I installed new mSATA SSD. Firstly i tried to use port above SIM card, but then i realized that this is not the right one (previous thread.
Then I inserted into port just next to processor (sucessfully changed screws ,…). And i alse performed factory reset.
But unfortunatelly it is not recognised in Luci. It is necessary another configuration??? Any ideas?
hi!
check the system and/or kernel log for any signs of the ssd
In system log is visible:
016-10-28T23:00:59+02:00 notice syslog-ng[1776]: syslog-ng starting up; version='3.0.9’
2016-10-28T23:00:59+02:00 info kernel[]: [ 6.520631] ata2: SATA link down (SStatus 0 SControl 300)
2016-10-28T23:00:59+02:00 info kernel[]: [ 6.720634] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
2016-10-28T23:00:59+02:00 info kernel[]: [ 6.726921] ata1.00: ATA-9: ADATA SP310, 5.2, max UDMA/133
2016-10-28T23:00:59+02:00 info kernel[]: [ 6.732432] ata1.00: 125045424 sectors, multi 16: LBA48 NCQ (depth 31/32)
2016-10-28T23:00:59+02:00 info kernel[]: [ 6.739367] ata1.00: configured for UDMA/133
2016-10-28T23:00:59+02:00 notice kernel[]: [ 6.743835] scsi 0:0:0:0: Direct-Access ATA ADATA SP310 5.2 PQ: 0 ANSI: 5
2016-10-28T23:00:59+02:00 notice kernel[]: [ 6.752356] sd 0:0:0:0: [sda] 125045424 512-byte logical blocks: (64.0 GB/59.6 GiB)
2016-10-28T23:00:59+02:00 notice kernel[]: [ 6.760136] sd 0:0:0:0: [sda] Write Protect is off
2016-10-28T23:00:59+02:00 debug kernel[]: [ 6.764958] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
2016-10-28T23:00:59+02:00 notice kernel[]: [ 6.765004] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
2016-10-28T21:01:00+02:00 notice netifd[]: radio1 (1744): Configuration file: /var/run/hostapd-phy1.conf
2016-10-28T21:01:00+02:00 notice netifd[]: Bridge ‘br-lan’ link is up
2016-10-28T21:01:00+02:00 notice netifd[]: Interface ‘lan’ has link connectivity
2016-10-28T21:01:00+02:00 notice netifd[]: radio1 (1744): wlan1: interface state UNINITIALIZED->COUNTRY_UPDATE
2016-10-28T21:01:00+02:00 notice netifd[]: radio1 (1744): Using interface wlan1 with hwaddr 04:f0:21:22:dc:1d and ssid "megadroid"
2016-10-28T21:01:00+02:00 notice netifd[]: radio1 (1744): wlan1: interface state COUNTRY_UPDATE->ENABLED
2016-10-28T21:01:00+02:00 notice netifd[]: radio1 (1744): wlan1: AP-ENABLED
2016-10-28T21:01:00+02:00 notice netifd[]: Network device ‘wlan1’ link is up
2016-10-28T21:01:00+02:00 notice netifd[]: radio0 (1743): command failed: Not supported (-95)
2016-10-28T21:01:01+02:00 notice netifd[]: radio0 (1743): Configuration file: /var/run/hostapd-phy0.conf
2016-10-28T23:01:04+02:00 notice kernel[]: [ 6.774880] sd 0:0:0:0: [sda] Attached SCSI removable disk
2016-10-28T23:01:04+02:00 info kernel[]: [ 6.781423] uhci_hcd: USB Universal Host Controller Interface driver
2016-10-28T23:01:04+02:00 info kernel[]: [ 6.788406] orion_wdt: Initial timeout 171 sec
2016-10-28T23:01:04+02:00 info kernel[]: [ 6.796844] xhci-hcd f10f0000.usb3: xHCI Host Controller
2016-10-28T23:01:04+02:00 info kernel[]: [ 6.802212] xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 2
2016-10-28T23:01:04+02:00 info kernel[]: [ 6.809815] xhci-hcd f10f0000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x00010010
2016-10-28T23:01:04+02:00 info kernel[]: [ 6.818395] xhci-hcd f10f0000.usb3: irq 46, io mem 0xf10f0000
2016-10-28T23:01:04+02:00 info kernel[]: [ 6.824427] hub 2-0:1.0: USB hub found
2016-10-28T23:01:04+02:00 info kernel[]: [ 6.828199] hub 2-0:1.0: 1 port detected
2016-10-28T23:01:04+02:00 info kernel[]: [ 6.832246] xhci-hcd f10f0000.usb3: xHCI Host Controller
2016-10-28T21:01:02+02:00 notice netifd[]: Network device ‘eth0’ link is up
2016-10-28T23:01:04+02:00 info kernel[]: [ 6.837575] xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 3
2016-10-28T23:01:04+02:00 info kernel[]: [ 6.845147] usb usb3: We don’t know the algorithms for LPM for this host, disabling LPM.
