Wifi has stopped working on my Mox, it is not seen over the air. At my Omnia, I have noticed that there was an update on June 4 2020.
Forris returning: 503 Service Not Available
I am not able to set SSH password via /cgi-bin/luci/admin/system/admin (getting an error) to try pkgupdate
Foris: 503 - Service Not Available
firmware: TurrisOS 5.0.0 21454a772bd8ccf13923db37a9bf02e48abeb278 / LuCI branch (git-20.016.50400-c59a6f3)
kernel: 4.14.180
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.14.180 (beast@slave10) (gcc version 7.5.0 (OpenWrt GCC 7.5.0 21454a7)) #0 SMP Wed Jun 3 00:57:44 2020
[ 0.000000] Boot CPU: AArch64 Processor [410fd034]
[ 0.000000] Machine model: CZ.NIC Turris Mox Board
[ 0.000000] earlycon: ar3700_uart0 at MMIO 0x00000000d0012000 (options '')
[ 0.000000] bootconsole [ar3700_uart0] enabled
[ 0.000000] On node 0 totalpages: 131072
[ 0.000000] DMA zone: 2048 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 131072 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] random: get_random_bytes called from start_kernel+0x9c/0x490 with crng_init=0
[ 0.000000] percpu: Embedded 16 pages/cpu s26648 r8192 d30696 u65536
[ 0.000000] pcpu-alloc: s26648 r8192 d30696 u65536 alloc=16*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 129024
[ 0.000000] Kernel command line: earlyprintk console=ttyMV0,115200 earlycon=ar3700_uart,0xd0012000 mangled_fs=btrfs root=PARTUUID=00000000-01 rootflags=commit=5,subvol=@ rootwait rw cfg80211.freg=
[ 0.000000] PID hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.000000] Memory: 496516K/524288K available (7294K kernel code, 468K rwdata, 1900K rodata, 320K init, 304K bss, 27772K reserved, 0K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff80087a0000 ( 7296 KB)
[ 0.000000] .rodata : 0xffffff80087a0000 - 0xffffff8008980000 ( 1920 KB)
[ 0.000000] .init : 0xffffff8008980000 - 0xffffff80089d0000 ( 320 KB)
[ 0.000000] .data : 0xffffff80089d0000 - 0xffffff8008a45008 ( 469 KB)
[ 0.000000] .bss : 0xffffff8008a45008 - 0xffffff8008a911b0 ( 305 KB)
[ 0.000000] fixed : 0xffffffbefe7fb000 - 0xffffffbefec00000 ( 4116 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf00800000 ( 8 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc020000000 ( 512 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] CONFIG_RCU_FANOUT set to non-default value of 32
[ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: no VLPI support, no direct LPI support
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000d1d40000
[ 0.000000] arch_timer: cp15 timer(s) running at 12.50MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049cda, max_idle_ns: 440795202628 ns
[ 0.000004] sched_clock: 56 bits at 12MHz, resolution 80ns, wraps every 4398046511080ns
[ 0.008426] Console: colour dummy device 80x25
[ 0.012936] Calibrating delay loop (skipped), value calculated using timer frequency.. 25.00 BogoMIPS (lpj=125000)
[ 0.023585] pid_max: default: 32768 minimum: 301
[ 0.028433] Mount-cache hash table entries: 1024 (order: 1, 8192 bytes)
[ 0.035175] Mountpoint-cache hash table entries: 1024 (order: 1, 8192 bytes)
[ 0.043421] ASID allocator initialised with 32768 entries
[ 0.049002] Hierarchical SRCU implementation.
[ 0.053860] smp: Bringing up secondary CPUs ...
[ 0.058820] Detected VIPT I-cache on CPU1
[ 0.058850] GICv3: CPU1: found redistributor 1 region 0:0x00000000d1d60000
[ 0.058881] CPU1: Booted secondary processor [410fd034]
[ 0.058973] smp: Brought up 1 node, 2 CPUs
[ 0.079680] SMP: Total of 2 processors activated.
