Ahoj hagrid,
Po updatech a migraci na btrfs jsem provedl upgrade, u toho zemrel.
Pred upgrade jsem v log videl nekolik chybovych hlaseni. Turris byl aktualizovan na verzi 3.11.23 (tedy 3.11.19), ale updater ve forisu hlasil potize aktualizovat a pres ssh jsem zjistil cyklicke zavislosti - neaktualizoval jsem vys.
root@turris:~# pkgupdate
WARN:Package wpad is in cyclic dependency. It might fail its post-install script.
WARN:Package hostapd is in cyclic dependency. It might fail its post-install script.
WARN:Requested package luci-i18n-ddns-sk that is missing, ignoring as requested.
INFO:Queue install of libgcc/turris/7.5.0-2
INFO:Queue install of libc/turris/1.1.24-2
INFO:Queue install of tos3to4-earliest/turris/2.4.1-1
INFO:Queue install of libjson-c/turris/0.12.1-3.1
INFO:Queue install of libubox/turris/2020-05-25-66195aee-1
INFO:Queue install of jsonfilter/turris/2018-02-04-c7e938d6-1
INFO:Queue install of busybox/turris/1.30.1-8
INFO:Queue install of ca-certificates/turris/20200601-1
INFO:Queue install of libopenssl/turris/1.1.1m-1
INFO:Queue install of libexpat/turris/2.2.9-1
INFO:Queue install of libbz2/turris/1.0.8-1
INFO:Queue install of libpthread/turris/1.1.24-2
INFO:Queue install of liblzma/turris/5.2.5-1
INFO:Queue install of zlib/turris/1.2.11-3
INFO:Queue install of libarchive/turris/3.4.2-1
INFO:Queue install of liburiparser/turris/0.9.6-1
INFO:Queue install of ca-bundle/turris/20200601-1
INFO:Queue install of libcurl/turris/7.66.0-3
INFO:Queue install of libevent2/turris/2.1.11-1
INFO:Queue install of liblua/turris/5.1.5-3
INFO:Queue install of libuci/turris/2019-09-01-415f9e48-4
INFO:Queue install of libuci-lua/turris/2019-09-01-415f9e48-4
INFO:Queue install of updater-ng/turris/69.1.3-2
Press return to continue, CTRL+C to abort
^C
Pripajim take system log z luci pred upgradem:
system log
2022-03-02 18:29:42 notice syslog-ng[5105]: syslog-ng starting up; version='3.21.1'
2022-03-02 18:29:42 info kernel[]: [ 0.000000] Using P2020 RDB machine description
2022-03-02 18:29:42 info kernel[]: [ 0.000000] Memory CAM mapping: 256/256 Mb, residual: 1536Mb
2022-03-02 18:29:42 info kernel[]: [ 0.000000] Initializing cgroup subsys cpuset
2022-03-02 18:29:42 info kernel[]: [ 0.000000] Initializing cgroup subsys cpuacct
2022-03-02 18:29:42 notice kernel[]: [ 0.000000] Linux version 4.4.199-f90a52a6230ecb072f657fce5aebd444-1 (beast@build) (gcc version 4.8.3 (OpenWrt/Linaro GCC 4.8-2014.04 r47055) ) #1 SMP Fri Jan 29 19:42:29 CET 2021
2022-03-02 18:29:42 debug kernel[]: [ 0.000000] Found legacy serial port 0 for /soc@ffe00000/serial@4500
2022-03-02 18:29:42 debug kernel[]: [ 0.000000] mem=ffe04500, taddr=ffe04500, irq=0, clk=600000000, speed=0
2022-03-02 18:29:42 debug kernel[]: [ 0.000000] Found legacy serial port 1 for /soc@ffe00000/serial@4600
2022-03-02 18:29:42 debug kernel[]: [ 0.000000] mem=ffe04600, taddr=ffe04600, irq=0, clk=600000000, speed=0
2022-03-02 18:29:42 info kernel[]: [ 0.000000] CPU maps initialized for 1 thread per core
2022-03-02 18:29:42 debug kernel[]: [ 0.000000] (thread shift is 0)
2022-03-02 18:29:42 info kernel[]: [ 0.000000] bootconsole [udbg0] enabled
2022-03-02 18:29:42 err kernel[]: [ 0.000000] mpc85xx_qe_init: Could not find Quicc Engine node
2022-03-02 18:29:42 info kernel[]: [ 0.000000] MPC85xx RDB board from Freescale Semiconductor
2022-03-02 18:29:42 info kernel[]: [ 0.000000] barrier-nospec: using isync; sync as speculation barrier
2022-03-02 18:29:42 debug kernel[]: [ 0.000000] barrier-nospec: patched 573 locations
2022-03-02 18:29:42 debug kernel[]: [ 0.000000] Top of RAM: 0x80000000, Total RAM: 0x80000000
2022-03-02 18:29:42 debug kernel[]: [ 0.000000] Memory hole size: 0MB
2022-03-02 18:29:42 info kernel[]: [ 0.000000] Zone ranges:
2022-03-02 18:29:42 info kernel[]: [ 0.000000] DMA [mem 0x0000000000000000-0x000000001fffffff]
2022-03-02 18:29:42 info kernel[]: [ 0.000000] Normal empty
2022-03-02 18:29:42 info kernel[]: [ 0.000000] HighMem [mem 0x0000000020000000-0x000000007fffffff]
2022-03-02 18:29:42 info kernel[]: [ 0.000000] Movable zone start for each node
2022-03-02 18:29:42 info kernel[]: [ 0.000000] Early memory node ranges
2022-03-02 18:29:42 info kernel[]: [ 0.000000] node 0: [mem 0x0000000000000000-0x000000007fffffff]
2022-03-02 18:29:42 info kernel[]: [ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000007fffffff]
2022-03-02 18:29:42 debug kernel[]: [ 0.000000] On node 0 totalpages: 524288
2022-03-02 18:29:42 debug kernel[]: [ 0.000000] free_area_init_node: node 0, pgdat c0657b20, node_mem_map dede0000
2022-03-02 18:29:42 debug kernel[]: [ 0.000000] DMA zone: 1152 pages used for memmap
2022-03-02 18:29:42 debug kernel[]: [ 0.000000] DMA zone: 0 pages reserved
2022-03-02 18:29:42 debug kernel[]: [ 0.000000] DMA zone: 131072 pages, LIFO batch:31
2022-03-02 18:29:42 debug kernel[]: [ 0.000000] HighMem zone: 393216 pages, LIFO batch:31
2022-03-02 18:29:42 info kernel[]: [ 0.000000] MMU: Allocated 1088 bytes of context maps for 255 contexts
2022-03-02 18:29:42 info kernel[]: [ 0.000000] PERCPU: Embedded 10 pages/cpu @dedc2000 s9420 r8192 d23348 u40960
2022-03-02 18:29:42 debug kernel[]: [ 0.000000] pcpu-alloc: s9420 r8192 d23348 u40960 alloc=10*4096
2022-03-02 18:29:42 debug kernel[]: [ 0.000000] pcpu-alloc: [0] 0 [0] 1
2022-03-02 18:29:42 info kernel[]: [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 523136
2022-03-02 18:29:42 notice kernel[]: [ 0.000000] Kernel command line: root=/dev/mmcblk0p2 rootwait rw rootfstype=btrfs rootflags=subvol=@,commit=5 console=ttyS0,115200
2022-03-02 18:29:42 info kernel[]: [ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
2022-03-02 18:29:42 info kernel[]: [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
2022-03-02 18:29:42 info kernel[]: [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
2022-03-02 18:29:42 notice kernel[]: [ 0.000000] Sorting __ex_table...
2022-03-02 18:29:42 info kernel[]: [ 0.000000] Memory: 2005324K/2097152K available (5048K kernel code, 180K rwdata, 1100K rodata, 200K init, 244K bss, 91828K reserved, 0K cma-reserved, 1572856K highmem)
2022-03-02 18:29:42 info kernel[]: [ 0.000000] Kernel virtual memory layout:
2022-03-02 18:29:42 info kernel[]: [ 0.000000] * 0xfffbf000..0xfffff000 : fixmap
2022-03-02 18:29:42 info kernel[]: [ 0.000000] * 0xffc00000..0xffe00000 : highmem PTEs
2022-03-02 18:29:42 info kernel[]: [ 0.000000] * 0xffbfd000..0xffc00000 : early ioremap
2022-03-02 18:29:42 info kernel[]: [ 0.000000] * 0xe1000000..0xffbfd000 : vmalloc & ioremap
2022-03-02 18:29:42 info kernel[]: [ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
2022-03-02 18:29:42 info kernel[]: [ 0.000000] Hierarchical RCU implementation.
2022-03-02 18:29:42 info kernel[]: [ 0.000000] NR_IRQS:512 nr_irqs:512 16
2022-03-02 18:29:42 debug kernel[]: [ 0.000000] mpic: Resetting
2022-03-02 18:29:42 info kernel[]: [ 0.000000] mpic: Setting up MPIC " OpenPIC " version 1.2 at ffe40000, max 2 CPUs
2022-03-02 18:29:42 info kernel[]: [ 0.000000] mpic: ISU size: 256, shift: 8, mask: ff
2022-03-02 18:29:42 info kernel[]: [ 0.000000] mpic: Initializing for 256 sources
2022-03-02 18:29:42 err kernel[]: [ 0.000000] mpc85xx_rdb_pic_init: Could not find qe-ic node
2022-03-02 18:29:42 debug kernel[]: [ 0.000000] time_init: decrementer frequency = 75.000000 MHz
2022-03-02 18:29:42 debug kernel[]: [ 0.000000] time_init: processor frequency = 1200.000000 MHz
2022-03-02 18:29:42 info kernel[]: [ 0.000008] clocksource: timebase: mask: 0xffffffffffffffff max_cycles: 0x114c1bade8, max_idle_ns: 440795203839 ns
2022-03-02 18:29:42 info kernel[]: [ 0.010277] clocksource: timebase mult[d555555] shift[24] registered
2022-03-02 18:29:42 debug kernel[]: [ 0.016624] clockevent: decrementer mult[13333333] shift[32] cpu[0]
2022-03-02 18:29:42 info kernel[]: [ 0.016658] pid_max: default: 32768 minimum: 301
2022-03-02 18:29:42 info kernel[]: [ 0.021306] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
2022-03-02 18:29:42 info kernel[]: [ 0.027844] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
2022-03-02 18:29:42 info kernel[]: [ 0.035252] Initializing cgroup subsys io
2022-03-02 18:29:42 info kernel[]: [ 0.039190] Initializing cgroup subsys memory
2022-03-02 18:29:42 info kernel[]: [ 0.043541] Initializing cgroup subsys devices
2022-03-02 18:29:42 info kernel[]: [ 0.047963] Initializing cgroup subsys freezer
2022-03-02 18:29:42 info kernel[]: [ 0.052396] Initializing cgroup subsys net_cls
2022-03-02 18:29:42 info kernel[]: [ 0.056829] Initializing cgroup subsys pids
2022-03-02 18:29:42 info kernel[]: [ 0.061145] mpic: requesting IPIs...