2016-10-28T23:01:04+02:00 info kernel[]: [ 6.853481] hub 3-0:1.0: USB hub found
2016-10-28T23:01:04+02:00 info kernel[]: [ 6.857252] hub 3-0:1.0: 1 port detected
2016-10-28T23:01:04+02:00 info kernel[]: [ 6.861344] xhci-hcd f10f8000.usb3: xHCI Host Controller
2016-10-28T23:01:04+02:00 info kernel[]: [ 6.866675] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 4
2016-10-28T23:01:04+02:00 info kernel[]: [ 6.874283] xhci-hcd f10f8000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x00010010
2016-10-28T23:01:04+02:00 info kernel[]: [ 6.882859] xhci-hcd f10f8000.usb3: irq 47, io mem 0xf10f8000
2016-10-28T23:01:04+02:00 info kernel[]: [ 6.888848] hub 4-0:1.0: USB hub found
2016-10-28T23:01:04+02:00 info kernel[]: [ 6.892634] hub 4-0:1.0: 1 port detected
2016-10-28T23:01:04+02:00 info kernel[]: [ 6.896658] xhci-hcd f10f8000.usb3: xHCI Host Controller
2016-10-28T23:01:04+02:00 info kernel[]: [ 6.902000] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 5
2016-10-28T23:01:04+02:00 info kernel[]: [ 6.909528] usb usb5: We don’t know the algorithms for LPM for this host, disabling LPM.
2016-10-28T23:01:04+02:00 info kernel[]: [ 6.917858] hub 5-0:1.0: USB hub found
2016-10-28T23:01:04+02:00 info kernel[]: [ 6.921639] hub 5-0:1.0: 1 port detected
2016-10-28T23:01:04+02:00 info kernel[]: [ 6.927021] usbcore: registered new interface driver usb-storage
2016-10-28T23:01:04+02:00 info kernel[]: 7.593264] init: - preinit -
2016-10-28T23:01:04+02:00 notice kernel[]: 10.643963] mount_root: mounting /dev/root
2016-10-28T23:01:04+02:00 info kernel[]: [ 10.648980] BTRFS info (device mmcblk0p1): disk space caching is enabled
2016-10-28T23:01:04+02:00 info kernel[]: 10.656202] mount_root: loading kmods from internal overlay
2016-10-28T23:01:04+02:00 info kernel[]: 10.869881] block: attempting to load /etc/config/fstab
2016-10-28T23:01:04+02:00 warning kernel[]: 10.876073] block: ignoring mount section cfg044d78 due to invalid target 'mnt/msata’
2016-10-28T23:01:04+02:00 info kernel[]: 10.883972] block: extroot: not configured
2016-10-28T23:01:04+02:00 info kernel[]: 10.890499] procd: - early -
2016-10-28T23:01:04+02:00 notice kernel[]: [ 10.996477] random: jshn urandom read with 25 bits of entropy available
2016-10-28T23:01:04+02:00 info kernel[]: 11.463047] procd: - watchdog -
2016-10-28T23:01:04+02:00 info kernel[]: 11.466562] procd: - ubus -
2016-10-28T23:01:04+02:00 info kernel[]: 12.481757] procd: - init -
did you already have a partition table and formated drive to some filesystem? if not start on same place as i did … https://wiki.openwrt.org/doc/howto/storage
for me it was fdisk and mkfs.ext4 commands
