Netdata - nezvyklé chyby
#1
Od verze 3.11.1 téměř trvalá chyba (cca 600x) 2018-12-26 20:12:10 err netdata[14139]: BTRFS: failed to read ‘/sys/fs/btrfs/ea9076db-29f3-43c1-ba9f-6eb8bdf41a61/allocation/data/total_bytes’
Po reinstalaci netdata a restartech problém nemizí.
2018-12-25 11:58:30 info netdata[14139]: resources control: allowed file descriptors: soft = 1024, max = 4096
2018-12-25 11:58:30 info netdata[14139]: Adjusted my Out-Of-Memory (OOM) score from 0 to 1000.
2018-12-25 11:58:30 err netdata[14139]: Cannot adjust netdata scheduling policy to idle (5), with priority 0. Falling back to nice.
2018-12-25 11:58:30 err netdata[14139]: Cannot get my current process scheduling policy.
2018-12-25 11:58:30 info netdata[14139]: netdata started on pid 14139.
2018-12-25 11:58:30 info netdata[14139]: CONFIG: cannot load user config '/etc/netdata/stream.conf'. Will try stock config.
2018-12-25 11:58:30 info netdata[14139]: Host 'Omnia' (at registry as 'Omnia') with guid '038fac8a-0834-11e9-b05b-d858d7003550' initialized, os 'linux', timezone 'GMT', tags '', program_name 'netdata', program_version '3.11-68-gfe363ac_rolling', update every 2, memory mode ram, history entries 4034, streaming disabled (to '' with api key ''), health disabled, cache_dir '/var/cache/netdata', varlib_dir '/var/lib/netdata', health_log '/var/lib/netdata/health/health-log.db', alarms default handler '/usr/lib/netdata/plugins.d/alarm-notify.sh', alarms default recipient 'root'
2018-12-25 11:58:30 info netdata[14139]: netdata initialization completed. Enjoy real-time performance monitoring!
2018-12-25 11:58:30 info netdata[14139]: thread created with task id 14143
2018-12-25 11:58:30 info netdata[14139]: thread created with task id 14144
2018-12-25 11:58:30 err netdata[14139]: Cannot advise the kernel about the memory usage (MADV_MERGEABLE) of file '(null)'.
2018-12-25 11:58:30 info netdata[14139]: thread created with task id 14145
2018-12-25 11:58:30 info netdata[14139]: thread created with task id 14142
2018-12-25 11:58:30 info netdata[14139]: thread created with task id 14146
2018-12-25 11:58:30 info netdata[14139]: cleaning up...
2018-12-25 11:58:30 info netdata[14139]: thread with task id 14146 finished
2018-12-25 11:58:30 info netdata[14139]: thread created with task id 14149
2018-12-25 11:58:30 info netdata[14139]: thread created with task id 14147
2018-12-25 11:58:30 info netdata[14139]: thread created with task id 14150
2018-12-25 11:58:30 info netdata[14139]: thread created with task id 14148
2018-12-25 11:58:30 info netdata[14139]: starting worker 2
2018-12-25 11:58:30 info netdata[14139]: STATSD collector thread started with taskid 14150
2018-12-25 11:58:30 info netdata[14139]: POLLFD: LISTENER: listening on 'tcp:0.0.0.0:19999'
2018-12-25 11:58:30 info netdata[14139]: POLLFD: LISTENER: listening on 'tcp:[::]:19999'
2018-12-25 11:58:30 info netdata[14139]: POLLFD: LISTENER: listening on 'udp:127.0.0.1:8125'
2018-12-25 11:58:30 info netdata[14139]: POLLFD: LISTENER: listening on 'tcp:127.0.0.1:8125'
2018-12-25 11:58:30 info netdata[14139]: thread created with task id 14151
2018-12-25 11:58:30 info netdata[14139]: cpufreq is using /sys/devices/system/cpu/cpu*/cpufreq/stats/time_in_state
2018-12-25 11:58:30 info netdata[14139]: Using now_boottime_usec() for uptime (dt is 3 ms)
2018-12-25 11:58:30 err netdata[14139]: PROCFILE: Cannot open file '/proc/net/sctp/snmp'
2018-12-25 11:58:30 err netdata[14139]: DEVICE-MAPPER ('ram0', 1:0): Cannot open directory '/dev/disk/by-label'.
