Hello!
I have a Mox Power WiFI + E + E modules. All worked very well until a day ago, when suddenly, both the E modules stopped working.
With “stopped working” i mean:
- they are recognized, i can chek in reforis for example which port has a device connected, it´s all correct
- connected devices all show fast flashing “transmission” led on their lan port
- no data transmission takes place, all devices connected to the E modules are unreachable
I did a rollback to 6.2.1, didn´t fix it. Anyone has any ideas what could cause it? And any advice on how to bugfix it? Bear with me, I´m not the most advanced. But I can connect to the mox via ssh so, it´s a start…
Edit:
Updated back to 6.2.2 again, no change. I ran the diagnostic, and i find the output for the lan ports weird…
At second 0.7 the modules are found normally.
At second 4.0 - 5.7the lan ports show (uninitialized)
At second 21 and later, the lan ports “entered disabled state”…
Is this normal behaviour?
############## dmesg
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 5.15.88 (packaging@turris.cz) (aarch64-openwrt-linux-musl-gcc (OpenWrt GCC 8.4.0 r16820+125-8b46a263ab) 8.4.0, GNU ld (GNU Binutils) 2.34) #0 SMP Wed Jan 18 07:04:32 2023
[ 0.000000] Machine model: CZ.NIC Turris Mox Board
[ 0.000000] earlycon: ar3700_uart0 at MMIO 0x00000000d0012000 (options '')
[ 0.000000] printk: bootconsole [ar3700_uart0] enabled
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000001fffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x0000000003ffffff]
[ 0.000000] node 0: [mem 0x0000000004000000-0x00000000041fffff]
[ 0.000000] node 0: [mem 0x0000000004200000-0x000000001fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000001fffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 16 pages/cpu s28184 r8192 d29160 u65536
[ 0.000000] pcpu-alloc: s28184 r8192 d29160 u65536 alloc=16*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 129024
[ 0.000000] Kernel command line: earlyprintk console=ttyMV0,115200 earlycon=ar3700_uart,0xd0012000 mangled_fs=btrfs root=PARTUUID=00000000-01 rootflags=commit=5,subvol=@ rootwait rw cfg80211.freg=
[ 0.000000] Unknown kernel command line parameters "earlyprintk mangled_fs=btrfs", will be passed to user space.
[ 0.000000] Dentry cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 497748K/524288K available (9792K kernel code, 960K rwdata, 2460K rodata, 576K init, 313K bss, 26540K reserved, 0K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 192 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000d1d40000
[ 0.000000] arch_timer: cp15 timer(s) running at 12.50MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049cda, max_idle_ns: 440795202628 ns
[ 0.000000] sched_clock: 56 bits at 12MHz, resolution 80ns, wraps every 4398046511080ns
[ 0.008484] Console: colour dummy device 80x25
[ 0.013008] Calibrating delay loop (skipped), value calculated using timer frequency.. 25.00 BogoMIPS (lpj=125000)
[ 0.023648] pid_max: default: 32768 minimum: 301
[ 0.028522] Mount-cache hash table entries: 1024 (order: 1, 8192 bytes, linear)
[ 0.035981] Mountpoint-cache hash table entries: 1024 (order: 1, 8192 bytes, linear)
[ 0.045488] rcu: Hierarchical SRCU implementation.
[ 0.050541] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[ 0.058678] smp: Bringing up secondary CPUs ...
[ 0.063765] Detected VIPT I-cache on CPU1
[ 0.063806] GICv3: CPU1: found redistributor 1 region 0:0x00000000d1d60000
[ 0.063854] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.063956] smp: Brought up 1 node, 2 CPUs
[ 0.086020] SMP: Total of 2 processors activated.
[ 0.090853] CPU features: detected: 32-bit EL0 Support
[ 0.096145] CPU features: detected: CRC32 instructions
[ 0.101469] CPU features: emulated: Privileged Access Never (PAN) using TTBR0_EL1 switching
[ 0.110036] CPU: All CPU(s) started at EL2
[ 0.114248] alternatives: patching kernel code
[ 0.119860] devtmpfs: initialized
[ 0.126251] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.136357] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.143423] pinctrl core: initialized pinctrl subsystem
[ 0.149826] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.156343] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations
[ 0.163592] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.171537] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.180049] thermal_sys: Registered thermal governor 'step_wise'
[ 0.180387] cpuidle: using governor ladder
[ 0.190904] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.197856] ASID allocator initialised with 65536 entries
[ 0.218068] cryptd: max_cpu_qlen set to 1000
[ 0.224053] raid6: skip pq benchmark and using algorithm neonx8
[ 0.230083] raid6: using neon recovery algorithm
[ 0.235730] SCSI subsystem initialized
[ 0.239756] libata version 3.00 loaded.
