <?>
Capabilities: [108 v1] Latency Tolerance Reporting
Max snoop latency: 0ns
Max no snoop latency: 0ns
Capabilities: [110 v1] L1 PM Substates
L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
PortCommonModeRestoreTime=3us PortTPowerOnTime=28us
L1SubCtl1: PCI-PM_L1.2- PCI-PM_L1.1- ASPM_L1.2- ASPM_L1.1-
T_CommonMode=0us LTR1.2_Threshold=0ns
L1SubCtl2: T_PwrOn=10us
Capabilities: [200 v2] Advanced Error Reporting
UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP+ ECRC- UnsupReq- ACSViol-
Kernel driver in use: mt7915e
Edit3: looking at Support request: Turris Omnia randomly Wi-Fi Module disappear - #2 by Pepe, I don’t know if is the same issue or not. I will contact tech suppport directly.
