Reason for post
Need help setting up three different VLAN’s or bridge devices on my TO for three straightforward setups
Setups
- VLAN for lan0 and lan1 for IPTV as it needs IGMP snooping and I want to keep it separate from the rest of my network to avoiding flooding. It will only need access to the internet, not the LAN or the gateway.
- VLAN for all lan2 and lan3 for LAN devices. It will need need access to the internet, and the gateway. This one is fairly straightforward, and once i can figure out the other two, this one should be easy
- VLAN for internet facing test device. It will only need access to the internet, not the LAN or the gateway
What I’ve tried
- Tried reading this and following the steps, but couldn’t make it work VLAN how to make it work
- Tried creating a bridge device which allowed me to enable IGMP snooping for the IPTV devices then i created an interface called IPTV and firewall zone. I’m able to get an IP when plugged into lan0, but its not within a range i expect. I get a .17 instead of a .3 or something like that. Also i can’t access the gateway or the internet.
Anyone know what i’m doing wrong, other than everything?