[ 0.239926] usbcore: registered new interface driver usbfs
[ 0.245579] usbcore: registered new interface driver hub
[ 0.250993] usbcore: registered new device driver usb
[ 0.257445] clocksource: Switched to clocksource arch_sys_counter
[ 0.268256] NET: Registered PF_INET protocol family
[ 0.273361] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.281313] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 0.289874] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.297831] TCP established hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.305826] TCP bind hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 0.313208] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.319790] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.326447] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.333769] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.339548] PCI: CLS 0 bytes, default 64
[ 0.344540] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.358734] workingset: timestamp_bits=46 max_order=17 bucket_order=0
[ 0.369399] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.375339] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.386372] xor: measuring software checksum speed
[ 0.396112] 8regs : 2036 MB/sec
[ 0.404772] 32regs : 2338 MB/sec
[ 0.414100] arm64_neon : 2000 MB/sec
[ 0.418506] xor: using function: 32regs (2338 MB/sec)
[ 0.423798] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 0.436680] advk-pcie d0070000.pcie: host bridge /soc/pcie@d0070000 ranges:
[ 0.443879] advk-pcie d0070000.pcie: IO 0x00e8000000..0x00e8ffffff -> 0x00e8000000
[ 0.452174] advk-pcie d0070000.pcie: MEM 0x00e9000000..0x00efffffff -> 0x00e9000000
[ 0.460671] advk-pcie d0070000.pcie: Clock unavailable (-2)
[ 0.468854] mv_xor d0060900.xor: Marvell shared XOR driver
[ 0.528176] mv_xor d0060900.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
[ 0.598158] mv_xor d0060900.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
[ 0.605854] debugfs: Directory 'd0060900.xor' with parent 'dmaengine' already present!
[ 0.614317] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[ 0.623982] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 0.634741] loop: module loaded
[ 0.637946] Loading iSCSI transport class v2.0-870.
[ 0.647109] spi-nor spi0.0: w25q64dw (8192 Kbytes)
[ 0.652334] 5 fixed-partitions partitions found on MTD device spi0.0
[ 0.658845] Creating 5 MTD partitions on "spi0.0":
[ 0.663742] 0x000000000000-0x000000020000 : "secure-firmware"
[ 0.670314] 0x000000020000-0x000000180000 : "a53-firmware"
[ 0.676448] 0x000000180000-0x000000190000 : "u-boot-env"
[ 0.682450] 0x000000190000-0x0000007f0000 : "Rescue system"
[ 0.688828] 0x0000007f0000-0x000000800000 : "dtb"
[ 0.696381] moxtet spi0.1: Found MOX A (CPU) module
[ 0.701382] moxtet spi0.1: Found MOX B (Mini-PCIe) module
[ 0.706895] moxtet spi0.1: Found MOX E (8 port switch) module
[ 0.712825] moxtet spi0.1: Found MOX E (8 port switch) module
[ 0.723608] hwmon hwmon0: temp1_input not attached to any thermal zone
[ 0.730991] mv88e6085 d0032004.mdio-mii:10: switch 0x1900 detected: Marvell 88E6190, revision 1
[ 0.755601] hwmon hwmon1: temp1_input not attached to any thermal zone
[ 0.767114] hwmon hwmon2: temp1_input not attached to any thermal zone
[ 0.778554] hwmon hwmon3: temp1_input not attached to any thermal zone
[ 0.789919] hwmon hwmon4: temp1_input not attached to any thermal zone
[ 0.801299] hwmon hwmon5: temp1_input not attached to any thermal zone
[ 0.812695] hwmon hwmon6: temp1_input not attached to any thermal zone
[ 0.824055] hwmon hwmon7: temp1_input not attached to any thermal zone
[ 0.835428] hwmon hwmon8: temp1_input not attached to any thermal zone
[ 0.851710] mv88e6085 d0032004.mdio-mii:11: switch 0x1900 detected: Marvell 88E6190, revision 1
[ 0.878525] hwmon hwmon1: temp1_input not attached to any thermal zone
[ 0.889893] hwmon hwmon2: temp1_input not attached to any thermal zone