2018-12-25 11:58:30 err netdata[14139]: DEVICE-MAPPER ('ram0', 1:0): Cannot open directory '/dev/vx/dsk'.
2018-12-25 11:58:30 err netdata[14139]: DEVICE-MAPPER ('ram1', 1:1): Cannot open directory '/dev/disk/by-label'.
2018-12-25 11:58:30 err netdata[14139]: DEVICE-MAPPER ('ram1', 1:1): Cannot open directory '/dev/vx/dsk'.
2018-12-25 11:58:30 err netdata[14139]: DEVICE-MAPPER ('ram2', 1:2): Cannot open directory '/dev/disk/by-label'.
2018-12-25 11:58:30 err netdata[14139]: DEVICE-MAPPER ('ram2', 1:2): Cannot open directory '/dev/vx/dsk'.
2018-12-25 11:58:30 err netdata[14139]: DEVICE-MAPPER ('ram3', 1:3): Cannot open directory '/dev/disk/by-label'.
2018-12-25 11:58:30 err netdata[14139]: DEVICE-MAPPER ('ram3', 1:3): Cannot open directory '/dev/vx/dsk'.
2018-12-25 11:58:30 err netdata[14139]: DEVICE-MAPPER ('ram4', 1:4): Cannot open directory '/dev/disk/by-label'.
2018-12-25 11:58:30 err netdata[14139]: DEVICE-MAPPER ('ram4', 1:4): Cannot open directory '/dev/vx/dsk'.
2018-12-25 11:58:30 err netdata[14139]: DEVICE-MAPPER ('ram5', 1:5): Cannot open directory '/dev/disk/by-label'.
2018-12-25 11:58:30 err netdata[14139]: DEVICE-MAPPER ('ram5', 1:5): Cannot open directory '/dev/vx/dsk'.
2018-12-25 11:58:30 err netdata[14139]: DEVICE-MAPPER ('ram6', 1:6): Cannot open directory '/dev/disk/by-label'.
2018-12-25 11:58:30 err netdata[14139]: DEVICE-MAPPER ('ram6', 1:6): Cannot open directory '/dev/vx/dsk'.
2018-12-25 11:58:30 err netdata[14139]: DEVICE-MAPPER ('ram7', 1:7): Cannot open directory '/dev/disk/by-label'.
2018-12-25 11:58:30 err netdata[14139]: DEVICE-MAPPER ('ram7', 1:7): Cannot open directory '/dev/vx/dsk'.
2018-12-25 11:58:30 err netdata[14139]: DEVICE-MAPPER ('ram8', 1:8): Cannot open directory '/dev/disk/by-label'.
2018-12-25 11:58:30 err netdata[14139]: DEVICE-MAPPER ('ram8', 1:8): Cannot open directory '/dev/vx/dsk'.
2018-12-25 11:58:30 err netdata[14139]: DEVICE-MAPPER ('ram9', 1:9): Cannot open directory '/dev/disk/by-label'.
2018-12-25 11:58:30 err netdata[14139]: DEVICE-MAPPER ('ram9', 1:9): Cannot open directory '/dev/vx/dsk'.
2018-12-25 11:58:30 err netdata[14139]: DEVICE-MAPPER ('ram10', 1:10): Cannot open directory '/dev/disk/by-label'.
2018-12-25 11:58:30 err netdata[14139]: DEVICE-MAPPER ('ram10', 1:10): Cannot open directory '/dev/vx/dsk'.
2018-12-25 11:58:30 err netdata[14139]: DEVICE-MAPPER ('ram11', 1:11): Cannot open directory '/dev/disk/by-label'.
2018-12-25 11:58:30 err netdata[14139]: DEVICE-MAPPER ('ram11', 1:11): Cannot open directory '/dev/vx/dsk'.
