NMAP and open ports
I tried to use a web service and scan for open ports, and it shows basically all ports as open. Is this normal, or did I break something?
Discovered open port 1723/tcp on
Discovered open port 143/tcp on
Discovered open port 110/tcp on
Discovered open port 22/tcp on
Discovered open port 80/tcp on
Discovered open port 445/tcp on
Discovered open port 3306/tcp on
Discovered open port 995/tcp on
Discovered open port 199/tcp on
Discovered open port 1025/tcp on
Discovered open port 111/tcp on
Discovered open port 3389/tcp on
Discovered open port 23/tcp on
Discovered open port 587/tcp on
Discovered open port 993/tcp on
Discovered open port 113/tcp on
Discovered open port 8888/tcp on
Discovered open port 8080/tcp on
Discovered open port 25/tcp on
Discovered open port 3128/tcp on
Is this from lan or wan?
From wan, that’s the problem.
Oh, it’s a false alarm. I forgot to specify the external port in Firewall - Port Forwards, so I redirected all the ports to the one I was trying to open.
