I have set up a local mail server with Power Mail-in-a-Box. Sending mails via other applications works.
But when I setup my server in the ReForis notification settings, it throws an error:
Feb 01 14:05:06 mail postfix/submission/smtpd[270373]: SSL_accept error from mox.home.arpa[192.168.100.18]: -1
Feb 01 14:05:06 mail postfix/submission/smtpd[270373]: warning: TLS library problem: error:0A000126:SSL routines::unexpected eof while reading:../ssl/record/rec_layer_s3.c:308:
Feb 01 14:05:06 mail postfix/submission/smtpd[270373]: lost connection after CONNECT from mox.home.arpa[192.168.100.18]
Feb 01 14:05:06 mail postfix/submission/smtpd[270373]: disconnect from mox.home.arpa[192.168.100.18] commands=0/0
that looks like turris client did not accept your servers’ SSL certificate. Is that from known certificate authority?
Does it contain IP4:192.168.100.160 within SubjectAlternativeName?
This file seems to be a pure example file without any configuration:
root@mox:~# cat /etc/msmtprc
# Example for a system wide configuration file
# A system wide configuration file is optional.
# If it exists, it usually defines a default account.
# This allows msmtp to be used like /usr/sbin/sendmail.
account default
# The SMTP smarthost
host mail.oursite.example
# Use TLS on port 465
port 465
tls on
tls_starttls off
# Construct envelope-from addresses of the form "user@oursite.example"
from %U@oursite.example
# Syslog logging with facility LOG_MAIL instead of the default LOG_USER
syslog LOG_MAIL
Adding tls_certcheck off here does not fix the problem.
Sorry I see now: /usr/bin/notifier sets explicitly “tls_certcheck on” in functions get_turris_smtp_settings and get_user_server_settings
it’s possible to disable TLS in it tho, so if you can enable unauthenticated mail on your mailserver from router, you can disable tls and go without TLS and without authentication.
Why not request a Lets Encrypt certificate? Instead of tinkering about the SSL not accepting it, grab a Lets Encrypt certificate, use a DNS server on your network to give them the right names and see if everything works at least. Then later on go and investigate if you want to disable the SSL certificates etc.