2018-12-25 11:58:30 err netdata[14139]: DEVICE-MAPPER ('ram12', 1:12): Cannot open directory '/dev/disk/by-label'.
2018-12-25 11:58:30 err netdata[14139]: DEVICE-MAPPER ('ram12', 1:12): Cannot open directory '/dev/vx/dsk'.
2018-12-25 11:58:30 err netdata[14139]: DEVICE-MAPPER ('ram13', 1:13): Cannot open directory '/dev/disk/by-label'.
2018-12-25 11:58:30 err netdata[14139]: DEVICE-MAPPER ('ram13', 1:13): Cannot open directory '/dev/vx/dsk'.
2018-12-25 11:58:30 err netdata[14139]: DEVICE-MAPPER ('ram14', 1:14): Cannot open directory '/dev/disk/by-label'.
2018-12-25 11:58:30 err netdata[14139]: DEVICE-MAPPER ('ram14', 1:14): Cannot open directory '/dev/vx/dsk'.
2018-12-25 11:58:30 err netdata[14139]: DEVICE-MAPPER ('ram15', 1:15): Cannot open directory '/dev/disk/by-label'.
2018-12-25 11:58:30 err netdata[14139]: DEVICE-MAPPER ('ram15', 1:15): Cannot open directory '/dev/vx/dsk'.
2018-12-25 11:58:30 err netdata[14139]: DEVICE-MAPPER ('mtdblock0', 31:0): Cannot open directory '/dev/disk/by-label'.
2018-12-25 11:58:30 err netdata[14139]: DEVICE-MAPPER ('mtdblock0', 31:0): Cannot open directory '/dev/vx/dsk'.
2018-12-25 11:58:30 err netdata[14139]: DEVICE-MAPPER ('mtdblock1', 31:1): Cannot open directory '/dev/disk/by-label'.
2018-12-25 11:58:30 err netdata[14139]: DEVICE-MAPPER ('mtdblock1', 31:1): Cannot open directory '/dev/vx/dsk'.
2018-12-25 11:58:30 err netdata[14139]: DEVICE-MAPPER ('mmcblk0', 179:0): Cannot open directory '/dev/disk/by-label'.
2018-12-25 11:58:30 err netdata[14139]: DEVICE-MAPPER ('mmcblk0', 179:0): Cannot open directory '/dev/vx/dsk'.
2018-12-25 11:58:30 err netdata[14139]: DEVICE-MAPPER ('mmcblk0p1', 179:1): Cannot open directory '/dev/disk/by-label'.
2018-12-25 11:58:30 err netdata[14139]: DEVICE-MAPPER ('mmcblk0p1', 179:1): Cannot open directory '/dev/vx/dsk'.
2018-12-25 11:58:30 err netdata[14139]: DEVICE-MAPPER ('mmcblk0rpmb', 179:24): Cannot open directory '/dev/disk/by-label'.
2018-12-25 11:58:30 err netdata[14139]: DEVICE-MAPPER ('mmcblk0rpmb', 179:24): Cannot open directory '/dev/vx/dsk'.
2018-12-25 11:58:31 err netdata[14139]: DEVICE-MAPPER ('mmcblk0boot1', 179:16): Cannot open directory '/dev/disk/by-label'.
2018-12-25 11:58:31 err netdata[14139]: DEVICE-MAPPER ('mmcblk0boot1', 179:16): Cannot open directory '/dev/vx/dsk'.
2018-12-25 11:58:31 err netdata[14139]: DEVICE-MAPPER ('mmcblk0boot0', 179:8): Cannot open directory '/dev/disk/by-label'.
2018-12-25 11:58:31 err netdata[14139]: DEVICE-MAPPER ('mmcblk0boot0', 179:8): Cannot open directory '/dev/vx/dsk'.
2018-12-25 11:58:31 err netdata[14139]: DEVICE-MAPPER ('sda', 8:0): Cannot open directory '/dev/disk/by-label'.
