Zdravim, konecne jsem obdrzel svuj MOX z kampane a updatoval na posledni verzi TOS, nicmene mi router denne (i nekolikrat) zamrzne na nekolik minut a nasledne se sam restartuje. behem te doby neni pristupny ani web ani ssh (seriovou linku nemam/neumim).
nevite nekdo jak zjistit co to dela?
p.s. v logu se nevyznam a ani nevim kde ho najit :-/
je nejake reseni jak se vyhnout temto nahodilym restartum, ktere trvaji nekolik minut ?? (rychlejsi je odpojit od napajeni a pripojit, ale to se obavam ze mi za chvili neco prestane fungovat)
tak se problemy s Moxem dale rozsiruji … nejenze tyto nahodile restarty mam uz skoro co hodinu, tak navic ve vetsine pripadu nenabehnou nektere sluzby (OpenVPN, nektere prikazy napisou chybu v Python atd). resp. OpenVPN se tvari ze je spustene, pravidla ve firewall atd jsou vsechny v poradku, ale stejne me to odmitne pripojit.
popravde jsem cekal ze Mox bude vice stabilni … a ne ze odejde po par mesicich bezneho pouzivani.
hmm stale se mi router restartuje nekolikrat denne a v system logu sam nic nevyctu
nekdo kdo by poradil?
restarty
Restarted: Wed Dec 11 00:39:11 2019
Restarted: Wed Dec 11 04:12:14 2019
Restarted: Wed Dec 11 09:46:36 2019
Restarted: Wed Dec 11 10:38:53 2019
Restarted: Wed Dec 11 17:48:55 2019
Restarted: Thu Dec 12 00:37:14 2019
Restarted: Thu Dec 12 12:12:42 2019
Restarted: Thu Dec 12 18:19:57 2019
Restarted: Fri Dec 13 08:12:12 2019
Restarted: Fri Dec 13 09:23:13 2019
Restarted: Fri Dec 13 11:47:09 2019
Restarted: Fri Dec 13 15:04:12 2019
Restarted: Fri Dec 13 22:18:33 2019
Restarted: Sat Dec 14 04:29:58 2019
Restarted: Sat Dec 14 05:36:42 2019
Restarted: Sat Dec 14 08:55:03 2019
Restarted: Sat Dec 14 09:35:23 2019
Restarted: Sat Dec 14 10:30:37 2019
Restarted: Sat Dec 14 11:27:19 2019
Restarted: Sat Dec 14 14:59:27 2019
Restarted: Sat Dec 14 16:30:25 2019
Restarted: Sat Dec 14 17:25:23 2019
Restarted: Sat Dec 14 22:56:36 2019
Restarted: Sun Dec 15 02:27:50 2019
Restarted: Sun Dec 15 02:46:45 2019
Restarted: Sun Dec 15 06:35:08 2019
Restarted: Sun Dec 15 09:09:01 2019
Restarted: Sun Dec 15 10:12:58 2019
Restarted: Sun Dec 15 12:52:48 2019
Restarted: Sun Dec 15 15:51:00 2019
Restarted: Sun Dec 15 16:18:14 2019
Restarted: Sun Dec 15 18:34:24 2019
Restarted: Sun Dec 15 20:12:38 2019
Restarted: Sun Dec 15 22:04:25 2019
Restarted: Mon Dec 16 03:44:55 2019
Restarted: Mon Dec 16 04:58:56 2019
Restarted: Mon Dec 16 06:04:52 2019
Restarted: Mon Dec 16 07:30:12 2019
Restarted: Mon Dec 16 11:17:12 2019
Restarted: Mon Dec 16 23:10:47 2019
Restarted: Tue Dec 17 01:29:19 2019
Restarted: Tue Dec 17 03:14:04 2019
Restarted: Tue Dec 17 04:59:24 2019
Restarted: Tue Dec 17 07:13:54 2019
Restarted: Wed Dec 18 01:20:35 2019
Restarted: Wed Dec 18 12:42:22 2019
Restarted: Thu Dec 19 02:28:29 2019
Restarted: Thu Dec 19 07:02:02 2019
Restarted: Fri Dec 20 23:52:47 2019
Restarted: Sun Dec 22 03:42:14 2019
Restarted: Sun Dec 22 17:57:11 2019
Restarted: Sun Dec 22 18:40:05 2019
vypis syslogu pred poslednim restartem …
Dec 22 17:57:41 mox_uk kresd[6603]: [result] => true
Dec 22 17:57:41 mox_uk 99-dhcp_host_domain_ng.py: Refresh kresd leases
Dec 22 17:57:48 mox_uk firewall: Reloading firewall due to ifup of wan (eth0)
