After finally achieving nextcloud version 18.0.7 (as provided by the stable branch - with some troubles because v16 didn’t want to ‘go away’),
I got a very good looking nextcloud instance.
However, if I go to the ‘Users’ tab to make a few user accounts, I only get a blank/empty page.
Has anyone a clue what could be happening? The error you see in the screenshot is the only error I found at the clientside (browser), at the serverside (on my Mox, version 5.1.2) I found the logs.
nextcloud.log at server side (only the line about url:"<restapi>/settings/users")
"app" : "no app in context",
"level" : 3,
"message" : {
"Code" : 0,
"CustomMessage" : "--",
"Exception" : "Doctrine\\DBAL\\Exception\\InvalidFieldNameException",
"File" : "/srv/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/AbstractMySQLDriver.php",
"Line" : 60,
"Message" : "An exception occurred while executing 'SELECT DISTINCT `class`, `entity`, `events` FROM `oc_flow_operations` WHERE `events` <> ?' with params [\"[]\"]:\n\nSQLSTATE[42S22]: Column not found: 1054 Unknown column 'entity' in 'field list'",
"Previous" : {
"Code" : "42S22",
"Exception" : "Doctrine\\DBAL\\Driver\\PDOException",
"File" : "/srv/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOStatement.php",
"Line" : 119,
"Message" : "SQLSTATE[42S22]: Column not found: 1054 Unknown column 'entity' in 'field list'",
"Previous" : {
"Code" : "42S22",
"Exception" : "PDOException",
"Line" : 117,
"Trace" : [
"args" : [
null
"class" : "PDOStatement",
"file" : "/srv/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOStatement.php",
"function" : "execute",
"line" : 117,
"type" : "->"
"args" : [],
"class" : "Doctrine\\DBAL\\Driver\\PDOStatement",
"file" : "/srv/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php",
"line" : 903,
"type" : "->"
"args" : [
"SELECT DISTINCT `class`, `entity`, `events` FROM `oc_flow_operations` WHERE `events` <> ?",
2
null
"class" : "Doctrine\\DBAL\\Connection",
"file" : "/srv/www/nextcloud/lib/private/DB/Connection.php",
"function" : "executeQuery",
"line" : 199,
"type" : "->"
"args" : [
"SELECT DISTINCT `class`, `entity`, `events` FROM `oc_flow_operations` WHERE `events` <> :dcValue1",
"dcValue1" : "[]"
"dcValue1" : 2
"class" : "OC\\DB\\Connection",
"file" : "/srv/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Query/QueryBuilder.php",
"line" : 200,
"type" : "->"
"args" : [],
"class" : "Doctrine\\DBAL\\Query\\QueryBuilder",
"file" : "/srv/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php",
"line" : 215,
"type" : "->"
"args" : [],
"class" : "OC\\DB\\QueryBuilder\\QueryBuilder",
"file" : "/srv/www/nextcloud/apps/workflowengine/lib/Manager.php",
"line" : 155,
"type" : "->"
"args" : [],
"class" : "OCA\\WorkflowEngine\\Manager",
"file" : "/srv/www/nextcloud/apps/workflowengine/lib/AppInfo/Application.php",
"function" : "getAllConfiguredEvents",
"line" : 84,
"type" : "->"
"args" : [],
"class" : "OCA\\WorkflowEngine\\AppInfo\\Application",
"file" : "/srv/www/nextcloud/apps/workflowengine/appinfo/app.php",
"function" : "registerRuleListeners",
"line" : 27,
"type" : "->"
"args" : [
"file" : "/srv/www/nextcloud/lib/private/legacy/app.php",
"function" : "require_once",
"line" : 266
"args" : [
"workflowengine"
"class" : "OC_App",
"function" : "requireAppFile",
"line" : 155,
"type" : "::"
"args" : [
"workflowengine"
"class" : "OC_App",
"function" : "loadApp",
"line" : 128,
"type" : "::"
"args" : [],
"class" : "OC_App",
"file" : "/srv/www/nextcloud/lib/base.php",
"function" : "loadApps",
"line" : 993,
"type" : "::"
"args" : [],
"class" : "OC",
"file" : "/srv/www/nextcloud/index.php",
"function" : "handleRequest",
"line" : 38,
"type" : "::"
"Trace" : [
"args" : [],
"line" : 903,
"type" : "->"
"args" : [
2
null
"line" : 199,
"type" : "->"
"args" : [
"dcValue1" : "[]"
"dcValue1" : 2
"line" : 200,
"type" : "->"
"args" : [],
"line" : 215,
"type" : "->"
"args" : [],
"line" : 155,
"type" : "->"
"args" : [],
"line" : 84,
"type" : "->"
"args" : [],
"line" : 27,
"type" : "->"
"args" : [
"line" : 266
"args" : [
"workflowengine"
"class" : "OC_App",
"line" : 155,
"type" : "::"
"args" : [
"workflowengine"
"class" : "OC_App",
"line" : 128,
"type" : "::"
"args" : [],
"class" : "OC_App",
"line" : 993,
"type" : "::"
"args" : [],
"class" : "OC",
"line" : 38,
"type" : "::"
"Trace" : [
"args" : [
"__class__" : "Doctrine\\DBAL\\Driver\\PDOException",
"errorInfo" : [
"42S22",
1054,
"Unknown column 'entity' in 'field list'"
"class" : "Doctrine\\DBAL\\Driver\\AbstractMySQLDriver",
"file" : "/srv/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DBALException.php",
"function" : "convertException",
"line" : 169,
"type" : "->"
"args" : [
"__class__" : "Doctrine\\DBAL\\Driver\\PDOMySql\\Driver"
"errorInfo" : [
"42S22",
1054,
"class" : "Doctrine\\DBAL\\DBALException",
"function" : "wrapException",
"line" : 145,
"type" : "::"
"args" : [
"errorInfo" : [
"42S22",
1054,
"1" : "[]"
"function" : "driverExceptionDuringQuery",
"line" : 911,
"type" : "::"
"args" : [
2
null
"line" : 199,
"type" : "->"
"args" : [
"dcValue1" : "[]"
"dcValue1" : 2
"line" : 200,
"type" : "->"
"args" : [],
"line" : 215,
"type" : "->"
"args" : [],
"line" : 155,
"type" : "->"
"args" : [],
"line" : 84,
"type" : "->"
"args" : [],
"line" : 27,
"type" : "->"
"args" : [
"line" : 266
"args" : [
"workflowengine"
"class" : "OC_App",
"line" : 155,
"type" : "::"
"args" : [
"workflowengine"
"class" : "OC_App",
"line" : 128,
"type" : "::"
"args" : [],
"class" : "OC_App",
"line" : 993,
"type" : "::"
"args" : [],
"class" : "OC",
"line" : 38,
"type" : "::"
"method" : "GET",
"remoteAddr" : "192.168.141.173",
"reqId" : "WSZgDrudtEqzfufSOYq6",
"time" : "2020-11-05T16:52:02+00:00",
"url" : "/nextcloud/index.php/settings/users",
"user" : "admin",
"userAgent" : "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:82.0) Gecko/20100101 Firefox/82.0",
"version" : "18.0.7.1"
Error: Loading chunk 6 failed. (missing: https://turris.local/nextcloud/apps/settings/js/vue-6.js)
Webpack 24
[vue-router.esm.js:1897](webpack:///node_modules/vue-router/dist/vue-router.esm.js)
i vue-router.esm.js:1897
l vue-router.esm.js:1939
p vue-router.esm.js:1760
xt vue-router.esm.js:1825
If no other people know what’s going on, I’ll see if I can get it in the bug tracker…
