No LAN internet despite WAN passing DNS and IP connectivity checks
cant get internet out of the LAN ports, what gives. WAN port passes all connection tests. DNS passes and DNSSEC passes This thing is user hostile.
What‘s your network setup? (ISP, type of internet connection, ISP modem/router?, Client …)
Since WAN connectivity appears established and connectivity from LAN client to Foris it sounds like potential firewall and/or routing issue - suspect latter by seeing the VPN issues from other threads you posted in.
From one of the LAN clients what is the output of a traceroute?
For some reason the first few reboots did nothing but a reboot the next day after being unplugged from WAN for a day did the trick.
I am getting normal routing now