Dec 22 17:57:55 mox_uk firewall: Reloading firewall due to ifup of vpn_turris (tun_turris)
Dec 22 17:58:02 mox_uk firewall: Reloading firewall due to ifup of wan6 (eth0)
Dec 22 18:00:01 mox_uk /usr/sbin/cron[9143]: (root) CMD (/usr/bin/notifier)
Dec 22 18:00:01 mox_uk /usr/sbin/cron[9142]: (root) CMD (netmetr --autostart --dwlhist --rwait 1800 &)
Dec 22 18:00:01 mox_uk /usr/sbin/cron[9145]: (root) CMD (/usr/bin/get-api-crl)
Dec 22 18:05:01 mox_uk /usr/sbin/cron[9485]: (root) CMD (/usr/libexec/pakon-light/backup_sqlite.sh /var/lib/pakon.db /srv/pakon/pakon.db.xz)
Dec 22 18:05:01 mox_uk /usr/sbin/cron[9487]: (root) CMD (/usr/bin/notifier)
Dec 22 18:10:01 mox_uk /usr/sbin/cron[9887]: (root) CMD (/usr/bin/notifier)
Dec 22 18:12:01 mox_uk /usr/sbin/cron[10027]: (root) CMD (/usr/sbin/logrotate -s /tmp/logrotate.state /etc/logrotate.conf)
Dec 22 18:15:01 mox_uk /usr/sbin/cron[10200]: (root) CMD (/usr/bin/notifier)
Dec 22 18:20:01 mox_uk /usr/sbin/cron[10521]: (root) CMD (/usr/bin/notifier)
Dec 22 18:25:01 mox_uk /usr/sbin/cron[10856]: (root) CMD (/usr/bin/notifier)
Dec 22 18:30:01 mox_uk /usr/sbin/cron[11165]: (root) CMD (/usr/bin/get-api-crl)
Dec 22 18:30:01 mox_uk /usr/sbin/cron[11166]: (root) CMD (/usr/bin/notifier)
Dec 22 18:35:01 mox_uk /usr/sbin/cron[11502]: (root) CMD (/usr/bin/notifier)
Dec 22 18:39:58 mox_uk syslog-ng[3622]: syslog-ng starting up; version=‘3.21.1’
Dec 22 18:39:58 mox_uk kernel: [ 0.000000] Booting Linux on physical CPU 0x0
Dec 22 18:39:58 mox_uk kernel: [ 0.000000] Linux version 4.14.158 (beast@slave10) (gcc version 7.3.0 (OpenWrt GCC 7.3.0 cf29b8f)) #0 SMP Fri Dec 20 00:10:25 2019
Nemůže to dělat napájení?
Není na stejné fázi třeba nějaký motor, nebo topení?
Napěťové špičky nebo poklesy vyvolají restart…
Nepozorujete třeba změny svitu obyč žárovek?
Je to divné. Nemáte možnost připojit před router nějakou UPSku?
napajeni to klidne delat muze …
nicmene nepozoruji zadne ze zminenych ci jinych elektrickych problemu, navic kdyz nastane ten restart tak na routeru normalne blika aktivita na sitovem pripojeni, ale neni dostupny tak 5 minut … pak se rozjede. kdyz udelam rucni restart (odpojeni kabelu) tak router nabehne do minuty
UPS bohuzel zadnou nemam, ale zkusim nejakou levnou sehnat a zkusit.
dekuji za tip
p.s. je ale zvlastni ze jedine MOX by mel s temi spickami takove problemy , DSL model, monitor, nebo dalsi periferie jedou uplne normalne bez nejakych znamek poklesu/spicky napeti …
Napsal jsem na supoport a do jednoho dne odpoved s moznym postupem reseni.
nyni 4 dny bez restartu, takze reseni bylo nejspise spravne (bezel mi Home Assistant a Pakon => nestacila operacni pamet Moxe, coz mohlo vest k samovolnym restartum.)
Technicke podpore dekuji za velmi rychlou reakci !
tak po tydeni pauze kdy mi jel router bez problemu mi znovu zacal delat co predtim … tedy nahodne restarty a uplne stejne symptomy … v logu nic neni (viz predesle vypisy logu) , jen cetnost je jednou za 2-3 dny a ne nekolikrat denne …
krom jednoho LXC (s pi-hole) mi na routeru nic nebezi a to ma 1GB operacni pameti …
na UPS je napojen takze kolisani napeti uz by taky nemelo nastavat (ikdyz to nebylo i predtim)