2022-03-02 18:29:42 info kernel[]: [ 0.065665] Brought up 2 CPUs
2022-03-02 18:29:42 info kernel[]: [ 0.070674] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
2022-03-02 18:29:42 info kernel[]: [ 0.080351] futex hash table entries: 512 (order: 2, 16384 bytes)
2022-03-02 18:29:42 info kernel[]: [ 0.086527] xor: measuring software checksum speed
2022-03-02 18:29:42 info kernel[]: [ 0.101287] 8regs : 1472.000 MB/sec
2022-03-02 18:29:42 info kernel[]: [ 0.115425] 8regs_prefetch: 1312.000 MB/sec
2022-03-02 18:29:42 info kernel[]: [ 0.129909] 32regs : 1472.000 MB/sec
2022-03-02 18:29:42 info kernel[]: [ 0.144044] 32regs_prefetch: 1356.000 MB/sec
2022-03-02 18:29:42 info kernel[]: [ 0.148577] xor: using function: 32regs (1472.000 MB/sec)
2022-03-02 18:29:42 info kernel[]: [ 0.154296] NET: Registered protocol family 16
2022-03-02 18:29:42 info kernel[]: [ 0.163700] cpuidle: using governor ladder
2022-03-02 18:29:42 info kernel[]: [ 0.173956] Found FSL PCI host bridge at 0x00000000ffe08000. Firmware bus number: 0->0
2022-03-02 18:29:42 info kernel[]: [ 0.181806] PCI host bridge /pcie@ffe08000 (primary) ranges:
2022-03-02 18:29:42 info kernel[]: [ 0.187454] MEM 0x00000000c0000000..0x00000000dfffffff -> 0x00000000c0000000
2022-03-02 18:29:42 info kernel[]: [ 0.194666] IO 0x00000000ffc20000..0x00000000ffc2ffff -> 0x0000000000000000
2022-03-02 18:29:42 info kernel[]: [ 0.201804] /pcie@ffe08000: PCICSRBAR @ 0xfff00000
2022-03-02 18:29:42 info kernel[]: [ 0.206575] setup_pci_atmu: end of DRAM 80000000
2022-03-02 18:29:42 info kernel[]: [ 0.211439] Found FSL PCI host bridge at 0x00000000ffe09000. Firmware bus number: 0->1
2022-03-02 18:29:42 info kernel[]: [ 0.219280] PCI host bridge /pcie@ffe09000 ranges:
2022-03-02 18:29:42 info kernel[]: [ 0.224148] MEM 0x00000000a0000000..0x00000000bfffffff -> 0x00000000a0000000
2022-03-02 18:29:42 info kernel[]: [ 0.231362] IO 0x00000000ffc10000..0x00000000ffc1ffff -> 0x0000000000000000
2022-03-02 18:29:42 info kernel[]: [ 0.238498] /pcie@ffe09000: PCICSRBAR @ 0xfff00000
2022-03-02 18:29:42 info kernel[]: [ 0.243270] setup_pci_atmu: end of DRAM 80000000
2022-03-02 18:29:42 info kernel[]: [ 0.248127] Found FSL PCI host bridge at 0x00000000ffe0a000. Firmware bus number: 0->0
2022-03-02 18:29:42 info kernel[]: [ 0.255969] PCI host bridge /pcie@ffe0a000 ranges:
2022-03-02 18:29:42 info kernel[]: [ 0.260838] MEM 0x0000000080000000..0x000000009fffffff -> 0x0000000080000000
2022-03-02 18:29:42 info kernel[]: [ 0.268051] IO 0x00000000ffc00000..0x00000000ffc0ffff -> 0x0000000000000000
2022-03-02 18:29:42 info kernel[]: [ 0.275187] /pcie@ffe0a000: PCICSRBAR @ 0xfff00000
2022-03-02 18:29:42 info kernel[]: [ 0.279960] setup_pci_atmu: end of DRAM 80000000
2022-03-02 18:29:42 info kernel[]: [ 0.293311] PCI: Probing PCI hardware
2022-03-02 18:29:42 info kernel[]: [ 0.297046] fsl-pci ffe08000.pcie: PCI host bridge to bus 0000:00
2022-03-02 18:29:42 info kernel[]: [ 0.303067] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
2022-03-02 18:29:42 info kernel[]: [ 0.309233] pci_bus 0000:00: root bus resource [mem 0xc0000000-0xdfffffff]
2022-03-02 18:29:42 info kernel[]: [ 0.316102] pci_bus 0000:00: root bus resource [bus 00-ff]
2022-03-02 18:29:42 debug kernel[]: [ 0.321580] pci_bus 0000:00: busn_res: [bus 00-ff] end is updated to ff
2022-03-02 18:29:42 debug kernel[]: [ 0.321610] pci 0000:00:00.0: [1957:0070] type 01 class 0x0b2000
2022-03-02 18:29:42 debug kernel[]: [ 0.321633] pci 0000:00:00.0: reg 0x10: [mem 0xfff00000-0xffffffff]
2022-03-02 18:29:42 debug kernel[]: [ 0.321677] pci 0000:00:00.0: supports D1 D2
2022-03-02 18:29:42 debug kernel[]: [ 0.321685] pci 0000:00:00.0: PME# supported from D0 D1 D2 D3hot D3cold
2022-03-02 18:29:42 info kernel[]: [ 0.321874] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
2022-03-02 18:29:42 info kernel[]: [ 0.329894] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
2022-03-02 18:29:42 debug kernel[]: [ 0.335043] pci 0000:00:00.0: bridge window [io 0x0000-0x0fff]
2022-03-02 18:29:42 debug kernel[]: [ 0.335052] pci 0000:00:00.0: bridge window [mem 0x00000000-0x000fffff]
2022-03-02 18:29:42 debug kernel[]: [ 0.335061] pci 0000:00:00.0: bridge window [mem 0x00000000-0x000fffff 64bit pref]
2022-03-02 18:29:42 debug kernel[]: [ 0.335075] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
2022-03-02 18:29:42 debug kernel[]: [ 0.335085] pci_bus 0000:00: busn_res: [bus 00-ff] end is updated to 01
2022-03-02 18:29:42 info kernel[]: [ 0.335237] fsl-pci ffe09000.pcie: PCI host bridge to bus 0001:02
2022-03-02 18:29:42 info kernel[]: [ 0.341258] pci_bus 0001:02: root bus resource [io 0x20000-0x2ffff] (bus address [0x0000-0xffff])
2022-03-02 18:29:42 info kernel[]: [ 0.350207] pci_bus 0001:02: root bus resource [mem 0xa0000000-0xbfffffff]
2022-03-02 18:29:42 info kernel[]: [ 0.357074] pci_bus 0001:02: root bus resource [bus 02-ff]
2022-03-02 18:29:42 debug kernel[]: [ 0.362552] pci_bus 0001:02: busn_res: [bus 02-ff] end is updated to ff
2022-03-02 18:29:42 debug kernel[]: [ 0.362572] pci 0001:02:00.0: [1957:0070] type 01 class 0x0b2000
2022-03-02 18:29:42 debug kernel[]: [ 0.362590] pci 0001:02:00.0: reg 0x10: [mem 0xfff00000-0xffffffff]
2022-03-02 18:29:42 debug kernel[]: [ 0.362623] pci 0001:02:00.0: supports D1 D2
2022-03-02 18:29:42 debug kernel[]: [ 0.362630] pci 0001:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
2022-03-02 18:29:42 warning kernel[]: [ 0.362794] pci 0001:02:00.0: Primary bus is hard wired to 0
2022-03-02 18:29:42 info kernel[]: [ 0.368377] pci 0001:02:00.0: bridge configuration invalid ([bus 01-01]), reconfiguring
2022-03-02 18:29:42 debug kernel[]: [ 0.376476] pci 0001:03:00.0: [168c:0030] type 00 class 0x028000
2022-03-02 18:29:42 debug kernel[]: [ 0.376514] pci 0001:03:00.0: reg 0x10: [mem 0xa0000000-0xa001ffff 64bit]
2022-03-02 18:29:42 debug kernel[]: [ 0.376550] pci 0001:03:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
2022-03-02 18:29:42 debug kernel[]: [ 0.376605] pci 0001:03:00.0: supports D1
2022-03-02 18:29:42 debug kernel[]: [ 0.376613] pci 0001:03:00.0: PME# supported from D0 D1 D3hot
2022-03-02 18:29:42 info kernel[]: [ 0.378398] pci 0001:02:00.0: PCI bridge to [bus 03-ff]
2022-03-02 18:29:42 debug kernel[]: [ 0.383551] pci 0001:02:00.0: bridge window [io 0x20000-0x20fff]
2022-03-02 18:29:42 debug kernel[]: [ 0.383560] pci 0001:02:00.0: bridge window [mem 0xa0000000-0xa00fffff]
2022-03-02 18:29:42 debug kernel[]: [ 0.383604] pci_bus 0001:03: busn_res: [bus 03-ff] end is updated to 03
2022-03-02 18:29:42 debug kernel[]: [ 0.383615] pci_bus 0001:02: busn_res: [bus 02-ff] end is updated to 03
2022-03-02 18:29:42 info kernel[]: [ 0.383757] fsl-pci ffe0a000.pcie: PCI host bridge to bus 0002:04
2022-03-02 18:29:42 info kernel[]: [ 0.389782] pci_bus 0002:04: root bus resource [io 0x40000-0x4ffff] (bus address [0x0000-0xffff])
2022-03-02 18:29:42 info kernel[]: [ 0.398726] pci_bus 0002:04: root bus resource [mem 0x80000000-0x9fffffff]
2022-03-02 18:29:42 info kernel[]: [ 0.405594] pci_bus 0002:04: root bus resource [bus 04-ff]
2022-03-02 18:29:42 debug kernel[]: [ 0.411071] pci_bus 0002:04: busn_res: [bus 04-ff] end is updated to ff
2022-03-02 18:29:42 debug kernel[]: [ 0.411091] pci 0002:04:00.0: [1957:0070] type 01 class 0x0b2000
2022-03-02 18:29:42 debug kernel[]: [ 0.411110] pci 0002:04:00.0: reg 0x10: [mem 0xfff00000-0xffffffff]
2022-03-02 18:29:42 debug kernel[]: [ 0.411145] pci 0002:04:00.0: supports D1 D2
2022-03-02 18:29:42 debug kernel[]: [ 0.411152] pci 0002:04:00.0: PME# supported from D0 D1 D2 D3hot D3cold
2022-03-02 18:29:42 info kernel[]: [ 0.411323] pci 0002:04:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
2022-03-02 18:29:42 info kernel[]: [ 0.419339] pci 0002:04:00.0: PCI bridge to [bus 05-ff]
2022-03-02 18:29:42 debug kernel[]: [ 0.424488] pci 0002:04:00.0: bridge window [io 0x40000-0x40fff]
2022-03-02 18:29:42 debug kernel[]: [ 0.424496] pci 0002:04:00.0: bridge window [mem 0x00000000-0x000fffff]
2022-03-02 18:29:42 debug kernel[]: [ 0.424505] pci 0002:04:00.0: bridge window [mem 0x00000000-0x000fffff 64bit pref]
2022-03-02 18:29:42 debug kernel[]: [ 0.424518] pci_bus 0002:05: busn_res: [bus 05-ff] end is updated to 05
2022-03-02 18:29:42 debug kernel[]: [ 0.424527] pci_bus 0002:04: busn_res: [bus 04-ff] end is updated to 05
2022-03-02 18:29:42 warning kernel[]: [ 0.424574] PCI: Cannot allocate resource region 0 of PCI bridge 1, will remap
2022-03-02 18:29:42 warning kernel[]: [ 0.431725] PCI: Cannot allocate resource region 0 of device 0000:00:00.0, will remap
2022-03-02 18:29:42 warning kernel[]: [ 0.439545] PCI: Cannot allocate resource region 0 of device 0001:02:00.0, will remap
2022-03-02 18:29:42 warning kernel[]: [ 0.447368] PCI: Cannot allocate resource region 0 of device 0002:04:00.0, will remap
2022-03-02 18:29:42 debug kernel[]: [ 0.455196] PCI 0001:02 Cannot reserve Legacy IO [io 0x20000-0x20fff]
2022-03-02 18:29:42 debug kernel[]: [ 0.455203] PCI 0002:04 Cannot reserve Legacy IO [io 0x40000-0x40fff]
2022-03-02 18:29:42 info kernel[]: [ 0.455224] pci 0000:00:00.0: BAR 0: no space for [mem size 0x00100000]
2022-03-02 18:29:42 info kernel[]: [ 0.461798] pci 0000:00:00.0: BAR 0: failed to assign [mem size 0x00100000]
2022-03-02 18:29:42 info kernel[]: [ 0.468752] pci 0000:00:00.0: PCI bridge to [bus 01]
2022-03-02 18:29:42 info kernel[]: [ 0.473707] pci 0000:00:00.0: bridge window [mem 0xc0000000-0xdfffffff]
2022-03-02 18:29:42 info kernel[]: [ 0.480488] pci_bus 0000:00: Some PCI device resources are unassigned, try booting with pci=realloc
2022-03-02 18:29:42 debug kernel[]: [ 0.489528] pci_bus 0000:00: resource 4 [io 0x0000-0xffff]
2022-03-02 18:29:42 debug kernel[]: [ 0.489536] pci_bus 0000:00: resource 5 [mem 0xc0000000-0xdfffffff]
2022-03-02 18:29:42 debug kernel[]: [ 0.489544] pci_bus 0000:01: resource 1 [mem 0xc0000000-0xdfffffff]
2022-03-02 18:29:42 info kernel[]: [ 0.489559] pci 0001:02:00.0: BAR 0: no space for [mem size 0x00100000]
2022-03-02 18:29:42 info kernel[]: [ 0.496135] pci 0001:02:00.0: BAR 0: failed to assign [mem size 0x00100000]
2022-03-02 18:29:42 info kernel[]: [ 0.503094] pci 0001:03:00.0: BAR 6: assigned [mem 0xa0020000-0xa002ffff pref]
2022-03-02 18:29:42 info kernel[]: [ 0.510310] pci 0001:02:00.0: PCI bridge to [bus 03]
2022-03-02 18:29:42 info kernel[]: [ 0.515261] pci 0001:02:00.0: bridge window [io 0x20000-0x2ffff]
2022-03-02 18:29:42 info kernel[]: [ 0.521520] pci 0001:02:00.0: bridge window [mem 0xa0000000-0xbfffffff]
2022-03-02 18:29:42 info kernel[]: [ 0.528301] pci_bus 0001:02: Some PCI device resources are unassigned, try booting with pci=realloc
2022-03-02 18:29:42 debug kernel[]: [ 0.537341] pci_bus 0001:02: resource 4 [io 0x20000-0x2ffff]
2022-03-02 18:29:42 debug kernel[]: [ 0.537349] pci_bus 0001:02: resource 5 [mem 0xa0000000-0xbfffffff]
2022-03-02 18:29:42 debug kernel[]: [ 0.537357] pci_bus 0001:03: resource 0 [io 0x20000-0x2ffff]
2022-03-02 18:29:42 debug kernel[]: [ 0.537364] pci_bus 0001:03: resource 1 [mem 0xa0000000-0xbfffffff]
2022-03-02 18:29:42 info kernel[]: [ 0.537379] pci 0002:04:00.0: BAR 0: no space for [mem size 0x00100000]
2022-03-02 18:29:42 info kernel[]: [ 0.543949] pci 0002:04:00.0: BAR 0: failed to assign [mem size 0x00100000]
2022-03-02 18:29:42 info kernel[]: [ 0.550903] pci 0002:04:00.0: PCI bridge to [bus 05]
2022-03-02 18:29:42 info kernel[]: [ 0.555858] pci 0002:04:00.0: bridge window [io 0x40000-0x4ffff]
2022-03-02 18:29:42 info kernel[]: [ 0.562117] pci 0002:04:00.0: bridge window [mem 0x80000000-0x9fffffff]
2022-03-02 18:29:42 info kernel[]: [ 0.568898] pci_bus 0002:04: Some PCI device resources are unassigned, try booting with pci=realloc
2022-03-02 18:29:42 debug kernel[]: [ 0.577939] pci_bus 0002:04: resource 4 [io 0x40000-0x4ffff]
2022-03-02 18:29:42 debug kernel[]: [ 0.577947] pci_bus 0002:04: resource 5 [mem 0x80000000-0x9fffffff]
2022-03-02 18:29:42 debug kernel[]: [ 0.577954] pci_bus 0002:05: resource 0 [io 0x40000-0x4ffff]
2022-03-02 18:29:42 debug kernel[]: [ 0.577962] pci_bus 0002:05: resource 1 [mem 0x80000000-0x9fffffff]
2022-03-02 18:29:42 info kernel[]: [ 0.578223] mpic-msgr ffe41400.message: Found 0 message registers
2022-03-02 18:29:42 info kernel[]: [ 0.584240] mpic-msgr ffe41400.message: Of-device full name /soc@ffe00000/message@41400
2022-03-02 18:29:42 err kernel[]: [ 0.592244] mpic-msgr ffe41400.message: Failed to find message register block alias
2022-03-02 18:29:42 debug kernel[]: [ 0.600000] Setting up Freescale MSI support
2022-03-02 18:29:42 debug kernel[]: [ 0.600478] Registering qe_ic with sysfs...
