Since the last upgrade, the LXC containers of my Turris Omnia has problems with many (all) network programs. It takes 20 to 40 seconds even for “ping -c 1 127.0.0.1”
% time ping -c 1 127.0.0.1
PING 127.0.0.1 (127.0.0.1) 56(84) bytes of data.
64 bytes from 127.0.0.1: icmp_seq=1 ttl=64 time=0.063 ms
--- 127.0.0.1 ping statistics ---
1 packets transmitted, 1 received, 0% packet loss, time 0ms
rtt min/avg/max/mdev = 0.063/0.063/0.063/0.000 ms
ping -c 1 127.0.0.1 0.00s user 0.00s system 0% cpu 28.573 total
Running with strace -r, I see that ping hangs on the exit() system call:
0.000086 write(1, "rtt min/avg/max/mdev = 0.293/0.2"..., 50rtt min/avg/max/mdev = 0.293/0.293/0.293/0.000 ms
) = 50
0.000236 exit_group(0) = ?
13.016139 +++ exited with 0 +++
Other programs such as ssh hangs on a sendto call:
0.000062 sendto(3, {{len=20, type=0x16 /* NLMSG_??? */, flags=NLM_F_REQUEST|0x300, seq=1530520638, pid=0}, "\x00\x00\x00\x00"}, 20, 0, {sa_family=AF_NETLINK, nl_pid=0, nl_groups=00000000}, 12
2.999693 recvmsg(3, {msg_name={sa_family=AF_NETLINK, nl_pid=0, nl_groups=00000000}, msg_namelen=12, msg_iov=[{iov_base={{len=20, type=NLMSG_DONE, flags=NLM_F_MULTI, seq=1530520661, pid=26088}, 0}, iov_len=4096}], msg_iovlen=1, msg_controllen=0, msg_flags=0}, 0) = 20
It sems a Netlink problem. I see that Netlink on the Turris itself also has a problem:
root@turris:~# time ip route show
default via 82.251.62.254 dev eth1 proto static src 82.251.62.29
82.251.62.0/24 dev eth1 proto kernel scope link src 82.251.62.29
82.251.62.254 dev eth1 proto static scope link src 82.251.62.29
192.168.2.0/24 dev br-lan proto kernel scope link src 192.168.2.254
real 0m 18.47s
user 0m 0.00s
sys 0m 0.00s
Why does it take so much time for Netlink route requests?
Is it the reason why my network programs hang? (On the Turris itself, network programs work fine, only the LXC containers have problems)
