Hi
I buy a Netac NT01N5M-002T-M3X 2TB mSATA drive. But when connected to Turris Omnia, it is not detected correctly and with a volume of 1GB.
root@router:~# lsblk -n -S
sda 0:0:0:0 disk ATA SM59XT2A-10-00K2 0308 sata
root@router:~# fdisk -l
Disk /dev/sda: 1023.75 MiB, 1073479680 bytes, 2096640 sectors
Disk model: SM59XT2A-10-00K2
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
When I try to format via reForis I get an error:
Disk formatting failed, try turning it off and on again.
Technical details: btrfs-progs v5.11
See http://btrfs.wiki.kernel.org for more information.
No valid Btrfs found on /dev/sda
ERROR: open ctree failed
When connected to a Windows computer via a USB adapter, the disk is detected correctly and has a capacity of 1.82TB.
Any ideas? Driver?
I will be grateful for any help.