[ 0.901257] hwmon hwmon3: temp1_input not attached to any thermal zone
[ 0.912573] hwmon hwmon4: temp1_input not attached to any thermal zone
[ 0.923918] hwmon hwmon5: temp1_input not attached to any thermal zone
[ 0.935307] hwmon hwmon6: temp1_input not attached to any thermal zone
[ 0.946662] hwmon hwmon7: temp1_input not attached to any thermal zone
[ 0.958096] hwmon hwmon8: temp1_input not attached to any thermal zone
[ 0.968826] mvneta d0030000.ethernet eth0: Using device tree mac address d8:58:d7:00:be:7c
[ 0.977812] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.984469] ehci-pci: EHCI PCI platform driver
[ 0.989131] ehci-platform: EHCI generic platform driver
[ 0.994617] ehci-orion: EHCI orion driver
[ 0.998999] orion-ehci d005e000.usb: EHCI Host Controller
[ 1.004507] orion-ehci d005e000.usb: new USB bus registered, assigned bus number 1
[ 1.012428] orion-ehci d005e000.usb: irq 23, io mem 0xd005e000
[ 1.047459] orion-ehci d005e000.usb: USB 2.0 started, EHCI 1.00
[ 1.054077] hub 1-0:1.0: USB hub found
[ 1.057947] hub 1-0:1.0: 1 port detected
[ 1.063111] usbcore: registered new interface driver usb-storage
[ 1.069482] i2c_dev: i2c /dev entries driver
[ 1.074826] armada_37xx_wdt d0008300.watchdog: Initial timeout 120 sec
[ 1.082371] sdhci: Secure Digital Host Controller Interface driver
[ 1.088727] sdhci: Copyright(c) Pierre Ossman
[ 1.093331] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.099501] xenon-sdhci d00d0000.sdhci: allocated mmc-pwrseq
[ 1.100963] NET: Registered PF_INET6 protocol family
[ 1.105588] xenon-sdhci d00d8000.sdhci: Got CD GPIO
[ 1.116709] Segment Routing with IPv6
[ 1.120480] In-situ OAM (IOAM) with IPv6
[ 1.124494] NET: Registered PF_PACKET protocol family
[ 1.129718] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.143173] 8021q: 802.1Q VLAN Support v1.8
[ 1.150041] Btrfs loaded, crc32c=crc32c-generic, zoned=no, fsverity=no
[ 1.159116] d0012000.serial: ttyMV0 at MMIO 0xd0012000 (irq = 0, base_baud = 1562500) is a mvebu-uart
[ 1.168601] printk: console [ttyMV0] enabled
[ 1.177339] printk: bootconsole [ar3700_uart0] disabled
[ 1.189920] advk-pcie d0070000.pcie: host bridge /soc/pcie@d0070000 ranges:
[ 1.197151] advk-pcie d0070000.pcie: IO 0x00e8000000..0x00e8ffffff -> 0x00e8000000
[ 1.205618] advk-pcie d0070000.pcie: MEM 0x00e9000000..0x00efffffff -> 0x00e9000000
[ 1.214176] advk-pcie d0070000.pcie: Clock unavailable (-2)
[ 1.220691] advk-pcie d0070000.pcie: issuing PERST via reset GPIO for 10ms
[ 1.251943] advk-pcie d0070000.pcie: link down
[ 1.337443] advk-pcie d0070000.pcie: link up
[ 1.342134] advk-pcie d0070000.pcie: PCI host bridge to bus 0000:00
[ 1.348623] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.354287] pci_bus 0000:00: root bus resource [io 0x0000-0xffffff] (bus address [0xe8000000-0xe8ffffff])
[ 1.364255] pci_bus 0000:00: root bus resource [mem 0xe9000000-0xefffffff]
[ 1.371394] pci 0000:00:00.0: [11ab:0100] type 01 class 0x060400
[ 1.378837] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.387301] pci 0000:01:00.0: [14c3:7915] type 00 class 0x000280
[ 1.393593] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x000fffff 64bit pref]
[ 1.401101] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x00003fff 64bit pref]
[ 1.408597] pci 0000:01:00.0: reg 0x20: [mem 0x00000000-0x00000fff 64bit pref]
[ 1.416088] pci 0000:01:00.0: Upstream bridge's Max Payload Size set to 128 (was 512, max 512)
[ 1.424987] pci 0000:01:00.0: Max Payload Size set to 128 (was 128, max 128)
[ 1.432474] pci 0000:01:00.0: supports D1 D2
[ 1.436876] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.443776] pci 0000:01:00.0: 2.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x1 link at 0000:00:00.0 (capable of 4.000 Gb/s with 5.0 GT/s PCIe x1 link)
[ 1.460310] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 1.467182] pci 0000:00:00.0: BAR 8: assigned [mem 0xe9000000-0xe91fffff]