2018-12-25 11:58:31 err netdata[14139]: DEVICE-MAPPER ('sda', 8:0): Cannot open directory '/dev/vx/dsk'.
2018-12-25 11:58:31 err netdata[14139]: BTRFS: failed to read '/sys/fs/btrfs/ea9076db-29f3-43c1-ba9f-6eb8bdf41a61/allocation/data/total_bytes'
2018-12-25 11:58:42 err netdata[14139]: Cannot refresh interface guest_turris_1 speed by reading '/sys/class/net/guest_turris_1/speed'. Will not update its speed anymore.
2018-12-25 11:58:42 err netdata[14139]: Cannot refresh interface wlan0 speed by reading '/sys/class/net/wlan0/speed'. Will not update its speed anymore.
2018-12-25 11:58:42 err netdata[14139]: Cannot refresh interface wlan1 speed by reading '/sys/class/net/wlan1/speed'. Will not update its speed anymore.
2018-12-25 11:58:53 info ucollect[14181]: Initializing emergency signal handlers
2018-12-25 11:58:53 info ucollect[14181]: Creating a main loop
2018-12-25 11:58:53 info ucollect[14181]: Creating uplink
2018-12-25 11:58:53 err ucollect[14181]: Can't load configuration of ucollect
2018-12-25 11:58:53 crit ucollect[14181]: No configuration available
2018-12-25 11:59:01 info /usr/sbin/cron[14193]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-12-25 11:59:30 err netdata[14139]: BTRFS: failed to read '/sys/fs/btrfs/ea9076db-29f3-43c1-ba9f-6eb8bdf41a61/allocation/data/total_bytes'
2018-12-25 11:59:53 info ucollect[14232]: Initializing emergency signal handlers
2018-12-25 11:59:53 info ucollect[14232]: Creating a main loop
2018-12-25 11:59:53 info ucollect[14232]: Creating uplink
2018-12-25 11:59:53 err ucollect[14232]: Can't load configuration of ucollect
2018-12-25 11:59:53 crit ucollect[14232]: No configuration available
2018-12-25 11:59:57 info netdata[14139]: POLLFD: LISTENER: client slot 2 (fd 24) from '192.168.2.120:58631' is idle for more than 60 seconds - closing it.
2018-12-25 11:59:57 info netdata[14139]: POLLFD: LISTENER: client slot 3 (fd 25) from '192.168.2.120:58634' is idle for more than 60 seconds - closing it.
2018-12-25 11:59:57 info netdata[14139]: POLLFD: LISTENER: client slot 4 (fd 28) from '192.168.2.120:58636' is idle for more than 60 seconds - closing it.
2018-12-25 11:59:57 info netdata[14139]: POLLFD: LISTENER: client slot 5 (fd 27) from '192.168.2.120:58637' is idle for more than 60 seconds - closing it.
2018-12-25 11:59:57 info netdata[14139]: POLLFD: LISTENER: client slot 2 (fd 26) from '192.168.2.120:58635' is idle for more than 60 seconds - closing it.
2018-12-25 11:59:57 info netdata[14139]: POLLFD: LISTENER: client slot 3 (fd 29) from '192.168.2.120:58638' is idle for more than 60 seconds - closing it.
