I created a new interface through LuCi but I don’t receive any DHCP reply from the router. In network -> Interface
settings I can see that Tx is 0:
Protocol: Static address
Uptime: 0h 3m 48s
MAC: D8:58:D7:xx:xx:xx
RX: 16.52 KB (49 Pkts.)
TX: 0 B (0 Pkts.)
IPv4: x.x.x.x/24
My /etc/config/network for this new interface look like this:
config interface 'switch'
option device 'lan1'
option proto 'static'
option ipaddr 'xx.xx.xx.xx'
And for /etc/config/dhcp:
config dhcp 'switch'
option start '100'
option leasetime '12h'
option limit '150'
option interface 'switch'
list dhcp_option '6,xx.xx.xx.xx'
option force '1'
list ra_flags 'none'
FYI:
root@router:~# cat /etc/turris-version
6.3.3
Any idea about how to fix this ?
Did you create a firewall zone for this interface or attach it to an existing one?
Yes I have a firewall zone for this interface. Below my /etc/config/firewall
config defaults
option forward 'REJECT'
option synflood_protect '1'
option input 'REJECT'
option output 'REJECT'
config zone
option name 'lan'
option input 'ACCEPT'
option output 'ACCEPT'
option family 'ipv4'
list network 'lan'
config zone
option name 'wan'
option masq '1'
option mtu_fix '1'
option forward 'ACCEPT'
list network 'wan'
config forwarding
option src 'lan'
option dest 'wan'
config rule
option name 'Allow-DHCP-Renew'
option src 'wan'
option proto 'udp'
option dest_port '68'
option target 'ACCEPT'
config rule
option name 'Allow-Ping'
option src 'wan'
option proto 'icmp'
option icmp_type 'echo-request'
config rule
option name 'Allow-IGMP'
option src 'wan'
option proto 'igmp'
config rule
option name 'Allow-MLD'
option src 'wan'
option proto 'icmp'
option src_ip 'fe80::/10'
list icmp_type '130/0'
list icmp_type '131/0'
list icmp_type '132/0'
list icmp_type '143/0'
option family 'ipv6'
config include
option path '/etc/firewall.user'
config include
option path '/usr/share/firewall/turris'
option reload '1'
config include
option path '/etc/firewall.d/with_reload/firewall.include.sh'
option reload '1'
config include
option path '/etc/firewall.d/without_reload/firewall.include.sh'
option reload '0'
config rule
option src 'wan'
option dest 'lan'
option proto 'esp'
config rule
option src 'wan'
option dest 'lan'
option dest_port '500'
option proto 'udp'
config rule 'turris_wan_6in4_rule'
option enabled '0'
config include 'bcp38'
option type 'script'
option path '/usr/lib/bcp38/run.sh'
option family 'IPv4'
option reload '1'
config include 'miniupnpd'
option path '/usr/share/miniupnpd/firewall.include'
option family 'any'
option reload '1'
config zone
option name 'wifi2'
list network 'wifi2'
config zone
option name 'wifi5'
list network 'wifi5'
config forwarding
option dest 'wan'
option src 'wifi2'
config forwarding
option dest 'wan'
option src 'wifi5'
config zone
option name 'switch'
list network 'switch'
config forwarding
option dest 'wan'
option src 'switch'
Problem solved. By copy/pasta the firewall rule, I noticed the ‘REJECT’ for the interface.
Thanks
system
Closed
5
