Po upgradu routeru Turris Omnia se nelze dostat do webového rozhraní. Učinil jsem i nutný restart, bez kterého nefungovalo připojení přes Wi-Fi. Na mail mi přišlo
Restart is needed
Your network settings will be automatically migrated on next reboot, please refrain from changes in the configuration until then.
The system was updated, but some changes will take effect only after reboot. Please reboot the device.
The device will be restarted automatically on Thursday, October 20 at 06:00 AM CEST.
Error notifications
Updater failed: Failed operations:
fix-omnia-leds-migrate/postinst: Command failed: Not found
/usr/libexec/rainbow/led_activity.sh: line 165: /sys/class/leds/rgb:wan/trigger: No such file or directory
grep: /sys/class/leds/rgb:wan/trigger: No such file or directory
Warning: activity setup failed for: wan
/usr/libexec/rainbow/led_activity.sh: line 165: /sys/class/leds/rgb:wlan-1/trigger: No such file or directory
grep: /sys/class/leds/rgb:wlan-1/trigger: No such file or directory
Warning: activity setup failed for: wlan-1
/usr/libexec/rainbow/led_activity.sh: line 165: /sys/class/leds/rgb:wlan-2/trigger: No such file or directory
grep: /sys/class/leds/rgb:wlan-2/trigger: No such file or directory
Warning: activity setup failed for: wlan-2
privoxy/preinst: [31;1mDIE [0m:Failed to exec /usr/lib/opkg/info//privoxy.preinst: Exec format error