2022-03-02 18:29:42 info kernel[]: [ 0.624755] raid6: int32x1 gen() 171 MB/s
2022-03-02 18:29:42 info kernel[]: [ 0.646141] raid6: int32x1 xor() 220 MB/s
2022-03-02 18:29:42 info kernel[]: [ 0.667455] raid6: int32x2 gen() 300 MB/s
2022-03-02 18:29:42 info kernel[]: [ 0.688824] raid6: int32x2 xor() 261 MB/s
2022-03-02 18:29:42 info kernel[]: [ 0.710126] raid6: int32x4 gen() 398 MB/s
2022-03-02 18:29:42 info kernel[]: [ 0.731429] raid6: int32x4 xor() 283 MB/s
2022-03-02 18:29:42 info kernel[]: [ 0.752791] raid6: int32x8 gen() 378 MB/s
2022-03-02 18:29:42 info kernel[]: [ 0.774126] raid6: int32x8 xor() 253 MB/s
2022-03-02 18:29:42 info kernel[]: [ 0.778311] raid6: using algorithm int32x4 gen() 398 MB/s
2022-03-02 18:29:42 info kernel[]: [ 0.783700] raid6: .... xor() 283 MB/s, rmw enabled
2022-03-02 18:29:42 info kernel[]: [ 0.788568] raid6: using intx1 recovery algorithm
2022-03-02 18:29:42 info kernel[]: [ 0.794434] clocksource: Switched to clocksource timebase
2022-03-02 18:29:42 info kernel[]: [ 0.800693] NET: Registered protocol family 2
2022-03-02 18:29:42 info kernel[]: [ 0.805331] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
2022-03-02 18:29:42 info kernel[]: [ 0.812336] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
2022-03-02 18:29:42 info kernel[]: [ 0.818775] TCP: Hash tables configured (established 4096 bind 4096)
2022-03-02 18:29:42 info kernel[]: [ 0.825146] UDP hash table entries: 256 (order: 1, 8192 bytes)
2022-03-02 18:29:42 info kernel[]: [ 0.830925] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
2022-03-02 18:29:42 info kernel[]: [ 0.837284] NET: Registered protocol family 1
2022-03-02 18:29:42 debug kernel[]: [ 0.841622] PCI: CLS 32 bytes, default 32
2022-03-02 18:29:42 info kernel[]: [ 0.847819] squashfs: version 4.0 (2009/01/31) Phillip Lougher
2022-03-02 18:29:42 info kernel[]: [ 0.853745] jffs2: version 2.2 (NAND) (SUMMARY) (ZLIB) (LZO) (LZMA) (RTIME) (RUBIN) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
2022-03-02 18:29:42 info kernel[]: [ 0.866434] bounce: pool size: 64 pages
2022-03-02 18:29:42 info kernel[]: [ 0.870247] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
2022-03-02 18:29:42 info kernel[]: [ 0.877587] io scheduler noop registered
2022-03-02 18:29:42 info kernel[]: [ 0.881494] io scheduler deadline registered (default)
2022-03-02 18:29:42 info kernel[]: [ 0.886915] pcieport 0001:02:00.0: enabling device (0106 -> 0107)
2022-03-02 18:29:42 info kernel[]: [ 0.893080] pcieport 0002:04:00.0: enabling device (0106 -> 0107)
2022-03-02 18:29:42 debug kernel[]: [ 0.899302] aer 0000:00:00.0:pcie02: service driver aer loaded
2022-03-02 18:29:42 debug kernel[]: [ 0.899334] aer 0001:02:00.0:pcie02: service driver aer loaded
2022-03-02 18:29:42 debug kernel[]: [ 0.899362] aer 0002:04:00.0:pcie02: service driver aer loaded
2022-03-02 18:29:42 info kernel[]: [ 0.899419] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
2022-03-02 18:29:42 debug kernel[]: [ 0.906309] pcie_pme 0000:00:00.0:pcie01: service driver pcie_pme loaded
2022-03-02 18:29:42 info kernel[]: [ 0.906334] pcieport 0001:02:00.0: Signaling PME through PCIe PME interrupt
2022-03-02 18:29:42 info kernel[]: [ 0.913259] pci 0001:03:00.0: Signaling PME through PCIe PME interrupt
2022-03-02 18:29:42 debug kernel[]: [ 0.919781] pcie_pme 0001:02:00.0:pcie01: service driver pcie_pme loaded
2022-03-02 18:29:42 info kernel[]: [ 0.919812] pcieport 0002:04:00.0: Signaling PME through PCIe PME interrupt
2022-03-02 18:29:42 debug kernel[]: [ 0.926735] pcie_pme 0002:04:00.0:pcie01: service driver pcie_pme loaded
2022-03-02 18:29:42 info kernel[]: [ 0.952810] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
2022-03-02 18:29:42 info kernel[]: [ 0.961309] console [ttyS0] disabled
2022-03-02 18:29:42 info kernel[]: [ 0.964839] serial8250.0: ttyS0 at MMIO 0xffe04500 (irq = 42, base_baud = 37500000) is a 16550A
2022-03-02 18:29:42 info kernel[]: [ 0.973515] console [ttyS0] enabled
2022-03-02 18:29:42 info kernel[]: [ 0.980455] bootconsole [udbg0] disabled
2022-03-02 18:29:42 info kernel[]: [ 0.988687] serial8250.0: ttyS1 at MMIO 0xffe04600 (irq = 42, base_baud = 37500000) is a 16550A
2022-03-02 18:29:42 info kernel[]: [ 0.997973] console [ttyS0] disabled
2022-03-02 18:29:42 info kernel[]: [ 1.001576] ffe04500.serial: ttyS0 at MMIO 0xffe04500 (irq = 42, base_baud = 37500000) is a 16550
2022-03-02 18:29:42 info kernel[]: [ 1.001588] console [ttyS0] enabled
2022-03-02 18:29:42 info kernel[]: [ 1.005492] ffe04600.serial: ttyS1 at MMIO 0xffe04600 (irq = 42, base_baud = 37500000) is a 16550
2022-03-02 18:29:42 info kernel[]: [ 1.021757] brd: module loaded
2022-03-02 18:29:42 info kernel[]: [ 1.025554] ef000000.nor: Found 1 x16 devices at 0x0 in 16-bit bank. Manufacturer ID 0x000001 Chip ID 0x002101
2022-03-02 18:29:42 info kernel[]: [ 1.035576] Amd/Fujitsu Extended Query Table at 0x0040
2022-03-02 18:29:42 info kernel[]: [ 1.040744] Amd/Fujitsu Extended Query version 1.3.
2022-03-02 18:29:42 notice kernel[]: [ 1.045802] number of CFI chips: 1
2022-03-02 18:29:42 notice kernel[]: [ 1.049428] 6 ofpart partitions found on MTD device ef000000.nor
2022-03-02 18:29:42 notice kernel[]: [ 1.055454] Creating 6 MTD partitions on "ef000000.nor":
2022-03-02 18:29:42 notice netifd[]: Interface 'loopback' is enabled
2022-03-02 18:29:42 notice netifd[]: Interface 'loopback' is setting up now
2022-03-02 18:29:42 notice kernel[]: [ 1.060774] 0x000000000000-0x000000020000 : "NOR (RO) DTB Image"
2022-03-02 18:29:42 notice kernel[]: [ 1.067368] 0x000000020000-0x0000001c0000 : "NOR (RO) Linux Kernel Image"
2022-03-02 18:29:42 notice kernel[]: [ 1.074676] 0x0000001c0000-0x000000340000 : "NOR (RO) JFFS2 Root File System"
2022-03-02 18:29:42 notice kernel[]: [ 1.082379] 0x000000340000-0x000000e40000 : "NOR (RO) NAND FW backup"
2022-03-02 18:29:42 notice kernel[]: [ 1.089487] 0x000000e40000-0x000000f00000 : "NOR (RW) Cert backup"
2022-03-02 18:29:42 notice kernel[]: [ 1.096349] 0x000000f00000-0x000001000000 : "NOR (RO) U-Boot Image"
2022-03-02 18:29:42 info kernel[]: [ 1.103717] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xda
2022-03-02 18:29:42 info kernel[]: [ 1.110102] nand: Micron MT29F2G08ABAEAWP
2022-03-02 18:29:42 info kernel[]: [ 1.114119] nand: 256 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
2022-03-02 18:29:42 info kernel[]: [ 1.122990] Bad block table found at page 131008, version 0x01
2022-03-02 18:29:42 notice netifd[]: Interface 'loopback' is now up
2022-03-02 18:29:42 info kernel[]: [ 1.129586] Bad block table found at page 130944, version 0x01
2022-03-02 18:29:42 notice kernel[]: [ 1.135989] 4 ofpart partitions found on MTD device ff800000.flash
2022-03-02 18:29:42 notice kernel[]: [ 1.142186] Creating 4 MTD partitions on "ff800000.flash":
2022-03-02 18:29:42 notice kernel[]: [ 1.147686] 0x000000000000-0x000000200000 : "NAND (RW) DTB Image"
2022-03-02 18:29:42 notice kernel[]: [ 1.154371] 0x000000200000-0x000000700000 : "NAND (RW) Linux Kernel Image"
2022-03-02 18:29:42 notice kernel[]: [ 1.161779] 0x000000700000-0x000010000000 : "NAND (RW) JFFS2 Root File System"
2022-03-02 18:29:42 notice kernel[]: [ 1.169735] 0x000000000000-0x000010000000 : "rootfs-ubifs"
2022-03-02 18:29:42 info kernel[]: [ 1.175950] eLBC NAND device at 0xff800000, bank 1
2022-03-02 18:29:42 info kernel[]: [ 1.181214] fsl_espi ffe07000.spi: cs=0, init_csmode=0x100008
2022-03-02 18:29:42 info kernel[]: [ 1.186981] fsl_espi ffe07000.spi: cs=1, init_csmode=0x100008
2022-03-02 18:29:42 info kernel[]: [ 1.192738] fsl_espi ffe07000.spi: cs=2, init_csmode=0x100008
2022-03-02 18:29:42 info kernel[]: [ 1.198495] fsl_espi ffe07000.spi: cs=3, init_csmode=0x100008
2022-03-02 18:29:42 info kernel[]: [ 1.205332] fsl_espi ffe07000.spi: at 0xe11c0000 (irq = 59)
2022-03-02 18:29:42 info kernel[]: [ 1.211341] libphy: Fixed MDIO Bus: probed
2022-03-02 18:29:42 info kernel[]: [ 1.215651] libphy: Freescale PowerQUICC MII Bus: probed
2022-03-02 18:29:42 info kernel[]: [ 1.223525] switch0: Atheros AR8337 rev. 2 switch registered on mdio@ffe24520
2022-03-02 18:29:42 info kernel[]: [ 1.275206] fsl-gianfar ffe24000.ethernet: enabled errata workarounds, flags: 0x4
2022-03-02 18:29:42 info kernel[]: [ 1.293157] fsl-gianfar ffe24000.ethernet eth0: mac: 00:00:00:00:00:00
2022-03-02 18:29:42 info kernel[]: [ 1.299698] fsl-gianfar ffe24000.ethernet eth0: Running with NAPI enabled
2022-03-02 18:29:42 info kernel[]: [ 1.306494] fsl-gianfar ffe24000.ethernet eth0: RX BD ring size for Q[0]: 256
2022-03-02 18:29:42 notice netifd[]: Interface 'wan' is enabled
2022-03-02 18:29:42 info kernel[]: [ 1.313637] fsl-gianfar ffe24000.ethernet eth0: TX BD ring size for Q[0]: 256
2022-03-02 18:29:42 info kernel[]: [ 1.321055] fsl-gianfar ffe25000.ethernet: enabled errata workarounds, flags: 0x4
2022-03-02 18:29:42 info kernel[]: [ 1.338934] fsl-gianfar ffe25000.ethernet eth1: mac: 00:00:00:00:00:00
2022-03-02 18:29:42 info kernel[]: [ 1.345477] fsl-gianfar ffe25000.ethernet eth1: Running with NAPI enabled
2022-03-02 18:29:42 info kernel[]: [ 1.352272] fsl-gianfar ffe25000.ethernet eth1: RX BD ring size for Q[0]: 256
2022-03-02 18:29:42 info kernel[]: [ 1.359416] fsl-gianfar ffe25000.ethernet eth1: TX BD ring size for Q[0]: 256
2022-03-02 18:29:42 info kernel[]: [ 1.366639] fsl-gianfar ffe26000.ethernet: enabled errata workarounds, flags: 0x4
2022-03-02 18:29:42 info kernel[]: [ 1.384497] fsl-gianfar ffe26000.ethernet eth2: mac: 00:00:00:00:00:00
2022-03-02 18:29:42 info kernel[]: [ 1.391048] fsl-gianfar ffe26000.ethernet eth2: Running with NAPI enabled
2022-03-02 18:29:42 info kernel[]: [ 1.397844] fsl-gianfar ffe26000.ethernet eth2: RX BD ring size for Q[0]: 256
2022-03-02 18:29:42 notice netifd[]: Network device 'eth2' link is up
2022-03-02 18:29:42 notice netifd[]: Interface 'wan' has link connectivity
2022-03-02 18:29:42 notice netifd[]: Interface 'wan' is setting up now
2022-03-02 18:29:42 info kernel[]: [ 1.404988] fsl-gianfar ffe26000.ethernet eth2: TX BD ring size for Q[0]: 256
2022-03-02 18:29:42 info kernel[]: [ 1.412220] ucc_geth_driver: QE UCC Gigabit Ethernet Controller
2022-03-02 18:29:42 info kernel[]: [ 1.418344] i2c /dev entries driver
2022-03-02 18:29:42 info kernel[]: [ 1.421976] mpc-i2c ffe03000.i2c: timeout 1000000 us
2022-03-02 18:29:42 info kernel[]: [ 1.429458] rtc-ds1307 0-006f: rtc core: registered mcp7940x as rtc0
2022-03-02 18:29:42 info kernel[]: [ 1.435839] rtc-ds1307 0-006f: 64 bytes nvram
2022-03-02 18:29:42 info kernel[]: [ 1.440374] mpc-i2c ffe03100.i2c: timeout 1000000 us
2022-03-02 18:29:42 info kernel[]: [ 1.445613] booke_wdt: powerpc book-e watchdog driver loaded
2022-03-02 18:29:42 info kernel[]: [ 1.451455] sdhci: Secure Digital Host Controller Interface driver
2022-03-02 18:29:42 info kernel[]: [ 1.457645] sdhci: Copyright(c) Pierre Ossman
2022-03-02 18:29:42 notice netifd[]: Network device 'eth0' link is up
2022-03-02 18:29:42 info kernel[]: [ 1.462007] sdhci-pltfm: SDHCI platform and OF driver helper
2022-03-02 18:29:42 info kernel[]: [ 1.467852] sdhci-esdhc ffe2e000.sdhc: No vmmc regulator found
2022-03-02 18:29:42 info kernel[]: [ 1.473696] sdhci-esdhc ffe2e000.sdhc: No vqmmc regulator found
2022-03-02 18:29:42 info kernel[]: [ 1.502047] mmc0: SDHCI controller on ffe2e000.sdhc [ffe2e000.sdhc] using DMA
2022-03-02 18:29:42 info kernel[]: [ 1.509902] NET: Registered protocol family 10
2022-03-02 18:29:42 info kernel[]: [ 1.514987] NET: Registered protocol family 17
2022-03-02 18:29:42 info kernel[]: [ 1.519490] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
2022-03-02 18:29:42 notice kernel[]: [ 1.532147] Bridge firewalling registered
2022-03-02 18:29:42 info kernel[]: [ 1.536177] 8021q: 802.1Q VLAN Support v1.8
2022-03-02 18:29:42 warning kernel[]: [ 1.541198] BTRFS: using crc32c-generic for crc32c
2022-03-02 18:29:42 notice netifd[]: bridge 'br-lan' link is up
2022-03-02 18:29:42 notice netifd[]: Interface 'lan' has link connectivity
2022-03-02 18:29:42 notice netifd[]: Network device 'eth1' link is up
2022-03-02 18:29:42 info kernel[]: [ 1.547334] Btrfs loaded, integrity-checker=on
2022-03-02 18:29:42 info kernel[]: [ 1.553288] rtc-ds1307 0-006f: setting system clock to 2022-03-02 17:29:23 UTC (1646242163)
2022-03-02 18:29:42 info kernel[]: [ 1.562220] Waiting for root device /dev/mmcblk0p2...