[ 1.474204] pci 0000:00:00.0: BAR 9: assigned [mem 0xe9200000-0xe93fffff 64bit pref]
[ 1.482199] pci 0000:00:00.0: BAR 7: assigned [io 0x1000-0x1fff]
[ 1.488494] pci 0000:01:00.0: BAR 0: assigned [mem 0xe9200000-0xe92fffff 64bit pref]
[ 1.496519] pci 0000:01:00.0: BAR 2: assigned [mem 0xe9300000-0xe9303fff 64bit pref]
[ 1.504543] pci 0000:01:00.0: BAR 4: assigned [mem 0xe9304000-0xe9304fff 64bit pref]
[ 1.512567] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.517698] pci 0000:00:00.0: bridge window [io 0x1000-0x1fff]
[ 1.523985] pci 0000:00:00.0: bridge window [mem 0xe9000000-0xe91fffff]
[ 1.530992] pci 0000:00:00.0: bridge window [mem 0xe9200000-0xe93fffff 64bit pref]
[ 1.539143] pcieport 0000:00:00.0: enabling device (0000 -> 0003)
[ 1.545564] pcieport 0000:00:00.0: pciehp: Slot #1 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise- Interlock- NoCompl+ IbPresDis- LLActRep+
[ 1.560608] mv88e6085 d0032004.mdio-mii:10: switch 0x1900 detected: Marvell 88E6190, revision 1
[ 1.585593] hwmon hwmon9: temp1_input not attached to any thermal zone
[ 1.597030] hwmon hwmon10: temp1_input not attached to any thermal zone
[ 1.608632] hwmon hwmon11: temp1_input not attached to any thermal zone
[ 1.620192] hwmon hwmon12: temp1_input not attached to any thermal zone
[ 1.631722] hwmon hwmon13: temp1_input not attached to any thermal zone
[ 1.643254] hwmon hwmon14: temp1_input not attached to any thermal zone
[ 1.654817] hwmon hwmon15: temp1_input not attached to any thermal zone
[ 1.666334] hwmon hwmon16: temp1_input not attached to any thermal zone
[ 1.684095] mvneta d0040000.ethernet eth1: Using device tree mac address d8:58:d7:00:be:7d
[ 1.694028] xhci-hcd d0058000.usb: xHCI Host Controller
[ 1.699481] xhci-hcd d0058000.usb: new USB bus registered, assigned bus number 2
[ 1.707233] xhci-hcd d0058000.usb: hcc params 0x0a000998 hci version 0x100 quirks 0x0000000000010090
[ 1.716718] xhci-hcd d0058000.usb: irq 22, io mem 0xd0058000
[ 1.722703] xhci-hcd d0058000.usb: xHCI Host Controller
[ 1.728104] xhci-hcd d0058000.usb: new USB bus registered, assigned bus number 3
[ 1.735740] xhci-hcd d0058000.usb: Host supports USB 3.0 SuperSpeed
[ 1.742885] hub 2-0:1.0: USB hub found
[ 1.746808] hub 2-0:1.0: 1 port detected
[ 1.751188] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.760185] hub 3-0:1.0: USB hub found
[ 1.764106] hub 3-0:1.0: 1 port detected
[ 1.802316] Turris Mox serial number 0000000D30003E74
[ 1.807580] board version 22
[ 1.811536] burned RAM size 512 MiB
[ 1.912137] turris-mox-rwtm firmware:armada-3700-rwtm: HWRNG successfully registered
[ 1.942132] random: crng init done
[ 1.947882] xenon-sdhci d00d0000.sdhci: allocated mmc-pwrseq
[ 1.950476] xenon-sdhci d00d8000.sdhci: Got CD GPIO
[ 1.956712] mv88e6085 d0032004.mdio-mii:10: switch 0x1900 detected: Marvell 88E6190, revision 1
[ 1.988404] hwmon hwmon9: temp1_input not attached to any thermal zone
[ 1.997613] mmc1: SDHCI controller on d00d0000.sdhci [d00d0000.sdhci] using ADMA
[ 2.006225] hwmon hwmon10: temp1_input not attached to any thermal zone
[ 2.013365] mmc0: SDHCI controller on d00d8000.sdhci [d00d8000.sdhci] using ADMA
[ 2.022466] hwmon hwmon11: temp1_input not attached to any thermal zone
[ 2.034145] hwmon hwmon12: temp1_input not attached to any thermal zone
[ 2.045759] hwmon hwmon13: temp1_input not attached to any thermal zone
[ 2.057329] hwmon hwmon14: temp1_input not attached to any thermal zone
[ 2.069108] hwmon hwmon15: temp1_input not attached to any thermal zone
[ 2.080789] hwmon hwmon16: temp1_input not attached to any thermal zone
[ 2.090952] mmc0: new ultra high speed SDR104 SDHC card at address aaaa
[ 2.098828] mmcblk0: mmc0:aaaa SA16G 14.8 GiB
[ 2.105501] mmcblk0: p1
[ 2.114899] xenon-sdhci d00d0000.sdhci: Timing issue might occur in DDR mode
[ 2.124264] mmc1: new ultra high speed DDR50 SDIO card at address 0001
[ 4.006345] mv88e6085 d0032004.mdio-mii:11: configuring for inband/2500base-x link mode
[ 4.047610] mv88e6085 d0032004.mdio-mii:10: configuring for inband/2500base-x link mode
[ 4.087979] mv88e6085 d0032004.mdio-mii:10: configuring for inband/2500base-x link mode
[ 4.203344] mv88e6085 d0032004.mdio-mii:11 lan9 (uninitialized): PHY [!soc!internal-regs@d0000000!mdio@32004!switch1@11!mdio:01] driver [Marvell 88E6390 Family] (irq=67)
[ 4.313329] mv88e6085 d0032004.mdio-mii:11 lan10 (uninitialized): PHY [!soc!internal-regs@d0000000!mdio@32004!switch1@11!mdio:02] driver [Marvell 88E6390 Family] (irq=68)
[ 4.413330] mv88e6085 d0032004.mdio-mii:11 lan11 (uninitialized): PHY [!soc!internal-regs@d0000000!mdio@32004!switch1@11!mdio:03] driver [Marvell 88E6390 Family] (irq=69)
[ 4.513329] mv88e6085 d0032004.mdio-mii:11 lan12 (uninitialized): PHY [!soc!internal-regs@d0000000!mdio@32004!switch1@11!mdio:04] driver [Marvell 88E6390 Family] (irq=70)
[ 4.613328] mv88e6085 d0032004.mdio-mii:11 lan13 (uninitialized): PHY [!soc!internal-regs@d0000000!mdio@32004!switch1@11!mdio:05] driver [Marvell 88E6390 Family] (irq=71)
[ 4.651584] mv88e6085 d0032004.mdio-mii:10: Link is Up - 2.5Gbps/Full - flow control rx/tx
[ 4.666960] mv88e6085 d0032004.mdio-mii:11: Link is Up - 2.5Gbps/Full - flow control rx/tx
[ 4.723318] mv88e6085 d0032004.mdio-mii:11 lan14 (uninitialized): PHY [!soc!internal-regs@d0000000!mdio@32004!switch1@11!mdio:06] driver [Marvell 88E6390 Family] (irq=72)
[ 4.823331] mv88e6085 d0032004.mdio-mii:11 lan15 (uninitialized): PHY [!soc!internal-regs@d0000000!mdio@32004!switch1@11!mdio:07] driver [Marvell 88E6390 Family] (irq=73)
[ 4.923330] mv88e6085 d0032004.mdio-mii:11 lan16 (uninitialized): PHY [!soc!internal-regs@d0000000!mdio@32004!switch1@11!mdio:08] driver [Marvell 88E6390 Family] (irq=74)
[ 5.033321] mv88e6085 d0032004.mdio-mii:10 lan1 (uninitialized): PHY [!soc!internal-regs@d0000000!mdio@32004!switch0@10!mdio:01] driver [Marvell 88E6390 Family] (irq=93)
[ 5.133331] mv88e6085 d0032004.mdio-mii:10 lan2 (uninitialized): PHY [!soc!internal-regs@d0000000!mdio@32004!switch0@10!mdio:02] driver [Marvell 88E6390 Family] (irq=94)
[ 5.233329] mv88e6085 d0032004.mdio-mii:10 lan3 (uninitialized): PHY [!soc!internal-regs@d0000000!mdio@32004!switch0@10!mdio:03] driver [Marvell 88E6390 Family] (irq=95)
[ 5.333329] mv88e6085 d0032004.mdio-mii:10 lan4 (uninitialized): PHY [!soc!internal-regs@d0000000!mdio@32004!switch0@10!mdio:04] driver [Marvell 88E6390 Family] (irq=96)
[ 5.433328] mv88e6085 d0032004.mdio-mii:10 lan5 (uninitialized): PHY [!soc!internal-regs@d0000000!mdio@32004!switch0@10!mdio:05] driver [Marvell 88E6390 Family] (irq=97)
[ 5.533329] mv88e6085 d0032004.mdio-mii:10 lan6 (uninitialized): PHY [!soc!internal-regs@d0000000!mdio@32004!switch0@10!mdio:06] driver [Marvell 88E6390 Family] (irq=98)
[ 5.633338] mv88e6085 d0032004.mdio-mii:10 lan7 (uninitialized): PHY [!soc!internal-regs@d0000000!mdio@32004!switch0@10!mdio:07] driver [Marvell 88E6390 Family] (irq=99)
[ 5.733319] mv88e6085 d0032004.mdio-mii:10 lan8 (uninitialized): PHY [!soc!internal-regs@d0000000!mdio@32004!switch0@10!mdio:08] driver [Marvell 88E6390 Family] (irq=100)
[ 5.752654] DSA: tree 0 setup
[ 5.760647] squashfs: Unknown parameter 'commit'
[ 5.766009] F2FS-fs (mmcblk0p1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
[ 5.773519] F2FS-fs (mmcblk0p1): Can't find valid F2FS filesystem in 1th superblock
[ 5.782367] F2FS-fs (mmcblk0p1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
[ 5.789837] F2FS-fs (mmcblk0p1): Can't find valid F2FS filesystem in 2th superblock
[ 5.798860] BTRFS: device fsid f4bce1d5-da88-40b5-a1b7-ef91d9140d77 devid 1 transid 4302 /dev/root scanned by swapper/0 (1)
[ 5.812213] BTRFS info (device mmcblk0p1): disk space caching is enabled
[ 5.819212] BTRFS info (device mmcblk0p1): has skinny extents
[ 5.836984] BTRFS info (device mmcblk0p1): enabling ssd optimizations
[ 5.849690] VFS: Mounted root (btrfs filesystem) on device 0:14.
