I’ve installed Adblock after migrating to TOS 5, but I am not able to get it work.
Any hints how to solve? More info below.
opkg --force-maintainer --force-reinstal --force-overwrite install adblock luci-app-adblock
opkg list-installed "*adblock"
adblock - 4.0.7-9
luci-app-adblock - git-21.314.39495-8bd4e78-1
/etc/init.d/adblock status
::: adblock runtime information
+ adblock_status : error
+ adblock_version : 4.0.7
+ blocked_domains : 0
+ active_sources : adaway adguard disconnect yoyo
+ dns_backend : -, -
+ run_utils : -
+ run_ifaces : trigger: lan, report: -
+ run_directories : base: /tmp, backup: /tmp, report: /tmp, jail: /tmp
+ run_flags : backup: 1, reset: 0, flush: 1, force: 0, search: 0, report: 0, mail: 0, jail: 0
+ last_run : stop, n/a, 2067/1616/1694, 04.12.2021 13:35:55
+ system : Turris Omnia, TurrisOS 5.3.1 8fb714edd6e4340729e271139164a0163b027d68
cat /etc/config/adblock
config adblock 'global'
option adb_enabled '1'
option adb_safesearch '0'
option adb_dnsfilereset '0'
option adb_mail '0'
option adb_report '0'
option adb_backup '1'
option adb_maxqueue '4'
list adb_sources 'adaway'
list adb_sources 'adguard'
list adb_sources 'disconnect'
list adb_sources 'yoyo'
option adb_forcedns '1'
option adb_dnsflush '1'
option adb_dns 'kresd'
option adb_debug '1'
option adb_repiface 'br-lan'
option adb_fetchutil 'curl'
grep adblock /var/log/messages
Dec 4 12:30:59 turris adblock-4.0.7[19320]: Please enable the 'DNS Report' option to use the reporting feature
Dec 4 12:30:59 turris adblock-4.0.7[19320]: f_report ::: action: report, report: 0, search: +, count: 50, process: false, print: json, dump_util: /usr/sbin/tcpdump, repdir: /tmp, repiface: -, replisten: 53, repchunksize: 1, repchunkcnt: 5, bg_pid:
Dec 4 12:31:29 turris adblock-4.0.7[19460]: Please enable the 'DNS Report' option to use the reporting feature
Dec 4 12:31:29 turris adblock-4.0.7[19460]: f_report ::: action: report, report: 0, search: +, count: 50, process: false, print: json, dump_util: /usr/sbin/tcpdump, repdir: /tmp, repiface: -, replisten: 53, repchunksize: 1, repchunkcnt: 5, bg_pid:
Dec 4 12:35:55 turris adblock-4.0.7[20785]: local opkg package repository is not available, please set 'adb_fetchutil' and 'adb_dns' manually
Dec 4 12:35:55 turris adblock-4.0.7[20785]: f_rmtemp ::: tmp_dir: -, src_file: /tmp/adb_sources.json, pid_file: /var/run/adblock.pid
Dec 4 12:35:55 turris adblock-4.0.7[20785]: f_rmdns ::: dns: , status: -, dns_dir: , dns_file: adb_list.overall, rt_file: /tmp/adb_runtime.json, backup_dir: /tmp
Dec 4 12:35:55 turris adblock-4.0.7[20785]: f_bgserv ::: status: stop, bg_pid: -, dns_filereset: 0, ubus_service: /etc/adblock/adblock.monitor
Dec 4 12:35:55 turris adblock-4.0.7[20785]: f_jsnup ::: status: error, cnt: 0, mail: 0, mail_service: /etc/adblock/adblock.mail, mail_cnt: 0, mail_pid: -