2022-03-02 18:29:42 info kernel[]: [ 1.577220] mmc0: new high speed SDHC card at address 5048
2022-03-02 18:29:42 info kernel[]: [ 1.583076] mmcblk0: mmc0:5048 Y032V 28.9 GiB
2022-03-02 18:29:42 info kernel[]: [ 1.588843] mmcblk0: p1 p2
2022-03-02 18:29:42 info kernel[]: [ 1.668877] BTRFS: device fsid b63eaec4-2425-4be0-b31b-3a2e263ef69a devid 1 transid 10 /dev/root
2022-03-02 18:29:42 info kernel[]: [ 1.679026] BTRFS info (device mmcblk0p2): disk space caching is enabled
2022-03-02 18:29:42 info kernel[]: [ 1.685748] BTRFS: has skinny extents
2022-03-02 18:29:42 info kernel[]: [ 1.702719] BTRFS: detected SSD devices, enabling SSD mode
2022-03-02 18:29:42 notice netifd[]: Network device 'lo' link is up
2022-03-02 18:29:42 info kernel[]: [ 1.718073] VFS: Mounted root (btrfs filesystem) on device 0:13.
2022-03-02 18:29:42 info kernel[]: [ 1.724327] Freeing unused kernel memory: 200K
2022-03-02 18:29:42 info kernel[]: 1.846981] init: Console is alive
2022-03-02 18:29:42 info kernel[]: 1.850515] init: - watchdog -
2022-03-02 18:29:42 info kernel[]: [ 2.229149] usbcore: registered new interface driver usbfs
2022-03-02 18:29:42 info kernel[]: [ 2.234693] usbcore: registered new interface driver hub
2022-03-02 18:29:42 info kernel[]: [ 2.240068] usbcore: registered new device driver usb
2022-03-02 18:29:42 info kernel[]: [ 2.246744] Button Hotplug driver version 0.4.1
2022-03-02 18:29:42 info kernel[]: [ 2.253134] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
2022-03-02 18:29:42 info kernel[]: [ 2.260071] ehci-platform: EHCI generic platform driver
2022-03-02 18:29:42 notice netifd[]: Interface 'loopback' has link connectivity
2022-03-02 18:29:42 info kernel[]: [ 2.265798] ehci-fsl: Freescale EHCI Host controller driver
2022-03-02 18:29:42 info kernel[]: [ 2.271442] fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller
2022-03-02 18:29:42 info kernel[]: [ 2.278081] fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1
2022-03-02 18:29:42 info kernel[]: [ 2.285369] fsl-ehci fsl-ehci.0: irq 28, io mem 0xffe22000
2022-03-02 18:29:42 info kernel[]: [ 2.296056] fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00
2022-03-02 18:29:42 info kernel[]: [ 2.302074] hub 1-0:1.0: USB hub found
2022-03-02 18:29:42 info kernel[]: [ 2.305863] hub 1-0:1.0: 1 port detected
2022-03-02 18:29:42 info kernel[]: [ 2.311169] uhci_hcd: USB Universal Host Controller Interface driver
2022-03-02 18:29:42 info kernel[]: [ 2.611052] usb 1-1: new high-speed USB device number 2 using fsl-ehci
2022-03-02 18:29:42 info kernel[]: [ 2.731731] hub 1-1:1.0: USB hub found
2022-03-02 18:29:42 info kernel[]: [ 2.735629] hub 1-1:1.0: 2 ports detected
2022-03-02 18:29:42 info kernel[]: 2.853971] init: - preinit -
2022-03-02 18:29:42 notice kernel[]: [ 3.515328] random: mktemp: uninitialized urandom read (6 bytes read, 64 bits of entropy available)
2022-03-02 18:29:42 notice kernel[]: [ 3.526489] random: mktemp: uninitialized urandom read (6 bytes read, 64 bits of entropy available)
2022-03-02 18:29:42 notice kernel[]: [ 3.537518] random: mktemp: uninitialized urandom read (6 bytes read, 64 bits of entropy available)
2022-03-02 18:29:42 notice kernel[]: 6.580716] mount_root: mounting /dev/root
2022-03-02 18:29:42 info kernel[]: [ 6.758862] BTRFS info (device mmcblk0p2): disk space caching is enabled
2022-03-02 18:29:42 info kernel[]: 6.773196] procd: - early -
2022-03-02 18:29:42 info kernel[]: 6.776307] procd: - watchdog -
2022-03-02 18:29:42 notice kernel[]: [ 6.914208] random: jshn: uninitialized urandom read (4 bytes read, 87 bits of entropy available)
2022-03-02 18:29:42 notice kernel[]: [ 6.957609] random: jshn: uninitialized urandom read (4 bytes read, 88 bits of entropy available)
2022-03-02 18:29:42 notice kernel[]: [ 7.010900] random: jshn: uninitialized urandom read (4 bytes read, 90 bits of entropy available)
2022-03-02 18:29:42 notice kernel[]: [ 7.046144] random: jshn: uninitialized urandom read (4 bytes read, 90 bits of entropy available)
2022-03-02 18:29:42 info kernel[]: 7.441420] procd: - ubus -
2022-03-02 18:29:42 notice kernel[]: [ 8.398087] random: nonblocking pool is initialized
2022-03-02 18:29:42 info kernel[]: 8.444844] procd: - init -
2022-03-02 18:29:42 info kernel[]: [ 8.531510] Netfilter messages via NETLINK v0.30.
2022-03-02 18:29:42 info kernel[]: [ 8.539844] NET: Registered protocol family 8
2022-03-02 18:29:42 info kernel[]: [ 8.544237] NET: Registered protocol family 20
2022-03-02 18:29:42 info kernel[]: [ 8.562723] tun: Universal TUN/TAP device driver, 1.6
2022-03-02 18:29:42 info kernel[]: [ 8.567842] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
2022-03-02 18:29:42 info kernel[]: [ 8.578914] sit: IPv6 over IPv4 tunneling driver
2022-03-02 18:29:42 info kernel[]: [ 8.586466] gre: GRE over IPv4 demultiplexor driver
2022-03-02 18:29:42 info kernel[]: [ 8.592516] ip_gre: GRE over IPv4 tunneling driver
2022-03-02 18:29:42 info kernel[]: [ 8.600410] PPP generic driver version 2.4.2
2022-03-02 18:29:42 info kernel[]: [ 8.606569] ip6_tables: (C) 2000-2006 Netfilter Core Team
2022-03-02 18:29:42 info kernel[]: [ 8.619483] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
2022-03-02 18:29:42 info kernel[]: [ 8.745561] ip_set: protocol 6
2022-03-02 18:29:42 info kernel[]: [ 9.239465] Loading modules backported from Linux version wt-2017-01-31-0-ge882dff19e7f
2022-03-02 18:29:42 info kernel[]: [ 9.247500] Backport generated by backports.git backports-20160324-13-g24da7d3c
2022-03-02 18:29:42 info kernel[]: [ 9.542585] u32 classifier
2022-03-02 18:29:42 info kernel[]: [ 9.545323] input device check on
2022-03-02 18:29:42 info kernel[]: [ 9.548993] Actions configured
2022-03-02 18:29:42 info kernel[]: [ 9.604597] Mirror/redirect action on
2022-03-02 18:29:42 info kernel[]: [ 9.717487] GACT probability on
2022-03-02 18:29:42 info kernel[]: [ 10.182548] netem: version 1.3
2022-03-02 18:29:42 info kernel[]: [ 10.389032] usbcore: registered new interface driver cdc_wdm
2022-03-02 18:29:42 info kernel[]: [ 10.399598] Ebtables v2.0 registered
2022-03-02 18:29:42 info kernel[]: [ 10.406541] ip_tables: (C) 2000-2006 Netfilter Core Team
2022-03-02 18:29:42 info kernel[]: [ 10.419783] ctnetlink v0.93: registering with nfnetlink.
2022-03-02 18:29:42 info kernel[]: [ 10.460221] nfnl_acct: registering with nfnetlink.
2022-03-02 18:29:42 info kernel[]: [ 10.466574] PPP MPPE Compression module registered
2022-03-02 18:29:42 info kernel[]: [ 10.472256] NET: Registered protocol family 24
2022-03-02 18:29:42 info kernel[]: [ 10.483597] usbcore: registered new interface driver usbserial
2022-03-02 18:29:42 info kernel[]: [ 10.489551] usbcore: registered new interface driver usbserial_generic
2022-03-02 18:29:42 info kernel[]: [ 10.496167] usbserial: USB Serial support registered for generic
2022-03-02 18:29:42 info kernel[]: [ 10.518108] xt_time: kernel timezone is -0000
2022-03-02 18:29:42 info kernel[]: [ 10.526604] usbcore: registered new interface driver cdc_ether
2022-03-02 18:29:42 info kernel[]: [ 10.542393] usbcore: registered new interface driver qmi_wwan
2022-03-02 18:29:42 info kernel[]: [ 10.549821] usbcore: registered new interface driver rndis_host
2022-03-02 18:29:42 debug kernel[]: [ 10.682827] ath: EEPROM regdomain: 0x0
2022-03-02 18:29:42 debug kernel[]: [ 10.682839] ath: EEPROM indicates default country code should be used
2022-03-02 18:29:42 debug kernel[]: [ 10.682843] ath: doing EEPROM country->regdmn map search
2022-03-02 18:29:42 debug kernel[]: [ 10.682854] ath: country maps to regdmn code: 0x3a
2022-03-02 18:29:42 debug kernel[]: [ 10.682859] ath: Country alpha2 being used: US
2022-03-02 18:29:42 debug kernel[]: [ 10.682863] ath: Regpair used: 0x3a
2022-03-02 18:29:42 debug kernel[]: [ 10.690773] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
2022-03-02 18:29:42 info kernel[]: [ 10.692754] ieee80211 phy0: Atheros AR9300 Rev:3 mem=0xe3140000, irq=27
2022-03-02 18:29:42 info kernel[]: [ 10.702152] usbcore: registered new interface driver option
2022-03-02 18:29:42 info kernel[]: [ 10.707872] usbserial: USB Serial support registered for GSM modem (1-port)
2022-03-02 18:29:42 info kernel[]: [ 16.239836] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
2022-03-02 18:29:42 info kernel[]: [ 16.242380] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
2022-03-02 18:29:42 info kernel[]: [ 16.244945] IPv6: ADDRCONF(NETDEV_UP): eth2: link is not ready
2022-03-02 18:29:42 info kernel[]: [ 18.242229] fsl-gianfar ffe24000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
2022-03-02 18:29:42 info kernel[]: [ 18.242310] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
2022-03-02 18:29:42 info kernel[]: [ 18.246059] fsl-gianfar ffe25000.ethernet eth1: Link is Up - 1Gbps/Full - flow control rx/tx
2022-03-02 18:29:42 info kernel[]: [ 18.246075] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
2022-03-02 18:29:42 info kernel[]: [ 20.252433] fsl-gianfar ffe26000.ethernet eth2: Link is Up - 1Gbps/Full - flow control rx/tx
2022-03-02 18:29:42 info kernel[]: [ 20.252460] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
2022-03-02 18:29:42 info kernel[]: [ 21.252808] device eth0 entered promiscuous mode
2022-03-02 18:29:42 info kernel[]: [ 21.253989] br-lan: port 1(eth0) entered forwarding state
2022-03-02 18:29:42 info kernel[]: [ 21.254021] br-lan: port 1(eth0) entered forwarding state
2022-03-02 18:29:42 info kernel[]: [ 21.348804] device eth1 entered promiscuous mode
2022-03-02 18:29:42 info kernel[]: [ 21.348852] br-lan: port 2(eth1) entered forwarding state
2022-03-02 18:29:42 info kernel[]: [ 21.348869] br-lan: port 2(eth1) entered forwarding state
2022-03-02 18:29:43 notice netifd[]: wan (5287): udhcpc: started, v1.29.3
2022-03-02 18:29:43 notice netifd[]: wan (5287): udhcpc: sending discover
2022-03-02 18:29:43 notice firewall[]: Reloading firewall due to ifup of lan (br-lan)
2022-03-02 18:29:43 err turris-firewall-rules[]: (v64) Unable to determine the WAN interface. Exiting...
