I can see on the device via tcpdump (with tcpdump -i eth0 -vv src 192.168.2.21 and igmp -n) the IGMPv2 report packets to join the group:
09:22:21.516913 IP (tos 0xc0, ttl 1, id 0, offset 0, flags [DF], proto IGMP (2), length 32, options (RA))
192.168.2.21 > 239.77.3.6: igmp v2 report 239.77.3.6
However if I listen on the Omnia side with tcpdump -i lan4 -vv src 192.168.2.21 and igmp -n I cannot see any traffic at all. Other traffic like ICMP or TCP is visible as it should.
I think the filter is okay, it works fine in the “client” (the device with IPv4 address 192.168.2.21 wired to lan4) and the versions of tcpdump and libpcap are very similar. Anyway, I gave it a go:
Thanks. libpcap sees inbound traffic before it’s processed by netfilter so it shouldn’t be a firewall issue. It looks like the traffic is dropped by the NIC or the driver.
I can confirm the same problem. I just spent quite a while trying to figure this out and so far without success.
Turris OS version 6.2.4
Kernel version 5.15.94
One thing that I noticed and that may help pinpoint it is that there is some inbound multicast traffic visible on the bridge interface of the router from devices connected via wifi - a laptop and some android phones. But with two desktop machines that are connected over wired connection, no dice.
It appears that something happened with the way the physical ports/switch are configured, or a ethernet device driver or something. One thing that I’m going to try out when I get a bit of time is whether the one extra ethernet port that is connected directly to the CPU instead of over the switch behaves differently. That could help it pinpoint further.
We have 2025 and problem is the same. I got two Turris devices (MOX and Omnia) I see output IGMP packets on MOX but no input IGMP packets on Omnia. I wrote to support and wait for replay.
Thanks for replay.
Unfortunately, firewall rules do not help.
Setting udpxy sounds useless because I cannot change configuration of client device. It is configured by ISP.
I reported issue with dropping IGMP packets to support a moth ago. I dumped logs from both devices but still without response. It looks like IGMP packets is kind of abandoned topic.
I have a good news! I got the answer from the support with the DTB files to replace on my Omina device. After reboot it seams to stop dropping IGMP packets. (TV traffics is working) Support inform me this fixes will be included in future TOS release. I will come back with any updates.