[ 5.857017] devtmpfs: mounted
[ 5.860426] Freeing unused kernel memory: 576K
[ 5.907489] Run /sbin/init as init process
[ 5.911714] with arguments:
[ 5.911717] /sbin/init
[ 5.911720] earlyprintk
[ 5.911723] with environment:
[ 5.911726] HOME=/
[ 5.911729] TERM=linux
[ 5.911732] mangled_fs=btrfs
[ 5.953050] init: Console is alive
[ 5.956710] init: - watchdog -
[ 6.408373] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[ 6.479010] ehci-fsl: Freescale EHCI Host controller driver
[ 6.488057] usbcore: registered new interface driver uas
[ 6.493832] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[ 6.511454] init: - preinit -
[ 8.650138] mount_root: mounting /dev/root
[ 9.011609] F2FS-fs (mtdblock1): Magic Mismatch, valid(0xf2f52010) - read(0xaa0103e3)
[ 9.019748] F2FS-fs (mtdblock1): Can't find valid F2FS filesystem in 1th superblock
[ 9.029722] F2FS-fs (mtdblock1): Magic Mismatch, valid(0xf2f52010) - read(0xd53e1000)
[ 9.037816] F2FS-fs (mtdblock1): Can't find valid F2FS filesystem in 2th superblock
[ 9.055929] urandom-seed: Seeding with /etc/urandom.seed
[ 9.287336] BTRFS info: devid 1 device path /dev/root changed to /dev/mmcblk0p1 scanned by btrfs (902)
[ 9.301463] procd: - early -
[ 9.304505] procd: - watchdog -
[ 9.868417] procd: - watchdog -
[ 9.872099] procd: - ubus -
[ 9.926679] procd: - init -
[ 10.156381] kmodloader: loading kernel modules from /etc/modules.d/*
[ 10.221738] zram: Added device: zram0
[ 10.233170] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 10.276799] i2c i2c-0: PXA I2C adapter
[ 10.284174] Loading modules backported from Linux version v5.15.81-0-ge4a7232c917c
[ 10.292128] Backport generated by backports.git v5.15.81-1-0-ge1867d55
[ 10.327100] hid: raw HID events driver (C) Jiri Kosina
[ 10.335616] GACT probability on
[ 10.340171] Mirror/redirect action on
[ 10.351268] u32 classifier
[ 10.354086] input device check on
[ 10.357957] Actions configured
[ 10.391832] Bluetooth: Core ver 2.22
[ 10.395654] NET: Registered PF_BLUETOOTH protocol family
[ 10.401161] Bluetooth: HCI device and connection manager initialized
[ 10.407747] Bluetooth: HCI socket layer initialized
[ 10.412782] Bluetooth: L2CAP socket layer initialized
[ 10.418028] Bluetooth: SCO socket layer initialized
[ 10.424335] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 10.429884] Bluetooth: BNEP filters: protocol multicast
[ 10.435285] Bluetooth: BNEP socket layer initialized
[ 10.441617] Bridge firewalling registered
[ 10.449522] Bluetooth: vendor=0x2df, device=0x9142, class=255, fn=2
[ 12.012664] Bluetooth: FW download over, size 623240 bytes
[ 12.257494] btmrvl_sdio mmc1:0001:2: sdio device tree data not available
[ 12.267291] usbcore: registered new interface driver btusb
[ 12.283099] Bluetooth: HCI UART driver ver 2.3
[ 12.287744] Bluetooth: HCI UART protocol H4 registered
[ 12.293042] Bluetooth: HCI UART protocol BCSP registered
[ 12.298532] Bluetooth: HCI UART protocol ATH3K registered
[ 12.305371] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 12.311559] Bluetooth: HIDP socket layer initialized
[ 12.331631] mt7915e 0000:01:00.0: enabling device (0000 -> 0002)
[ 12.482612] mt7915e 0000:01:00.0: HW/SW Version: 0x8a108a10, Build Time: 20211222184017a
[ 12.482612]
[ 12.512208] mt7915e 0000:01:00.0: WM Firmware Version: ____000000, Build Time: 20211222184052
[ 12.544151] mt7915e 0000:01:00.0: WA Firmware Version: DEV_000000, Build Time: 20211222184111
[ 17.988734] mwifiex_sdio mmc1:0001:1: WLAN FW already running! Skip FW dnld
[ 17.995958] mwifiex_sdio mmc1:0001:1: WLAN FW is active
[ 18.001837] Bluetooth: RFCOMM TTY layer initialized
[ 18.006938] Bluetooth: RFCOMM socket layer initialized
[ 18.012370] Bluetooth: RFCOMM ver 1.11
[ 18.021650] genirq: Flags mismatch irq 53. 00002082 (mcp7940x) vs. 00002002 (moxtet)
[ 18.030871] rtc-ds1307 0-006f: unable to request IRQ!
