Hi everyone,
I want to ask you if someone of you is able to help. It seems that my Omnia is not updated for some time (at least two month already I guess). Traffic data are not sent back to CZ.NIC for two month and now I realized that the lighttpd is not up and cannot be started.
I have checked similar threads here in forum and tested all hints I was able to found but without progress.
I can access via SSH but web GUI is dead.
And updated is failing and also the recommended opkg update solution is not working because of certificates. See details bellow:
root@gw:~# cat /etc/turris-version
3.2.1
root@gw:~# ls /etc/lighttpd/modules.d/
10-redirect.load 30-alias.load 30-cgi.load 30-fastcgi.load 30-setenv.load
root@gw:~# /etc/init.d/lighttpd start
2017-03-13 14:03:30: (plugin.c.475) plugin-version doesn’t match lighttpd-version for redirect
2017-03-13 14:03:30: (server.c.943) Initialization of plugins failed. Going down.
root@gw:~# opkg update
Collected errors:
- opkg_download: Failed to download https://api.turris.cz/openwrt-repo/omnia/packages//base/Packages.gz, curl returned 60.
root@gw:~# updater.sh
INFO:End of subprogram output
DIE:
[string “transaction”]:311: [string “transaction”]:144: Collisions:
• /usr/bin/scp: openssh-client (new), dropbear (existing)
• /usr/bin/ssh: openssh-client (new), dropbear (existing)