[ 0.084527] CPU features: detected: GIC system register CPU interface
[ 0.091148] CPU features: detected: 32-bit EL0 Support
[ 0.096447] CPU: All CPU(s) started at EL2
[ 0.100660] alternatives: patching kernel code
[ 0.105918] devtmpfs: initialized
[ 0.111306] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.121405] futex hash table entries: 512 (order: 4, 65536 bytes)
[ 0.127765] xor: measuring software checksum speed
[ 0.232670] 8regs : 1918.800 MB/sec
[ 0.332706] 8regs_prefetch: 1710.400 MB/sec
[ 0.432743] 32regs : 2358.400 MB/sec
[ 0.532779] 32regs_prefetch: 1984.400 MB/sec
[ 0.537446] xor: using function: 32regs (2358.400 MB/sec)
[ 0.543013] pinctrl core: initialized pinctrl subsystem
[ 0.549130] NET: Registered protocol family 16
[ 0.554832] cpuidle: using governor ladder
[ 0.559109] vdso: 2 pages (1 code @ ffffff80087a5000, 1 data @ ffffff80089d4000)
[ 0.566677] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.573916] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.581401] d0012000.serial: ttyMV0 at MMIO 0xd0012000 (irq = 9, base_baud = 0) is a mvebu-uart
[ 0.590347] console [ttyMV0] enabled
[ 0.597649] bootconsole [ar3700_uart0] disabled
[ 0.787229] raid6: int64x1 gen() 320 MB/s
[ 0.957207] raid6: int64x1 xor() 317 MB/s
[ 1.127320] raid6: int64x2 gen() 519 MB/s
[ 1.297371] raid6: int64x2 xor() 449 MB/s
[ 1.467452] raid6: int64x4 gen() 783 MB/s
[ 1.637551] raid6: int64x4 xor() 550 MB/s
[ 1.807633] raid6: int64x8 gen() 939 MB/s
[ 1.977681] raid6: int64x8 xor() 561 MB/s
[ 2.147763] raid6: neonx1 gen() 594 MB/s
[ 2.317840] raid6: neonx1 xor() 624 MB/s
[ 2.487929] raid6: neonx2 gen() 985 MB/s
[ 2.657974] raid6: neonx2 xor() 943 MB/s
[ 2.828069] raid6: neonx4 gen() 1312 MB/s
[ 2.998128] raid6: neonx4 xor() 1166 MB/s
[ 3.168191] raid6: neonx8 gen() 1296 MB/s
[ 3.338269] raid6: neonx8 xor() 1131 MB/s
[ 3.342501] raid6: using algorithm neonx4 gen() 1312 MB/s
[ 3.347896] raid6: .... xor() 1166 MB/s, rmw enabled
[ 3.353026] raid6: using neon recovery algorithm
[ 3.358802] SCSI subsystem initialized
[ 3.362967] libata version 3.00 loaded.
[ 3.363259] usbcore: registered new interface driver usbfs
[ 3.368995] usbcore: registered new interface driver hub
[ 3.374175] usbcore: registered new device driver usb
[ 3.379962] pxa2xx-i2c d0011000.i2c: could not find pctldev for node /soc/internal-regs@d0000000/pinctrl@13800/i2c1-pins, deferring probe
[ 3.393833] clocksource: Switched to clocksource arch_sys_counter
[ 3.406427] NET: Registered protocol family 2
[ 3.411379] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 3.418560] TCP bind hash table entries: 4096 (order: 4, 65536 bytes)
[ 3.425315] TCP: Hash tables configured (established 4096 bind 4096)
[ 3.431545] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 3.437940] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 3.444210] NET: Registered protocol family 1
[ 3.448490] PCI: CLS 0 bytes, default 128
[ 3.449152] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 3.461505] Crashlog allocated RAM at address 0x3f00000
[ 3.467139] workingset: timestamp_bits=46 max_order=17 bucket_order=0
[ 3.478162] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 3.483896] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 3.496889] io scheduler noop registered
[ 3.500504] io scheduler deadline registered (default)
[ 3.510713] mv_xor d0060900.xor: Marvell shared XOR driver
[ 3.574404] mv_xor d0060900.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
[ 3.664405] mv_xor d0060900.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
[ 3.672600] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[ 3.681256] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 3.690974] loop: module loaded
