I have a problem similar to you with my moooox (A+G+B+E+E+D).
My problem is that the G and B modules are not visible by the router. They never worked. How did you do to make them work?
How to check if it is a hardware or software problem?
Have you found a solution to your problem?
I was thinking of replacing a Cisco RV345P+2 nomadic routers LTE, by that, but I am so disappointed with my purchase and I am spending so much time trying to make it work and without a response from Turris!
If someone could help me. Thanks in advance.
