Hi. Upgraded to 5.1.9. It seems like I do not have DHCP working on the LAN or WiFi. Also in the DHCP start field I usually have 150. It says that I should enter a number below 106! This is mission critical. Would be nice with a fix. Thank you
Can you show your current DHCP config?
I experience also no DHCP after update to 5.1.9 on Turris 1.0. After rollback to 5.1.8 DHCP is working fine.
Can you point me to the procedure for a rollback? I’d like to try 5.1.8.
Made a rollback to before I updated. Everything is back in order
