the LED’s light up and flash. but I can’t get the unit to communicate with me, So I connected to the seial port and got this output, I have tried medkits, but they din’t change a thing.
BootROM - 1.73
Booting from SPI flash
U-Boot SPL 2022.10-rc4-OpenWrt-r16653+119-44ce70f0e2 (Sep 15 2022 - 18:21:35 +0000)
High speed PHY - Version: 2.0
MiniPCIe/mSATA card detection… mSATA
WWAN slot configuration… PCIe+USB2.0
Detected Device ID 6820
board SerDes lanes topology details:
| Lane # | Speed | Type |
| 0 | 6 | SATA0 |
| 1 | 5 | USB3 HOST0 |
| 2 | 5 | PCIe1 |
| 3 | 5 | USB3 HOST1 |
| 4 | 5 | PCIe2 |
| 5 | 0 | SGMII2 |
mv_ddr: 14.0.0
DDR3 Training Sequence - Switching XBAR Window to FastPath Window
mv_ddr: completed successfully
Trying to boot from SPI
U-Boot 2022.10-rc4-OpenWrt-r16653+119-44ce70f0e2 (Sep 15 2022 - 18:21:35 +0000)
SoC: MV88F6820-A0 at 1600 MHz
DRAM: 2 GiB (800 MHz, 32-bit, 2T, ECC not enabled)
Core: 72 devices, 26 uclasses, devicetree: separate
WDT: Started watchdog@20300 with servicing (60s timeout)
MMC: mv_sdh: 0
Loading Environment from SPIFlash… SF: Detected s25fl164k with page size 256 Bytes, erase size 4 KiB, total 8 MiB
OK
Model: Turris Omnia
MCU type: STM32
MCU version: b5a8a24e007eb72be16aeb3fff6f03ec647023e4/67eddc9540526d0a9d9660f7a7867af9a28a68d6
RAM size: 2048 MiB
Serial Number: 0000000E40001FA9
Disabling MCU watchdog… disabled
Regdomain set to **
pcie1.0: Link up
pcie2.0: Link up
Net: eth0: ethernet@70000, eth1: ethernet@30000, eth2: ethernet@34000
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1…
Found U-Boot script /boot.scr
1199 bytes read in 87 ms (12.7 KiB/s)
Executing script at 01800000
gpio: pin gpio@71_4 (gpio 68) value is 1
21434 bytes read in 103 ms (203.1 KiB/s)
4283112 bytes read in 347 ms (11.8 MiB/s)
Kernel image @ 0x1000000 [ 0x000000 - 0x415ae8 ]
Flattened Device Tree blob at 02000000
Booting using the fdt blob at 0x2000000
Loading Device Tree to 0fff7000, end 0ffff3b9 … OK
Starting kernel …
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.15.148 (packaging@turris.cz) (arm-openwrt-linux-muslgnueabi-gcc (OpenWrt GCC 11.2.0 r20316+125-7b8ccbd37c) 11.2.0, GNU ld (GNU Binutils) 2.37) #0 SMP Thu Jul 4 01:39:07 2024
[ 0.000000] CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Turris Omnia
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000000000000-0x000000002fffffff]
[ 0.000000] HighMem [mem 0x0000000030000000-0x000000007fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000007fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000007fffffff]
[ 0.000000] percpu: Embedded 11 pages/cpu s14988 r8192 d21876 u45056
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 522560
[ 0.000000] Kernel command line: earlyprintk rootwait console=ttyS0,115200 rootfstype=btrfs root=PARTUUID=00000000-01 rootflags=commit=5,subvol=@ rw cfg80211.freg=**
[ 0.000000] Bootloader command line not present
[ 0.000000] Unknown kernel command line parameters “earlyprintk mangled_fs=btrfs”, will be passed to user space.