2022-03-02 18:29:43 info ucollect[5446]: Initializing emergency signal handlers
2022-03-02 18:29:43 info ucollect[5446]: Creating a main loop
2022-03-02 18:29:43 info ucollect[5446]: Creating uplink
2022-03-02 18:29:43 info ucollect[5446]: Initializing PCAP (in) on lo
2022-03-02 18:29:43 info ucollect[5446]: Initializing PCAP (out) on lo
2022-03-02 18:29:43 info ucollect[5446]: Loading plugin library libplugin_ucollect_badconf_25.so
2022-03-02 18:29:43 info ucollect[5446]: Installing plugin Badconf with api version 0
2022-03-02 18:29:43 info ucollect[5446]: Loading plugin library libplugin_ucollect_bandwidth_22.so
2022-03-02 18:29:43 info ucollect[5446]: Installing plugin Bandwidth with api version 0
2022-03-02 18:29:43 info ucollect[5446]: Loading plugin library libplugin_ucollect_count_28.so
2022-03-02 18:29:43 info ucollect[5446]: Installing plugin Count with api version 0
2022-03-02 18:29:43 info ucollect[5446]: Loading plugin library libplugin_ucollect_fake_23.so
2022-03-02 18:29:43 info ucollect[5446]: Installing plugin Fake with api version 0
2022-03-02 18:29:43 info ucollect[5446]: Loading plugin library libplugin_ucollect_flow_33.so
2022-03-02 18:29:43 info ucollect[5446]: Installing plugin Flow with api version 2
2022-03-02 18:29:43 info ucollect[5446]: Loading plugin library libpluglib_ucollect_diffstore_1.2.so
2022-03-02 18:29:43 info ucollect[5446]: Loading plugin library libplugin_ucollect_fwup_12.so
2022-03-02 18:29:43 info ucollect[5446]: Installing plugin Fwup with api version 2
2022-03-02 18:29:43 info ucollect[5446]: Loading plugin library libplugin_ucollect_refused_13.so
2022-03-02 18:29:43 info ucollect[5446]: Installing plugin Refused with api version 0
2022-03-02 18:29:43 info ucollect[5446]: Loading plugin library libplugin_ucollect_sniff_19.so
2022-03-02 18:29:43 info ucollect[5446]: Installing plugin Sniff with api version 0
2022-03-02 18:29:43 info ucollect[5446]: Loading plugin library libplugin_ucollect_spoof_8.so
2022-03-02 18:29:43 info ucollect[5446]: Installing plugin Spoof with api version 0
2022-03-02 18:29:43 info ucollect[5446]: Changing remote uplink address to api.turris.cz:5679
2022-03-02 18:29:43 err ucollect[5446]: Failed to resolve uplink api.turris.cz:5679: Name or service not known
2022-03-02 18:29:43 warning ucollect[5446]: Didn't get any V4 address in resolution of api.turris.cz
2022-03-02 18:29:43 warning ucollect[5446]: Didn't get any V6 address in resolution of api.turris.cz
2022-03-02 18:29:43 info ucollect[5446]: Sending login credentials disabled
2022-03-02 18:29:43 info ucollect[5105]: Last message 'Sending login creden' repeated 5 times, suppressed by syslog-ng on turris
2022-03-02 18:29:43 info ucollect[5446]: Unloading plugin library
2022-03-02 18:29:43 info ucollect[5446]: Running the main loop
2022-03-02 18:29:43 info ucollect[5446]: Reconnecting to api.turris.cz:5679 now
2022-03-02 18:29:43 info ucollect[5446]: Socat started
2022-03-02 18:29:43 err ucollect[5446]: Error from socat: 2022/03/02 18:29:43 socat[5466] E getaddrinfo("api.turris.cz", "NULL", {1,10,1,6}, {}): Name or service not known
2022-03-02 18:29:43 warning ucollect[5446]: Remote closed the uplink api.turris.cz:5679, reconnecting
2022-03-02 18:29:43 warning ucollect[5446]: epoll_wait on 4 interrupted, retry
2022-03-02 18:29:43 warning ucollect[5446]: Reconnecting too often, waiting a little while
2022-03-02 18:29:43 info ucollect[5446]: Going to reconnect to api.turris.cz:5679 after 2 seconds
2022-03-02 18:29:44 info kernel[]: [ 23.254254] fsl-gianfar ffe24000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
2022-03-02 18:29:44 info kernel[]: [ 23.260054] br-lan: port 1(eth0) entered forwarding state
2022-03-02 18:29:44 info kernel[]: [ 23.352057] br-lan: port 2(eth1) entered forwarding state
2022-03-02 18:29:44 info kernel[]: [ 23.352304] fsl-gianfar ffe25000.ethernet eth1: Link is Up - 1Gbps/Full - flow control rx/tx
2022-03-02 18:29:44 notice netifd[]: Network device 'eth2' link is down
2022-03-02 18:29:44 notice netifd[]: Interface 'wan' has link connectivity loss
2022-03-02 18:29:44 notice netifd[]: wan (5287): udhcpc: received SIGTERM
2022-03-02 18:29:45 info ucollect[5446]: Reconnecting to api.turris.cz:5679 now
2022-03-02 18:29:45 info ucollect[5446]: Socat started
2022-03-02 18:29:45 err ucollect[5446]: Failed to resolve uplink api.turris.cz:5679: Name or service not known
2022-03-02 18:29:45 warning ucollect[5446]: Didn't get any V4 address in resolution of api.turris.cz
2022-03-02 18:29:45 warning ucollect[5446]: Didn't get any V6 address in resolution of api.turris.cz
2022-03-02 18:29:46 err ucollect[5446]: Error from socat: 2022/03/02 18:29:46 socat[5754] E getaddrinfo("api.turris.cz", "NULL", {1,2,1,6}, {}): Name or service not known
2022-03-02 18:29:46 warning ucollect[5446]: Remote closed the uplink api.turris.cz:5679, reconnecting
2022-03-02 18:29:46 warning ucollect[5446]: epoll_wait on 4 interrupted, retry
2022-03-02 18:29:46 info ucollect[5446]: Reconnecting to api.turris.cz:5679 now
2022-03-02 18:29:46 warning ucollect[5446]: Reconnecting too often, waiting a little while
2022-03-02 18:29:46 info ucollect[5446]: Going to reconnect to api.turris.cz:5679 after 4 seconds
2022-03-02 18:29:46 emerg turris[]: Router Turris successfully started.
2022-03-02 18:29:46 info procd[]: - init complete -
2022-03-02 18:29:46 notice dnsmasq[]: DNS rebinding protection is active, will discard upstream RFC1918 responses!
2022-03-02 18:29:46 notice dnsmasq[]: Allowing 127.0.0.0/8 responses
2022-03-02 18:29:47 info unbound[]: [5888:0] info: start of service (unbound 1.13.0).
2022-03-02 18:29:49 notice netifd[]: Network device 'eth2' link is up
2022-03-02 18:29:49 notice netifd[]: Interface 'wan' has link connectivity
2022-03-02 18:29:49 notice netifd[]: Interface 'wan' is setting up now
2022-03-02 18:29:49 info kernel[]: [ 28.376509] fsl-gianfar ffe26000.ethernet eth2: Link is Up - 1Gbps/Full - flow control rx/tx
2022-03-02 18:29:49 notice netifd[]: wan (5948): udhcpc: started, v1.29.3
2022-03-02 18:29:50 info ucollect[5446]: Reconnecting to api.turris.cz:5679 now
2022-03-02 18:29:50 info ucollect[5446]: Socat started
2022-03-02 18:29:50 notice netifd[]: wan (5948): udhcpc: sending discover
2022-03-02 18:29:50 err unbound[]: [5888:0] error: udp connect failed: Network is unreachable for 192.5.5.241 port 53
2022-03-02 18:29:50 err unbound[]: [5888:0] error: udp connect failed: Network is unreachable for 192.33.4.12 port 53
2022-03-02 18:29:50 err unbound[]: [5888:0] error: udp connect failed: Permission denied for 2001:503:c27::2:30 port 53
2022-03-02 18:29:50 err unbound[]: [5888:0] error: udp connect failed: Permission denied for 2001:500:a8::e port 53
2022-03-02 18:29:50 err unbound[]: [5888:0] error: udp connect failed: Permission denied for 2001:dc3::35 port 53
2022-03-02 18:29:50 err unbound[]: [5888:0] error: udp connect failed: Network is unreachable for 198.41.0.4 port 53
2022-03-02 18:29:50 err unbound[]: [5888:0] error: udp connect failed: Network is unreachable for 199.9.14.201 port 53
2022-03-02 18:29:50 err unbound[5105]: Last message '[5888:0] error: udp ' repeated 1 times, suppressed by syslog-ng on turris
2022-03-02 18:29:50 err unbound[]: [5888:0] error: udp connect failed: Permission denied for 2001:7fd::1 port 53
2022-03-02 18:29:50 err unbound[]: [5888:0] error: udp connect failed: Network is unreachable for 202.12.27.33 port 53
2022-03-02 18:29:50 err unbound[]: [5888:0] error: udp connect failed: Network is unreachable for 199.7.83.42 port 53
2022-03-02 18:29:50 err unbound[]: [5888:0] error: udp connect failed: Network is unreachable for 198.97.190.53 port 53
2022-03-02 18:29:50 err unbound[]: [5888:0] error: udp connect failed: Permission denied for 2001:503:ba3e::2:30 port 53
2022-03-02 18:29:50 err unbound[]: [5888:0] error: udp connect failed: Network is unreachable for 199.7.91.13 port 53
2022-03-02 18:29:50 err unbound[]: [5888:0] error: udp connect failed: Permission denied for 2001:500:2f::f port 53
2022-03-02 18:29:50 err unbound[]: [5888:0] error: udp connect failed: Permission denied for 2001:7fe::53 port 53
2022-03-02 18:29:50 err unbound[]: [5888:0] error: udp connect failed: Permission denied for 2001:500:2d::d port 53
2022-03-02 18:29:50 err unbound[]: [5888:0] error: udp connect failed: Network is unreachable for 192.203.230.10 port 53
2022-03-02 18:29:50 err unbound[]: [5888:0] error: udp connect failed: Permission denied for 2001:500:1::53 port 53
2022-03-02 18:29:50 err unbound[]: [5888:0] error: udp connect failed: Network is unreachable for 193.0.14.129 port 53
2022-03-02 18:29:50 err unbound[]: [5888:0] error: udp connect failed: Permission denied for 2001:500:9f::42 port 53
2022-03-02 18:29:50 err unbound[]: [5888:0] error: udp connect failed: Network is unreachable for 192.112.36.4 port 53
2022-03-02 18:29:50 err unbound[]: [5888:0] error: udp connect failed: Network is unreachable for 192.58.128.30 port 53
2022-03-02 18:29:50 notice netifd[]: wan (5948): udhcpc: sending select for 192.168.0.123
2022-03-02 18:29:50 err unbound[]: [5888:0] error: udp connect failed: Permission denied for 2001:500:200::b port 53
2022-03-02 18:29:50 err unbound[]: [5888:0] error: udp connect failed: Permission denied for 2001:500:2::c port 53
2022-03-02 18:29:50 notice netifd[]: wan (5948): udhcpc: lease of 192.168.0.123 obtained, lease time 86400
2022-03-02 18:29:50 err unbound[]: [5888:0] error: udp connect failed: Permission denied for 2001:500:12::d0d port 53
2022-03-02 18:29:50 err unbound[]: [5888:0] error: udp connect failed: Network is unreachable for 192.36.148.17 port 53
2022-03-02 18:29:50 notice netifd[]: Interface 'wan6' is enabled
2022-03-02 18:29:50 notice netifd[]: Network alias 'eth2' link is up
2022-03-02 18:29:50 notice netifd[]: Interface 'wan6' has link connectivity
2022-03-02 18:29:50 notice netifd[]: Interface 'wan6' is setting up now
2022-03-02 18:29:50 notice netifd[]: Interface 'wan' is now up
2022-03-02 18:29:50 info dnsmasq[5976]: started, version 2.79 DNS disabled
2022-03-02 18:29:50 info dnsmasq[5976]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth no-nettlehash no-DNSSEC loop-detect inotify
2022-03-02 18:29:50 info dnsmasq-dhcp[5976]: DHCP, IP range 192.168.1.100 -- 192.168.1.249, lease time 12h
2022-03-02 18:29:50 info dnsmasq-dhcp[5976]: read /etc/ethers - 0 addresses
2022-03-02 18:29:50 err unbound[]: [5888:0] error: udp connect failed: Permission denied for 2001:678:11::1 port 53
2022-03-02 18:29:50 err unbound[]: [5888:0] error: udp connect failed: Permission denied for 2001:678:1::1 port 53
2022-03-02 18:29:50 err unbound[]: [5888:0] error: udp connect failed: Permission denied for 2001:678:f::1 port 53
2022-03-02 18:29:50 err unbound[]: [5888:0] error: udp connect failed: Permission denied for 2001:678:10::1 port 53
2022-03-02 18:29:50 info unbound[]: [5888:0] info: service stopped (unbound 1.13.0).
2022-03-02 18:29:50 info unbound[]: [6056:0] info: start of service (unbound 1.13.0).
