Since the switch to Turris OS 6.0, the NFS on the USB drive connected to Turris 1.0 hangs.
I have external drive connected to USB and mounted to /mnt/my_drive
. I can see it’s contents from turris shell.
The current NFS setup /etc/exports
/mnt 192.168.1.0/255.255.255.0(ro,subtree_check,insecure,crossmnt)
I also created a test file /mnt/nfs-test
I mount the NFS as
sudo mount 192.168.1.1:/mnt /media/turris/
I can see the file /media/turris/nfs-test
and an empty directory /media/turris/my_drive
. But when I try to access the /media/turris/my_drive
all commands, e.g. ls /media/turris/my_drive
hang. I found nothing in any log file.
It definitely worked before the upgrade. I tried several options to set up, but with no success. I also couldn’t quite anything useful to debug the problem.
