Nemam zaple automaticke aktualizace, protoze probirat kazdou chvili chciply mox me nebavilo, ale uz se tesim na TOS6 kde to snad bude vyresene.
Pustil jsem pkgupdate v domeni ze me to migruje na hbs 5.4.5 kde budu cekat az se vyresi update na TOS6 kde je vyresena SDIO 2.4G karta. Zkousel jsem opakovane prejit na 5.4.5, ale vzdycky jsem po rebootu skoncil na 5.4.4 viz schnapps
98 | pre | 25.48MiB | 2022-10-02 08:47:30 +0200 | Automatic pre-update snapshot (TurrisOS 5.4.2)
99 | post | 11.82MiB | 2022-10-02 08:50:03 +0200 | Automatic post-update snapshot (TurrisOS 5.4.4)
100 | pre | 14.14MiB | 2022-10-07 14:57:35 +0200 | Automatic pre-update snapshot (TurrisOS 5.4.4)
101 | post | 11.61MiB | 2022-10-07 14:58:19 +0200 | Automatic post-update snapshot (TurrisOS 5.4.4)
102 | pre | 11.63MiB | 2022-10-07 18:06:52 +0200 | Automatic pre-update snapshot (TurrisOS 5.4.4)
103 | post | 11.90MiB | 2022-10-07 18:07:41 +0200 | Automatic post-update snapshot (TurrisOS 5.4.4)
104 | time | 11.68MiB | 2022-10-09 01:05:01 +0200 | Snapshot created by cron
105 | pre | 14.14MiB | 2022-10-10 19:14:57 +0200 | Automatic pre-update snapshot (TurrisOS 5.4.4)
106 | post | 11.85MiB | 2022-10-10 19:15:42 +0200 | Automatic post-update snapshot (TurrisOS 5.4.4)
107 | pre | 14.37MiB | 2022-10-14 15:57:24 +0200 | Automatic pre-update snapshot (TurrisOS 5.4.4)
108 | post | 11.67MiB | 2022-10-14 15:58:08 +0200 | Automatic post-update snapshot (TurrisOS 5.4.4)
109 | time | 11.66MiB | 2022-10-16 01:05:01 +0200 | Snapshot created by cron
110 | single | 11.66MiB | 2022-10-18 22:06:19 +0200 | manual544
Aktualne dostavam vsak hlasku nize
Warning: Changes performed using anything other than
official web interface reForis are not covered by
Turris support team unless instructed!
BusyBox v1.30.1 () built-in shell (ash)
______ _ ____ _____
/_ __/_ ____________(_)____ / __ \/ ___/
/ / / / / / ___/ ___/ / ___/ / / / /\__
/ / / /_/ / / / / / (__ ) / /_/ /___/ /
/_/ \__,_/_/ /_/ /_/____/ \____//____/
TurrisOS 5.4.4, Turris Mox
root@hlogw:~# pkgupdate
INFO:Target Turris OS: 6.0
line not found
line not found
line not found
line not found
line not found
ERROR:
inconsistent: Requested package wireguard that is not available.
Pak jeste neni dostupne tohle repo
Downloading https://repo.turris.cz/hbs/mox/packages/sidn/Packages.gz
*** Failed to download the package list from https://repo.turris.cz/hbs/mox/packages/sidn/Packages.gz
Collected errors:
* opkg_download: Failed to download https://repo.turris.cz/hbs/mox/packages/sidn/Packages.gz, wget returned 8.
Rucne prepnout na hbs-sdio zkousim … ale zda si to taha z hbs nikoliv z h
root@hlogw:~# switch-branch --force hbs-sdio
Downloading https://repo.turris.cz/hbs/mox/packages/core/Packages.gz
Updated list of available packages in /var/opkg-lists/turrisos_core
Downloading https://repo.turris.cz/hbs/mox/packages/core/Packages.sig
Cekal bych https://repo.turris.cz/hbs-sdio/mox/packages/core/Packages.sig
Neprobehne tam nastaveni jako kdyz prepinam na hbs?
+ uci set 'updater.turris=turris'
+ uci set 'updater.turris.mode=branch'
+ uci set 'updater.turris.branch=hbs'
+ sed -i 's|https://repo\.turris\.cz/.*/\([^/]*\)/packages/|https://repo\.turris\.cz/hbs/\1/packages/|' /etc/opkg/distfeeds.conf
+ uci commit updater.turris
+ set +x
Takhle asi OK, jen se radsi ujistim at nedelam nejakou lamerinu
root@hlogw:~# uci set 'updater.turris.branch=hbs-sdio'
root@hlogw:~# uci commit