2018-12-25 12:15:44 err netdata[14139]: BTRFS: failed to read '/sys/fs/btrfs/ea9076db-29f3-43c1-ba9f-6eb8bdf41a61/allocation/data/total_bytes'
2018-12-25 12:15:53 info ucollect[15834]: Initializing emergency signal handlers
2018-12-25 12:15:53 info ucollect[15834]: Creating a main loop
2018-12-25 12:15:53 info ucollect[15834]: Creating uplink
2018-12-25 12:15:53 err ucollect[15834]: Can't load configuration of ucollect
2018-12-25 12:15:53 crit ucollect[15834]: No configuration available
2018-12-25 12:16:01 info /usr/sbin/cron[15837]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-12-25 12:16:01 info /usr/sbin/cron[15838]: (root) CMD (nethist_stats.lua)
2018-12-25 12:16:46 err netdata[14139]: BTRFS: failed to read '/sys/fs/btrfs/ea9076db-29f3-43c1-ba9f-6eb8bdf41a61/allocation/data/total_bytes'
2018-12-25 12:16:53 info ucollect[15869]: Initializing emergency signal handlers
2018-12-25 12:16:53 info ucollect[15869]: Creating a main loop
2018-12-25 12:16:53 info ucollect[15869]: Creating uplink
2018-12-25 12:16:53 err ucollect[15869]: Can't load configuration of ucollect
2018-12-25 12:16:53 crit ucollect[15869]: No configuration available
2018-12-25 12:17:01 info /usr/sbin/cron[15871]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-12-25 12:17:46 err netdata[14139]: BTRFS: failed to read '/sys/fs/btrfs/ea9076db-29f3-43c1-ba9f-6eb8bdf41a61/allocation/data/total_bytes'
2018-12-25 12:17:53 info ucollect[15905]: Initializing emergency signal handlers
2018-12-25 12:17:53 info ucollect[15905]: Creating a main loop
2018-12-25 12:17:53 info ucollect[15905]: Creating uplink
2018-12-25 12:17:53 err ucollect[15905]: Can't load configuration of ucollect
2018-12-25 12:17:53 crit ucollect[15905]: No configuration available
2018-12-25 12:18:01 info /usr/sbin/cron[15910]: (root) CMD (nethist_stats.lua)
2018-12-25 12:18:01 info /usr/sbin/cron[15909]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-12-25 12:18:01 info /usr/sbin/cron[15911]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-12-25 12:18:46 err netdata[14139]: BTRFS: failed to read '/sys/fs/btrfs/ea9076db-29f3-43c1-ba9f-6eb8bdf41a61/allocation/data/total_bytes'
2018-12-25 12:18:53 info ucollect[15977]: Initializing emergency signal handlers
2018-12-25 12:18:53 info ucollect[15977]: Creating a main loop
2018-12-25 12:18:53 info ucollect[15977]: Creating uplink
2018-12-25 12:18:53 err ucollect[15977]: Can't load configuration of ucollect
2018-12-25 12:18:53 crit ucollect[15977]: No configuration available
2018-12-25 12:19:01 info /usr/sbin/cron[15979]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-12-25 12:19:48 err netdata[14139]: BTRFS: failed to read '/sys/fs/btrfs/ea9076db-29f3-43c1-ba9f-6eb8bdf41a61/allocation/data/total_bytes'
2018-12-25 12:19:53 info ucollect[16010]: Initializing emergency signal handlers
2018-12-25 12:19:53 info ucollect[16010]: Creating a main loop
2018-12-25 12:19:53 info ucollect[16010]: Creating uplink
2018-12-25 12:19:53 err ucollect[16010]: Can't load configuration of ucollect
2018-12-25 12:19:53 crit ucollect[16010]: No configuration available
2018-12-25 12:20:01 info /usr/sbin/cron[16014]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-12-25 12:20:01 info /usr/sbin/cron[16015]: (root) CMD (nethist_stats.lua)
2018-12-25 12:20:01 info /usr/sbin/cron[16016]: (root) CMD (   /usr/bin/notifier)
2018-12-25 12:20:48 err netdata[14139]: BTRFS: failed to read '/sys/fs/btrfs/ea9076db-29f3-43c1-ba9f-6eb8bdf41a61/allocation/data/total_bytes'
2018-12-25 12:20:53 info ucollect[16081]: Initializing emergency signal handlers
2018-12-25 12:20:53 info ucollect[16081]: Creating a main loop
2018-12-25 12:20:53 info ucollect[16081]: Creating uplink
2018-12-25 12:20:53 err ucollect[16081]: Can't load configuration of ucollect
2018-12-25 12:20:53 crit ucollect[16081]: No configuration available
2018-12-25 12:21:01 info /usr/sbin/cron[16085]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-12-25 12:21:01 info /usr/sbin/cron[16084]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2018-12-25 12:21:50 err netdata[14139]: BTRFS: failed to read '/sys/fs/btrfs/ea9076db-29f3-43c1-ba9f-6eb8bdf41a61/allocation/data/total_bytes'
#2
Pokračování
2018-12-29 21:12:21 err netdata[5366]: DEVICE-MAPPER ('ram0', 1:0): Cannot open directory '/dev/disk/by-label'. Disabling device-mapper support.
