Hello world,
I have this
root@turris:~# cat /etc/config/network
config interface 'loopback'
option ifname 'lo'
option proto 'static'
option ipaddr '127.0.0.1'
option netmask '255.0.0.0'
config globals 'globals'
option ula_prefix 'fdd0:5769:6ab9::/48'
config interface 'wan'
option proto 'pppoe'
option username '*'
option password '*'
option ipv6 'auto'
option mtu '1492'
option _orig_ifname 'eth1'
option _orig_bridge 'false'
option ifname 'eth1.7'
config switch
option name 'switch0'
option reset '1'
option enable_vlan '1'
config switch_vlan
option device 'switch0'
option vlan '1'
option vid '1'
option ports '5t 6t'
config switch_vlan
option vlan '2'
option vid '2'
option ports '0 5t'
config switch_vlan
option vlan '3'
option vid '3'
option ports '1 5t'
config switch_vlan
option vlan '4'
option vid '4'
option ports '2 3 5t'
config interface 'LANoben'
option ifname 'eth0.2'
option ipaddr '10.10.10.1'
config interface 'Cam'
option ifname 'eth0.3'
option ipaddr '192.168.111.1'
option netmask '255.255.0.0'
config interface 'DMZ'
option ifname 'eth0.4'
option ipaddr '10.111.222.1'
As you can tell, I would like separate zones for seperate vlan on separate ports. Each zone should get an own ip and subnet range and be strongly isolated from each other, the dmz even from among each other. So I wrote this:
root@turris:~# cat /etc/config/dhcp
config dnsmasq
option domainneeded '1'
option boguspriv '1'
option localise_queries '1'
option rebind_protection '1'
option rebind_localhost '1'
option local '/lan/'
option domain 'lan'
option expandhosts '1'
option authoritative '1'
option readethers '1'
option leasefile '/tmp/dhcp.leases'
option resolvfile '/tmp/resolv.conf.auto'
option port '0'
option localservice '1'
option nonwildcard '0'
config dhcp 'lan'
option interface 'lan'
option start '100'
option limit '150'
option leasetime '12h'
option dhcpv6 'server'
option ra 'server'
list dhcp_option '6,192.168.1.1'
config dhcp 'wan'
option interface 'wan'
option ignore '1'
config odhcpd 'odhcpd'
option maindhcp '0'
option leasefile '/tmp/hosts/odhcpd'
option leasetrigger '/usr/sbin/odhcpd-update'
config dhcp 'LANoben'
option limit '150'
option interface 'LANoben'
option start '10'
list dhcp_option '6,10.10.10.1'
option ra 'server'
option ra_management '1'
option force '1'
config dhcp 'Cam'
option start '100'
option interface 'Cam'
option limit '2'
list dhcp_option '6,192.168.111.1'
config dhcp 'DMZ'
option start '100'
option limit '150'
option interface 'DMZ'
option leasetime '1h'
list dhcp_option '6,10.111.222.1'
option force '1'
and this
root@turris:~# cat /etc/config/firewall
config defaults
option syn_flood '1'
option input 'ACCEPT'
option output 'ACCEPT'
option forward 'REJECT'
config zone
option name 'lan'
option network 'lan LANoben'
config zone
option name 'wan'
option masq '1'
option mtu_fix '1'
option network 'wan wan6 wan2'
option input 'DROP'
option forward 'DROP'
config forwarding
option src 'lan'
option dest 'wan'
config rule
option name 'Allow-DHCP-Renew'
option src 'wan'
option proto 'udp'
option dest_port '68'
option target 'ACCEPT'
option family 'ipv4'
config rule
option name 'Allow-Ping'
option src 'wan'
option proto 'icmp'
option icmp_type 'echo-request'
config rule
option name 'Allow-IGMP'
option src 'wan'
option proto 'igmp'
config rule
option name 'Allow-DHCPv6'
option src 'wan'
option proto 'udp'
option src_ip 'fe80::/10'
option src_port '547'
option dest_ip 'fe80::/10'
option dest_port '546'
option family 'ipv6'
config rule
option name 'Allow-MLD'
option src 'wan'
option proto 'icmp'
list icmp_type '130/0'
list icmp_type '131/0'
list icmp_type '132/0'
list icmp_type '143/0'
config rule
option name 'Allow-ICMPv6-Input'
option src 'wan'
option proto 'icmp'
list icmp_type 'echo-request'
list icmp_type 'echo-reply'
list icmp_type 'destination-unreachable'
list icmp_type 'packet-too-big'
list icmp_type 'time-exceeded'
list icmp_type 'bad-header'
list icmp_type 'unknown-header-type'
list icmp_type 'router-solicitation'
list icmp_type 'neighbour-solicitation'
list icmp_type 'router-advertisement'
list icmp_type 'neighbour-advertisement'
option limit '1000/sec'
config rule
option name 'Allow-ICMPv6-Forward'
option src 'wan'
option dest '*'
option proto 'icmp'
config include
option path '/etc/firewall.user'
config include
option path '/usr/share/firewall/turris'
option reload '1'
config include
option path '/etc/firewall.d/with_reload/firewall.include.sh'
option reload '1'
config include
option path '/etc/firewall.d/without_reload/firewall.include.sh'
option reload '0'
config rule
option src 'wan'
option dest 'lan'
option proto 'esp'
config rule
option src 'wan'
option dest 'lan'
option dest_port '500'
option proto 'udp'
config include 'miniupnpd'
option type 'script'
option path '/usr/share/miniupnpd/firewall.include'
option family 'any'
option reload '1'
config rule 'turris_wan_6in4_rule'
option enabled '0'
config zone 'dmz'
option enabled '1'
option name 'dmz'
option input 'REJECT'
option network 'DMZ'
config forwarding 'guest_turris_forward_wan'
option name 'dmz to wan forward'
option dest 'wan'
option enabled '1'
option src 'dmz'
config rule 'guest_turris_dns_rule'
option name 'dmz dns rule'
option proto 'tcpudp'
option dest_port '53'
option enabled '1'
option src 'dmz'
config rule 'guest_turris_dhcp_rule'
option name 'dmz dhcp rule'
option proto 'udp'
option src_port '67-68'
option dest_port '67-68'
option enabled '1'
option src 'dmz'
config redirect 'adblock_dns'
option name 'Adblock DNS'
option src 'lan'
option proto 'tcp udp'
option src_dport '53'
option target 'DNAT'
config zone
option name 'cam'
option network 'Cam'
config forwarding
option dest 'lan'
option src 'cam'
config forwarding
option dest 'wan'
option src 'cam'
config forwarding
option dest 'cam'
option src 'lan'
config forwarding
option dest 'dmz'
option src 'lan'
config redirect
option enabled '1'
option name 'Adblock Guest'
option src 'dmz'
The behaviour I expect is that, depending on the zone a host connects to, they dynamically get a configuration to use the internet. The behaviour I see instead is
- a host known from one zone (and therefore with a dhcp lease) gets the same configuration in a different zone disabling wan access.
- an unknown host connecting to the dmz zone gets a configuration from the lan range and is unable to connect to wan until I manually change it.
Could you point out what I’ve misconfigured or could try reinitializing? Many thanks,
P
