NetMetr - spontaneous planning
Although I repeatedly turn off the NetMetr test plan and save it and then check it, I repeatedly find that the tests still run at one random time. It behaves the same way if I cancel the test plan in the configuration file
/etc/config/netmetr
config settings 'settings'
	option control_server 'control.netmetr.cz'
	option max_history_logs '50'
	option client 'HW-PROBE'
	option uuid '5d8b8a67-xxxx-yyyy-zzzz-123456789012'
	option autostart_delay '2724'
	option protocol_mode 'prefer_6'
	option autostart_enabled '0'
	option sync_code 'abcdefghijkl'
Just by randomly checking, I find that it’s constantly and repeatedly triggering
Date and Time Download [Mb/s] Upload [Mb/s] Ping [ms] Link
3/7/2023 12:45 AM 93 94 6.9 Details
3/6/2023 12:45 AM 94 94 7 Details
3/5/2023 12:45 AM 94 94 7.1 Details
3/4/2023 12:45 AM 64 90 7.1 Details
3/3/2023 12:45 AM 92 94 7.1 Details
3/2/2023 3:36 PM 89 94 7.1 Details
3/1/2023 10:45 PM 82 94 7.4 Details
2/28/2023 10:45 PM 80 77 7.3 Details
2/27/2023 10:45 PM 86 94 7.2 Details
2/26/2023 10:45 PM 66 88 7.3 Details
2/25/2023 10:45 PM 77 93 7.3 Details
2/25/2023 12:30 PM 82 93 7.2 Details
2/25/2023 4:45 AM 94 94 6.9 Details
2/24/2023 4:45 AM 94 94 7 Details
2/23/2023 4:45 AM 94 94 7 Details
2/22/2023 4:45 AM 94 94 7 Details
2/21/2023 7:30 PM 68 93 7.4 Details
2/21/2023 12:45 AM 55 74 7.3 Details
2/20/2023 12:45 AM 94 94 7 Details
2/19/2023 12:45 AM 83 86 7.3 Details
2/17/2023 10:45 PM 93 94 7.1 Details
2/16/2023 10:45 PM 57 64 7.6 Details
2/16/2023 6:52 PM 70 92 7.3 Details
2/16/2023 1:53 PM 94 94 7.2 Details
2/16/2023 6:45 AM 94 94 7 Details
2/15/2023 6:45 AM 79 89 7.1 Details
2/14/2023 6:45 AM 94 94 7 Details
2/13/2023 6:45 AM 94 94 7 Details
2/12/2023 6:45 AM 91 94 7 Details
2/12/2023 12:19 AM 94 93 7.1 Details
2/11/2023 11:45 PM 48 92 7.5 Details
2/11/2023 10:45 AM 93 94 7.1 Details
2/10/2023 9:45 AM 82 93 7 Details
2/9/2023 9:45 AM 94 94 7 Details
2/8/2023 9:45 AM 94 94 7.1 Details
2/7/2023 9:45 AM 94 94 7 Details
I found only one solution - to comment out line in /etc/cron.d/netmetr:
MAILTO=""
#00     *       *       *       *       root    netmetr --autostart --dwlhist --syslog &
However, this is completely unsystematic, and the cause of this behaviour is not identified - when the application changes its settings spontaneously. I haven’t yet tracked down when the problem starts … restarting the router isn’t it.
Rather, I’m wondering if this is a problem only with me, or if it occurs in general. NetMetr hasn’t been this bad before, it should be of interest to the developers in support…
I have a same issue on fresh install of 6.2.4
After running the netmetr once it started doing this even if config it was supposed to be disbled.
Turris MOX A+C, TurrisOS 6.2.4. For me, it works as expected.
With the difference that I just click on “Enable autostart” to turn it off and then just hit “Save”. I’m leaving out your step 1) when you change the schedule time for tests.