2018-12-29 21:12:21 err netdata[5366]: DEVICE-MAPPER ('ram1', 1:1): Cannot open directory '/dev/disk/by-label'. Disabling device-mapper support.
2018-12-29 21:12:21 err netdata[5366]: DEVICE-MAPPER ('ram2', 1:2): Cannot open directory '/dev/disk/by-label'. Disabling device-mapper support.
2018-12-29 21:12:21 err netdata[5366]: DEVICE-MAPPER ('ram3', 1:3): Cannot open directory '/dev/disk/by-label'. Disabling device-mapper support.
2018-12-29 21:12:21 err netdata[5366]: DEVICE-MAPPER ('ram4', 1:4): Cannot open directory '/dev/disk/by-label'. Disabling device-mapper support.
2018-12-29 21:12:21 err netdata[5366]: DEVICE-MAPPER ('ram5', 1:5): Cannot open directory '/dev/disk/by-label'. Disabling device-mapper support.
2018-12-29 21:12:21 err netdata[5366]: DEVICE-MAPPER ('ram6', 1:6): Cannot open directory '/dev/disk/by-label'. Disabling device-mapper support.
2018-12-29 21:12:21 err netdata[5366]: DEVICE-MAPPER ('ram7', 1:7): Cannot open directory '/dev/disk/by-label'. Disabling device-mapper support.
2018-12-29 21:12:21 err netdata[5366]: DEVICE-MAPPER ('ram8', 1:8): Cannot open directory '/dev/disk/by-label'. Disabling device-mapper support.
2018-12-29 21:12:21 err netdata[5366]: DEVICE-MAPPER ('ram9', 1:9): Cannot open directory '/dev/disk/by-label'. Disabling device-mapper support.
2018-12-29 21:12:21 err netdata[5366]: DEVICE-MAPPER ('ram10', 1:10): Cannot open directory '/dev/disk/by-label'. Disabling device-mapper support.
2018-12-29 21:12:21 err netdata[5366]: DEVICE-MAPPER ('ram11', 1:11): Cannot open directory '/dev/disk/by-label'. Disabling device-mapper support.
2018-12-29 21:12:21 err netdata[5366]: DEVICE-MAPPER ('ram12', 1:12): Cannot open directory '/dev/disk/by-label'. Disabling device-mapper support.
2018-12-29 21:12:21 err netdata[5366]: DEVICE-MAPPER ('ram13', 1:13): Cannot open directory '/dev/disk/by-label'. Disabling device-mapper support.
2018-12-29 21:12:21 err netdata[5366]: DEVICE-MAPPER ('ram14', 1:14): Cannot open directory '/dev/disk/by-label'. Disabling device-mapper support.
2018-12-29 21:12:21 err netdata[5366]: DEVICE-MAPPER ('ram15', 1:15): Cannot open directory '/dev/disk/by-label'. Disabling device-mapper support.
2018-12-29 21:12:21 err netdata[5366]: DEVICE-MAPPER ('mtdblock0', 31:0): Cannot open directory '/dev/disk/by-label'. Disabling device-mapper support.
2018-12-29 21:12:21 err netdata[5366]: DEVICE-MAPPER ('mtdblock1', 31:1): Cannot open directory '/dev/disk/by-label'. Disabling device-mapper support.
2018-12-29 21:12:21 err netdata[5366]: DEVICE-MAPPER ('mmcblk0', 179:0): Cannot open directory '/dev/disk/by-label'. Disabling device-mapper support.
2018-12-29 21:12:21 err netdata[5366]: DEVICE-MAPPER ('mmcblk0p1', 179:1): Cannot open directory '/dev/disk/by-label'. Disabling device-mapper support.
