I am using a security camera.
In ONVIF my camera is detected, but when I try to view it says no signal. The pan/tilt commands can be used via ONVIF, but no image.
I suppose it is a matter of open ports.
I tried to open the ports in my omnia router, but when I do a port check I see: “ports closed”
How can I solve this problem?
How did you set up the port forward? Are the ports, source and destination selected correctly?
Please rethink/redesign your idea if what you are trying to do is open your router/firewall so you can access the camera from the internet.
Your camera will probably get owned in a couple of hours, and probably the rest of your netwok as well…
Then why would I bother you say?, well it has the potential to affect us all as the camera will, with high confidence, be a part of a botnet used to launch DDoS and other nasties.
So please hide your camera behind a proxy or vpn with strong authentication.
Just my 5 cents
EDIT:
Sorry, forgot to hint where you can find port forwards (if what you trying to do is access local resources from the internet)
If you appreciate GUI
reForis → Advanced Administration → Network → Firewall → Port Forwards
