### ⚠️ This issue respects the following points: ⚠️
- [X] This is a **bug**, …not a question or a configuration/webserver/proxy issue.
- [X] This issue is **not** already reported on Github _(I've searched it)_.
- [X] Nextcloud Server **is** up to date. See [Maintenance and Release Schedule](https://github.com/nextcloud/server/wiki/Maintenance-and-Release-Schedule) for supported versions.
- [X] Nextcloud Server **is** running on 64bit capable CPU, PHP and OS.
- [X] I agree to follow Nextcloud's [Code of Conduct](https://nextcloud.com/contribute/code-of-conduct/).
### Bug description
I updated nextcloud from 24.0.7 (I think, or 24.0.6) to the latest 24.0.9. After running through the update procedure, I can provide my password at login, but when it should ask for 2FA, it comes with a Internal server error.
In the logs (enormous line), I get a "strpos(): Argument #1 ($haystack) must be of type string, bool given" error. It seems to be linked to my test-setup that runs on the same host on a different virtual host (and different subdomain). I use federated shares between the instances which might cause the issue somehow.
The testsetup has now the same issue (was on NC 25.0.1), I upgraded the testsetup to the 25.0.4RC1. It doesn't change anything. Now I put the testsetup in maintenance mode, still the same error.
### Steps to reproduce
1. Use two setups on different subdomain on the same host (ip address)
2. Update to 24.0.9
### Expected behavior
Not having this error?
### Installation method
Community Manual installation with Archive
### Operating system
Other
### PHP engine version
PHP 8.1
### Web server
Nginx
### Database engine version
MariaDB
### Is this bug present after an update or on a fresh install?
Updated from a minor version (ex. 22.2.3 to 22.2.4)
### Are you using the Nextcloud Server Encryption module?
Encryption is Disabled
### What user-backends are you using?
- [X] Default user-backend _(database)_
- [ ] LDAP/ Active Directory
- [ ] SSO - SAML
- [ ] Other
### Configuration report
```shell
"system": {
"installed": true,
"dbtype": "mysql",
"dbname": "***REMOVED SENSITIVE VALUE***",
"dbuser": "***REMOVED SENSITIVE VALUE***",
"dbpassword": "***REMOVED SENSITIVE VALUE***",
"dbhost": "***REMOVED SENSITIVE VALUE***",
"dbtableprefix": "",
"forcessl": true,
"blacklisted_files": [
".htaccess"
"allow_user_to_change_display_name": true,
"updatechecker": false,
"has_internet_connection": true,
"enablebackup": false,
"datadirectory": "***REMOVED SENSITIVE VALUE***",
"version": "24.0.9.2",
"installedat": "1325006970.14",
"lastupdatedat": "1329928732.51",
"loglevel": 1,
"logdateformat": "F d, Y H:i:s",
"log_rotate_size": 100000000,
"instanceid": "***REMOVED SENSITIVE VALUE***",
"maintenance": false,
"theme": "",
"trusted_domains": [
"example.com",
"example.com",
"example.com"
"asset-pipeline.enabled": false,
"overwritewebroot": "\/",
"htaccess.RewriteBase": "\/",
"mail_from_address": "***REMOVED SENSITIVE VALUE***",
"mail_smtpmode": "sendmail",
"mail_domain": "***REMOVED SENSITIVE VALUE***",
"secret": "***REMOVED SENSITIVE VALUE***",
"activity_expire_days": 90,
"memcache.local": "\\OC\\Memcache\\APCu",
"memcache.locking": "\\OC\\Memcache\\Redis",
"redis": {
"host": "***REMOVED SENSITIVE VALUE***",
"port": 0
"trashbin_retention_obligation": "auto, 200",
"mysql.utf8mb4": true,
"mail_smtpauthtype": "LOGIN",
"updater.release.channel": "stable",
"mail_sendmailmode": "pipe",
"overwrite.cli.url": "https:\/\/example.com"
### List of activated Apps
```shell
Enabled:
- accessibility: 1.10.0
- activity: 2.16.0
- admin_audit: 1.14.0
- announcementcenter: 6.3.1
- apporder: 0.15.0
- audioplayer: 3.3.1
- bookmarks: 11.0.4
- calendar: 3.5.5
- camerarawpreviews: 0.8.1
- checksum: 1.2.0
- circles: 24.0.1
- cloud_federation_api: 1.7.0
- comments: 1.14.0
- contacts: 4.2.4
- contactsinteraction: 1.5.0
- dav: 1.22.0
- deck: 1.7.3
- federatedfilesharing: 1.14.0
- federation: 1.14.0
- files: 1.19.0
- files_accesscontrol: 1.14.1
- files_automatedtagging: 1.14.0
- files_external: 1.16.1
- files_pdfviewer: 2.5.0
- files_rightclick: 1.3.0
- files_sharing: 1.16.2
- files_trashbin: 1.14.0
- files_versions: 1.17.0
- files_videoplayer: 1.13.0
- firstrunwizard: 2.13.0
- forms: 2.5.1
- gpxpod: 4.3.0
- lookup_server_connector: 1.12.0
- news: 20.0.1
- nextcloud_announcements: 1.13.0
- notifications: 2.12.1
- oauth2: 1.12.0
- password_policy: 1.14.0
- photos: 1.6.0
- polls: 3.8.4
- privacy: 1.8.0
- provisioning_api: 1.14.0
- recommendations: 1.3.0
- serverinfo: 1.14.0
- settings: 1.6.0
- sharebymail: 1.14.0
- spreed: 14.0.8
- survey_client: 1.12.0
- systemtags: 1.14.0
- tasks: 0.14.5
- text: 3.5.1
- theming: 1.15.0
- twofactor_backupcodes: 1.13.0
- twofactor_totp: 6.4.1
- updatenotification: 1.14.0
- user_status: 1.4.0
- viewer: 1.8.0
- workflowengine: 2.6.0
### Nextcloud Signing status
```shell
I cannot login!