2018-12-29 21:12:21 err netdata[5366]: DEVICE-MAPPER ('mmcblk0rpmb', 179:24): Cannot open directory '/dev/disk/by-label'. Disabling device-mapper support.
2018-12-29 21:12:21 err netdata[5366]: DEVICE-MAPPER ('mmcblk0boot1', 179:16): Cannot open directory '/dev/disk/by-label'. Disabling device-mapper support.
2018-12-29 21:12:21 err netdata[5366]: DEVICE-MAPPER ('mmcblk0boot0', 179:8): Cannot open directory '/dev/disk/by-label'. Disabling device-mapper support.
2018-12-29 21:12:21 err netdata[5366]: DEVICE-MAPPER ('sda', 8:0): Cannot open directory '/dev/disk/by-label'. Disabling device-mapper support.
2018-12-29 21:12:21 err netdata[5366]: BTRFS: failed to read '/sys/fs/btrfs/ea9076db-29f3-43c1-ba9f-6eb8bdf41a61/allocation/data/total_bytes'
#3
Navazující chyby po odinstalaci netdata
2019-01-01 01:00:02 info nikola[]: (v43) recognized WAN interfaces: eth1, lo
2019-01-01 01:00:02 err server_uplink[]: Failed to download contract status
2019-01-01 01:00:22 info nikola[]: (v43) Establishing connection took 1.902365 seconds
2019-01-01 01:00:22 info nikola[]: (v43) Logrotate took 0.004408 seconds
2019-01-01 01:00:22 info nikola[]: (v43) Syslog parsing took 0.056766 seconds
2019-01-01 01:00:23 info nikola[]: (v43) Session init took 0.796957 seconds
2019-01-01 01:00:23 info nikola[]: (v43) Records parsed: 66
2019-01-01 01:00:23 info nikola[]: (v43) Records after filtering: 52
2019-01-01 01:00:23 info nikola[]: (v43) Records filtering took 0.011473 seconds
2019-01-01 01:00:23 info nikola[]: (v43) {'msg': 'Data were inserted into work queue.'}
2019-01-01 01:00:23 info nikola[]: (v43) Sending records took 0.309069 seconds
2019-01-01 01:01:01 info /usr/sbin/cron[6876]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-01 01:01:07 err server_uplink[]: Failed to get registration code
2019-01-01 01:02:01 info /usr/sbin/cron[6912]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-01 01:02:01 info /usr/sbin/cron[6913]: (root) CMD (nethist_stats.lua)
2019-01-01 01:02:08 err turris-firewall-rules[]: (v63) Failed to download https://api.turris.cz/firewall/turris-ipsets.gz.sign
2019-01-01 02:00:01 info /usr/sbin/cron[10666]: (root) CMD (netmetr --autostart --dwlhist --rwait 1800 &)
2019-01-01 02:00:01 err server_uplink[]: Failed to download contract status
2019-01-01 02:00:02 info nikola[]: (v43) recognized WAN interfaces: eth1, lo
2019-01-01 02:00:08 err nikola[]: (v43) Exception thrown: failed to initialize crypto library
2019-01-01 02:00:08 err nikola[]: (v43) Exception traceback: [<FrameSummary file /usr/lib/python3.6/site-packages/nikola/__main__.py, line 186 in main>, <FrameSummary file /usr/lib/python3.6/site-packages/nikola/rpc_wrapper.py, line 30 in __init__>]
2019-01-01 02:00:56 info ucollect[12684]: Started task Ping as PID 10824 and fd 26
2019-01-01 02:01:01 info /usr/sbin/cron[10840]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-01 02:01:25 info ucollect[12684]: Finished task Ping, success 1
2019-01-01 02:01:25 warning ucollect[12684]: epoll_wait on 4 interrupted, retry
2019-01-01 02:02:01 err server_uplink[]: Failed to get registration code
#4
Následující chybu:
Vyřeší tohle:
Váš poslední příspěvek se balíčku Netdata nijak netýká.