2022-03-02 18:29:55 err ucollect[5446]: Failed to resolve uplink api.turris.cz:5679: Name or service not known
2022-03-02 18:29:55 warning ucollect[5446]: Didn't get any V4 address in resolution of api.turris.cz
2022-03-02 18:29:55 warning ucollect[5446]: Didn't get any V6 address in resolution of api.turris.cz
2022-03-02 18:29:55 err ucollect[5446]: Error from socat: 2022/03/02 18:29:55 socat[5953] E getaddrinfo("api.turris.cz", "NULL", {1,10,1,6}, {}): Name or service not known
2022-03-02 18:29:55 warning ucollect[5446]: Remote closed the uplink api.turris.cz:5679, reconnecting
2022-03-02 18:29:55 warning ucollect[5446]: epoll_wait on 4 interrupted, retry
2022-03-02 18:29:55 info ucollect[5446]: Reconnecting to api.turris.cz:5679 now
2022-03-02 18:29:55 info ucollect[5446]: Socat started
2022-03-02 18:29:55 err ucollect[5446]: Error from socat: 2022/03/02 18:29:55 socat[6789] E getaddrinfo("api.turris.cz", "NULL", {1,2,1,6}, {}): Name or service not known
2022-03-02 18:29:55 warning ucollect[5446]: Reconnecting too often, waiting a little while
2022-03-02 18:29:55 info ucollect[5446]: Going to reconnect to api.turris.cz:5679 after 8 seconds
2022-03-02 18:29:57 info dnsmasq-dhcp[5976]: DHCPDISCOVER(br-lan) 00:e0:4c:68:06:85
2022-03-02 18:29:57 info dnsmasq-dhcp[5976]: DHCPOFFER(br-lan) 192.168.1.199 00:e0:4c:68:06:85
2022-03-02 18:29:57 info dnsmasq[5976]: exiting on receipt of SIGTERM
2022-03-02 18:29:57 info dnsmasq[6922]: started, version 2.79 DNS disabled
2022-03-02 18:29:57 info dnsmasq[6922]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth no-nettlehash no-DNSSEC loop-detect inotify
2022-03-02 18:29:57 info dnsmasq-dhcp[6922]: DHCP, IP range 192.168.1.100 -- 192.168.1.249, lease time 12h
2022-03-02 18:29:57 info dnsmasq-dhcp[6922]: read /etc/ethers - 0 addresses
2022-03-02 18:29:58 info dnsmasq-dhcp[6922]: DHCPREQUEST(br-lan) 192.168.1.199 00:e0:4c:68:06:85
2022-03-02 18:29:58 info dnsmasq-dhcp[6922]: DHCPACK(br-lan) 192.168.1.199 00:e0:4c:68:06:85 Computor
2022-03-02 18:30:00 notice firewall[]: Reloading firewall due to ifup of wan (eth2)
2022-03-02 18:30:00 info turris-firewall-rules[]: (v64) IPv4 WAN interface used - 'eth2'
2022-03-02 18:30:00 info turris-firewall-rules[]: (v64) IPv6 WAN interface used - 'eth2'
2022-03-02 18:30:00 info turris-firewall-rules[]: (v64) injected ipset loaded 'create turris_100FA4E0_lb_a_4 hash:net family inet hashsize 131072 maxelem 131072'
2022-03-02 18:30:00 info turris-firewall-rules[]: (v64) injected ipset loaded 'create turris_100FA4E0_lb_a_6 hash:net family inet6 hashsize 1024 maxelem 1024'
2022-03-02 18:30:01 info turris-firewall-rules[]: (v64) 3524 ipv4 address(es) and 3 ipv6 address(es) were loaded (c83b72d5b03454292e5000b3967bc350), 0 rule(s) overriden, 0 rule(s) skipped
2022-03-02 18:30:01 info /usr/sbin/cron[7526]: (root) CMD (nethist_stats.lua)
2022-03-02 18:30:01 info /usr/sbin/cron[7531]: (root) CMD (/usr/bin/notifier)
2022-03-02 18:30:01 info /usr/sbin/cron[7534]: (root) CMD (/usr/bin/get-api-crl)
2022-03-02 18:30:01 info /usr/sbin/cron[7529]: (root) CMD (/usr/share/nikola/bin/nikola.sh)
2022-03-02 18:30:01 info /usr/sbin/cron[7533]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2022-03-02 18:30:03 info ucollect[5446]: Reconnecting to api.turris.cz:5679 now
2022-03-02 18:30:03 info ucollect[5446]: Socat started
2022-03-02 18:30:03 warning ucollect[5446]: Didn't get any V4 address in resolution of api.turris.cz
2022-03-02 18:30:03 err ucollect[5446]: Error from socat: 2022/03/02 18:30:03 socat[7994] E connect(5, AF=10 [2001:1488:ac15:ff80:0000:0000:0000:0101]:5679, 28): Permission denied
2022-03-02 18:30:03 warning ucollect[5446]: Remote closed the uplink api.turris.cz:5679, reconnecting
2022-03-02 18:30:03 warning ucollect[5446]: epoll_wait on 4 interrupted, retry
2022-03-02 18:30:03 warning ucollect[5446]: Reconnecting too often, waiting a little while
2022-03-02 18:30:03 info ucollect[5446]: Going to reconnect to api.turris.cz:5679 after 16 seconds
2022-03-02 18:30:04 info nikola[]: (v43.1) recognized WAN interfaces: eth2, lo
2022-03-02 18:30:07 err nikola[]: (v43.1) socket: [Errno 2] No such file or directory
2022-03-02 18:30:19 info sshd[8010]: Failed password for root from 192.168.1.199 port 51582 ssh2
2022-03-02 18:30:19 info ucollect[5446]: Reconnecting to api.turris.cz:5679 now
2022-03-02 18:30:19 info ucollect[5446]: Socat started
2022-03-02 18:30:19 warning ucollect[5446]: Didn't get any V4 address in resolution of api.turris.cz
2022-03-02 18:30:20 err ucollect[5446]: Error from socat: 2022/03/02 18:30:19 socat[8012] E getaddrinfo("api.turris.cz", "NULL", {1,2,1,6}, {}): Name or service not known
2022-03-02 18:30:20 warning ucollect[5446]: Remote closed the uplink api.turris.cz:5679, reconnecting
2022-03-02 18:30:20 warning ucollect[5446]: epoll_wait on 4 interrupted, retry
2022-03-02 18:30:20 info ucollect[5446]: Reconnecting to api.turris.cz:5679 now
2022-03-02 18:30:20 warning ucollect[5446]: Reconnecting too often, waiting a little while
2022-03-02 18:30:20 info ucollect[5446]: Going to reconnect to api.turris.cz:5679 after 32 seconds
2022-03-02 18:30:43 warning ucollect[5446]: epoll_wait on 4 interrupted, retry
2022-03-02 18:30:43 info ucollect[5446]: Destroying uplink to api.turris.cz:5679
2022-03-02 18:30:43 info ucollect[5446]: Releasing the main loop
2022-03-02 18:30:43 info ucollect[5446]: Closing both PCAPs on lo
2022-03-02 18:30:43 info ucollect[5446]: Removing plugin Badconf
2022-03-02 18:30:43 info ucollect[5446]: Unloading plugin library
2022-03-02 18:30:43 info ucollect[5446]: Removing plugin Bandwidth
2022-03-02 18:30:43 info ucollect[5446]: Removing plugin Count
2022-03-02 18:30:43 info ucollect[5446]: Removing plugin Fake
2022-03-02 18:30:43 info ucollect[5446]: Removing plugin Flow
2022-03-02 18:30:43 info ucollect[5446]: Removing plugin Fwup
2022-03-02 18:30:43 info ucollect[5446]: Removing plugin Refused
2022-03-02 18:30:43 info ucollect[5446]: Removing plugin Sniff
2022-03-02 18:30:43 info ucollect[5446]: Removing plugin Spoof
2022-03-02 18:30:43 info ucollect[8140]: Initializing emergency signal handlers
2022-03-02 18:30:43 info ucollect[8140]: Creating a main loop
2022-03-02 18:30:43 info ucollect[8140]: Creating uplink
2022-03-02 18:30:43 info ucollect[8140]: Initializing PCAP (in) on eth2
2022-03-02 18:30:43 info ucollect[8140]: Initializing PCAP (out) on eth2
2022-03-02 18:30:43 info ucollect[8140]: Initializing PCAP (in) on lo
2022-03-02 18:30:43 info ucollect[8140]: Initializing PCAP (out) on lo
2022-03-02 18:30:43 info ucollect[8140]: Loading plugin library libplugin_ucollect_badconf_25.so
2022-03-02 18:30:43 info ucollect[8140]: Installing plugin Badconf with api version 0
2022-03-02 18:30:43 info ucollect[8140]: Loading plugin library libplugin_ucollect_bandwidth_22.so
2022-03-02 18:30:43 info ucollect[8140]: Installing plugin Bandwidth with api version 0
2022-03-02 18:30:43 info ucollect[8140]: Loading plugin library libplugin_ucollect_count_28.so
2022-03-02 18:30:43 info ucollect[8140]: Installing plugin Count with api version 0
2022-03-02 18:30:43 info ucollect[8140]: Loading plugin library libplugin_ucollect_fake_23.so
2022-03-02 18:30:43 info ucollect[8140]: Installing plugin Fake with api version 0
2022-03-02 18:30:43 info ucollect[8140]: Loading plugin library libplugin_ucollect_flow_33.so
2022-03-02 18:30:43 info ucollect[8140]: Installing plugin Flow with api version 2
2022-03-02 18:30:43 info ucollect[8140]: Loading plugin library libpluglib_ucollect_diffstore_1.2.so
2022-03-02 18:30:43 info ucollect[8140]: Loading plugin library libplugin_ucollect_fwup_12.so
2022-03-02 18:30:43 info ucollect[8140]: Installing plugin Fwup with api version 2
2022-03-02 18:30:43 info ucollect[8140]: Loading plugin library libplugin_ucollect_refused_13.so
2022-03-02 18:30:43 info ucollect[8140]: Installing plugin Refused with api version 0
2022-03-02 18:30:43 info ucollect[8140]: Loading plugin library libplugin_ucollect_sniff_19.so
2022-03-02 18:30:43 info ucollect[8140]: Installing plugin Sniff with api version 0
2022-03-02 18:30:43 info ucollect[8140]: Loading plugin library libplugin_ucollect_spoof_8.so
2022-03-02 18:30:43 info ucollect[8140]: Installing plugin Spoof with api version 0
2022-03-02 18:30:43 info ucollect[8140]: Changing remote uplink address to api.turris.cz:5679
2022-03-02 18:30:43 warning ucollect[8140]: Didn't get any V4 address in resolution of api.turris.cz
2022-03-02 18:30:43 info ucollect[8140]: Sending login credentials disabled
2022-03-02 18:30:43 info ucollect[5105]: Last message 'Sending login creden' repeated 5 times, suppressed by syslog-ng on turris
2022-03-02 18:30:43 info ucollect[8140]: Unloading plugin library
2022-03-02 18:30:43 info ucollect[8140]: Running the main loop
2022-03-02 18:30:43 info ucollect[8140]: Reconnecting to api.turris.cz:5679 now
2022-03-02 18:30:43 info ucollect[8140]: Socat started
2022-03-02 18:30:43 err ucollect[8140]: Error from socat: 2022/03/02 18:30:43 socat[8143] E connect(5, AF=10 [2001:1488:ac15:ff80:0000:0000:0000:0101]:5679, 28): Permission denied
2022-03-02 18:30:43 warning ucollect[8140]: Remote closed the uplink api.turris.cz:5679, reconnecting
2022-03-02 18:30:43 warning ucollect[8140]: epoll_wait on 4 interrupted, retry
2022-03-02 18:30:43 warning ucollect[8140]: Reconnecting too often, waiting a little while
2022-03-02 18:30:43 info ucollect[8140]: Going to reconnect to api.turris.cz:5679 after 2 seconds
2022-03-02 18:30:45 info ucollect[8140]: Reconnecting to api.turris.cz:5679 now
2022-03-02 18:30:45 info ucollect[8140]: Socat started
2022-03-02 18:30:45 warning ucollect[8140]: Didn't get any V4 address in resolution of api.turris.cz
2022-03-02 18:30:45 err ucollect[8140]: Error from socat: 2022/03/02 18:30:45 socat[8146] E getaddrinfo("api.turris.cz", "NULL", {1,2,1,6}, {}): Name or service not known
2022-03-02 18:30:45 warning ucollect[8140]: Remote closed the uplink api.turris.cz:5679, reconnecting
2022-03-02 18:30:45 warning ucollect[8140]: epoll_wait on 4 interrupted, retry
2022-03-02 18:30:45 warning ucollect[8140]: Reconnecting too often, waiting a little while
2022-03-02 18:30:45 info ucollect[8140]: Going to reconnect to api.turris.cz:5679 after 4 seconds
2022-03-02 18:30:49 info ucollect[8140]: Reconnecting to api.turris.cz:5679 now
2022-03-02 18:30:49 info ucollect[8140]: Socat started
2022-03-02 18:30:49 warning ucollect[8140]: Didn't get any V4 address in resolution of api.turris.cz
2022-03-02 18:30:49 err ucollect[8140]: Error from socat: 2022/03/02 18:30:49 socat[8147] E connect(5, AF=10 [2001:1488:ac15:ff80:0000:0000:0000:0101]:5679, 28): Permission denied
2022-03-02 18:30:49 warning ucollect[8140]: Remote closed the uplink api.turris.cz:5679, reconnecting
2022-03-02 18:30:49 warning ucollect[8140]: epoll_wait on 4 interrupted, retry
2022-03-02 18:30:49 warning ucollect[8140]: Reconnecting too often, waiting a little while
2022-03-02 18:30:49 info ucollect[8140]: Going to reconnect to api.turris.cz:5679 after 8 seconds
2022-03-02 18:30:51 warning ucollect[8140]: epoll_wait on 4 interrupted, retry
2022-03-02 18:30:51 info ucollect[8140]: Destroying uplink to api.turris.cz:5679
2022-03-02 18:30:51 info ucollect[8140]: Releasing the main loop
2022-03-02 18:30:51 info ucollect[8140]: Closing both PCAPs on eth2
2022-03-02 18:30:51 info ucollect[8140]: Closing both PCAPs on lo
2022-03-02 18:30:51 info ucollect[8140]: Removing plugin Badconf
2022-03-02 18:30:51 info ucollect[8140]: Unloading plugin library
2022-03-02 18:30:51 info ucollect[8140]: Removing plugin Bandwidth
2022-03-02 18:30:51 info ucollect[8140]: Removing plugin Count
2022-03-02 18:30:51 info ucollect[8140]: Removing plugin Fake
2022-03-02 18:30:51 info ucollect[8140]: Removing plugin Flow
2022-03-02 18:30:51 info ucollect[8140]: Removing plugin Fwup
2022-03-02 18:30:51 info ucollect[8140]: Removing plugin Refused
2022-03-02 18:30:51 info ucollect[8140]: Removing plugin Sniff
2022-03-02 18:30:51 info ucollect[8140]: Removing plugin Spoof
2022-03-02 18:30:51 info ucollect[8252]: Initializing emergency signal handlers
2022-03-02 18:30:51 info ucollect[8252]: Creating a main loop
2022-03-02 18:30:51 info ucollect[8252]: Creating uplink
2022-03-02 18:30:51 info ucollect[8252]: Initializing PCAP (in) on eth2
2022-03-02 18:30:51 info ucollect[8252]: Initializing PCAP (out) on eth2
2022-03-02 18:30:51 info ucollect[8252]: Initializing PCAP (in) on lo
2022-03-02 18:30:51 info ucollect[8252]: Initializing PCAP (out) on lo
2022-03-02 18:30:51 info ucollect[8252]: Loading plugin library libplugin_ucollect_badconf_25.so
2022-03-02 18:30:51 info ucollect[8252]: Installing plugin Badconf with api version 0
2022-03-02 18:30:51 info ucollect[8252]: Loading plugin library libplugin_ucollect_bandwidth_22.so
2022-03-02 18:30:51 info ucollect[8252]: Installing plugin Bandwidth with api version 0
2022-03-02 18:30:51 info ucollect[8252]: Loading plugin library libplugin_ucollect_count_28.so
2022-03-02 18:30:51 info ucollect[8252]: Installing plugin Count with api version 0
2022-03-02 18:30:51 info ucollect[8252]: Loading plugin library libplugin_ucollect_fake_23.so
2022-03-02 18:30:51 info ucollect[8252]: Installing plugin Fake with api version 0
2022-03-02 18:30:51 info ucollect[8252]: Loading plugin library libplugin_ucollect_flow_33.so
2022-03-02 18:30:51 info ucollect[8252]: Installing plugin Flow with api version 2
2022-03-02 18:30:51 info ucollect[8252]: Loading plugin library libpluglib_ucollect_diffstore_1.2.so
2022-03-02 18:30:51 info ucollect[8252]: Loading plugin library libplugin_ucollect_fwup_12.so
2022-03-02 18:30:51 info ucollect[8252]: Installing plugin Fwup with api version 2
2022-03-02 18:30:51 info ucollect[8252]: Loading plugin library libplugin_ucollect_refused_13.so
2022-03-02 18:30:51 info ucollect[8252]: Installing plugin Refused with api version 0
2022-03-02 18:30:51 info ucollect[8252]: Loading plugin library libplugin_ucollect_sniff_19.so
2022-03-02 18:30:51 info ucollect[8252]: Installing plugin Sniff with api version 0
2022-03-02 18:30:51 info ucollect[8252]: Loading plugin library libplugin_ucollect_spoof_8.so
2022-03-02 18:30:51 info ucollect[8252]: Installing plugin Spoof with api version 0