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 2062464K/2097152K available (10240K kernel code, 672K rwdata, 2192K rodata, 1024K init, 258K bss, 34688K reserved, 0K cma-reserved, 1310720K highmem)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] Registering MPIC SoC Error Interrupt Controller
[ 0.000000] L2C: DT/platform modifies aux control register: 0x06070000 → 0x16070000
[ 0.000000] L2C-310 enabling early BRESP for Cortex-A9
[ 0.000000] L2C-310 full line of zeros enabled for Cortex-A9
[ 0.000000] L2C-310 D prefetch enabled, offset 1 lines
[ 0.000000] L2C-310 dynamic clock gating enabled, standby mode enabled
[ 0.000000] L2C-310 Coherent cache controller enabled, 16 ways, 1024 kB
[ 0.000000] L2C-310 Coherent: CACHE_ID 0x410054c9, AUX_CTRL 0x56070001
[ 0.000001] sched_clock: 64 bits at 800MHz, resolution 1ns, wraps every 4398046511103ns
[ 0.000017] clocksource: arm_global_timer: mask: 0xffffffffffffffff max_cycles: 0xb881274fa3, max_idle_ns: 440795210636 ns
[ 0.000034] Switching to timer-based delay loop, resolution 1ns
[ 0.000175] Ignoring duplicate/late registration of read_current_timer delay
[ 0.000181] clocksource: armada_370_xp_clocksource: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 76450417870 ns
[ 0.000366] Console: colour dummy device 80x30
[ 0.000393] Calibrating delay loop (skipped), value calculated using timer frequency… 1600.00 BogoMIPS (lpj=8000000)
[ 0.000402] CPU: Testing write buffer coherency: ok
[ 0.000420] CPU0: Spectre v2: using BPIALL workaround
[ 0.000425] pid_max: default: 32768 minimum: 301
[ 0.000508] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.000517] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.000984] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.001289] Setting up static identity map for 0x100000 - 0x100060
[ 0.001370] mvebu-soc-id: MVEBU SoC ID=0x6820, Rev=0x4
[ 0.001456] mvebu-pmsu: Initializing Power Management Service Unit
[ 0.001517] rcu: Hierarchical SRCU implementation.
[ 0.001595] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[ 0.001658] smp: Bringing up secondary CPUs …
[ 0.001827] Booting CPU 1
[ 0.001956] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.001962] CPU1: Spectre v2: using BPIALL workaround
[ 0.002017] smp: Brought up 1 node, 2 CPUs
[ 0.002024] SMP: Total of 2 processors activated (3200.00 BogoMIPS).
[ 0.002029] CPU: All CPU(s) started in SVC mode.
[ 0.002370] devtmpfs: initialized
[ 0.004281] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[ 0.004334] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.004345] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.004417] pinctrl core: initialized pinctrl subsystem
[ 0.004950] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.005470] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.005932] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.006068] cpuidle: using governor ladder
[ 0.006158] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
[ 0.006164] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.006286] mvebu-pmsu: CPU hotplug support is currently broken on Armada 38x: disabling
[ 0.006293] mvebu-pmsu: CPU idle is currently broken on Armada 38x: disabling
[ 0.014651] cryptd: max_cpu_qlen set to 1000
[ 0.015468] raid6: skip pq benchmark and using algorithm neonx8
[ 0.015477] raid6: using neon recovery algorithm
[ 0.015738] SCSI subsystem initialized
[ 0.015908] usbcore: registered new interface driver usbfs
[ 0.015930] usbcore: registered new interface driver hub
[ 0.015947] usbcore: registered new device driver usb
[ 0.016560] clocksource: Switched to clocksource arm_global_timer
[ 0.018802] NET: Registered PF_INET protocol family
[ 0.018908] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.019405] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[ 0.019422] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.019431] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.019469] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.019531] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.019577] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.019607] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.019712] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.019731] PCI: CLS 0 bytes, default 64
[ 0.020230] hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
[ 0.022124] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[ 0.024106] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.024113] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.024539] xor: measuring software checksum speed
[ 0.028372] arm4regs : 2598 MB/sec
[ 0.033494] 8regs : 1922 MB/sec
[ 0.038629] 32regs : 1917 MB/sec
[ 0.043653] neon : 1958 MB/sec
[ 0.043656] xor: using function: arm4regs (2598 MB/sec)
[ 0.043699] bounce: pool size: 64 pages
[ 0.043729] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 0.044811] armada-38x-pinctrl f1018000.pinctrl: registered pinctrl driver
[ 0.045340] debugfs: Directory ‘f1018100.gpio’ with parent ‘regmap’ already present!
[ 0.045631] debugfs: Directory ‘f1018140.gpio’ with parent ‘regmap’ already present!