[ 18.038183] rtc-ds1307 0-006f: registered as rtc0
[ 18.044130] rtc-ds1307 0-006f: setting system clock to 2023-01-26T14:09:20 UTC (1674742160)
[ 18.057147] usbcore: registered new interface driver ums-alauda
[ 18.064455] usbcore: registered new interface driver ums-cypress
[ 18.072045] usbcore: registered new interface driver ums-datafab
[ 18.079432] usbcore: registered new interface driver ums-freecom
[ 18.086564] usbcore: registered new interface driver ums-isd200
[ 18.093939] usbcore: registered new interface driver ums-jumpshot
[ 18.101415] usbcore: registered new interface driver ums-karma
[ 18.108942] usbcore: registered new interface driver ums-sddr09
[ 18.115966] usbcore: registered new interface driver ums-sddr55
[ 18.123422] usbcore: registered new interface driver ums-usbat
[ 18.146074] mwifiex_sdio mmc1:0001:1: info: MWIFIEX VERSION: mwifiex 1.0 (16.68.1.p197)
[ 18.154521] mwifiex_sdio mmc1:0001:1: driver_version = mwifiex 1.0 (16.68.1.p197)
[ 18.168368] xt_time: kernel timezone is -0000
[ 18.198578] PPP generic driver version 2.4.2
[ 18.204794] NET: Registered PF_PPPOX protocol family
[ 18.235084] kmodloader: done loading kernel modules from /etc/modules.d/*
[ 18.770222] zram0: detected capacity change from 0 to 497664
[ 18.786651] Adding 248828k swap on /dev/zram0. Priority:-2 extents:1 across:248828k SSDsc
[ 20.874778] mvneta d0040000.ethernet eth1: configuring for inband/2500base-x link mode
[ 20.889723] mv88e6085 d0032004.mdio-mii:10 lan1: configuring for phy/ link mode
[ 20.904361] br-lan: port 1(lan1) entered blocking state
[ 20.909914] br-lan: port 1(lan1) entered disabled state
[ 20.920686] mvneta d0040000.ethernet eth1: Link is Up - 2.5Gbps/Full - flow control rx/tx
[ 20.960461] mv88e6085 d0032004.mdio-mii:10: Link is Up - 2.5Gbps/Full - flow control rx/tx
[ 20.992536] device lan1 entered promiscuous mode
[ 20.997330] device eth1 entered promiscuous mode
[ 21.419976] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[ 21.449018] mv88e6085 d0032004.mdio-mii:11 lan10: configuring for phy/ link mode
[ 21.459013] br-lan: port 2(lan10) entered blocking state
[ 21.464519] br-lan: port 2(lan10) entered disabled state
[ 21.533529] device lan10 entered promiscuous mode
[ 21.607352] mv88e6085 d0032004.mdio-mii:11 lan11: configuring for phy/ link mode
[ 21.749015] br-lan: port 3(lan11) entered blocking state
[ 21.754526] br-lan: port 3(lan11) entered disabled state
[ 21.805218] device lan11 entered promiscuous mode
[ 21.849538] mv88e6085 d0032004.mdio-mii:11 lan12: configuring for phy/ link mode
[ 21.971078] br-lan: port 4(lan12) entered blocking state
[ 21.976589] br-lan: port 4(lan12) entered disabled state
[ 22.032563] device lan12 entered promiscuous mode
[ 22.075947] mv88e6085 d0032004.mdio-mii:11 lan13: configuring for phy/ link mode
[ 22.188917] br-lan: port 5(lan13) entered blocking state
[ 22.194428] br-lan: port 5(lan13) entered disabled state
[ 22.246092] device lan13 entered promiscuous mode
[ 22.288913] mv88e6085 d0032004.mdio-mii:11 lan14: configuring for phy/ link mode
[ 22.398957] br-lan: port 6(lan14) entered blocking state
[ 22.404462] br-lan: port 6(lan14) entered disabled state
[ 22.456600] device lan14 entered promiscuous mode
[ 22.499668] mv88e6085 d0032004.mdio-mii:11 lan15: configuring for phy/ link mode
[ 22.608900] br-lan: port 7(lan15) entered blocking state
[ 22.614405] br-lan: port 7(lan15) entered disabled state
[ 22.673657] device lan15 entered promiscuous mode
[ 22.720607] mv88e6085 d0032004.mdio-mii:11 lan16: configuring for phy/ link mode
[ 22.730749] br-lan: port 8(lan16) entered blocking state
[ 22.736263] br-lan: port 8(lan16) entered disabled state
[ 22.804190] device lan16 entered promiscuous mode
[ 22.856063] mv88e6085 d0032004.mdio-mii:10 lan2: configuring for phy/ link mode
[ 22.971394] br-lan: port 9(lan2) entered blocking state
[ 22.976818] br-lan: port 9(lan2) entered disabled state
[ 23.048126] device lan2 entered promiscuous mode
[ 23.107155] mv88e6085 d0032004.mdio-mii:10 lan1: Link is Up - 100Mbps/Full - flow control rx/tx
[ 23.116810] mv88e6085 d0032004.mdio-mii:10 lan3: configuring for phy/ link mode
[ 23.142335] br-lan: port 1(lan1) entered blocking state
[ 23.147784] br-lan: port 1(lan1) entered forwarding state
[ 23.261060] br-lan: port 10(lan3) entered blocking state
[ 23.266578] br-lan: port 10(lan3) entered disabled state
[ 23.343839] device lan3 entered promiscuous mode
