I have connected NVMe SSD disk to Omnia. It is correctly seen by OS, I was able to partition, mkfs.btrfs and mount it, but it is not seen by reforis.
The disk is available at:
nvme0n1 259:0 0 238.5G 0 disk
└─nvme0n1p1 259:1 0 238.5G 0 part
And can be mounted e.g.:
/dev/nvme0n1p1 on /mnt/test type btrfs (rw,relatime,ssd,space_cache=v2,subvolid=5,subvol=/)
I am running:
|Serial number|47244704122|
|reForis version|1.4.1|
|Turris OS version|6.4.4|
|Turris OS branch|[HBS]
My guess would be that foris does not expect /dev/nvme* as disk block device. Is there some workaround, or how can I mount it manually so that I can use it correctly?
For connection I used this adapter (in leftmost Omnia slot):
which then holds normal (and cheap) 2280 nvme ssd disk, seen by lspci as:
03:00.0 Non-Volatile memory controller: Phison Electronics Corporation PS5013 E13 NVMe Controller (rev 01)
NVMe disks are not supported in reForis, yet. However, for more than 5 months, it is waiting to get some attention from Turris team to be reviewed and merged:
