Otestoval jsem TurrisOS branch HBK. Narazil jsem hned na první problém.
BusyBox v1.28.4 () built-in shell (ash)
______ _ ____ _____ /_ __/_ ____________(_)____ / __ \/ ___/ / / / / / / ___/ ___/ / ___/ / / / /\__ / / / /_/ / / / / / (__ ) / /_/ /___/ / /_/ \__,_/_/ /_/ /_/____/ \____//____/
TurrisOS 4.0-alpha3, aefd3d08d4
root@turris:~# pkgupdate
Error loading shared library libevent-2.1.so.6: No such file or directory (needed by /usr/lib/libupdater.so)
Error loading shared library libcrypto.so.1.1: No such file or directory (needed by /usr/lib/libupdater.so)
Error relocating /usr/lib/libupdater.so: event_config_free: symbol not found
Error relocating /usr/lib/libupdater.so: event_base_new_with_config: symbol not found
Error relocating /usr/lib/libupdater.so: event_base_free: symbol not found
Error relocating /usr/lib/libupdater.so: bufferevent_free: symbol not found
Error relocating /usr/lib/libupdater.so: bufferevent_enable: symbol not found
Error relocating /usr/lib/libupdater.so: bufferevent_setcb: symbol not found
Error relocating /usr/lib/libupdater.so: bufferevent_socket_new: symbol not found
Error relocating /usr/lib/libupdater.so: event_assign: symbol not found
Error relocating /usr/lib/libupdater.so: evbuffer_get_length: symbol not found
Error relocating /usr/lib/libupdater.so: event_pending: symbol not found
Error relocating /usr/lib/libupdater.so: event_del: symbol not found
Error relocating /usr/lib/libupdater.so: bufferevent_read: symbol not found
Error relocating /usr/lib/libupdater.so: event_add: symbol not found
Error relocating /usr/lib/libupdater.so: event_config_new: symbol not found
Error relocating /usr/lib/libupdater.so: bufferevent_write: symbol not found
Error relocating /usr/lib/libupdater.so: event_free: symbol not found
Error relocating /usr/lib/libupdater.so: event_config_set_flag: symbol not found
Error relocating /usr/lib/libupdater.so: event_base_loop: symbol not found
Error relocating /usr/lib/libupdater.so: event_config_require_features: symbol not found
Error relocating /usr/lib/libupdater.so: bufferevent_get_input: symbol not found
Error relocating /usr/lib/libupdater.so: event_new: symbol not found
Error relocating /usr/lib/libupdater.so: bufferevent_disable: symbol not found
