So my omnia 2016 1G nowifi (original indiegogo hw) is boot looping after upgrade to 6.0
easily reverted to 5.4.4 via 2 led reset button trick
I’d say this is the relevant part from the serial console log:
[ 2.037329] BTRFS: device fsid 30605799-ecc5-4556-ac68-6a0b46c6ff76 devid 1 transid 1051161 /dev/root scanned by swapper/0 (1)
[ 2.049338] BTRFS info (device mmcblk0p1): disk space caching is enabled
[ 2.056059] BTRFS info (device mmcblk0p1): has skinny extents
[ 2.066449] BTRFS critical (device mmcblk0p1): corrupt leaf: block=153014272 slot=26 extent bytenr=13107200 len=4096 previous extent [12988416 168 364544] overlaps current extent [13107200 169 0]
[ 2.083896] BTRFS error (device mmcblk0p1): block=153014272 read time tree block corruption detected
[ 2.086965] usb-storage 2-1:1.0: USB Mass Storage device detected
[ 2.099209] BTRFS error (device mmcblk0p1): failed to read block groups: -5
[ 2.106509] scsi host2: usb-storage 2-1:1.0
[ 2.111127] BTRFS error (device mmcblk0p1): open_ctree failed
[ 2.118114] squashfs: Unknown parameter 'commit'
[ 2.122965] F2FS-fs (mmcblk0p1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
[ 2.130226] F2FS-fs (mmcblk0p1): Can't find valid F2FS filesystem in 1th superblock
[ 2.138092] F2FS-fs (mmcblk0p1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
[ 2.145334] F2FS-fs (mmcblk0p1): Can't find valid F2FS filesystem in 2th superblock
[ 2.153838] BTRFS info (device mmcblk0p1): disk space caching is enabled
[ 2.160624] BTRFS info (device mmcblk0p1): has skinny extents
[ 2.170933] BTRFS critical (device mmcblk0p1): corrupt leaf: block=153014272 slot=26 extent bytenr=13107200 len=4096 previous extent [12988416 168 364544] overlaps current extent [13107200 169 0]
[ 2.188392] BTRFS error (device mmcblk0p1): block=153014272 read time tree block corruption detected
[ 2.197573] BTRFS error (device mmcblk0p1): failed to read block groups: -5
[ 2.204924] BTRFS error (device mmcblk0p1): open_ctree failed
[ 2.210815] List of all partitions:
[ 2.214321] 1f00 960 mtdblock0
[ 2.214326] (driver?)
[ 2.220889] 1f01 7168 mtdblock1
[ 2.220893] (driver?)
[ 2.227463] 1f02 64 mtdblock2
[ 2.227467] (driver?)
[ 2.234020] 0800 31266648 sda
[ 2.234023] driver: sd
[ 2.240145] 0801 31265607 sda1 75206d7c-69db-a541-8044-ef029c8fecc9
[ 2.240150]
[ 2.248709] b300 7634944 mmcblk0
[ 2.248713] driver: mmcblk
[ 2.255525] b301 7633920 mmcblk0p1 109ac059-01
[ 2.255528]
[ 2.262348] No filesystem could mount root, tried:
[ 2.262350] ext3
[ 2.267240] ext2
[ 2.269167] ext4
[ 2.271094] squashfs
[ 2.273021] f2fs
[ 2.275295] btrfs
[ 2.277225]
[ 2.280730] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,1)
[ 2.289187] CPU1: stopping
[ 2.291901] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 5.15.74 #0
[ 2.297925] Hardware name: Marvell Armada 380/385 (Device Tree)
[ 2.303861] [<c010eab8>] (unwind_backtrace) from [<c010a814>] (show_stack+0x10/0x14)
[ 2.311634] [<c010a814>] (show_stack) from [<c05e3e48>] (dump_stack_lvl+0x40/0x4c)
[ 2.319226] [<c05e3e48>] (dump_stack_lvl) from [<c010cce8>] (do_handle_IPI+0xf8/0x12c)
[ 2.327163] [<c010cce8>] (do_handle_IPI) from [<c010cd34>] (ipi_handler+0x18/0x20)
[ 2.334753] [<c010cd34>] (ipi_handler) from [<c0184774>] (handle_percpu_devid_irq+0x78/0x12c)
[ 2.343303] [<c0184774>] (handle_percpu_devid_irq) from [<c017ec70>] (handle_domain_irq+0x5c/0x78)
[ 2.352290] [<c017ec70>] (handle_domain_irq) from [<c05fc200>] (gic_handle_irq+0x7c/0x90)
[ 2.360494] [<c05fc200>] (gic_handle_irq) from [<c0100b7c>] (__irq_svc+0x5c/0x78)
[ 2.367998] Exception stack(0xc1083f58 to 0xc1083fa0)
[ 2.373061] 3f40: 00001054 00000000
[ 2.381259] 3f60: 00000001 c0117aa0 ffffe000 c0e04f50 c0e04f94 00000002 00000000 c0e04f08
[ 2.389456] 3f80: c0d580a8 00000000 c107c03c c1083fa8 c010783c c0107840 60000013 ffffffff
[ 2.397651] [<c0100b7c>] (__irq_svc) from [<c0107840>] (arch_cpu_idle+0x38/0x3c)
[ 2.405071] [<c0107840>] (arch_cpu_idle) from [<c09e4960>] (default_idle_call+0x2c/0x3c)
[ 2.413187] [<c09e4960>] (default_idle_call) from [<c015c3bc>] (do_idle+0x1d8/0x1e0)
[ 2.420956] [<c015c3bc>] (do_idle) from [<c015c6ec>] (cpu_startup_entry+0x18/0x1c)
[ 2.428548] [<c015c6ec>] (cpu_startup_entry) from [<00101550>] (0x101550)
[ 2.435359] Rebooting in 1 seconds..
any pointers @Pepe ?
thanks for all the effort !