If I run "php occ integrity:check-core" it just returns nothing (no error, but no ok either)
### Nextcloud Logs
```shell
"reqId": "FOygCZuiHSXNIt0GPl8v",
"level": 3,
"time": "February 11, 2023 09:55:30",
"remoteAddr": "IPADDR",
"user": "USERNAME",
"app": "index",
"method": "POST",
"url": "/index.php",
"message": "strpos(): Argument #1 ($haystack) must be of type string, bool given in file '/usr/local/www/nextcloud/lib/private/Http/Client/LocalAddressChecker.php' line 82",
"userAgent": "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/109.0",
"exception": {
"Exception": "Exception",
"Message": "strpos(): Argument #1 ($haystack) must be of type string, bool given in file '/usr/local/www/nextcloud/lib/private/Http/Client/LocalAddressChecker.php' line 82",
"Code": 0,
"Trace": [
"file": "/usr/local/www/nextcloud/lib/private/AppFramework/App.php",
"line": 172,
"function": "dispatch",
"class": "OC\\AppFramework\\Http\\Dispatcher",
"type": "->",
"args": [
"__class__": "OC\\Core\\Controller\\LoginController"
"tryLogin"
"file": "/usr/local/www/nextcloud/lib/private/Route/Router.php",
"line": 298,
"function": "main",
"class": "OC\\AppFramework\\App",
"type": "::",
"args": [
"OC\\Core\\Controller\\LoginController",
"tryLogin",
"__class__": "OC\\AppFramework\\DependencyInjection\\DIContainer"
"core.login.tryLogin"
"file": "/usr/local/www/nextcloud/lib/base.php",
"line": 1030,
"function": "match",
"class": "OC\\Route\\Router",
"type": "->",
"args": [
"/login"
"file": "/usr/local/www/nextcloud/index.php",
"line": 36,
"function": "handleRequest",
"class": "OC",
"type": "::",
"args": []
"File": "/usr/local/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php",
"Line": 165,
"Previous": {
"Exception": "TypeError",
"Message": "strpos(): Argument #1 ($haystack) must be of type string, bool given",
"Code": 0,
"Trace": [
"file": "/usr/local/www/nextcloud/lib/private/Http/Client/LocalAddressChecker.php",
"line": 82,
"function": "strpos",
"args": [
"*** sensitive parameters replaced ***",
"file": "/usr/local/www/nextcloud/lib/private/Http/Client/Client.php",
"line": 184,
"function": "ThrowIfLocalAddress",
"class": "OC\\Http\\Client\\LocalAddressChecker",
"type": "->",
"args": [
"https://testsetup.example.com/ocs-provider/"
"line": 217,
"function": "preventLocalAddress",
"class": "OC\\Http\\Client\\Client",
"type": "->",
"args": [
"https://testsetup.example.com/ocs-provider/",
10,
10
"file": "/usr/local/www/nextcloud/lib/private/OCS/DiscoveryService.php",
"line": 85,
"function": "get",
"type": "->",
"args": [
10,
10
"file": "/usr/local/www/nextcloud/apps/files_sharing/lib/External/Storage.php",
"line": 88,
"function": "discover",
"class": "OC\\OCS\\DiscoveryService",
"type": "->",
"args": [
"https://testsetup.example.com",
"FEDERATED_SHARING"
"file": "/usr/local/www/nextcloud/lib/private/Files/Mount/MountPoint.php",
"line": 167,
"function": "__construct",
"class": "OCA\\Files_Sharing\\External\\Storage",
"type": "->",
"args": [
"https://testsetup.example.com/",
"18DXT2hsvEto69J",
"/username/files/share_folder",
"And 5 more entries, set log level to debug to see all entries"
"line": 192,
"function": "createStorage",
"class": "OC\\Files\\Mount\\MountPoint",
"type": "->",
"args": []
"file": "/usr/local/www/nextcloud/lib/private/Files/Config/UserMountCache.php",
"line": 88,
"function": "getStorage",
"type": "->",
"args": []
"function": "OC\\Files\\Config\\{closure}",
"class": "OC\\Files\\Config\\UserMountCache",
"type": "->",
"args": [
"line": 89,
"function": "array_filter",
"args": [
"__class__": "OC\\Files\\Mount\\MountPoint"
"__class__": "OCA\\Files_Sharing\\SharedMount"
"__class__": "Closure"
"file": "/usr/local/www/nextcloud/lib/private/Files/SetupManager.php",
"line": 292,
"function": "registerMounts",
"type": "->",
"args": [