[ 3.700278] random: fast init done
[ 3.709198] m25p80 spi0.0: w25q64dw (8192 Kbytes)
[ 3.714098] 5 fixed-partitions partitions found on MTD device spi0.0
[ 3.720312] Creating 5 MTD partitions on "spi0.0":
[ 3.725191] 0x000000000000-0x000000020000 : "secure-firmware"
[ 3.731966] 0x000000020000-0x000000180000 : "u-boot"
[ 3.737457] 0x000000180000-0x000000190000 : "u-boot-env"
[ 3.743171] 0x000000190000-0x0000007f0000 : "Rescue system"
[ 3.749366] 0x0000007f0000-0x000000800000 : "dtb"
[ 3.754871] moxtet spi0.1: Found SD Turris Mox CPU module
[ 3.760600] libphy: Fixed MDIO Bus: probed
[ 3.765253] libphy: orion_mdio_bus: probed
[ 3.771508] mvneta d0030000.ethernet eth0: Using device tree mac address d8:58:d7:00:c4:5c
[ 3.780416] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 3.787194] ehci-pci: EHCI PCI platform driver
[ 3.791393] ehci-platform: EHCI generic platform driver
[ 3.796949] ehci-orion: EHCI orion driver
[ 3.801485] orion-ehci d005e000.usb: EHCI Host Controller
[ 3.807027] orion-ehci d005e000.usb: new USB bus registered, assigned bus number 1
[ 3.814819] orion-ehci d005e000.usb: irq 12, io mem 0xd005e000
[ 3.843829] orion-ehci d005e000.usb: USB 2.0 started, EHCI 1.00
[ 3.850040] hub 1-0:1.0: USB hub found
[ 3.853996] hub 1-0:1.0: 1 port detected
[ 3.859003] usbcore: registered new interface driver usb-storage
[ 3.865339] i2c /dev entries driver
[ 3.869501] armada_37xx_wdt d0008300.watchdog: Initial timeout 120 sec
[ 3.876857] sdhci: Secure Digital Host Controller Interface driver
[ 3.882895] sdhci: Copyright(c) Pierre Ossman
[ 3.887880] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.894104] xenon-sdhci d00d0000.sdhci: allocated mmc-pwrseq
[ 3.899796] xenon-sdhci d00d8000.sdhci: Got CD GPIO
[ 3.906574] NET: Registered protocol family 10
[ 3.911664] Segment Routing with IPv6
[ 3.915365] NET: Registered protocol family 17
[ 3.919628] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 3.933630] 8021q: 802.1Q VLAN Support v1.8
[ 3.939710] Btrfs loaded, crc32c=crc32c-arm64-ce
[ 3.948462] rtc-ds1307 0-006f: registered as rtc0
[ 3.952936] i2c i2c-0: PXA I2C adapter
[ 3.957320] xhci-hcd d0058000.usb: xHCI Host Controller
[ 3.962388] xhci-hcd d0058000.usb: new USB bus registered, assigned bus number 2
[ 3.970439] xhci-hcd d0058000.usb: hcc params 0x0a000998 hci version 0x100 quirks 0x0000000000010010
[ 3.979588] xhci-hcd d0058000.usb: irq 11, io mem 0xd0058000
[ 3.986144] hub 2-0:1.0: USB hub found
[ 3.990054] hub 2-0:1.0: 1 port detected
[ 3.994358] xhci-hcd d0058000.usb: xHCI Host Controller
[ 3.999414] xhci-hcd d0058000.usb: new USB bus registered, assigned bus number 3
[ 4.007446] xhci-hcd d0058000.usb: Host supports USB 3.0 SuperSpeed
[ 4.014100] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
[ 4.022714] hub 3-0:1.0: USB hub found
[ 4.026291] hub 3-0:1.0: 1 port detected
[ 4.030968] xenon-sdhci d00d0000.sdhci: allocated mmc-pwrseq
[ 4.093832] mmc0: SDHCI controller on d00d0000.sdhci [d00d0000.sdhci] using ADMA
[ 4.101924] xenon-sdhci d00d8000.sdhci: Got CD GPIO
[ 4.147079] sdio_read_cccr card report SDIO_UHS_DDR50
[ 4.152220] sdio_read_cccr card report SDIO_UHS_SDR50
[ 4.157363] sdio_read_cccr card report SDIO_UHS_SDR104
[ 4.164046] mmc1: SDHCI controller on d00d8000.sdhci [d00d8000.sdhci] using ADMA
[ 4.180362] armada-37xx-rwtm-mailbox d00b0000.mailbox: Trust Status: 00000000
[ 4.310383] Turris Mox serial number 0000000D30005EC4
[ 4.315442] board version 22
[ 4.319202] burned RAM size 512 MiB
[ 4.560400] random: crng init done
[ 4.563493] rtc-ds1307 0-006f: setting system clock to 2020-06-05 09:12:04 UTC (1591348324)
[ 4.712735] Waiting for root device PARTUUID=00000000-01...
