From routers like the fritzboxes I know that one network SSID can serve 2 frequencies.
The MOX has a single wifi chips, unlike the MOX, which makes this even weirder.
Can I have the same name and leave the switching to my router or OS, automatically? Depending on the availability
Or is this not really a thing?
Edit: I will see if just using the same name does the trick.
