NAS & samba works good with ntfs USB flash disc, but miniDLNA not - I see mediaserver on client (PC, phone, smart TV), but any files.
USB disc is mounted on /mnt/nas
/dev/sda1 /mnt/nas 2.06 GB / 3.77 GB 45% (1.71 GB)
media directory in miniDLNA setting is /mnt/nas too, but
Service miniDLNA is active, provides 0 audio, 0 video and 0 picture files.
Where can be a mistake?
Solution:
It is necessary to change start priority for script “nas” which is used for mounting ntfs disc after restart router (described in CZ documentation for Turris1 https://www.turris.cz/doc/cs/howto/nas because the default start priority for miniDLNA is 50 and priority described script is 99 (look LuCI >> System >> Startup), but miniDLNA use disc mounted by "nas"script.
Adapted script:
cat > nas <<EOF
#!/bin/sh /etc/rc.common
START=48
STOP=99
start() {
umount /dev/sda1
ntfs-3g /dev/sda1 /mnt/nas
stop() {
umount /mnt/nas
hd-idle -t sda
EOF
There is a new row before ntfs-3g (umount /dev/sda1) - when I use original script new disc were automatically mounted after restart as different directory - it was impossible to mount it as “/mnt/nas” described on next row.
Now NAS (samba) and miniDLNA works flawlessly with flash disc in USB port or 500GB mSATA disc connected on the main board
- tested on smart TV, streamer CXN, android smart phone (VNC media player) and PC (VNC media player)
I’ am not a LINUX expert (my experiences are only 24 hour long
), so I would like to see to my editing has also expressed a Linux guru, who would eventually suggested a better functional solution.
Not working for me.
But this worked:
/etc/init.d/minidlna reload
start() {
umount /dev/sda1
