I have an older Android tablet here that I’d like to connect to my wireless network, but that doesn’t work. It tires to connect multiple times until the network is listed as “Deactivated”.
Turris syslog shows this entries:
Sep 7 18:00:38 turris hostapd: guest_net_1: STA 08:60:6e:xx:xx:xx IEEE 802.11: authenticated
Sep 7 18:00:38 turris hostapd: guest_net_1: STA 08:60:6e:xx:xx:xx IEEE 802.11: associated (aid 1)
Sep 7 18:00:38 turris hostapd: guest_net_1: AP-STA-CONNECTED 08:60:6e:xx:xx:xx
Sep 7 18:00:38 turris hostapd: guest_net_1: STA 08:60:6e:xx:xx:xx RADIUS: starting accounting session 7[redacted]A
Sep 7 18:00:38 turris hostapd: guest_net_1: STA 08:60:6e:xx:xx:xx WPA: pairwise key handshake completed (RSN)
Sep 7 18:00:38 turris hostapd: guest_net_1: EAPOL-4WAY-HS-COMPLETED 08:60:6e:xx:xx:xx
Sep 7 18:00:41 turris hostapd: guest_net_1: STA 08:60:6e:xx:xx:xx IEEE 802.11: authenticated
Sep 7 18:00:43 turris hostapd: guest_net_1: STA 08:60:6e:xx:xx:xx IEEE 802.11: authenticated
Sep 7 18:00:43 turris hostapd: guest_net_1: STA 08:60:6e:xx:xx:xx IEEE 802.11: associated (aid 1)
Sep 7 18:00:43 turris hostapd: guest_net_1: STA 08:60:6e:xx:xx:xx RADIUS: starting accounting session 7[redacted]A
Sep 7 18:00:43 turris hostapd: guest_net_1: STA 08:60:6e:xx:xx:xx WPA: pairwise key handshake completed (RSN)
Sep 7 18:00:43 turris hostapd: guest_net_1: EAPOL-4WAY-HS-COMPLETED 08:60:6e:xx:xx:xx
Sep 7 18:01:28 turris hostapd: guest_net_1: STA 08:60:6e:xx:xx:xx IEEE 802.11: authenticated
Sep 7 18:01:34 turris hostapd: guest_net_1: STA 08:60:6e:xx:xx:xx IEEE 802.11: authenticated
Sep 7 18:01:34 turris hostapd: guest_net_1: STA 08:60:6e:xx:xx:xx IEEE 802.11: associated (aid 1)
Sep 7 18:01:34 turris hostapd: guest_net_1: STA 08:60:6e:xx:xx:xx RADIUS: starting accounting session 7[redacted]A
Sep 7 18:01:34 turris hostapd: guest_net_1: STA 08:60:6e:xx:xx:xx WPA: pairwise key handshake completed (RSN)
Sep 7 18:09:30 turris hostapd: guest_net_1: AP-STA-DISCONNECTED 08:60:6e:xx:xx:xx
Sep 7 18:09:30 turris hostapd: guest_net_1: STA 08:60:6e:xx:xx:xx IEEE 802.11: disassociated due to inactivity
Sep 7 18:09:31 turris hostapd: guest_net_1: STA 08:60:6e:xx:xx:xx IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Turris: TurrisOS 7.0.2
Tablet: Google Nexus 7, Android 7.1.2 (Inofficial LineageOS 14.1-20210313)
Wireles connections to other networks already worked.
Wireless connections to this network with Android 5.1 tablets also work.
What can I do to connect the tablet?