[ 0.045950] mvebu-pcie soc:pcie: host bridge /soc/pcie ranges:
[ 0.045979] mvebu-pcie soc:pcie: MEM 0x00f1080000…0x00f1081fff → 0x0000080000
[ 0.045998] mvebu-pcie soc:pcie: MEM 0x00f1040000…0x00f1041fff → 0x0000040000
[ 0.046011] mvebu-pcie soc:pcie: MEM 0x00f1044000…0x00f1045fff → 0x0000044000
[ 0.046023] mvebu-pcie soc:pcie: MEM 0x00f1048000…0x00f1049fff → 0x0000048000
[ 0.046035] mvebu-pcie soc:pcie: MEM 0xffffffffffffffff…0x00fffffffe → 0x0100000000
[ 0.046047] mvebu-pcie soc:pcie: IO 0xffffffffffffffff…0x00fffffffe → 0x0100000000
[ 0.046059] mvebu-pcie soc:pcie: MEM 0xffffffffffffffff…0x00fffffffe → 0x0200000000
[ 0.046070] mvebu-pcie soc:pcie: IO 0xffffffffffffffff…0x00fffffffe → 0x0200000000
[ 0.046081] mvebu-pcie soc:pcie: MEM 0xffffffffffffffff…0x00fffffffe → 0x0300000000
[ 0.046092] mvebu-pcie soc:pcie: IO 0xffffffffffffffff…0x00fffffffe → 0x0300000000
[ 0.046103] mvebu-pcie soc:pcie: MEM 0xffffffffffffffff…0x00fffffffe → 0x0400000000
[ 0.046112] mvebu-pcie soc:pcie: IO 0xffffffffffffffff…0x00fffffffe → 0x0400000000
[ 0.046198] mvebu-pcie soc:pcie: pcie1.0: Slot power limit 10.0W
[ 0.046252] mvebu-pcie soc:pcie: pcie2.0: Slot power limit 10.0W
[ 0.047060] mvebu-pcie soc:pcie: PCI host bridge to bus 0000:00
[ 0.047072] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.047082] pci_bus 0000:00: root bus resource [mem 0xf1080000-0xf1081fff] (bus address [0x00080000-0x00081fff])
[ 0.047089] pci_bus 0000:00: root bus resource [mem 0xf1040000-0xf1041fff] (bus address [0x00040000-0x00041fff])
[ 0.047096] pci_bus 0000:00: root bus resource [mem 0xf1044000-0xf1045fff] (bus address [0x00044000-0x00045fff])
[ 0.047108] pci_bus 0000:00: root bus resource [mem 0xf1048000-0xf1049fff] (bus address [0x00048000-0x00049fff])
[ 0.047114] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xe7ffffff]
[ 0.047119] pci_bus 0000:00: root bus resource [io 0x1000-0xeffff]
[ 0.047215] pci 0000:00:02.0: [11ab:6820] type 01 class 0x060400
[ 0.047369] pci 0000:00:03.0: [11ab:6820] type 01 class 0x060400
[ 0.048205] PCI: bus0: Fast back to back transfers disabled
[ 0.048213] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.048224] pci 0000:00:03.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.048302] pci 0000:01:00.0: [168c:002e] type 00 class 0x028000
[ 0.048325] pci 0000:01:00.0: reg 0x10: [mem 0xc0000000-0xc000ffff 64bit]
[ 0.048424] pci 0000:01:00.0: supports D1
[ 0.048430] pci 0000:01:00.0: PME# supported from D0 D1 D3hot
[ 0.049317] PCI: bus1: Fast back to back transfers disabled
[ 0.049325] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 0.049396] pci 0000:02:00.0: [168c:003c] type 00 class 0x028000
[ 0.049418] pci 0000:02:00.0: reg 0x10: [mem 0xc8000000-0xc81fffff 64bit]
[ 0.049449] pci 0000:02:00.0: reg 0x30: [mem 0xc8200000-0xc820ffff pref]
[ 0.049517] pci 0000:02:00.0: supports D1 D2
[ 0.050397] PCI: bus2: Fast back to back transfers disabled
[ 0.050404] pci_bus 0000:02: busn_res: [bus 02-ff] end is updated to 02
[ 0.050427] pci 0000:00:02.0: BAR 8: assigned [mem 0xe0000000-0xe03fffff]
[ 0.050437] pci 0000:00:03.0: BAR 8: assigned [mem 0xe0400000-0xe07fffff]
[ 0.050444] pci 0000:00:02.0: BAR 7: assigned [io 0x10000-0x10fff]
[ 0.050450] pci 0000:00:03.0: BAR 7: assigned [io 0x20000-0x20fff]
[ 0.050458] pci 0000:01:00.0: BAR 0: assigned [mem 0xe0000000-0xe000ffff 64bit]
[ 0.050470] pci 0000:00:02.0: PCI bridge to [bus 01]
[ 0.050476] pci 0000:00:02.0: bridge window [io 0x10000-0x10fff]
