Hi guys,
sorry to bother you, but I tried all the possible combinations that I have in my managed switch and I don’t find similar topics or documentation.
With the current setup: MOX Power-WiFi plus the MOX PoE add-on and, as a switch, Netgear GS310TP PoE+; the link is not starting up.
I tried with different IEEE specs and Power Limit following the doc
Do you have any ideas?
i power a mox power wifi + c module via the poe add on… i use a injector (TP-Link TL-POE160S PoE+) and a 25m cat 6 cable. it just works.
so, either your poe module is faulty, wrongly installed or there is something weird going on in your switch, because it absolutety should be able to power the mox with it´s 55W poe capability.