2022-03-02 18:30:51 info ucollect[8252]: Changing remote uplink address to api.turris.cz:5679
2022-03-02 18:30:51 warning ucollect[8252]: Didn't get any V4 address in resolution of api.turris.cz
2022-03-02 18:30:51 info ucollect[8252]: Sending login credentials disabled
2022-03-02 18:30:51 info ucollect[5105]: Last message 'Sending login creden' repeated 5 times, suppressed by syslog-ng on turris
2022-03-02 18:30:51 info ucollect[8252]: Unloading plugin library
2022-03-02 18:30:51 info ucollect[8252]: Running the main loop
2022-03-02 18:30:51 info ucollect[8252]: Reconnecting to api.turris.cz:5679 now
2022-03-02 18:30:51 info ucollect[8252]: Socat started
2022-03-02 18:30:51 err ucollect[8252]: Error from socat: 2022/03/02 18:30:51 socat[8255] E connect(5, AF=10 [2001:1488:ac15:ff80:0000:0000:0000:0101]:5679, 28): Permission denied
2022-03-02 18:30:51 warning ucollect[8252]: Remote closed the uplink api.turris.cz:5679, reconnecting
2022-03-02 18:30:51 warning ucollect[8252]: epoll_wait on 4 interrupted, retry
2022-03-02 18:30:51 warning ucollect[8252]: Reconnecting too often, waiting a little while
2022-03-02 18:30:51 info ucollect[8252]: Going to reconnect to api.turris.cz:5679 after 2 seconds
2022-03-02 18:30:52 info sshd[8010]: Failed password for root from 192.168.1.199 port 51582 ssh2
2022-03-02 18:30:53 info ucollect[8252]: Reconnecting to api.turris.cz:5679 now
2022-03-02 18:30:53 info ucollect[8252]: Socat started
2022-03-02 18:30:53 warning ucollect[8252]: Didn't get any V4 address in resolution of api.turris.cz
2022-03-02 18:30:53 err ucollect[8252]: Error from socat: 2022/03/02 18:30:53 socat[8256] E getaddrinfo("api.turris.cz", "NULL", {1,2,1,6}, {}): Name or service not known
2022-03-02 18:30:53 warning ucollect[8252]: Remote closed the uplink api.turris.cz:5679, reconnecting
2022-03-02 18:30:53 warning ucollect[8252]: epoll_wait on 4 interrupted, retry
2022-03-02 18:30:53 warning ucollect[8252]: Reconnecting too often, waiting a little while
2022-03-02 18:30:53 info ucollect[8252]: Going to reconnect to api.turris.cz:5679 after 4 seconds
2022-03-02 18:30:55 info sshd[8010]: Accepted password for root from 192.168.1.199 port 51582 ssh2
2022-03-02 18:30:57 info ucollect[8252]: Reconnecting to api.turris.cz:5679 now
2022-03-02 18:30:57 info ucollect[8252]: Socat started
2022-03-02 18:30:57 warning ucollect[8252]: Didn't get any V4 address in resolution of api.turris.cz
2022-03-02 18:30:57 err ucollect[8252]: Error from socat: 2022/03/02 18:30:57 socat[8271] E connect(5, AF=10 [2001:1488:ac15:ff80:0000:0000:0000:0101]:5679, 28): Permission denied
2022-03-02 18:30:57 warning ucollect[8252]: Remote closed the uplink api.turris.cz:5679, reconnecting
2022-03-02 18:30:57 warning ucollect[8252]: epoll_wait on 4 interrupted, retry
2022-03-02 18:30:57 warning ucollect[8252]: Reconnecting too often, waiting a little while
2022-03-02 18:30:57 info ucollect[8252]: Going to reconnect to api.turris.cz:5679 after 8 seconds
2022-03-02 18:31:01 info /usr/sbin/cron[8273]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2022-03-02 18:31:05 info ucollect[8252]: Reconnecting to api.turris.cz:5679 now
2022-03-02 18:31:05 info ucollect[8252]: Socat started
2022-03-02 18:31:05 warning ucollect[8252]: Didn't get any V4 address in resolution of api.turris.cz
2022-03-02 18:31:05 err ucollect[8252]: Error from socat: 2022/03/02 18:31:05 socat[8276] E getaddrinfo("api.turris.cz", "NULL", {1,2,1,6}, {}): Name or service not known
2022-03-02 18:31:05 warning ucollect[8252]: Remote closed the uplink api.turris.cz:5679, reconnecting
2022-03-02 18:31:05 warning ucollect[8252]: epoll_wait on 4 interrupted, retry
2022-03-02 18:31:05 warning ucollect[8252]: Reconnecting too often, waiting a little while
2022-03-02 18:31:05 info ucollect[8252]: Going to reconnect to api.turris.cz:5679 after 16 seconds
2022-03-02 18:31:21 info ucollect[8252]: Reconnecting to api.turris.cz:5679 now
2022-03-02 18:31:21 info ucollect[8252]: Socat started
2022-03-02 18:31:21 warning ucollect[8252]: Didn't get any V4 address in resolution of api.turris.cz
2022-03-02 18:31:21 err ucollect[8252]: Error from socat: 2022/03/02 18:31:21 socat[8289] E connect(5, AF=10 [2001:1488:ac15:ff80:0000:0000:0000:0101]:5679, 28): Permission denied
2022-03-02 18:31:21 warning ucollect[8252]: Remote closed the uplink api.turris.cz:5679, reconnecting
2022-03-02 18:31:21 warning ucollect[8252]: epoll_wait on 4 interrupted, retry
2022-03-02 18:31:21 warning ucollect[8252]: Reconnecting too often, waiting a little while
2022-03-02 18:31:21 info ucollect[8252]: Going to reconnect to api.turris.cz:5679 after 32 seconds
2022-03-02 18:31:53 info ucollect[8252]: Reconnecting to api.turris.cz:5679 now
2022-03-02 18:31:53 info ucollect[8252]: Socat started
2022-03-02 18:31:53 warning ucollect[8252]: Didn't get any V4 address in resolution of api.turris.cz
2022-03-02 18:31:53 err ucollect[8252]: Error from socat: 2022/03/02 18:31:53 socat[8310] E getaddrinfo("api.turris.cz", "NULL", {1,2,1,6}, {}): Name or service not known
2022-03-02 18:31:53 warning ucollect[8252]: Remote closed the uplink api.turris.cz:5679, reconnecting
2022-03-02 18:31:53 warning ucollect[8252]: epoll_wait on 4 interrupted, retry
2022-03-02 18:31:54 info ucollect[8252]: Reconnecting to api.turris.cz:5679 now
2022-03-02 18:31:54 warning ucollect[8252]: Reconnecting too often, waiting a little while
2022-03-02 18:31:54 info ucollect[8252]: Going to reconnect to api.turris.cz:5679 after 64 seconds
2022-03-02 18:32:01 info /usr/sbin/cron[8323]: (root) CMD (nethist_stats.lua)
2022-03-02 18:32:01 info /usr/sbin/cron[8324]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2022-03-02 18:32:58 info ucollect[8252]: Reconnecting to api.turris.cz:5679 now
2022-03-02 18:32:58 info ucollect[8252]: Socat started
2022-03-02 18:32:58 warning ucollect[8252]: Didn't get any V4 address in resolution of api.turris.cz
2022-03-02 18:32:58 err ucollect[8252]: Error from socat: 2022/03/02 18:32:58 socat[8410] E connect(5, AF=10 [2001:1488:ac15:ff80:0000:0000:0000:0101]:5679, 28): Permission denied
2022-03-02 18:32:58 warning ucollect[8252]: Remote closed the uplink api.turris.cz:5679, reconnecting
2022-03-02 18:32:58 warning ucollect[8252]: epoll_wait on 4 interrupted, retry
2022-03-02 18:32:58 warning ucollect[8252]: Reconnecting too often, waiting a little while
2022-03-02 18:32:58 info ucollect[8252]: Going to reconnect to api.turris.cz:5679 after 128 seconds
2022-03-02 18:33:01 info /usr/sbin/cron[8447]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2022-03-02 18:34:01 info /usr/sbin/cron[8622]: (root) CMD (nethist_stats.lua)
2022-03-02 18:34:01 info /usr/sbin/cron[8625]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2022-03-02 18:35:01 info /usr/sbin/cron[8666]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2022-03-02 18:35:01 info /usr/sbin/cron[8668]: (root) CMD (/usr/bin/notifier)
2022-03-02 18:35:06 info ucollect[8252]: Reconnecting to api.turris.cz:5679 now
2022-03-02 18:35:06 info ucollect[8252]: Socat started
2022-03-02 18:35:06 warning ucollect[8252]: Didn't get any V4 address in resolution of api.turris.cz
2022-03-02 18:35:06 err ucollect[8252]: Error from socat: 2022/03/02 18:35:06 socat[8698] E getaddrinfo("api.turris.cz", "NULL", {1,2,1,6}, {}): Name or service not known
2022-03-02 18:35:06 warning ucollect[8252]: Remote closed the uplink api.turris.cz:5679, reconnecting
2022-03-02 18:35:06 warning ucollect[8252]: epoll_wait on 4 interrupted, retry
2022-03-02 18:35:06 warning ucollect[8252]: Reconnecting too often, waiting a little while
2022-03-02 18:35:06 info ucollect[8252]: Going to reconnect to api.turris.cz:5679 after 256 seconds
2022-03-02 18:35:31 info kernel[]: [ 370.856523] BTRFS info (device mmcblk0p2): quota is enabled
2022-03-02 18:35:32 info kernel[]: [ 371.310912] BTRFS info (device mmcblk0p2): qgroup scan completed (inconsistency flag cleared)
2022-03-02 18:36:01 info /usr/sbin/cron[8765]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2022-03-02 18:36:01 info /usr/sbin/cron[8764]: (root) CMD (nethist_stats.lua)
2022-03-02 18:36:05 info kernel[]: [ 404.876012] BTRFS info (device mmcblk0p2): quota is enabled
2022-03-02 18:37:01 info /usr/sbin/cron[8853]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2022-03-02 18:38:01 info /usr/sbin/cron[8897]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2022-03-02 18:38:01 info /usr/sbin/cron[8896]: (root) CMD (nethist_stats.lua)
2022-03-02 18:39:01 info /usr/sbin/cron[8939]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2022-03-02 18:39:22 info ucollect[8252]: Reconnecting to api.turris.cz:5679 now
2022-03-02 18:39:22 info ucollect[8252]: Socat started
2022-03-02 18:39:22 err ucollect[8252]: Failed to resolve uplink api.turris.cz:5679: Name or service not known
2022-03-02 18:39:22 warning ucollect[8252]: Didn't get any V4 address in resolution of api.turris.cz
2022-03-02 18:39:22 warning ucollect[8252]: Didn't get any V6 address in resolution of api.turris.cz
2022-03-02 18:39:22 err ucollect[8252]: Error from socat: 2022/03/02 18:39:22 socat[8954] E connect(5, AF=10 [2001:1488:ac15:ff80:0000:0000:0000:0101]:5679, 28): Permission denied
2022-03-02 18:39:22 warning ucollect[8252]: Remote closed the uplink api.turris.cz:5679, reconnecting
2022-03-02 18:39:22 warning ucollect[8252]: epoll_wait on 4 interrupted, retry
2022-03-02 18:39:22 warning ucollect[8252]: Reconnecting too often, waiting a little while
2022-03-02 18:39:22 info ucollect[8252]: Going to reconnect to api.turris.cz:5679 after 300 seconds
2022-03-02 18:40:01 info /usr/sbin/cron[8985]: (root) CMD (nethist_stats.lua)
2022-03-02 18:40:01 info /usr/sbin/cron[8988]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2022-03-02 18:40:01 info /usr/sbin/cron[8987]: (root) CMD (/usr/bin/notifier)
2022-03-02 18:41:01 info /usr/sbin/cron[9056]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2022-03-02 18:42:01 info /usr/sbin/cron[9218]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2022-03-02 18:42:01 info /usr/sbin/cron[9217]: (root) CMD (nethist_stats.lua)
2022-03-02 18:43:01 info /usr/sbin/cron[9504]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2022-03-02 18:44:01 info /usr/sbin/cron[9574]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2022-03-02 18:44:01 info /usr/sbin/cron[9573]: (root) CMD (nethist_stats.lua)
2022-03-02 18:44:22 info ucollect[8252]: Reconnecting to api.turris.cz:5679 now
2022-03-02 18:44:22 info ucollect[8252]: Socat started
2022-03-02 18:44:24 info ucollect[8252]: Activating plugin Count
2022-03-02 18:44:24 info ucollect[8252]: Activating plugin Sniff
2022-03-02 18:44:24 info ucollect[8252]: Activating plugin Flow
2022-03-02 18:44:24 info ucollect[8252]: Activating plugin Refused
2022-03-02 18:44:24 info ucollect[8252]: Activating plugin Bandwidth
2022-03-02 18:44:24 info ucollect[8252]: Activating plugin Fake
2022-03-02 18:44:24 info ucollect[8252]: Activating plugin Fwup
2022-03-02 18:44:24 info ucollect[8252]: Activating plugin Spoof
2022-03-02 18:44:24 info ucollect[8252]: Received configuration 49828441 (max. 5000 flows, 1800000 ms timeout)
2022-03-02 18:44:24 info ucollect[8252]: Received Refused config version 3
2022-03-02 18:44:24 info ucollect[8252]: Fake configuration version 1
2022-03-02 18:44:24 info ucollect[8252]: FWUp config 48834208 with 2 sets
2022-03-02 18:44:24 warning ucollect[8252]: epoll_wait on 4 interrupted, retry
2022-03-02 18:44:24 info ucollect[8252]: Updating filter addresses from version 0 to version 54874614 (epoch 4)
2022-03-02 18:44:24 info ucollect[8252]: Updating ipset turris_100FA4E0_lb_a_4_X from version 0 to version 54874654 (epoch 4)
2022-03-02 18:44:34 warning ucollect[5105]: Last message 'epoll_wait on 4 inte' repeated 1 times, suppressed by syslog-ng on turris
2022-03-02 18:45:01 info /usr/sbin/cron[9624]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2022-03-02 18:45:01 info /usr/sbin/cron[9627]: (root) CMD (/usr/share/nikola/bin/nikola.sh)
2022-03-02 18:45:01 info /usr/sbin/cron[9626]: (root) CMD (/usr/bin/notifier)
2022-03-02 18:45:03 info nikola[]: (v43.1) recognized WAN interfaces: eth2, lo
2022-03-02 18:45:08 info nikola[]: (v43.1) Establishing connection took 0.694481 seconds
2022-03-02 18:45:08 info nikola[]: (v43.1) Logrotate took 0.013623 seconds
2022-03-02 18:45:08 info nikola[]: (v43.1) Syslog parsing took 0.056658 seconds
2022-03-02 18:45:09 info nikola[]: (v43.1) Session init took 0.626001 seconds
2022-03-02 18:45:09 info nikola[]: (v43.1) Records parsed: 17
2022-03-02 18:45:09 info nikola[]: (v43.1) Records after filtering: 16
2022-03-02 18:45:09 info nikola[]: (v43.1) Records filtering took 0.013545 seconds
2022-03-02 18:45:09 info nikola[]: (v43.1) {'msg': 'Data were inserted into work queue.'}
2022-03-02 18:45:09 info nikola[]: (v43.1) Sending records took 0.089333 seconds
2022-03-02 18:46:01 info /usr/sbin/cron[9717]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2022-03-02 18:46:01 info /usr/sbin/cron[9716]: (root) CMD (nethist_stats.lua)
2022-03-02 18:47:01 info /usr/sbin/cron[9759]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2022-03-02 18:48:01 info /usr/sbin/cron[9801]: (root) CMD (nethist_stats.lua)
2022-03-02 18:48:01 info /usr/sbin/cron[9803]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2022-03-02 18:49:01 info /usr/sbin/cron[9844]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2022-03-02 18:50:01 info /usr/sbin/cron[9887]: (root) CMD (nethist_stats.lua)
2022-03-02 18:50:01 info /usr/sbin/cron[9890]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2022-03-02 18:50:01 info /usr/sbin/cron[9889]: (root) CMD (/usr/bin/notifier)
2022-03-02 18:51:01 info /usr/sbin/cron[9958]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2022-03-02 18:52:01 info /usr/sbin/cron[10002]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2022-03-02 18:52:01 info /usr/sbin/cron[10001]: (root) CMD (nethist_stats.lua)
2022-03-02 18:52:30 info updater-supervisor[]: Running pkgupdate
2022-03-02 18:52:52 warning updater[10052]: planner.lua:344 (pkg_plan): Requested package luci-i18n-ddns-en that is missing, ignoring as requested.