[ 0.050486] pci 0000:00:02.0: bridge window [mem 0xe0000000-0xe03fffff]
[ 0.050498] pci 0000:02:00.0: BAR 0: assigned [mem 0xe0400000-0xe05fffff 64bit]
[ 0.050510] pci 0000:02:00.0: BAR 6: assigned [mem 0xe0600000-0xe060ffff pref]
[ 0.050516] pci 0000:00:03.0: PCI bridge to [bus 02]
[ 0.050521] pci 0000:00:03.0: bridge window [io 0x20000-0x20fff]
[ 0.050530] pci 0000:00:03.0: bridge window [mem 0xe0400000-0xe07fffff]
[ 0.050591] pcieport 0000:00:02.0: enabling device (0140 → 0143)
[ 0.050650] pcieport 0000:00:02.0: pciehp: Slot #2 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise- Interlock- NoCompl+ IbPresDis- LLActRep+
[ 0.050932] pcieport 0000:00:03.0: enabling device (0140 → 0143)
[ 0.050988] pcieport 0000:00:03.0: pciehp: Slot #3 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise- Interlock- NoCompl+ IbPresDis- LLActRep+
[ 0.051563] mv_xor f1060800.xor: Marvell shared XOR driver
[ 0.066559] mvebu-pcie soc:pcie: pcie2.0: link up
[ 0.066582] mvebu-pcie soc:pcie: pcie1.0: link up
[ 0.106948] mv_xor f1060800.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
[ 0.107099] mv_xor f1060900.xor: Marvell shared XOR driver
[ 0.166934] mv_xor f1060900.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
[ 0.167206] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[ 0.168310] printk: console [ttyS0] disabled
[ 0.188410] f1012000.serial: ttyS0 at MMIO 0xf1012000 (irq = 30, base_baud = 15625000) is a 16550A
[ 1.351584] printk: console [ttyS0] enabled
[ 1.376250] f1012100.serial: ttyS1 at MMIO 0xf1012100 (irq = 31, base_baud = 15625000) is a 16550A
[ 1.387513] loop: module loaded
[ 1.390674] Loading iSCSI transport class v2.0-870.
[ 1.396814] ahci-mvebu f10a8000.sata: supply ahci not found, using dummy regulator
[ 1.404479] ahci-mvebu f10a8000.sata: supply phy not found, using dummy regulator
[ 1.412011] ahci-mvebu f10a8000.sata: supply target not found, using dummy regulator
[ 1.419845] ahci-mvebu f10a8000.sata: AHCI 0001.0000 32 slots 2 ports 6 Gbps 0x3 impl platform mode
[ 1.428923] ahci-mvebu f10a8000.sata: flags: 64bit ncq sntf led only pmp fbs pio slum part sxs
[ 1.438234] scsi host0: ahci-mvebu
[ 1.441929] scsi host1: ahci-mvebu
[ 1.445421] ata1: SATA max UDMA/133 mmio [mem 0xf10a8000-0xf10a9fff] port 0x100 irq 53
[ 1.453380] ata2: SATA max UDMA/133 mmio [mem 0xf10a8000-0xf10a9fff] port 0x180 irq 53
[ 1.462335] spi-nor spi0.0: s25fl164k (8192 Kbytes)
[ 1.467373] 3 fixed-partitions partitions found on MTD device spi0.0
[ 1.473746] Creating 3 MTD partitions on “spi0.0”:
[ 1.478579] 0x000000000000-0x0000000f0000 : “U-Boot”
[ 1.483827] 0x000000100000-0x000000800000 : “Rescue system”
[ 1.489651] 0x0000000f0000-0x000000100000 : “u-boot-env”
[ 1.497815] hwmon hwmon0: temp1_input not attached to any thermal zone
[ 1.504971] mv88e6085 f1072004.mdio-mii:10: switch 0x1760 detected: Marvell 88E6176, revision 1
[ 1.529837] hwmon hwmon1: temp1_input not attached to any thermal zone
[ 1.546795] hwmon hwmon2: temp1_input not attached to any thermal zone
[ 1.560961] hwmon hwmon3: temp1_input not attached to any thermal zone
[ 1.577789] hwmon hwmon4: temp1_input not attached to any thermal zone
[ 1.596834] hwmon hwmon5: temp1_input not attached to any thermal zone
[ 1.732320] mvneta_bm f10c8000.bm: Buffer Manager for network controller enabled
[ 1.741320] mvneta f1070000.ethernet eth0: Using device tree mac address d8:58:d7:01:44:c6
[ 1.750879] mvneta f1030000.ethernet eth1: Using device tree mac address d8:58:d7:01:44:c4
[ 1.760419] mvneta f1034000.ethernet eth2: Using device tree mac address d8:58:d7:01:44:c5
[ 1.768850] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.775397] ehci-pci: EHCI PCI platform driver
[ 1.779893] ehci-platform: EHCI generic platform driver
[ 1.785209] ehci-orion: EHCI orion driver
[ 1.789327] orion-ehci f1058000.usb: EHCI Host Controller
[ 1.792892] ata2: SATA link down (SStatus 0 SControl 300)
[ 1.794749] orion-ehci f1058000.usb: new USB bus registered, assigned bus number 1
[ 1.807791] orion-ehci f1058000.usb: irq 49, io mem 0xf1058000
[ 1.836567] orion-ehci f1058000.usb: USB 2.0 started, EHCI 1.00
[ 1.842799] hub 1-0:1.0: USB hub found
[ 1.846590] hub 1-0:1.0: 1 port detected
[ 1.850947] xhci-hcd f10f0000.usb3: xHCI Host Controller
[ 1.856282] xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 2
[ 1.863854] xhci-hcd f10f0000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x0000000000010010
[ 1.873127] xhci-hcd f10f0000.usb3: irq 55, io mem 0xf10f0000
[ 1.878968] xhci-hcd f10f0000.usb3: xHCI Host Controller
[ 1.884297] xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 3
[ 1.891843] xhci-hcd f10f0000.usb3: Host supports USB 3.0 SuperSpeed
[ 1.898472] hub 2-0:1.0: USB hub found
[ 1.902247] hub 2-0:1.0: 1 port detected
[ 1.906313] usb usb3: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.914646] hub 3-0:1.0: USB hub found
[ 1.918428] hub 3-0:1.0: 1 port detected
[ 1.922548] xhci-hcd f10f8000.usb3: xHCI Host Controller
[ 1.927894] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 4
[ 1.935461] xhci-hcd f10f8000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x0000000000010010
[ 1.944734] xhci-hcd f10f8000.usb3: irq 56, io mem 0xf10f8000
[ 1.950569] xhci-hcd f10f8000.usb3: xHCI Host Controller
[ 1.955898] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 5
[ 1.963426] xhci-hcd f10f8000.usb3: Host supports USB 3.0 SuperSpeed
[ 1.970035] hub 4-0:1.0: USB hub found
[ 1.973807] hub 4-0:1.0: 1 port detected
[ 1.976577] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.977873] usb usb5: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.992259] hub 5-0:1.0: USB hub found
[ 1.996034] ata1.00: ATA-9: Dogfish SSD 512GB, U0330A0, max UDMA/133
[ 1.996040] hub 5-0:1.0: 1 port detected
[ 2.002420] ata1.00: 1000215216 sectors, multi 1: LBA48 NCQ (depth 32)
[ 2.006547] usbcore: registered new interface driver usb-storage
[ 2.019436] armada38x-rtc f10a3800.rtc: registered as rtc0
[ 2.025013] armada38x-rtc f10a3800.rtc: setting system clock to 2024-07-07T00:43:42 UTC (1720313022)
[ 2.034193] ata1.00: configured for UDMA/133
[ 2.034330] i2c_dev: i2c /dev entries driver
[ 2.038821] scsi 0:0:0:0: Direct-Access ATA Dogfish SSD 512G 0A0 PQ: 0 ANSI: 5
[ 2.045063] orion_wdt: Initial timeout 171 sec
[ 2.051852] sd 0:0:0:0: [sda] 1000215216 512-byte logical blocks: (512 GB/477 GiB)
[ 2.055584] sdhci: Secure Digital Host Controller Interface driver
[ 2.064032] sd 0:0:0:0: [sda] Write Protect is off
[ 2.069150] sdhci: Copyright(c) Pierre Ossman
[ 2.069266] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.079288] marvell-cesa f1090000.crypto: CESA device successfully registered
[ 2.085195] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 2.100822] NET: Registered PF_INET6 protocol family
[ 2.106238] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 2.112121] Segment Routing with IPv6
[ 2.115815] In-situ OAM (IOAM) with IPv6
[ 2.119800] NET: Registered PF_PACKET protocol family
[ 2.124892] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 2.138049] 8021q: 802.1Q VLAN Support v1.8
[ 2.142327] Registering SWP/SWPB emulation handler
[ 2.149449] Btrfs loaded, crc32c=crc32c-generic, zoned=no, fsverity=no
[ 2.157387] mv88e6085 f1072004.mdio-mii:10: switch 0x1760 detected: Marvell 88E6176, revision 1
[ 2.166940] mmc0: SDHCI controller on f10d8000.sdhci [f10d8000.sdhci] using ADMA
[ 2.189979] hwmon hwmon2: temp1_input not attached to any thermal zone
[ 2.214745] hwmon hwmon3: temp1_input not attached to any thermal zone
[ 2.231584] hwmon hwmon4: temp1_input not attached to any thermal zone
[ 2.248439] hwmon hwmon5: temp1_input not attached to any thermal zone
[ 2.257463] mmc0: new high speed MMC card at address 0001
[ 2.263162] mmcblk0: mmc0:0001 008G30 7.28 GiB
[ 2.269009] mmcblk0: p1
[ 2.271824] mmcblk0boot0: mmc0:0001 008G30 4.00 MiB
[ 2.275608] hwmon hwmon6: temp1_input not attached to any thermal zone
[ 2.277135] mmcblk0boot1: mmc0:0001 008G30 4.00 MiB
[ 2.288689] mmcblk0rpmb: mmc0:0001 008G30 4.00 MiB, chardev (247:0)
[ 2.296657] usb 3-1: new SuperSpeed USB device number 2 using xhci-hcd
[ 2.327701] usb-storage 3-1:1.0: USB Mass Storage device detected
[ 2.334039] scsi host2: usb-storage 3-1:1.0
[ 3.175962] mv88e6085 f1072004.mdio-mii:10: configuring for fixed/rgmii-id link mode
[ 3.185870] mv88e6085 f1072004.mdio-mii:10: configuring for fixed/rgmii-id link mode
[ 3.195276] mv88e6085 f1072004.mdio-mii:10: Link is Up - 1Gbps/Full - flow control off
[ 3.205067] mv88e6085 f1072004.mdio-mii:10: Link is Up - 1Gbps/Full - flow control off
[ 3.297955] mv88e6085 f1072004.mdio-mii:10 lan0 (uninitialized): PHY [mv88e6xxx-1:00] driver [Marvell 88E1540] (irq=76)
[ 3.367273] scsi 2:0:0:0: Direct-Access SanDisk Ultra Fit 1.00 PQ: 0 ANSI: 6
[ 3.375934] sd 2:0:0:0: [sdb] 30031250 512-byte logical blocks: (15.4 GB/14.3 GiB)
[ 3.384769] sd 2:0:0:0: [sdb] Write Protect is off
[ 3.389841] sd 2:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn’t support DPO or FUA
[ 3.405252] sdb: sdb1
[ 3.408514] sd 2:0:0:0: [sdb] Attached SCSI removable disk
[ 3.425529] mv88e6085 f1072004.mdio-mii:10 lan1 (uninitialized): PHY [mv88e6xxx-1:01] driver [Marvell 88E1540] (irq=77)
[ 3.547956] mv88e6085 f1072004.mdio-mii:10 lan2 (uninitialized): PHY [mv88e6xxx-1:02] driver [Marvell 88E1540] (irq=78)
[ 3.678841] mv88e6085 f1072004.mdio-mii:10 lan3 (uninitialized): PHY [mv88e6xxx-1:03] driver [Marvell 88E1540] (irq=79)
[ 3.788844] mv88e6085 f1072004.mdio-mii:10 lan4 (uninitialized): PHY [mv88e6xxx-1:04] driver [Marvell 88E1540] (irq=80)
[ 3.804797] DSA: tree 0 setup
[ 3.809951] squashfs: Unknown parameter ‘commit’
[ 3.815619] F2FS-fs (mmcblk0p1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
[ 3.822876] F2FS-fs (mmcblk0p1): Can’t find valid F2FS filesystem in 1th superblock
[ 3.831546] F2FS-fs (mmcblk0p1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
[ 3.838797] F2FS-fs (mmcblk0p1): Can’t find valid F2FS filesystem in 2th superblock
[ 3.847463] BTRFS: device fsid abf68c92-1522-40e4-b789-9d1a42e30e95 devid 1 transid 267 /dev/root scanned by swapper/0 (1)
[ 3.859822] BTRFS info (device mmcblk0p1): using crc32c (crc32c-generic) checksum algorithm
[ 3.868245] BTRFS info (device mmcblk0p1): disk space caching is enabled
[ 3.874963] BTRFS info (device mmcblk0p1): has skinny extents
[ 3.890170] BTRFS info (device mmcblk0p1): enabling ssd optimizations
[ 3.901523] VFS: Mounted root (btrfs filesystem) on device 0:14.
[ 3.908986] devtmpfs: mounted
[ 3.912525] Freeing unused kernel image (initmem) memory: 1024K
[ 3.956729] Run /sbin/init as init process
[ 3.999993] init: Console is alive
[ 4.003513] init: - watchdog -
[ 4.210960] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[ 4.232476] SGI XFS with ACLs, security attributes, no debug enabled
[ 4.240322] fsl-ehci: Freescale EHCI Host controller driver
[ 4.249202] usbcore: registered new interface driver uas
[ 4.254674] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[ 4.264733] init: - preinit -
Press the [1], [2], [3] or [4] key and hit [enter] to select the debug level
rm: can’t remove ‘/tmp/tmp.kILcjb’: No such file or directory
[ 6.386527] mount_root: mounting /dev/root
[ 6.413193] urandom-seed: Seeding with /etc/urandom.seed
Scanning for Btrfs filesystems
registered: /dev[ 6.876158] BTRFS info: devid 1 device path /dev/root changed to /dev/mmcblk0p1 scanned by btrfs (722)
/sda
registered[ 6.886888] BTRFS: device label srv devid 1 transid 186310 /dev/sda scanned by btrfs (722)
: /dev/mmcblk0p1
[ 6.899086] procd: - early -
[ 6.902026] procd: - watchdog -
[ 7.437743] procd: - watchdog -
[ 7.441100] procd: - ubus -
[ 7.449124] random: ubusd: uninitialized urandom read (4 bytes read)
[ 7.494150] random: ubusd: uninitialized urandom read (4 bytes read)
[ 7.500655] random: ubusd: uninitialized urandom read (4 bytes read)
[ 7.507733] procd: - init -
Please press Enter to activate this console.
[ 7.872796] kmodloader: loading kernel modules from /etc/modules.d/*
[ 7.948397] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 7.981727] turris-omnia-mcu 1-002a: MCU type STM32
[ 7.988965] turris-omnia-mcu 1-002a: MCU bootloader firmware version hash: b5a8a24e007eb72be16aeb3fff6f03ec647023e4
[ 8.002590] turris-omnia-mcu 1-002a: MCU application firmware version hash: 67eddc9540526d0a9d9660f7a7867af9a28a68d6
[ 8.019858] turris-omnia-mcu 1-002a: registered as rtc1
[ 8.057599] i2c i2c-0: Added multiplexed i2c bus 1
[ 8.062710] i2c i2c-0: Added multiplexed i2c bus 2
[ 8.072843] i2c i2c-0: Added multiplexed i2c bus 3
[ 8.080280] i2c i2c-0: Added multiplexed i2c bus 4
[ 8.085391] i2c i2c-0: Added multiplexed i2c bus 5
[ 8.092616] i2c i2c-0: Added multiplexed i2c bus 6
[ 8.099800] i2c i2c-0: Added multiplexed i2c bus 7
[ 8.105141] pca953x 8-0071: supply vcc not found, using dummy regulator
[ 8.111933] pca953x 8-0071: using no AI
[ 8.122740] i2c i2c-0: Added multiplexed i2c bus 8
[ 8.127599] pca954x 0-0070: registered 8 multiplexed busses for I2C mux pca9547
[ 8.137124] GACT probability on
[ 8.141369] Mirror/redirect action on
[ 8.148456] u32 classifier
[ 8.151176] input device check on
[ 8.154845] Actions configured
[ 8.164349] at24 1-0054: supply vcc not found, using dummy regulator
[ 8.175645] at24 1-0054: 8192 byte 24c64 EEPROM, writable, 1 bytes/write
[ 8.183245] Bridge firewalling registered
[ 8.185514] random: crng init done
[ 8.187794] Loading modules backported from Linux version v5.15.153-0-g9465fef4ae351
[ 8.190710] random: 21 urandom warning(s) missed due to ratelimiting
[ 8.198489] Backport generated by backports.git v5.15.153-1-0-g7e70bbef
[ 8.207708] usbcore: registered new interface driver ums-alauda
[ 8.218006] usbcore: registered new interface driver ums-cypress
[ 8.224396] usbcore: registered new interface driver ums-datafab
[ 8.234668] usbcore: registered new interface driver ums-freecom
[ 8.241081] usbcore: registered new interface driver ums-isd200
[ 8.247406] usbcore: registered new interface driver ums-jumpshot
[ 8.253847] usbcore: registered new interface driver ums-karma
[ 8.263896] usbcore: registered new interface driver ums-sddr09
[ 8.270221] usbcore: registered new interface driver ums-sddr55
[ 8.276532] usbcore: registered new interface driver ums-usbat
[ 8.283342] usbcore: registered new interface driver usbserial_generic
[ 8.289936] usbserial: USB Serial support registered for generic
[ 8.305065] xt_time: kernel timezone is -0000
[ 8.341159] PPP generic driver version 2.4.2
[ 8.346045] NET: Registered PF_PPPOX protocol family
[ 8.361533] ath10k_pci 0000:02:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
[ 8.628420] ath10k_pci 0000:02:00.0: qca988x hw2.0 target 0x4100016c chip_id 0x043202ff sub 0000:0000
[ 8.637702] ath10k_pci 0000:02:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 0
[ 8.647319] ath10k_pci 0000:02:00.0: firmware ver 10.2.4-1.0-00047 api 5 features no-p2p,raw-mode,mfp,allows-mesh-bcast crc32 35bd9258
[ 8.705654] ath10k_pci 0000:02:00.0: board_file api 1 bmi_id N/A crc32 bebc7c08
[ 9.845071] ath10k_pci 0000:02:00.0: htt-ver 2.1 wmi-op 5 htt-op 2 cal otp max-sta 128 raw 0 hwcrypto 1
[ 9.967838] usbcore: registered new interface driver qcserial
[ 9.973659] usbserial: USB Serial support registered for Qualcomm USB modem
[ 10.084454] ieee80211 phy1: Atheros AR9287 Rev:2 mem=0x5e91cc83, irq=97
[ 10.091541] kmodloader: done loading kernel modules from /etc/modules.d/*
[ 10.174064] BTRFS info (device sda): using crc32c (crc32c-generic) checksum algorithm
[ 10.181992] BTRFS info (device sda): using free space tree
[ 10.187562] BTRFS info (device sda): has skinny extents
[ 10.197507] BTRFS info (device sda): enabling ssd optimizations
[ 10.260238] F2FS-fs (sdb): Magic Mismatch, valid(0xf2f52010) - read(0x0)
[ 10.267002] F2FS-fs (sdb): Can’t find valid F2FS filesystem in 1th superblock
[ 10.275188] F2FS-fs (sdb): Magic Mismatch, valid(0xf2f52010) - read(0x0)
[ 10.281945] F2FS-fs (sdb): Can’t find valid F2FS filesystem in 2th superblock
[ 10.294080] exFAT-fs (sdb): invalid fs_name
[ 10.298308] exFAT-fs (sdb): failed to read boot sector
[ 10.303461] exFAT-fs (sdb): failed to recognize exfat type
[ 12.195089] mvneta f1030000.ethernet eth1: configuring for fixed/rgmii link mode
[ 12.203032] mvneta f1030000.ethernet eth1: Link is Up - 1Gbps/Full - flow control off
[ 12.211183] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[ 12.219889] mv88e6085 f1072004.mdio-mii:10 lan0: configuring for phy/gmii link mode
[ 12.235842] br-lan: port 1(lan0) entered blocking state
[ 12.241127] br-lan: port 1(lan0) entered disabled state
[ 12.291061] device lan0 entered promiscuous mode
[ 12.295702] device eth1 entered promiscuous mode
[ 12.486690] mv88e6085 f1072004.mdio-mii:10 lan1: configuring for phy/gmii link mode
[ 12.501504] br-lan: port 2(lan1) entered blocking state
[ 12.506787] br-lan: port 2(lan1) entered disabled state
[ 12.590004] device lan1 entered promiscuous mode
[ 12.631224] mv88e6085 f1072004.mdio-mii:10 lan2: configuring for phy/gmii link mode
[ 12.723670] br-lan: port 3(lan2) entered blocking state
[ 12.728954] br-lan: port 3(lan2) entered disabled state
[ 12.780574] device lan2 entered promiscuous mode
[ 12.806447] mv88e6085 f1072004.mdio-mii:10 lan3: configuring for phy/gmii link mode
[ 12.878903] br-lan: port 4(lan3) entered blocking state
[ 12.884155] br-lan: port 4(lan3) entered disabled state
[ 12.936216] device lan3 entered promiscuous mode
[ 12.962062] mv88e6085 f1072004.mdio-mii:10 lan4: configuring for phy/gmii link mode
[ 13.026935] br-lan: port 5(lan4) entered blocking state
[ 13.032185] br-lan: port 5(lan4) entered disabled state
[ 13.038451] mv88e6085 f1072004.mdio-mii:10 lan4: Link is Up - 1Gbps/Full - flow control rx/tx
[ 13.091546] device lan4 entered promiscuous mode
[ 13.114126] br-lan: port 5(lan4) entered blocking state
[ 13.119404] br-lan: port 5(lan4) entered forwarding state
[ 13.126013] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
[ 13.207620] mvneta f1034000.ethernet eth2: PHY [f1072004.mdio-mii:01] driver [Marvell 88E1510] (irq=POLL)
[ 13.217418] mvneta f1034000.ethernet eth2: configuring for phy/sgmii link mode
Router Turris successfully started.
BusyBox v1.35.0 (2024-07-04 01:39:07 UTC) built-in shell (ash)
______ _ ____ _____
/_ __/_ ____________(_)____ / __ \/ ___/
/ / / / / / ___/ ___/ / ___/ / / / /\__
/ / / /_/ / / / / / (__ ) / /_/ /___/ /
/_/ \__,_/_/ /_/ /_/____/ \____//____/
TurrisOS 7.0.1, Turris Omnia
root@turris:/#