[ 4.735106] xenon-sdhci d00d0000.sdhci: Timing issue might occur in DDR mode
[ 4.747386] mmc0: new ultra high speed DDR50 SDIO card at address 0001
[ 4.796413] mmc1: new ultra high speed SDR104 SDHC card at address aaaa
[ 4.804013] mmcblk1: mmc1:aaaa SA16G 14.8 GiB
[ 4.811056] mmcblk1: p1
[ 4.844362] F2FS-fs (mmcblk1p1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
[ 4.851924] F2FS-fs (mmcblk1p1): Can't find valid F2FS filesystem in 1th superblock
[ 4.862008] F2FS-fs (mmcblk1p1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
[ 4.869389] F2FS-fs (mmcblk1p1): Can't find valid F2FS filesystem in 2th superblock
[ 4.877566] F2FS-fs (mmcblk1p1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
[ 4.884922] F2FS-fs (mmcblk1p1): Can't find valid F2FS filesystem in 1th superblock
[ 4.893016] F2FS-fs (mmcblk1p1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
[ 4.900151] F2FS-fs (mmcblk1p1): Can't find valid F2FS filesystem in 2th superblock
[ 4.909558] BTRFS: device label turris devid 1 transid 472 /dev/root
[ 4.917191] BTRFS info (device mmcblk1p1): disk space caching is enabled
[ 4.923996] BTRFS info (device mmcblk1p1): has skinny extents
[ 4.941965] BTRFS info (device mmcblk1p1): enabling ssd optimizations
[ 4.955995] VFS: Mounted root (btrfs filesystem) on device 0:12.
[ 4.964351] devtmpfs: mounted
[ 4.967733] Freeing unused kernel memory: 320K
[ 5.073935] init: Console is alive
[ 5.077357] init: - watchdog -
[ 5.365152] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[ 5.383766] usbcore: registered new interface driver uas
[ 5.389502] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[ 5.399605] init: - preinit -
[ 5.774436] mvneta d0030000.ethernet eth0: PHY [d0032004.mdio-mii:01] driver [Marvell 88E1510]
[ 5.783725] mvneta d0030000.ethernet eth0: configuring for phy/rgmii-id link mode
[ 5.794604] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 8.910642] mount_root: mounting /dev/root
[ 8.915772] BTRFS info (device mmcblk1p1): disk space caching is enabled
[ 8.924575] mount_root: loading kmods from internal overlay
[ 8.959466] kmodloader: loading kernel modules from //etc/modules-boot.d/*
[ 8.967685] kmodloader: done loading kernel modules from //etc/modules-boot.d/*
[ 9.384530] block: attempting to load /etc/config/fstab
[ 9.393418] block: extroot: not configured
[ 9.510041] F2FS-fs (mtdblock1): Magic Mismatch, valid(0xf2f52010) - read(0x910003fd)
[ 9.518268] F2FS-fs (mtdblock1): Can't find valid F2FS filesystem in 1th superblock
[ 9.554682] urandom-seed: Seeding with /etc/urandom.seed
[ 9.849924] procd: - early -
[ 9.852526] procd: - watchdog -
[ 10.505152] procd: - watchdog -
[ 10.509286] procd: - ubus -
[ 10.569086] procd: - init -
[ 10.721544] kmodloader: loading kernel modules from /etc/modules.d/*
[ 10.739636] zram: Added device: zram0
[ 10.752332] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 10.763421] Netfilter messages via NETLINK v0.30.