2022-03-02 18:52:52 warning updater[10052]: planner.lua:344 (pkg_plan): Requested package luci-i18n-ddns-sk that is missing, ignoring as requested.
2022-03-02 18:52:53 info updater[10052]: updater.lua:108 (Globals): Queue install of user-notify-l10n-sk/turris/1.4.0-1
2022-03-02 18:52:53 info updater[10052]: updater.lua:108 (Globals): Queue install of foris-l10n-sk/turris/100.5.1-3.6-3
2022-03-02 18:52:53 info updater[10052]: updater.lua:108 (Globals): Queue install of foris-diagnostics-plugin-l10n-sk/turris/11-3.6-1
2022-03-02 18:52:53 info updater[10052]: updater.lua:108 (Globals): Queue install of userlists-l10n-sk/turris/1.4.0-1
2022-03-02 18:52:53 info updater[10052]: updater.lua:108 (Globals): Queue install of luci-i18n-base-sk/turris/git-19.318.61483-fd63d5c-10
2022-03-02 18:52:53 info updater[10052]: updater.lua:108 (Globals): Queue install of luci-i18n-commands-sk/turris/git-19.318.61483-fd63d5c-1
2022-03-02 18:52:53 info updater[10052]: updater.lua:108 (Globals): Queue install of foris-data_collect-plugin-l10n-sk/turris/1.4-3.6-1
2022-03-02 18:52:53 info updater[10052]: updater.lua:108 (Globals): Queue install of luci-i18n-ahcp-sk/turris/git-19.318.61483-fd63d5c-1
2022-03-02 18:52:53 info updater[10052]: updater.lua:108 (Globals): Queue install of luci-i18n-firewall-sk/turris/git-19.318.61483-fd63d5c-1
2022-03-02 18:52:53 info updater[10052]: updater.lua:108 (Globals): Queue install of luci-i18n-minidlna-sk/turris/git-19.318.61483-fd63d5c-1
2022-03-02 18:52:53 info updater[10052]: updater.lua:108 (Globals): Queue install of luci-i18n-statistics-sk/turris/git-19.318.61483-fd63d5c-4
2022-03-02 18:52:53 info updater[10052]: updater.lua:108 (Globals): Queue install of luci-i18n-tinyproxy-sk/turris/git-19.318.61483-fd63d5c-1
2022-03-02 18:52:53 info updater[10052]: updater.lua:108 (Globals): Queue install of luci-i18n-transmission-sk/turris/git-19.318.61483-fd63d5c-2
2022-03-02 18:52:53 info updater[10052]: updater.lua:108 (Globals): Queue install of luci-i18n-upnp-sk/turris/git-19.318.61483-fd63d5c-1
2022-03-02 18:52:53 info updater[10052]: updater.lua:108 (Globals): Queue install of luci-i18n-wol-sk/turris/git-19.318.61483-fd63d5c-1
2022-03-02 18:52:53 info updater[10052]: updater.lua:108 (Globals): Queue install of tos3to4/turris/1.0.3-1
2022-03-02 18:52:53 info updater[10052]: updater.lua:140 (Globals): Queue removal of luci-i18n-firewall-cs
2022-03-02 18:52:53 info updater[10052]: updater.lua:140 (Globals): Queue removal of luci-i18n-ddns-cs
2022-03-02 18:52:53 info updater[10052]: updater.lua:140 (Globals): Queue removal of luci-i18n-ahcp-cs
2022-03-02 18:52:53 info updater[10052]: updater.lua:140 (Globals): Queue removal of luci-i18n-transmission-cs
2022-03-02 18:52:53 info updater[10052]: updater.lua:140 (Globals): Queue removal of luci-i18n-base-cs
2022-03-02 18:52:53 info updater[10052]: updater.lua:140 (Globals): Queue removal of luci-i18n-upnp-cs
2022-03-02 18:52:53 info updater[10052]: updater.lua:140 (Globals): Queue removal of luci-i18n-statistics-cs
2022-03-02 18:52:53 info updater[10052]: updater.lua:140 (Globals): Queue removal of foris-data_collect-plugin-l10n-cs
2022-03-02 18:52:53 info updater[10052]: updater.lua:140 (Globals): Queue removal of user-notify-l10n-cs
2022-03-02 18:52:53 info updater[10052]: updater.lua:140 (Globals): Queue removal of luci-i18n-minidlna-cs
2022-03-02 18:52:53 info updater[10052]: updater.lua:140 (Globals): Queue removal of luci-i18n-tinyproxy-cs
2022-03-02 18:52:53 info updater[10052]: updater.lua:140 (Globals): Queue removal of luci-i18n-commands-cs
2022-03-02 18:52:53 info updater[10052]: updater.lua:140 (Globals): Queue removal of foris-diagnostics-plugin-l10n-cs
2022-03-02 18:52:53 info updater[10052]: updater.lua:140 (Globals): Queue removal of foris-l10n-cs
2022-03-02 18:52:53 info updater[10052]: updater.lua:140 (Globals): Queue removal of userlists-l10n-cs
2022-03-02 18:52:53 info updater[10052]: updater.lua:140 (Globals): Queue removal of luci-i18n-wol-cs
2022-03-02 18:52:53 info updater[10052]: src/lib/logging.c:206 (log_subproc_open): Executing preupdate hook: 05_schnapps.sh
2022-03-02 18:52:53 info kernel[]: [ 1412.769307] BTRFS info (device mmcblk0p2): quota is enabled
2022-03-02 18:52:54 info updater[10052]: transaction.lua:77 (fun): Unpacking download packages
2022-03-02 18:52:55 info updater[10052]: transaction.lua:150 (fun): Checking for file collisions between packages
2022-03-02 18:52:55 info updater[10052]: transaction.lua:169 (fun): Running pre-install scripts and merging packages to root file system
2022-03-02 18:52:58 info updater[10052]: transaction.lua:215 (fun): Running post-install and post-rm scripts
2022-03-02 18:52:58 info updater[10052]: src/lib/logging.c:206 (log_subproc_open): Running postinst of user-notify-l10n-sk
2022-03-02 18:52:58 info updater[10052]: src/lib/logging.c:206 (log_subproc_open): Running postinst of foris-l10n-sk
2022-03-02 18:52:58 info updater[10052]: src/lib/logging.c:206 (log_subproc_open): Running postinst of foris-diagnostics-plugin-l10n-sk
2022-03-02 18:52:58 info updater[10052]: src/lib/logging.c:206 (log_subproc_open): Running postinst of userlists-l10n-sk
2022-03-02 18:52:58 info updater[10052]: src/lib/logging.c:206 (log_subproc_open): Running postinst of luci-i18n-base-sk
2022-03-02 18:52:58 info updater[10052]: src/lib/logging.c:206 (log_subproc_open): Running postinst of luci-i18n-commands-sk
2022-03-02 18:52:58 info updater[10052]: src/lib/logging.c:206 (log_subproc_open): Running postinst of foris-data_collect-plugin-l10n-sk
2022-03-02 18:52:59 info updater[10052]: src/lib/logging.c:206 (log_subproc_open): Running postinst of luci-i18n-ahcp-sk
2022-03-02 18:52:59 info updater[10052]: src/lib/logging.c:206 (log_subproc_open): Running postinst of luci-i18n-firewall-sk
2022-03-02 18:52:59 info updater[10052]: src/lib/logging.c:206 (log_subproc_open): Running postinst of luci-i18n-minidlna-sk
2022-03-02 18:53:00 info updater[10052]: src/lib/logging.c:206 (log_subproc_open): Running postinst of luci-i18n-statistics-sk
2022-03-02 18:53:00 info updater[10052]: src/lib/logging.c:206 (log_subproc_open): Running postinst of luci-i18n-tinyproxy-sk
2022-03-02 18:53:00 info updater[10052]: src/lib/logging.c:206 (log_subproc_open): Running postinst of luci-i18n-transmission-sk
2022-03-02 18:53:00 info updater[10052]: src/lib/logging.c:206 (log_subproc_open): Running postinst of luci-i18n-upnp-sk
2022-03-02 18:53:01 info updater[10052]: src/lib/logging.c:206 (log_subproc_open): Running postinst of luci-i18n-wol-sk
2022-03-02 18:53:01 info updater[10052]: src/lib/logging.c:206 (log_subproc_open): Running postinst of tos3to4
2022-03-02 18:53:01 info updater[10052]: src/lib/logging.c:206 (log_subproc_open): Running prerm of luci-i18n-firewall-cs
2022-03-02 18:53:01 info updater[10052]: src/lib/logging.c:206 (log_subproc_open): Running prerm of luci-i18n-ddns-cs
2022-03-02 18:53:01 info updater[10052]: src/lib/logging.c:206 (log_subproc_open): Running prerm of luci-i18n-ahcp-cs
2022-03-02 18:53:01 info /usr/sbin/cron[10880]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2022-03-02 18:53:01 info updater[10052]: src/lib/logging.c:206 (log_subproc_open): Running prerm of luci-i18n-transmission-cs
2022-03-02 18:53:01 info updater[10052]: src/lib/logging.c:206 (log_subproc_open): Running prerm of luci-i18n-base-cs
2022-03-02 18:53:01 info updater[10052]: src/lib/logging.c:206 (log_subproc_open): Running prerm of luci-i18n-upnp-cs
2022-03-02 18:53:01 info updater[10052]: src/lib/logging.c:206 (log_subproc_open): Running prerm of luci-i18n-statistics-cs
2022-03-02 18:53:02 info updater[10052]: src/lib/logging.c:206 (log_subproc_open): Running prerm of foris-data_collect-plugin-l10n-cs
2022-03-02 18:53:02 info updater[10052]: src/lib/logging.c:206 (log_subproc_open): Running prerm of user-notify-l10n-cs
2022-03-02 18:53:02 info updater[10052]: src/lib/logging.c:206 (log_subproc_open): Running prerm of luci-i18n-minidlna-cs
2022-03-02 18:53:02 info updater[10052]: src/lib/logging.c:206 (log_subproc_open): Running prerm of luci-i18n-tinyproxy-cs
2022-03-02 18:53:02 info updater[10052]: src/lib/logging.c:206 (log_subproc_open): Running prerm of luci-i18n-commands-cs
2022-03-02 18:53:02 info updater[10052]: src/lib/logging.c:206 (log_subproc_open): Running prerm of foris-diagnostics-plugin-l10n-cs
2022-03-02 18:53:02 info updater[10052]: src/lib/logging.c:206 (log_subproc_open): Running prerm of foris-l10n-cs
2022-03-02 18:53:02 info updater[10052]: src/lib/logging.c:206 (log_subproc_open): Running prerm of userlists-l10n-cs
2022-03-02 18:53:02 info updater[10052]: src/lib/logging.c:206 (log_subproc_open): Running prerm of luci-i18n-wol-cs
2022-03-02 18:53:02 info updater[10052]: transaction.lua:239 (fun): Removing packages and leftover files
2022-03-02 18:53:02 info updater[10052]: src/lib/logging.c:206 (log_subproc_open): Running postrm of foris-data_collect-plugin-l10n-cs
2022-03-02 18:53:03 info updater[10052]: src/lib/logging.c:206 (log_subproc_open): Running postrm of foris-diagnostics-plugin-l10n-cs
2022-03-02 18:53:03 info updater[10052]: src/lib/logging.c:206 (log_subproc_open): Running postrm of foris-l10n-cs
2022-03-02 18:53:08 info updater[10052]: transaction.lua:252 (fun): Cleaning up control files
2022-03-02 18:53:15 err updater[10052]: src/pkgupdate/main.c:255 (main):
2022-03-02 18:53:15 notice unreachable[]: https://repo.turris.cz/turris/lists/base.lua: Couldn't resolve host 'repo.turris.cz'
2022-03-02 18:53:15 info updater[10052]: src/lib/logging.c:206 (log_subproc_open): Executing postupdate hook: 05_schnapps.sh
2022-03-02 18:53:15 info kernel[]: [ 1434.493903] BTRFS info (device mmcblk0p2): quota is enabled
2022-03-02 18:53:15 info updater[10052]: src/lib/logging.c:206 (log_subproc_open): Executing postupdate hook: 10_kernel-install
2022-03-02 18:53:16 info updater[10052]: src/lib/logging.c:206 (log_subproc_open): Executing postupdate hook: 99_approvals_cleanup
2022-03-02 18:53:16 info updater[10052]: src/lib/logging.c:206 (log_subproc_open): Executing postupdate hook: update_alternatives.sh
2022-03-02 18:53:16 info updater-supervisor[]: pkgupdate exited with: 1
2022-03-02 18:54:01 info /usr/sbin/cron[12232]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2022-03-02 18:54:01 info /usr/sbin/cron[12231]: (root) CMD (nethist_stats.lua)
2022-03-02 18:55:01 info /usr/sbin/cron[12379]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2022-03-02 18:55:01 info /usr/sbin/cron[12380]: (root) CMD (/usr/bin/notifier)
2022-03-02 18:56:01 info /usr/sbin/cron[12489]: (root) CMD (nethist_stats.lua)
2022-03-02 18:56:01 info /usr/sbin/cron[12491]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2022-03-02 18:56:50 info updater-supervisor[]: Running pkgupdate
2022-03-02 18:56:54 err updater[12536]: src/pkgupdate/main.c:255 (main):
2022-03-02 18:56:54 notice unreachable[]: https://repo.turris.cz/turris/lists/base.lua: Couldn't resolve host 'repo.turris.cz'
2022-03-02 18:56:54 info updater-supervisor[]: pkgupdate exited with: 1
2022-03-02 18:57:01 info /usr/sbin/cron[12657]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
