This is my /etc/config/netboot (I want to use 5Ghz)
~# cat /etc/config/netboot
# WiFi specific settings
# 02df_9141 is MOX SDIO WiFi
# 168c_003c is WLE900VX - 5GHz AC PCIe WiFi card in MOX and Omnia
I found ssh_key in /srv/turris-netboot/clients/accepted/<some_id>/
but wasn’t able to connect to mox using root, admin, turris-netboot, turris or netboot usernames. (EDIT - now I see the link you posted in the ticket - i will dig deeper soon)
Thanks for the ticket. I am now following it too. I didn’t know where to file it and relied on the forum first.
An update to this:
My Mox doesn’t load the firmware for both cards, I suspect this is the culprit for this.
Attached a log output from the mox after booting it, which clearly states “loading firmware failed for XXX”
But this shouldn’t be necessary, it should import the first configured wifi automatically, that’s what in this documentation too and what I expect.
(I should give it a try anyway to see, if it’s just this simple issue or something else)
It’s now confidential because of my wifi config, which I uploaded for further analysation, the issue is still there.
The only workaround what’s working until now is to set up the wifi adapters like @Michal_Smolak suggested, the default config and especially the variables are somewhat broken.
I configured the WiFi on MOX manually as suggested above. This works fine as workaround.
Hopefully once the original issue is resolved, @0regano will let us know.
I tried the workaround @Michal_Smolak mentioned earlier, using only standard letters and numbers for SSID and password…; still the mox (power wifi with 8Lan extension) is not showing any WiFi-Signal. It IS connected to the Omnia as shown via netboot-manager list. I´ve factory reset it several times, but still nothing. Weird. Why should it work for your Mox, then? Did you #out any other lines of the config? are you using only one of the two WiFi adapters of the Mox?
ok, thanks for the clarification. for now, the “netboot” mode seems to be extremely experimental; I also believe it is the reason for one of my two MOX to not being flash-able anymore, it can´t be reset, nothing… so I would not recommend trying the netboot at this state at all, just in case anyone reads this.
any update on this? Just bought MOX pocket wifi and i ran into same issue. editing netboot config is a hit and miss for me, sometimes it works, sometimes after some restarts it does not .
well, i switched back to “regular” AP mode by manually configuring the mox. works fine, and in the end this took less time than to fix the weird netboot mode.