[ 10.770023] ip_set: protocol 6
[ 10.793451] Loading modules backported from Linux version v4.19.120-0-gfdc072324f3c
[ 10.801356] Backport generated by backports.git v4.19.120-1-0-g60c3a249
[ 10.845509] hidraw: raw HID events driver (C) Jiri Kosina
[ 10.853749] Mirror/redirect action on
[ 10.869272] u32 classifier
[ 10.872015] input device check on
[ 10.875985] Actions configured
[ 10.922978] Bluetooth: Core ver 2.22
[ 10.926552] NET: Registered protocol family 31
[ 10.930840] Bluetooth: HCI device and connection manager initialized
[ 10.937799] Bluetooth: HCI socket layer initialized
[ 10.942823] Bluetooth: L2CAP socket layer initialized
[ 10.948035] Bluetooth: SCO socket layer initialized
[ 10.955431] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 10.960888] Bluetooth: BNEP filters: protocol multicast
[ 10.966082] Bluetooth: BNEP socket layer initialized
[ 10.972558] Bridge firewalling registered
[ 10.981063] Bluetooth: vendor=0x2df, device=0x9142, class=255, fn=2
[ 12.587456] Bluetooth: FW download over, size 623240 bytes
[ 12.834142] sdio platform data not available
[ 12.842225] usbcore: registered new interface driver btusb
[ 12.865750] Ebtables v2.0 registered
[ 12.871075] Bluetooth: HCI UART driver ver 2.3
[ 12.875577] Bluetooth: HCI UART protocol H4 registered
[ 12.880854] Bluetooth: HCI UART protocol BCSP registered
[ 12.886506] Bluetooth: HCI UART protocol ATH3K registered
[ 12.894747] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 12.900950] Bluetooth: HIDP socket layer initialized
[ 12.910291] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 12.936430] nf_conntrack version 0.5.0 (4096 buckets, 16384 max)
[ 12.947294] ctnetlink v0.93: registering with nfnetlink.
[ 13.007159] Bluetooth: RFCOMM TTY layer initialized
[ 13.012097] Bluetooth: RFCOMM socket layer initialized
[ 13.017495] Bluetooth: RFCOMM ver 1.11
[ 13.025181] usbcore: registered new interface driver ums-alauda
[ 13.031863] usbcore: registered new interface driver ums-cypress
[ 13.039115] usbcore: registered new interface driver ums-datafab
[ 13.045901] usbcore: registered new interface driver ums-freecom
[ 13.052738] usbcore: registered new interface driver ums-isd200
[ 13.059770] usbcore: registered new interface driver ums-jumpshot
[ 13.066777] usbcore: registered new interface driver ums-karma
[ 13.073967] usbcore: registered new interface driver ums-sddr09
[ 13.079981] mwifiex_sdio mmc0:0001:1: WLAN is not the winner! Skip FW dnld
[ 13.080992] usbcore: registered new interface driver ums-sddr55
[ 13.094138] usbcore: registered new interface driver ums-usbat
[ 13.114633] xt_time: kernel timezone is -0000
[ 13.133453] PPP generic driver version 2.4.2
[ 13.139419] NET: Registered protocol family 24
[ 13.155193] kmodloader: done loading kernel modules from /etc/modules.d/*
[ 13.454066] mwifiex_sdio mmc0:0001:1: WLAN FW is active
[ 13.499658] mwifiex_sdio mmc0:0001:1: Unknown api_id: 3
[ 13.505172] mwifiex_sdio mmc0:0001:1: Unknown api_id: 4
[ 13.510511] mwifiex_sdio mmc0:0001:1: Unknown GET_HW_SPEC TLV type: 0x217
[ 13.538889] mwifiex_sdio mmc0:0001:1: info: MWIFIEX VERSION: mwifiex 1.0 (16.68.1.p197)
[ 13.547200] mwifiex_sdio mmc0:0001:1: driver_version = mwifiex 1.0 (16.68.1.p197)
[ 14.024282] zram0: detected capacity change from 0 to 253755392
[ 14.057477] Adding 247804k swap on /dev/zram0. Priority:-2 extents:1 across:247804k SS
[ 16.442202] IPv6: ADDRCONF(NETDEV_UP): br-guest_turris: link is not ready
[ 16.454694] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
[ 16.564743] mvneta d0030000.ethernet eth0: PHY [d0032004.mdio-mii:01] driver [Marvell 88E1510]
[ 16.575836] mvneta d0030000.ethernet eth0: configuring for phy/rgmii-id link mode
[ 16.584589] br-lan: port 1(eth0) entered blocking state
[ 16.589941] br-lan: port 1(eth0) entered disabled state
[ 16.595721] device eth0 entered promiscuous mode
[ 17.956531] mwifiex_sdio mmc0:0001:1: CMD_RESP: cmd 0x20 error, result=0x1
[ 19.814821] mvneta d0030000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[ 19.822743] br-lan: port 1(eth0) entered blocking state
[ 19.828434] br-lan: port 1(eth0) entered forwarding state
[ 19.853952] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
[ 92.293505] mwifiex_sdio mmc0:0001:1: cannot register network device