[ 23.398101] mv88e6085 d0032004.mdio-mii:10 lan4: configuring for phy/ link mode
[ 23.424725] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
[ 23.530738] br-lan: port 11(lan4) entered blocking state
[ 23.536254] br-lan: port 11(lan4) entered disabled state
[ 23.613585] device lan4 entered promiscuous mode
[ 23.667670] mv88e6085 d0032004.mdio-mii:10 lan5: configuring for phy/ link mode
[ 23.801129] br-lan: port 12(lan5) entered blocking state
[ 23.806647] br-lan: port 12(lan5) entered disabled state
[ 23.881830] device lan5 entered promiscuous mode
[ 23.929687] mv88e6085 d0032004.mdio-mii:10 lan6: configuring for phy/ link mode
[ 24.063586] br-lan: port 13(lan6) entered blocking state
[ 24.069190] br-lan: port 13(lan6) entered disabled state
[ 24.157422] device lan6 entered promiscuous mode
[ 24.212698] mv88e6085 d0032004.mdio-mii:10 lan7: configuring for phy/ link mode
[ 24.342000] br-lan: port 14(lan7) entered blocking state
[ 24.347575] br-lan: port 14(lan7) entered disabled state
[ 24.428443] device lan7 entered promiscuous mode
[ 24.491291] mv88e6085 d0032004.mdio-mii:10 lan8: configuring for phy/ link mode
[ 24.637182] br-lan: port 15(lan8) entered blocking state
[ 24.642805] br-lan: port 15(lan8) entered disabled state
[ 24.721548] device lan8 entered promiscuous mode
[ 24.789571] mv88e6085 d0032004.mdio-mii:11 lan9: configuring for phy/ link mode
[ 24.814270] br-lan: port 16(lan9) entered blocking state
[ 24.819894] br-lan: port 16(lan9) entered disabled state
[ 24.921876] device lan9 entered promiscuous mode
[ 24.967779] mv88e6085 d0032004.mdio-mii:11 lan11: Link is Up - 1Gbps/Full - flow control rx/tx
[ 24.998922] br-lan: port 3(lan11) entered blocking state
[ 25.004443] br-lan: port 3(lan11) entered forwarding state
[ 25.055405] mv88e6085 d0032004.mdio-mii:11 lan10: Link is Up - 1Gbps/Full - flow control rx/tx
[ 25.108481] mvneta d0030000.ethernet eth0: PHY [d0032004.mdio-mii:01] driver [Marvell 88E1510] (irq=POLL)
[ 25.119492] mvneta d0030000.ethernet eth0: configuring for phy/rgmii-id link mode
[ 25.139217] br-lan: port 17(eth0) entered blocking state
[ 25.144732] br-lan: port 17(eth0) entered disabled state
[ 25.150604] device eth0 entered promiscuous mode
[ 25.155637] br-lan: port 17(eth0) entered blocking state
[ 25.161160] br-lan: port 17(eth0) entered forwarding state
[ 25.205631] br-lan: port 2(lan10) entered blocking state
[ 25.211200] br-lan: port 2(lan10) entered forwarding state
[ 25.310615] mv88e6085 d0032004.mdio-mii:11 lan13: Link is Up - 1Gbps/Full - flow control rx/tx
[ 25.331226] br-lan: port 5(lan13) entered blocking state
[ 25.336748] br-lan: port 5(lan13) entered forwarding state
[ 25.440039] mv88e6085 d0032004.mdio-mii:11 lan12: Link is Up - 1Gbps/Full - flow control rx/tx
[ 25.457338] br-lan: port 4(lan12) entered blocking state
[ 25.462907] br-lan: port 4(lan12) entered forwarding state
[ 25.661193] mv88e6085 d0032004.mdio-mii:11 lan14: Link is Up - 1Gbps/Full - flow control rx/tx
[ 25.684068] br-lan: port 6(lan14) entered blocking state
[ 25.689639] br-lan: port 6(lan14) entered forwarding state
[ 26.012267] br-lan: port 17(eth0) entered disabled state
[ 26.451907] mv88e6085 d0032004.mdio-mii:10 lan2: Link is Up - 1Gbps/Full - flow control rx/tx
[ 26.480733] br-lan: port 9(lan2) entered blocking state
[ 26.486184] br-lan: port 9(lan2) entered forwarding state
[ 26.663728] mv88e6085 d0032004.mdio-mii:10 lan3: Link is Up - 1Gbps/Full - flow control rx/tx
[ 26.687696] br-lan: port 10(lan3) entered blocking state
[ 26.693215] br-lan: port 10(lan3) entered forwarding state
[ 27.079335] mv88e6085 d0032004.mdio-mii:10 lan4: Link is Up - 1Gbps/Full - flow control rx/tx
[ 27.108757] br-lan: port 11(lan4) entered blocking state
[ 27.114277] br-lan: port 11(lan4) entered forwarding state
[ 27.438003] mv88e6085 d0032004.mdio-mii:10 lan7: Link is Up - 1Gbps/Full - flow control rx/tx
[ 27.446875] br-lan: port 14(lan7) entered blocking state
[ 27.452409] br-lan: port 14(lan7) entered forwarding state
[ 28.477726] mv88e6085 d0032004.mdio-mii:11 lan9: Link is Up - 1Gbps/Full - flow control rx/tx
[ 28.486601] br-lan: port 16(lan9) entered blocking state
[ 28.492125] br-lan: port 16(lan9) entered forwarding state
[ 29.318215] mvneta d0030000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 29.326550] br-lan: port 17(eth0) entered blocking state
[ 29.332107] br-lan: port 17(eth0) entered forwarding state
