Update notifications
Your approval is required to apply pending updates. You can grant it in the reForis administrative interface in the 'Package Management — Updates' menu.
• Remove kmod-fs-hfs
• Remove firmware-updater
• Remove kmod-nls-cp866
• Remove turris-omnia-firmware
• Remove fstrim
• Remove kmod-nls-cp862
• Remove kmod-fs-xfs
• Remove acl
• Remove kmod-nls-iso8859-6
• Remove hfsfsck
• Remove luci-i18n-samba4-en
• Remove losetup
• Remove kmod-nls-cp852
• Remove nfs-kernel-server-utils
• Remove samba4-client
• Remove fuse-utils
• Remove kmod-nls-cp850
• Remove kmod-nls-cp932
• Remove kmod-fs-exfat
• Remove kmod-nls-iso8859-13
• Remove turris-nor-update
• Remove mtd
• Remove kmod-nls-iso8859-2
• Remove xfs-growfs
• Remove samba4-admin
• Remove kmod-fs-ext4
• Remove swap-utils
• Remove rsyncd
• Remove kmod-lib-crc16
• Remove mkhfs
• Remove kmod-fs-msdos
• Remove kmod-nls-cp1250
• Remove badblocks
• Remove luci-i18n-hd-idle-en
• Remove kmod-fs-hfsplus
• Remove kmod-nls-iso8859-15
• Remove ntfs-3g-utils
• Remove ntfs-3g
• Remove cifsmount
• Remove hdparm
• Remove kmod-fs-nfsd
• Remove kmod-fs-nfs-common-rpcsec
• Remove kmod-crypto-cts
• Remove kmod-crypto-arc4
• Remove kmod-fs-nfs-v4
• Remove rpcbind
• Remove nfs-utils-libs
• Remove libwrap
• Remove libkeyutils
• Remove kmod-fs-exportfs
• Remove xfs-fsck
• Remove blockd
• Remove kmod-fs-autofs4
• Remove kmod-nls-koi8r
• Remove kmod-fs-vfat
• Remove smartd
• Remove kmod-nls-cp437
• Remove luci-app-samba4
• Remove samba4-server
• Remove kmod-nls-cp864
• Remove lvm2
• Remove libaio
• Remove libdevmapper
• Remove kmod-dm
• Remove kmod-dax
• Remove kmod-keys-encrypted
• Remove kmod-crypto-cbc
• Remove kmod-nls-iso8859-8
• Remove asm1062-fix
• Remove kmod-cdrom
• Remove samba4-utils
• Remove samba4-libs
• Remove liburing
• Remove attr
• Remove libavahi-client
• Remove avahi-dbus-daemon
• Remove libavahi-dbus-support
• Remove libdaemon
• Remove block-mount
• Remove dosfstools
• Remove kmod-nls-cp775
• Remove kmod-nls-cp1251
• Remove blkdiscard
• Remove cfdisk
• Remove kmod-fs-cifs
• Remove kmod-crypto-sha512
• Remove kmod-crypto-ecb
• Remove kmod-crypto-des
• Remove kmod-dnsresolver
• Remove kmod-fs-ntfs
• Remove sshfs
• Remove fuse3-utils
• Remove libfuse3
• Remove resize2fs
• Remove e2fsprogs
• Remove libext2fs
• Remove libss
• Remove libcomerr
• Remove kmod-keys-trusted
• Remove kmod-crypto-sha1
• Remove kmod-tpm
• Remove kmod-random-core
• Remove kmod-asn1-decoder
• Remove kmod-asn1-encoder
• Remove kmod-oid-registry
• Remove smartmontools
• Remove uclibcxx
• Remove fdisk
• Remove omnia-mcutool
• Remove omnia-mcu-firmware
• Remove luci-app-hd-idle
• Remove libtasn1
• Remove smartmontools-drivedb
• Remove davfs2
• Remove libneon
• Remove libfdisk
• Remove libfuse
• Remove kmod-fuse
• Remove libgcrypt
• Remove libgpg-error
• Remove xfs-mkfs
• Remove dbus
• Remove libdbus
The update is going to be automatically updated some time after 2024-02-08T01:00:54.115432 unless there a newer update.
Disabling auto updates immediately, thankfully they’re set to delay