"OC\\Files\\Mount\\CacheMountProvider",
"OCA\\Files_External\\Config\\ConfigAdapter",
"OCA\\Files_Sharing\\MountProvider",
"OCA\\Files_Sharing\\External\\MountProvider"
"line": 228,
"function": "afterUserFullySetup",
"class": "OC\\Files\\SetupManager",
"type": "->",
"args": [
"file": "/usr/local/www/nextcloud/lib/private/Files/Filesystem.php",
"line": 379,
"function": "setupForUser",
"type": "->",
"args": [
"file": "/usr/local/www/nextcloud/lib/private/Cache/File.php",
"line": 57,
"function": "initMountPoints",
"class": "OC\\Files\\Filesystem",
"type": "::",
"args": [
"line": 178,
"class": "OC\\Cache\\File",
"type": "->",
"args": []
"line": 838,
"function": "gc",
"type": "->",
"args": []
"function": "{closure}",
"class": "OC",
"type": "::",
"args": [
"file": "/usr/local/www/nextcloud/lib/private/Hooks/EmitterTrait.php",
"line": 106,
"function": "call_user_func_array",
"args": [
"file": "/usr/local/www/nextcloud/lib/private/Hooks/PublicEmitter.php",
"line": 40,
"function": "emit",
"class": "OC\\Hooks\\BasicEmitter",
"type": "->",
"args": [
"\\OC\\User",
"postLogin",
"file": "/usr/local/www/nextcloud/lib/private/User/Session.php",
"line": 400,
"function": "emit",
"class": "OC\\Hooks\\PublicEmitter",
"type": "->",
"args": [
"\\OC\\User",
"postLogin",
"file": "/usr/local/www/nextcloud/lib/private/Authentication/Login/CompleteLoginCommand.php",
"line": 44,
"function": "completeLogin",
"class": "OC\\User\\Session",
"type": "->",
"args": [
"file": "/usr/local/www/nextcloud/lib/private/Authentication/Login/ALoginCommand.php",
"line": 40,
"function": "process",
"class": "OC\\Authentication\\Login\\CompleteLoginCommand",
"type": "->",
"args": [
"__class__": "OC\\Authentication\\Login\\LoginData"
"file": "/usr/local/www/nextcloud/lib/private/Authentication/Login/LoggedInCheckCommand.php",
"line": 60,
"function": "processNextOrFinishSuccessfully",
"class": "OC\\Authentication\\Login\\ALoginCommand",
"type": "->",
"args": [
"line": 40,
"class": "OC\\Authentication\\Login\\LoggedInCheckCommand",
"type": "->",
"args": [
"file": "/usr/local/www/nextcloud/lib/private/Authentication/Login/EmailLoginCommand.php",
"line": 70,
"type": "->",
"args": [
"line": 40,
"class": "OC\\Authentication\\Login\\EmailLoginCommand",
"type": "->",
"args": [
"file": "/usr/local/www/nextcloud/lib/private/Authentication/Login/UidLoginCommand.php",
"line": 54,
"type": "->",
"args": [
"line": 40,
"class": "OC\\Authentication\\Login\\UidLoginCommand",
"type": "->",
"args": [
"file": "/usr/local/www/nextcloud/lib/private/Authentication/Login/UserDisabledCheckCommand.php",
"line": 58,
"type": "->",
"args": [
"line": 40,
"class": "OC\\Authentication\\Login\\UserDisabledCheckCommand",
"type": "->",
"args": [
"file": "/usr/local/www/nextcloud/lib/private/Authentication/Login/PreLoginHookCommand.php",
"line": 53,
"type": "->",
"args": [
"file": "/usr/local/www/nextcloud/lib/private/Authentication/Login/Chain.php",
"line": 108,
"class": "OC\\Authentication\\Login\\PreLoginHookCommand",
"type": "->",
"args": [
"file": "/usr/local/www/nextcloud/core/Controller/LoginController.php",
"line": 329,
"class": "OC\\Authentication\\Login\\Chain",
"type": "->",
"args": [
"file": "/usr/local/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php",
"line": 225,
"function": "tryLogin",
"class": "OC\\Core\\Controller\\LoginController",
"type": "->",
"args": [
"line": 133,
"function": "executeController",
"type": "->",
"args": [
"tryLogin"
"line": 172,
"type": "->",
"args": [
"tryLogin"
"line": 298,
"function": "main",
"type": "::",
"args": [
"tryLogin",
"line": 1030,
"type": "->",
"args": [
"/login"
"line": 36,
"class": "OC",
"type": "::",
"args": []
"File": "/usr/local/www/nextcloud/lib/private/Http/Client/LocalAddressChecker.php",
"Line": 82
"CustomMessage": "--"
### Additional info
_No response_
